Meetme trennt nach Ansage
Aachen
13 Okt 2004
wenn ich meinen Conferenceroom 5000 anwähle, erhalte ich die "Join" message und dann "hangup".
-- Executing [5000@from-internal:1] Set("SIP/3000-084ef408", "MEETME_ROOMNUM=5000") in new stack
    -- Executing [5000@from-internal:2] GotoIf("SIP/3000-084ef408", "0?USER") in new stack
    -- Executing [5000@from-internal:3] Answer("SIP/3000-084ef408", "") in new stack
    -- Executing [5000@from-internal:4] Wait("SIP/3000-084ef408", "1") in new stack
    -- Executing [5000@from-internal:5] Set("SIP/3000-084ef408", "MEETME_OPTS=ciMs") in new stack
    -- Executing [5000@from-internal:6] Playback("SIP/3000-084ef408", "custom/enter-conf-5000") in new stack
    -- <SIP/3000-084ef408> Playing 'custom/enter-conf-5000' (language 'de')
    -- Executing [5000@from-internal:7] Goto("SIP/3000-084ef408", "STARTMEETME|1") in new stack
    -- Goto (from-internal,STARTMEETME,1)
  == Spawn extension (from-internal, STARTMEETME, 1) exited non-zero on 'SIP/3000-084ef408'
    -- Executing [h@from-internal:1] Macro("SIP/3000-084ef408", "hangupcall") in new stack
    -- Executing [s@macro-hangupcall:1] ResetCDR("SIP/3000-084ef408", "w") in new stack
    -- Executing [s@macro-hangupcall:2] NoCDR("SIP/3000-084ef408", "") in new stack
    -- Executing [s@macro-hangupcall:3] GotoIf("SIP/3000-084ef408", "1?skiprg") in new stack
    -- Goto (macro-hangupcall,s,6)
    -- Executing [s@macro-hangupcall:6] GotoIf("SIP/3000-084ef408", "1?skipblkvm") in new stack
    -- Goto (macro-hangupcall,s,9)
    -- Executing [s@macro-hangupcall:9] GotoIf("SIP/3000-084ef408", "1?theend") in new stack
    -- Goto (macro-hangupcall,s,11)
    -- Executing [s@macro-hangupcall:11] Hangup("SIP/3000-084ef408", "") in new stack
  == Spawn extension (macro-hangupcall, s, 11) exited non-zero on 'SIP/3000-084ef408' in macro 'hangupcall'
Asterisk 1.4.11 konfiguriert mit FreePBX
Hat jemand eine Idee??
Das problem hängt wohl mit dem Context STARTMEETME zusammen. Aber ohne Deine Config Dateien zu kennen, läßt sich dazu nicht viel mehr sagen.
Seufz, das vermutete ich auch schon mal kurz. Werde ich mal weiter prüfen. Nur dachte ich -denken ist ...-, daß bei automatisch konfigurierten Skripten solche Fehler nicht passieren sollten.
Ich finde auf der FreePBX-Seite leider kein Forum :-)
Danke erstmal. Ich suche und melde...
IchBinEsDoch
