MT-F or C3? Please advice
gcf
11 Nov 2007
I would like to buy one of these phones to use with my 7270 router.
Which one is better? Pros and cons?
I am particularly interested in using dect eco mode (zero activity in standby) if available.
Thanks in advance.
Hi gcf,
I know this is an old thread, but nobody has answered it yet. Of the two phones you mention, the MT-F is the better phone.
Basically, the MT-F has a better display (higher resolution), a headset connector and a different design. As the price difference is only marginal, I recommend getting the MT-F (I have two of them).
Both phones support dect eco mode. For this to work, you have to make sure only DECT phone which support this mode are registered on your fritz box.
I hope this helps
Peter
Lishheshuyg
