Neue Firmware SPA-942 V5.1.4 vom 31.10.2006
Ponozka
1 Mai 2006
Auch für das SPA-942 gibt es hier eine neue Firmware. Leider ohne Release Notes!
Release Notes for -- Linksys SPA-922/942 5.1.4
Die Release Notes finden sich lustigerweise unter "Drivers" auf der Linksys Website. Hier sind sie:
922 -- IP Phone
942 -- IP Phone
Copyright (C) 2006 by Linksys, a Division of Cisco Systems, Inc.
All Rights Reserved.
* * * * * * * * * * IMPORTANT * * * * * * * * * * * * * * * * *
* Use of Proprietary Information and Copyright Notice: *
* This release note document contains proprietary information *
* that is to be used only by Sipura Technology, Linksys(R), *
* and Cisco Systems, Inc. customers. Any unauthorized *
* disclosure, copying, distribution, or use of this *
* information is prohibited. This restriction includes *
* ALL Internet based discussion forums, e.g. DSLreports. *
New Features
### version: 5.1.4
- Updated SIP-B implementation
- Shared line can accept and make call before subscribe complete
### version: 5.1.0
- Added <Auth INVITE> option for Line 1/2 to enable challenging incoming initial INVITE requests
- Three parameters are added:
<Reg Retry Random Delay> = Random delay range (in seconds) to add to <Register Retry Intvl> when retrying REGISTER after a failure. Default is 0, which disables this feature
<Reg Retry Long Random Delay> = Random delay range (in seconds) to add to <Register Retry Long Intvl> when retrying REGISTER after a failure. Default is 0, which disables this feature
<Reg Retry Intvl Cap> = The maximum value to cap the expoential backoff retry delay (which starts at <Register Retry Intvl> and doubles every retry. Default value is 0, which disables the exponential backoff feature (i.e., error retry interval is always at <Register Retry Intvl>). If this feature is enabled, <Reg Retry Random Delay> is added on top of the exponential backoff delay value
Bug Fixes
### version: 5.1.4
- Fixed this bug: NOTIFY request for refer event during call transfer does not include subscription-state header that is required per RFC 3265
- Fixed this bug: SPA does not include RTP-Stat header in BYE after the BYE is challenged
- Fixed this bug: When unit fails over to secondary proxy during INVITE, the correspnding ACK might be sent to the primary if <Proxy Fallback Intvl> expires between the INVITE and the ACK.
- Fixed bug: Phone ACD window cannot disappear when user swich from ACD login window to Dial window
- Fixed bug: Phone reboots when pressing DND/CFWD with both ACD login window and Dial window are shown
- Fixed bug: After logout ACD group, softkey avail/unavail still show
- Fixed bug: memory corruption after going in and out of corporate directory a couple of times.
- better speakerphone performance in the presence of noise, or when the talker's volume is low.
### version: 5.1.0
- Fix bug: Ext 3/4/5/6 dialplan change cannot cause phone reboot
- Fixed the bug: Cannot factory reset call history
- Include "replaces" in Supported header in outbound SIP messages and accept "replaces" in Require header in inbound SIP messages
Inzwischen gibt es hier die Version 5.1.5 vom 29.11.06, diesmal mit Release Notes!
