[Problem] Modpatch: Error tffs-mknod.patch
estrange
12 Mrz 2009
bin mir jetzt net sicher ob es ein Freetzproblem ist, oder doch sp2f.
Falls, könnte ja bitte jemand den Thread verschieben.
Ich hab folgendes kleines Problem.
Wenn ich sp2f laufen lasse mit Basis t-com (aktuelle letzte Firmware), und 2te Firmware 54.04.90 7270v2, und 3te 74.04.90 7570, dann läuft alles durch, bis am Schluss folgendes kommt:
STEP 1: UNPACK
 unpacking firmware image
 splitting kernel image
 unpacking filesystem image
 3370 inodes (3776 blocks) to write
 created 2390 files
 created 166 directories
 created 631 symlinks
 created 349 devices
 created 0 fifos
 unpacking var.tar
 done.
 STEP 2: MODIFY
 applying symlinks, deleting additional webinterfaces in:
 applying patches
 applying patches (7270_v2_preview-de)
 applying patch file ./patches/7270_v2_preview/105-S06-logging.sh
 applying patch file ./patches/7270_v2_preview/115-S20-modload.sh
 applying patch file ./patches/110-multid-wait.patch
 patching file etc/init.d/rc.net
 applying patch file ./patches/110-system_status.patch
 patching file usr/bin/system_status
 applying patch file ./patches/7270_v2_preview/110-S08-tffs-mknod.patch
 patching file etc/init.d/S08-tffs
 Hunk #1 FAILED at 109.
 1 out of 1 hunk FAILED -- saving rejects to file etc/init.d/S08-tffs.rej
 ERROR: modpatch: Error in patch-file ./patches/7270_v2_preview/110-S08-tffs-mknod.patch
 make: *** [firmware-nocompile] Fehler 2
 modimage=
 _______________________________________________________________________________________________________________
 Something went wrong, Freetzfirmware not found!
 If Firmware was created, you may copy the freetz image yourself to:
 /home/fritz/Desktop/speed-to-fritz/Firmware.orig
 Then start speed-to-fretz setup (./start) again and select freetz image as AVM LABOR source
 All done .... Press 'ENTER' to return to the calling shell.
Kann evtl. jemand das Problem verifizieren?
Im Moment aktualieriese ich grad Ubuntu auf 10.10 in der VM.
Vielen Dank!
Schöne Grüsse
Ob das ein Freetz-Problem ist, bekommst du heraus, wenn du das speed2fritz weglässt und ein reines Freetz baust.
Wenn Du es so schreibst, wird es vermutlich stimmen.
Die Patches sind für bestimmte Firmware Versionen geschrieben. Wenn Du mit Freetz allein den Fehler hast, liegt es an Freetz. Wenn es dann nicht auftritt, liegt es daran, dass Freetz nicht die Firmware bekommt, für die es ausgelegt wurde.
habe es nun auch mit Freetz allein probiert, doch beim Aufruf von make krieg ich folgende Meldung:
*** End of Freetz configuration.
*** Execute 'make' to build the Freetz image.
fritz@fritz-desktop:~/Desktop/freetz-trunk$ make
WARNING: The program jam was not found in path.
make/gdb/gdb.mk:1: *** Undefined version for PKG_INIT in make/gdb/gdb.mk.  Schluss.
hab das ganze dann nochmal mit sp2f vorher getestet, auch das gleiche.
Was aber ein vollkommen anderer Fehler ist als den, den du oben gepostet hast. Von daher ist das wohl doch ein speed2fritz-Problem. Was den gdb angeht: Poste hier mal das log aus dem build-Verzeichnis von gdb.
gdb Problem ist behoben.
Oliver
danke, das geht jetzt wieder.
Jetzt ist wieder der ursprüngliche Fehler da.
Dann lass ich erstmal nochmal Freetz alleine ein Image erstellen.
zum Testen hab ich mal
7570_04.90freetz-devel.en_20110613-035506.image
erstellt, und diese wurde auch erzeugt ohne Fehlermeldung irgendwo.
Gut, dann ist es kein Freetz Problem.
Oliver
Hi all,
gleiches Problem / Fehlermeldung hier auch.
Verwende Ubuntu 11.04 64bit.
Kann es sein das im Freetz Menue noch das "*" bei:
[*] Beta/Labor
gesetzt ist ?
Wenn man das deaktiviert läuft freetz / sp2fritz ohne Fehlermeldung durch ;)
Gruss
KlausBock
Lösch mal deine .config und treste das noch einmal. Denn Beta/Labor sollte nicht aktiviert sein.
    applying patch file ./patches/7270_v2/de/110-S08-tffs-mknod.patch
ERROR: modpatch: Error in patch-file ./patches/7270_v2/de/110-S08-tffs-mknod.patch
ich kann machen was ich will, aber bei mir läuft freetz nicht durch, immer der gleiche Fehler.
Habe sp2fr && freetz jeweils neu auschecken lassen ...
Regards
hummingbird_de
Bitte ausschliesslich ohne sp2fr, sprich einen checkout direkt aus dem trunk.
Nun, wenn Du Dir die Mühe gemacht hättest meine Signatur zu lesen, würdest Du sehen, das ich sp2fr benötige, ist für ein W920V ...
Wozu benötigt man den Patch, wo kann ich den evtl. im freetz menu deaktivieren? Ich möchte eigentlich nur den USBMOUNT && DNSMASQ aus freetz dazu haben ...
Regards
hummingbird_de
sp2fritz macht aber Digne mit der Firmware, die wir nicht beeinflussen können. Teste doch mal mit einem sauberen trunk gegen mit der entsprechenden box, aus der sp2fr dann irgendwie ne Firmware strickt. Taucht der Fehler dort auch auf? Dann sehen wir weiter.
Ja, das habe ich schon gemacht, aber daran lags nicht. In sp2fr ist diese internationale FW 74.05.90 für 7270_v2 vorgewählt gewesen, dachte die wäre in Ordnung, aber nun habe ich diesen punkt mit der aktuellen 74.05.05 vorbelegt und siehe es geht ... jetzt schau ich mal bei welchen FW Versionen Kernel && ulibc zusammenpassen ...
Regards
hummingbird_de
Du kannst auch mit Freetz (ohne sp2fritz) eine Firmware für deinen W920V erzeugen...
Oliver
@olistudent
Jupp, habe ich heute Nacht noch gemacht, siehe Signatur ... ;)
An diesem Punkt der Dank an Euch Entwickler für Eure unermüdliche Arbeit.
Regards
hummingbird_de
Hi Hummingbird_de,
habe gerade das gleiche Problem beim Erzeugen eines neuen Images.
Wie hattest Du denn das Problem geloest?
Grüße,
Goggo
@Goggo16
Ich habe das Image direkt mit freetz gebaut, also ohne speed2fritz. Freetz verändert ein AVM Image nach Deinen Wünschen, ändert aber am Original wenig bis nix. Speed2fritz klebt ja verschiedene Stücke aus verschiedenen Images zu einem neuen zusammen und ruft hernach evtl. noch freetz auf.
Ich verwende eine orig. AVM FW auf meinem W920V eben mit freetz addon(s).
Regards
hummingbird_de
nightdeck
