Neue Intel Treiber
Vierstein
22 Apr 2004
Hi!
Es gibt neue Intel-WLAN-Treiber. Ich zitiere mal kurz:
Issue resolved in this release
o Intel® PRO/Wireless 3945ABG Network Connection might lose connectivity when operating in PSP mode. This issue applies ONLY to the Intel® PRO/Wireless 3945ABG Network Connection.
This issue does not occur when the Power Management setting is set to Highest.
This issue might occur if the Power Management setting is set to Use default value or any setting other than Highest.
Power Save Poll (PSP) mode allows the adapter to go to sleep for pre-defined intervals to save battery power.
The default Power Management setting for the adapter automatically selects the mode according to the computer's power source. PSP mode is used when your computer is using battery power. Depending upon the manufacturer of your computer, your adapter might or might not use PSP mode when plugged into the power adapter.
Ich will den Bugfix endlich auch für die 2200BG!! Hoffentlich löst das endlich das Problem mit den hängenden WLAN-Connections bei der FB, wenn PSP eingeschaltet ist.
Vierstein
Sora5
