Neues Problem mit Freetz und W920V
danage
16 Dez 2005
ich benutze die Firmware: fw_Speedport_920_75.04.94-14621_Fritz_Box_DECT_W920V_54.04.98-15220-sp2fr-09.09.22-r-570M-1033_OEM-avm.image
Wenn ich nun ./start-freetz.sh ausführe, läuft zunächst das speedport2fritz durch. Danach startet Freetz Menuconfig. Ich wähle die Pakete an, die ich haben möchte, verändere sonst nichts. Dann:
STEP 2: MODIFY
  Applying symlinks, deleting additional webinterfaces
applying patches
  applying patches (7270-de)
    applying patch file ./patches/7270/200-modules_symlink.sh
  making symlink for modules (-ur8)
    applying patch file ./patches/100-profile.patch
    patching file etc/profile
    applying patch file ./patches/110-multid-wait.patch
    patching file etc/init.d/rc.net
    applying patch file ./patches/110-system_status.patch
    patching file usr/bin/system_status
    applying patch file ./patches/130-fstab.patch
    patching file etc/fstab
    applying patch file ./patches/7270/100-rc.net-dnsmasq.patch
    applying patch file ./patches/7270/110-rc.S-mknod.patch
    patching file etc/init.d/rc.S
    applying patch file ./patches/7270/120-rc.S-dev.patch
    applying patch file ./patches/7270/130-rc.S-logging.patch
    applying patch file ./patches/7270/140-rc.S-no_avm_exit.patch
    Hunk #1 succeeded at 1554 with fuzz 2 (offset -72 lines).
    applying patch file ./patches/7270/de/130-foncalls.patch
    patching file usr/www/all/html/de/home/foncalls.js
    applying patch file ./patches/7270/de/190-webmenu.patch
    patching file usr/www/all/html/de/menus/menu2_homehome.html
    patching file usr/www/all/html/de/menus/menu2_konfig.html
    applying patch file ./patches/7270/de/200-sperre1.patch
    patching file usr/www/avm/html/de/fon/sperre1.js
    applying patch file ./patches/7270/de/210-notmountable.patch
    patching file usr/www/all/html/de/home/home.js
    Hunk #1 FAILED at 797.
    1 out of 1 hunk FAILED -- saving rejects to file usr/www/all/html/de/home/home.js.rej
ERROR: modpatch: Error in patch-file ./patches/7270/de/210-notmountable.patch
make: *** [firmware-nocompile] Error 2
Ich habe die Vermutung, das Freetz erst noch für diese Firmware angepasst werden muss?
Eigentlich nicht...laut Freetz-Trac ist die 15220 bereits am 18.09.09 eingebunden worden, siehe hier. Das Problem könnte eher bei der 14621 liegen.
mfg
Nein kann nicht an der 14621 liegen da Freetz ja nur die 15220 Firmware bearbeitet.
Versuch eine ältere Revisionsnummer für freetz vorzugeben, dazu gibt es bei den speed-to-fritz Optionen eine Menüeintrag.
Ich probiere es auch durch demnächst.
log ist angehängt.
Mit Revision 3764 probiert (die, wo die 15220-Firmware eingebaut wurde). Gleicher Fehler.
Aus irgend einen Grund ist bei dir nicht die 7270_labor_core Frimware bei Freetz ausgewählt.
Das sollte aber ohne jeglichen Eingriff, wenn du vorher ./start und anschließend ./start-freetz ausführst, automatisch eingestellt sein.
Ich habs auch mal mit aktuellem Script und neuester Freetz-Revision durchlaufen lassen...Firmware wird gebaut:
fw_C_Speedport_920_75.04.94-14621_Fritz_Box_DECT_W920V_54.04.98-15220-freetz-3694M-sp2fr-09.09.22-r-570M-1035_OEM-avm.image
Edit: noch die Firmware-Einstellungen dazu:
Select a special 7570 firmware as T-Home firmware ---> (NEW) : AVM_7570_14621 en-de-fr.75.04.94 used as T-Home firmware
Select a special AVM firmware ---> AVM_7270_CORE_15220 7270-54.04.98-15220 (Streaming Stick) (war bereits voreingestellt)
mfg
Bei mir geht es jetzt auch. Es lag tatsächlich an dem Fehler, den JPascher gefunden hat. Danke dafür!
Bei mir klappt es mal wieder nicht. Hier ein kompletter Auszug:
Invoke 'make' now? (y/n)?
`/home/d/speed-to-fritz/Firmware.orig/FRITZ.Box_Fon_WLAN_7270_LabCORE.AnnexB.54.04.98-15220.image' -> `dl/fw/FRITZ.Box_Fon_WLAN_7270_LabCORE.AnnexB.54.04.98-15220.image'
Be patient ...
PATH="/home/d/freetz-trunk/toolchain/target/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/sbin:/sbin:/sbin:/sbin" \
        SHARED_LDFLAGS="" \
        make -j2 -C source/openssl-0.9.8k \
        CC="/home/d/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc" \
        AR="mipsel-linux-uclibc-ar r" \
        RANLIB="mipsel-linux-uclibc-ranlib" \
        all
make[1]: Entering directory `/home/d/freetz-trunk/source/openssl-0.9.8k'
Makefile is older than Makefile.org, Configure or config.
Reconfigure the source tree (via './config' or 'perl Configure'), please.
make[1]: *** [Makefile] Error 1
make[1]: Leaving directory `/home/d/freetz-trunk/source/openssl-0.9.8k'
make: *** [source/openssl-0.9.8k/libssl.so.0.9.8] Error 2
Es gibt ein Cross-posting von mir dazu im Freetz-Forum. Ich habe die Streaming Stick Labor diesmal von Hand ausgewählt, damit hat es sonst eigentlich immer geklappt.
Ach ja, und ich habe ein anderes Linux benutzt, Ubuntu Karmic (vorher Jaunty).
Was mich sehr wundert ist das oben, in der zweiten Zeile, Source und Target identisch sind. Das sollte doch eigentlich geändert sein wenn man die Streaming Stick Labor ausgewählt hat, oder?
ich nutze fw_C_Speedport_920_75.04.94-15316_Fritz_Box_DECT_W920V_54.04.98-15220-sp2fr-09.10.17-r-605M-1600_OEM-avm.image
und bekomme oben beschriebenes Problem, wähle ich aber bei starten des scripts ./start-freetz.sh aus, dann läuft das script durch, ansonsten nicht. Ist dies nur mit dem Streaming Stick Labor Version funktionsfähig?
Bedanke mich für eure Hilfe.
Speedport 920V
@danage
Was in der Zeiten Zeile kopiert wurde besagt welche Firmware im Speed-to-fritz vorher ausgewählt war.
Ob die Einstellungen von Freetz dazu immer passen sollte kontrolliert werden.
Sollte aber normalerweise bereits richtig vorgewählt sein.
Die Fehlermeldung irritiert mich stark, nehme aber an, dass es wohl kaum mit den ./start-freetz Skript in Zusammenhang steht.
mit ./start wurde nichts besonders ausgewählt, sondern im Hauptbildschirm alles so belassen. Siehe Firmware.conf !!!
im 2ten Step ./start-freetz.sh habe ich dann auch alles so belassen, ausser die gewünschten Pakete ausgewählt und das wars. Dann bekomme ich leider immer besagten Fehler.
Wenn ich übrigens die Konfiguration von Ernest nehme dann bekomme ich keine VDSL-Verbindung ins Internet.
evaar
