Neue Firmware 1.2.2.14 verfügbar
Ciscofreak
8 Sep 2007
http://www.grandstream.com/firmware.html
CHANGES SINCE FIRMWARE RELEASE 1.2.1.4
BUG FIXES
• Fixed BT200 runs "Out-of-memory" at eth_malloc
• Fixed Call forward indication on GXP2010/2020 doesn't look good
• Fixed phone runs out of memory when attended transfer target is a direct IP call
• Fixed GXP2000 sends NOTIFY request for noevent Event with empty Request-Line and To
header
• Fixed phone fails to send session refresh requests after receiving UPDATE without a Session-
Expires header
• Fixed phone has noise during line switch
• Fixed abnormal busy tone under the G.722 voice codec
• Fixed GXP2020: XML app key unresponsive after network problem
• Fixed GXP sends out re-subscribe for 'presence' after subscription period expires
• Fixed Attended Transfer fails on BT200, GXE responses 403 forbidden to REFER
• Fixed iLBC RTP size error
• Fixed phone automatically sends out DTMF tone
• Fixed “End of Event” error when using DTMF RFC2833
• Fixed GXP cannot display the caller number correctly with "P-Asserted-Identity" header in INVITE
• Fixed GXP sends NOTIFY without from tag for dialog or presence events
• Fixed GXP2000 loses gateway IP address after sometime if it's set to use DHCP in some
particular network
• Fixed phone logs a missed call even there is a REASON header with "SIP;cause=200"
• Fixed GXP280 doesn't go back to idle screen after canceling a transferred call
• Fixed GXP2020/GXP2010 fails to pick up phone calls via BLF key on the extension module
• Fixed phone fails to reply SIP options query
• Fixed Cseq of PRACK does not increase
• Fixed Phonebook XML file which contains version attribute would cause GXP to crash
ENHANCEMENTS
• Added support for configuration via DHCP Option 66 tunnel through Option 43
• Added support to hide "ForwardAll" softkey if call feature code is disabled for Account 1
• Added support for HUB mode on GXP1200/GXP280
• Added support for Call Park and Pickup feature on GXP2020/2010
• Added support for automatically provisioning the HTTP provisioning URL via DHCP option 66
GRANDSTREAM NETWORKS Release Notes for F/W 1.2.2.14 10/2009
• Added support for Call Queue feature
• Added support for BLF "Offline" state to allow PBX to turn off BLF LED when subscribee lost
registration
• Added support for XML Application on GXP2010
• Added support to configure Call Pickup dialing prefix
• Added support to display MAC address in HTTP firmware upgrade request
• Added support for Reason header in BYE requests (RFC3326)
• Set default LCD contrast value to 10 for GXP2010 and GXP2020
Hat jemand die Firmware-Version hier laufen? Ich habe die mal installiert und danach waren meine Telefonbuch-Eintraege sehr konfus. Teile abgeschnitten, Nummern, wo Namen sein sollten, wirre Zeichen usw. Konnte das noch jemand beobachten?
hab diese FW seid Release bei 5 Telefonen laufen - Telefonbuch habe ich über eine Activa TSP Anbindung zu Outlook von daher kann ich dazu nix sagen - sry
Hallo !
Das mit dem Telefonbuch ist offensichtlich ein Firmwarefehler.
Sonst läuft die FW bei uns auf 24 Telefonen einwandfrei.
Es gibt jetzt auch schon eine Beta-Version ....19.
Da kann man bei den Apparaten die Konfiguration abschalten.
Das ist nicht schlecht, wenn mann Teilnehmer mit zu viel Spieltrieb hat.
Der Telefonbuchfehler ist in dieser Beta offensichtlich noch drin.
Gruß!
MB-100
Gut. Dann warte ich einfach mal ab :-) Die alte FW laeuft ja soweit auch ganz gut.
hatte den "Telefonbucheintragfehler" auch .... bin wieder zurück auf 1.2.2.14
Telefonbuchfehler
Hatte diesen Fehler auch. Hier hilft beim Download des Telefonbuches in den erweiterten Einstellungen des Webinterfaces das Häkchen bei "Manuelle editierte Eintraege in Download entfernen:" auf "Ja" zu setzen. Dann wird das aktuelle Telefonbuch gelöscht und durch ein korrektes Neues ersetzt.
Zurücksetzen auf Werkseinstellung hilft natürlich auch. Womöglich wurde in den neuen Firmwareversionen auch etwas an der Speicherverwaltung des Telefonbuches geändert.
Wenn natürlich kein zentrales Telefonbuch vorhanden ist und alles manuell eingegeben wurde, dann hilft nur abschreiben und anschließend neu eingeben.;)
Callendaar
