Mldonkey Cross-port
inshar_it
17 Feb 2006
Hi to all!
I am literally going crazy!
I am trying to cross-compile mldonkey 2.9.1 under DS15.2 toolchain.
As described in the wiki i have added the right PATH with shell command:
export PATH=/home/inshar/fritz_ds_mod/kernel2.6/ds26-15.2/toolchain/target/bin:$PATH
(this is exact path on my system)
After i give the ./configure
LDFLAGS=-static ./configure --host=mipsel-linux --enable-minimum
It seems all goes perfect and at end the configure says me:
Configuring MLDonkey 2.9.1 completed.
Network modules:
- eDonkey enabled (eMule SUI disabled)
- BitTorrent disabled
- FileTP (aka wget) disabled
- Fasttrack disabled
- Gnutella disabled - unmaintained
- Gnutella2 disabled - unmaintained
- Direct Connect disabled
- Open Napster disabled - currently not usable
- Soulseek disabled - currently not usable
- OpenFT disabled - currently not usable
Core features:
- zlib (required) enabled
- threads enabled
- bzip2 disabled
- iconv disabled
- libmagic disabled
- graphical stats disabled
Compilers:
- Ocaml version 3.09.2
- mipsel-linux-gcc version 4.2.0
Now execute 'make' to start compiling. Good luck!
To compile a static code execute: make mlnet.static
To produce a release tarball execute: make release.mlnet.static
To clean the build directory execute: make maintainerclean
root@inshar-desktop:/home/inshar/mldonkey-2.9.1#
Looking in the Compilers i see that is right cross platform (mipsel-gcc-version 4.2.0)
So at this point i give: make mlnet.static
All the compile & linking goes well...
But at the end the executable i get does not work on fritz!
I have tried to execute on UBUNTU machine and it works!!!!:mad:
So it compiles the mlnet.static for i386 and i do not understand why!?:confused:
So where is my mistake??? I am sure there is something i am missing!!!
Thanks a lot in advance
How about taking a look at some DS-Mod make includes (make/.../*.mk)? You might want to specify --target and --build as well.
As far as I can see ocaml is used instead of gcc. So you will need a ocaml cross-compiler!?
Greets Oliver
I do not understand well /*.mk what means , should i look something?
I am not linux compilation expert...
I have used also --target --build but they do not change result...
I think is ocaml problem...
Greets Oliver
Yes i also think that!
But what should be the directives to build with gcc or make ocaml cross-build?
I fear is needed ocaml cross-build toolchain right?!:confused:
Do not double-post, please. Rather edit previous messages ("Ändern" button) instead. And yes, you would need an O'Caml cross-toolchain, if something like this exists for an embedded target. And here I guess we are beginning to leave the domain of this forum. Anyway, there exists an O'Caml Debian package containing the byte-code as well as the native compiler. It is also available for the mipsel platform, so it might run on a Debian system which can either be installed via Debootstrap or downloaded as a pre-fabricated image. Some links for further investigation (but you should learn some Linux and compiling stuff before trying to pursue this any further):
Ok!
Thanks for advice...
I will try to compile directly by Debian Fritz Environment.
I will post results once done!
Protonator
