Multiple instances of OpenVPN
JPAdie
20 Sep 2006
hello
is it possible to run multiple instances of openvpn on an avm 7050? i've tried running two instances from the same directory, from a second directory with a symlinked binary and from a second directory with a new download of the binary. no luck.
thanks for any suggestions
justin
I think it should be possible, but you have to use a different listen port for each OpenVPN instance.
Joe
And: I read that it will cause some problems using the same static.key for both instances
Regards
André
Hi André!
I use two instances of OpenVPN with my 7050 and 7170. I use Port 1194 on both Fritze's for Remote Login from my Laptop and 1195 (new Port !!!) on both Fritze's to connect the networks behind the Fritz 7050 and 7170.
You also have to use different VPN Subnets for the VPN Connections. Eg. I use 10.0.0.1 and 10.0.0.2 for the "normal" Roadwarrior Tunnel and eg. 10.3.0.1 and 10.3.0.2 to let both Fritze's connect to each other.
For each VPN Connection (1194, 1195, etc.) you have to open a port in /var/flash/ar7.cfg
Good luck ;-)
Marco
EDIT: I use the same static.key for both connections - no problems
klaboom
