Neues Image fuer SIP 7940/7960 IP Phone v8.3(0)- Non-CallManager
tinyhunter
28 Sep 2004
Es gibt fuers 7940/7960wieder eine neue Firmware Version 8.3 SIP seit einigen Tagen Behoben wurdend folgende Punkte:
CSCee27487 Quality of ring tone is poor when set to lower audible levels
CSCef36868 Confrn LCD ICON status needs to change when UA is on HOLD
CSCsa88504 CDP code does not verify destination MAC address
CSCsb49849 Ringing call in focus may not get connected when handset off hook
CSCsb78781 UAS BYE re-INV with unacceptable CSP instead of 488
CSCsd03499 Cisco Unified IP Phone 7960 trapped in reboot cycle if TFTP replies Access
Violation
CSCsd07728 REFER handling failure during a conference call scenario
CSCsd27904 R-URI and To in triggered INVITE getting clipped at 256 characters
CSCsd28935 IP phone sends malformed Hostname option in DHCP request
CSCsd33828 Incorrect parsing error for Diversion Header
CSCsd37469 Incorrect softkey display for GARP Enabled parameter when unlocked
CSCsd49671 407 without Contact-Info crashes the IP phone
CSCsd52568 Update SIP Cisco Unified IP Phone 7960 SIP built-in font to include new zero
with a slash
CSCsd55393 Auto answer fails if first call is cancelled after second call comes in
CSCsd59085 Stress run failure
CSCsd74158 Cisco Unified IP Phone 7940 SIP sends multiple BYE messages
CSCsd76379 Cisco Unified IP Phone 7960 sends REGISTER message for a line even if
registration is disabled
CSCsd82151 Call directories should only preserve non-local SIP domains
CSCsd96695 Loss of digits when dialing consultative calls
CSCse01635 Phone with outbound proxy enabled does not register
CSCse17113 Phone does sends END OPTION in outgoing DHCP mesages
Hast du bei dir irgendwelche Besonderheiten feststellen können , weil ich habe im moment 7.4 und mich würde interessieren , ob sich der Upgrade lohnt.
CTU
Nein nicht wirklich. von 7.5 zu 8.2 hatte ich shcon keine Unterschiede gesehen.
Da aber di NBuliste zu 8 fast 3 DIN A4 Seiten lag war schadet es nicht ein upgarde zu machen
hab das update gemacht und bin soweit zufrieden. :rolleyes:
gruss
/alex
M.G.
