Neue "Tycho" Voicemail Client version
voiphead
7 Jun 2006
wir haben eine neue Version unseres "Tycho" Voicemail Managers released:
we are releasing an update of our "Tycho" Voicemail Manager. The update
to Beta 0.2 contains a bugfix and a couple of improvements over the 0.1 version:
Bug fix:
* missing "Channel Type" added to extension subscription
Improvements:
* adjustable refresh interval (voicemail)
* manual refresh button (voicemail)
* re-open windows after application restart (extensions, voicemail)
* "Support Forum" menu item - Web Link to our support Forum
* "Reset Perspective" menu item - Resets the windows to it's defaut locations
Please note that this version will delete your preference settings as well as any defined voicemailboxes and extensions. Help us and report all problems/bugs to our support forum. Thank you.
Note for "Trixbox" Users: When subcribing to an extension please use the context "from-internal" in the "context" field of the subscription menu.
For more Info, documentation and Downloads go here: http://sip-syndication.com
best regards,
VoipHead
IchBinEsDoch
