New problem with automount /ext3 /mdev using R2825
de-wolff
15 Nov 2008
Hello,
Sunday I made a new image with an external image un USB stick, based on R2821 ?, which was not mounted automatically. Just to be sure there was a real problem, I did an SVN update, make dirclean, and a new menuconfig, and built a new image based on R2825.
I have the same problem: When I start the box, with an USB stick connected, the stick is detected, but not mounted. After I have loaded ext3 by using modprobe, I can mount the stick by hand, and it is mounted without any problem.
Also when I detach and attach the stick, it is not mounted automaically.
With a previous build, based on R2810 the automounting did work correct.
There are more differences between my 2810 build, and my 2825 build, but I don't think they influence this problem. My 2810 based build was a build with a few patches I made myself, for 2825 I used the repository version.
The 2825 build has more packages, of which some are placed on the external USB stick.
For your information:
syslog of R2825 box, until I mounted the stick by hand
Jan  1 01:00:52 fritz user.warn kernel: [setup_irq]: irq 6 irqaction->handler 0x940015a4 (dummy_system_irq_2+0x0/0x14 )
Jan  1 01:00:52 fritz user.debug kernel: Calling initcall 0x940017e4: ohio_late_init+0x0/0x3c()
Jan  1 01:00:52 fritz user.warn kernel: [ohio_late_init]
Jan  1 01:00:52 fritz user.debug kernel: Calling initcall 0x94204164: ohio_clk_switch_init+0x0/0x60()
Jan  1 01:00:52 fritz user.debug kernel: Calling initcall 0x942043e0: speedup_init+0x0/0x3c()
Jan  1 01:00:52 fritz user.debug kernel: Calling initcall 0x94211ab8: seqgen_init+0x0/0x20()
Jan  1 01:00:52 fritz user.debug kernel: Calling initcall 0x940d4d00: avm_event_push_button_init+0x0/0x130()
Jan  1 01:00:52 fritz user.info kernel: [avm_new] push_button_gpio=8 value=1 enabled
Jan  1 01:00:52 fritz user.debug kernel: Calling initcall 0x94212d78: tffs_init+0x0/0x224()
Jan  1 01:00:52 fritz user.warn kernel: TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 2.0)
Jan  1 01:00:52 fritz user.warn kernel:       mount on mtd4 and mtd5 (double buffering)
Jan  1 01:00:52 fritz user.info kernel: Adam2
Jan  1 01:00:52 fritz user.info kernel: environment variables API installed.
Jan  1 01:00:52 fritz user.debug kernel: Calling initcall 0x94213bc8: early_uart_console_switch+0x0/0xb4()
Jan  1 01:00:52 fritz user.debug kernel: Calling initcall 0x9412cdf8: net_random_reseed+0x0/0x34()
Jan  1 01:00:52 fritz user.debug kernel: Calling initcall 0x94218200: ip_auto_config+0x0/0x1130()
Jan  1 01:00:52 fritz user.warn kernel: [prepare_namespace] new mount root /dev/mtdblock1
Jan  1 01:00:52 fritz user.warn kernel: NumProbs = 7990 / 2 -> 15980
Jan  1 01:00:52 fritz user.warn kernel: VFS: Mounted root (squashfs filesystem) readonly.
Jan  1 01:00:52 fritz user.warn kernel: Freeing prom memory: 0kb freed
Jan  1 01:00:52 fritz user.info kernel: Freeing unused kernel memory: 116k freed (7540 free)
Jan  1 01:00:52 fritz user.warn kernel: [setup_irq]: irq 15 irqaction->handler 0x940e0f6c (serial8250_interrupt+0x0/0x13c )
Jan  1 01:00:52 fritz user.warn kernel: AR7WDT: System Init UEberwachung 240 Sekunden
Jan  1 01:00:52 fritz user.warn kernel: TFFS Name Table E
Jan  1 01:00:52 fritz user.info kernel: [avm_new]push_button 'Wlan-Taster', released: GPIO=8 presses=6250 key=button_key_3
Jan  1 01:00:52 fritz user.info kernel: NET: Registered protocol family 10
Jan  1 01:00:52 fritz user.info kernel: Disabled Privacy Extensions on device 941df0f0(lo)
Jan  1 01:00:52 fritz user.warn kernel: failed to load transform for md5
Jan  1 01:00:52 fritz user.info kernel: IPv6 over IPv4 tunneling driver
Jan  1 01:00:52 fritz user.warn kernel: Piglet: module license '
Jan  1 01:00:52 fritz user.warn kernel: (C) Copyright 2005 by AVM
Jan  1 01:00:52 fritz user.warn kernel: ' taints kernel.
Jan  1 01:00:52 fritz user.warn kernel: EMIF: asize=1 ta=3 r_hold=0 w_strobe=6 r_strobe=6 ew=1
Jan  1 01:00:52 fritz user.info kernel: JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
Jan  1 01:00:52 fritz user.err kernel: jffs2: Too few erase blocks (2)
Jan  1 01:00:52 fritz user.warn kernel: registered device TI Avalanche SAR
Jan  1 01:00:52 fritz user.warn kernel: tiatm driver (patch_annex=0xc011d46c)
Jan  1 01:00:52 fritz user.warn kernel: [tiatm] Set StrictPriority=0
Jan  1 01:00:52 fritz user.warn kernel: DSP binary filesize = 327380 bytes
Jan  1 01:00:52 fritz user.warn kernel: [tiatm] INFO V2U-BRIDGEREGISTER: 0x00000019
Jan  1 01:00:52 fritz user.info kernel: [avm_power]Ohio250 detected -> overclocking possible
Jan  1 01:00:52 fritz user.info kernel: [avm_power]#### boostVoltage: DSP Core voltage set to 1,5 V ####
Jan  1 01:00:52 fritz user.warn kernel: [setup_irq]: irq 23 irqaction->handler 0xc0104208 (tn7atm_sar_irq+0x0/0x30 [tiatm] )
Jan  1 01:00:52 fritz user.warn kernel: [setup_irq]: irq 31 irqaction->handler 0xc0104238 (tn7atm_dsl_irq+0x0/0x28 [tiatm] )
Jan  1 01:00:52 fritz user.warn kernel: [tiatm]: Powermanagment (States => 1,3,10) supported!
Jan  1 01:00:52 fritz user.warn kernel: Texas Instruments ATM driver: version:[4.07.07.00]
Jan  1 01:00:52 fritz user.warn kernel: [tiatm] AvmInterface length: 44
Jan  1 01:00:52 fritz user.warn kernel: ubik2 driver (ubik2 - 0x10=0xc0131af4)
Jan  1 01:00:52 fritz user.warn kernel: atm_dsp_register_ubik2: ubik2_ToMIPS_notify=0xc0120bfc
Jan  1 01:00:52 fritz user.warn kernel: atm_dsp_register_ubik2: dsp mem pointer 0xa1c10b0c
Jan  1 01:00:52 fritz user.err kernel: ubik2_init_interface: DSP-Link Version v3 8480
Jan  1 01:00:52 fritz user.info kernel: driver params overwritten io_addr=0x0 irq_num=0
Jan  1 01:00:52 fritz user.warn kernel: [setup_irq]: irq 28 irqaction->handler 0xc012b5f0 (soft_interrupt_handler+0x0/0x30 [ubik2] )
Jan  1 01:00:52 fritz user.warn kernel: capicodec_init()
Jan  1 01:00:52 fritz user.warn kernel: [capi_codec] support fax
Jan  1 01:00:52 fritz user.warn kernel: [capi_codec] support Codecs
Jan  1 01:00:52 fritz user.info kernel: usbcore: registered new driver usbfs
Jan  1 01:00:52 fritz user.info kernel: usbcore: registered new driver hub
Jan  1 01:00:52 fritz user.info kernel: 	AHCI RevisionID = 0x02, RamSize = 16384, NumPorts= 1
Jan  1 01:00:52 fritz user.warn kernel: [setup_irq]: irq 9 irqaction->handler 0xc01cd490 (ahci_irq+0x0/0x880 [usbahcicore] )
Jan  1 01:00:52 fritz user.info kernel: ahci : new USB bus registered, assigned bus number 1
Jan  1 01:00:52 fritz user.info kernel: kdsldmod: init start (May  1 2008 16:11:33) sizeof(struct sk_buff)=176
Jan  1 01:00:52 fritz user.info kernel: kdsldmod: init done
Jan  1 01:00:52 fritz user.info kernel: kdsld: PPP led: off (value=0)
Jan  1 01:00:52 fritz user.info kernel: hub 1-0:1.0: USB hub found
Jan  1 01:00:52 fritz user.info kernel: hub 1-0:1.0: 1 port detected
Jan  1 01:00:52 fritz user.info kernel: avm_net_trace: New net trace device 'WLAN' registered with minor 0.
Jan  1 01:00:52 fritz user.err kernel: [avm_power] : ethernet port 0 status 2
Jan  1 01:00:52 fritz user.err kernel: [avm_power] : ethernet port 1 status 1
Jan  1 01:00:52 fritz user.err kernel: [avm_power] : ethernet port 2 status 1
Jan  1 01:00:52 fritz user.err kernel: [avm_power] : ethernet port 3 status 1
Jan  1 01:00:52 fritz user.info kernel: usb 1-1: new full speed USB device using ahci and address 2
Jan  1 01:00:52 fritz user.notice kernel: SCSI subsystem initialized
Jan  1 01:00:52 fritz user.info kernel: Initializing USB Mass Storage driver...
Jan  1 01:00:52 fritz user.info kernel: USB Mass Storage device (0204:6025) detected...
Jan  1 01:00:52 fritz user.info kernel: scsi0 : SCSI emulation for USB Mass Storage devices
Jan  1 01:00:52 fritz user.warn kernel: [ohio_vlynq_init] device 0
Jan  1 01:00:52 fritz user.warn kernel: [ohio_vlynq_startup_link]
Jan  1 01:00:52 fritz user.warn kernel: [setup_irq]: irq 29 irqaction->handler 0x9400592c (vlynq_interrupt+0x0/0x34 )
Jan  1 01:00:52 fritz user.warn kernel: [setup_irq]: irq 79 irqaction->handler 0xc03b739c (tiwlan_ddaVlynqIsr+0x0/0x28 [tiap] )
Jan  1 01:00:52 fritz user.debug kernel: usb-storage: device found at 2
Jan  1 01:00:52 fritz user.debug kernel: usb-storage: waiting for device to settle before scanning
Jan  1 01:00:52 fritz user.info kernel: usbcore: registered new driver usb-storage
Jan  1 01:00:52 fritz user.info kernel: USB Mass Storage support registered.
Jan  1 01:00:52 fritz user.notice kernel:   Vendor:           Model: Flash Disk        Rev: 5.00
Jan  1 01:00:52 fritz user.notice kernel:   Type:   Direct-Access                      ANSI SCSI revision: 02
Jan  1 01:00:52 fritz user.notice kernel: SCSI device sda: 1978368 512-byte hdwr sectors (1013 MB)
Jan  1 01:00:52 fritz user.notice kernel: sda: Write Protect is off
Jan  1 01:00:52 fritz user.debug kernel: sda: Mode Sense: 0b 00 00 08
Jan  1 01:00:52 fritz user.err kernel: sda: assuming drive cache: write through
Jan  1 01:00:52 fritz user.info kernel:  sda: sda1
Jan  1 01:00:52 fritz user.warn kernel: [setup_irq]: irq 27 irqaction->handler 0x940f1c7c (cpmac_mai
Jan  1 01:00:52 fritz user.info kernel: n_isr+0x0/0x78 )
Jan  1 01:00:52 fritz user.notice kernel: Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
Jan  1 01:00:52 fritz user.notice kernel: Attached scsi generic sg0 at scsi0, channel 0, id 0, lun 0,  type 0
Jan  1 01:00:52 fritz user.err kernel: [cpmac] cpmac_main_ioctl, unknown ioctl 35142
Jan  1 01:00:52 fritz user.info kernel: device eth0 entered promiscuous mode
Jan  1 01:00:52 fritz user.info kernel: device cpmac0 entered promiscuous mode
Jan  1 01:00:52 fritz user.info kernel: device tiwlan0 entered promiscuous mode
Jan  1 01:00:52 fritz user.info kernel: lan: port 2(tiwlan0) entering learning state
Jan  1 01:00:52 fritz user.info kernel: lan: topology change detected, propagating
Jan  1 01:00:52 fritz user.info kernel: lan: port 2(tiwlan0) entering forwarding state
Jan  1 01:00:52 fritz user.info kernel: device wdsup0 entered promiscuous mode
Jan  1 01:00:52 fritz user.info kernel: lan: port 3(wdsup0) entering learning state
Jan  1 01:00:52 fritz user.info kernel: lan: port 3(wdsup0) entering forwarding state
Jan  1 01:00:52 fritz user.info kernel: device wdsdw0 entered promiscuous mode
Jan  1 01:00:52 fritz user.info kernel: lan: port 4(wdsdw0) entering learning state
Jan  1 01:00:52 fritz user.info kernel: lan: port 4(wdsdw0) entering forwarding state
Jan  1 01:00:52 fritz user.info kernel: device wdsdw1 entered promiscuous mode
Jan  1 01:00:52 fritz user.info kernel: lan: port 5(wdsdw1) entering learning state
Jan  1 01:00:52 fritz user.info kernel: lan: port 5(wdsdw1) entering forwarding state
Jan  1 01:00:52 fritz user.info kernel: device wdsdw2 entered promiscuous mode
Jan  1 01:00:52 fritz user.info kernel: lan: port 6(wdsdw2) entering learning state
Jan  1 01:00:52 fritz user.info kernel: lan: port 6(wdsdw2) entering forwarding state
Jan  1 01:00:52 fritz user.info kernel: device wdsdw3 entered promiscuous mode
Jan  1 01:00:52 fritz user.info kernel: lan: port 7(wdsdw3) entering learning state
Jan  1 01:00:52 fritz user.info kernel: lan: port 7(wdsdw3) entering forwarding state
Jan  1 01:00:52 fritz user.debug kernel: usb-storage: device scan complete
Jan  1 01:00:52 fritz user.warn kernel: AR7WDT: System Init UEberwachung abgeschlossen (194810 ms noch verfuegbar)
Jan  1 01:00:52 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_cpuclock: norm_power_rate=100 act_rate=99 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=0 mW
Jan  1 01:00:52 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_dspclock: norm_power_rate=100 act_rate=84 mul=154 div=10 offset=974 NormP=2514 mW -> SumNormP=2514 mW
Jan  1 01:00:52 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_systemclock: norm_power_rate=100 act_rate=83 mul=65 div=10 offset=1793 NormP=2443 mW -> SumNormP=4957 mW
Jan  1 01:00:52 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_wlan: norm_power_rate=100 act_rate=-2147483548 mul=84 div=10 offset=100 NormP=940 mW -> SumNormP=5897 mW
Jan  1 01:00:52 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_isdnnt: norm_power_rate=100 act_rate=0 mul=1 div=1 offset=0 NormP=100 mW -> SumNormP=5997 mW
Jan  1 01:00:52 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_isdnte: norm_power_rate=100 act_rate=0 mul=1 div=1 offset=0 NormP=100 mW -> SumNormP=6097 mW
Jan  1 01:00:52 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_analog: norm_power_rate=300 act_rate=0 mul=141 div=10 offset=100 NormP=4330 mW -> SumNormP=10427 mW
Jan  1 01:00:52 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_dect: norm_power_rate=100 act_rate=0 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=10427 mW
Jan  1 01:00:52 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_ethernet: norm_power_rate=467 act_rate=150 mul=1 div=1 offset=50 NormP=517 mW -> SumNormP=10944 mW
Jan  1 01:00:52 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_dsl: norm_power_rate=100 act_rate=0 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=10944 mW
Jan  1 01:00:52 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_host: norm_power_rate=500 act_rate=100 mul=55 div=10 offset=50 NormP=2800 mW -> SumNormP=13744 mW
Jan  1 01:00:52 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_client: norm_power_rate=0 act_rate=0 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=13744 mW
Jan  1 01:00:52 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_charge: norm_power_rate=446 act_rate=0 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=13744 mW
Jan  1 01:00:52 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_loadrate: norm_power_rate=100 act_rate=19 mul=29 div=10 offset=-17 NormP=273 mW -> SumNormP=14017 mW
Jan  1 01:00:52 fritz user.info kernel: SysRq : Changing Loglevel
Jan  1 01:00:52 fritz user.warn kernel: Loglevel set to 4
Jan  1 01:00:52 fritz user.debug kernel: wdsup0: no IPv6 routers present
Jan  1 01:00:52 fritz user.debug kernel: tiwlan0: no IPv6 routers present
Jan  1 01:00:52 fritz user.debug kernel: wdsdw0: no IPv6 routers present
Jan  1 01:00:52 fritz user.debug kernel: wdsdw1: no IPv6 routers present
Jan  1 01:00:52 fritz user.debug kernel: wdsdw2: no IPv6 routers present
Jan  1 01:00:52 fritz user.debug kernel: wdsdw3: no IPv6 routers present
Jan  1 01:00:53 fritz user.debug kernel: lan: no IPv6 routers present
Jan  1 01:00:53 fritz user.debug kernel: cpmac0: no IPv6 routers present
Jan  1 01:00:53 fritz user.debug kernel: eth0: no IPv6 routers present
Jan  1 01:01:05 fritz authpriv.info dropbear[920]: Running in background
Jan  1 01:01:08 fritz user.info multid[1015]: startup ($Revision: 1.140 $$CompileDate: May  1 2008 16:10:41 $)
Jan  1 01:01:08 fritz user.err multid[1017]: already running (611), exit
Jan  1 01:01:09 fritz user.info kernel: lan: port 3(wdsup0) entering disabled state
Jan  1 01:01:16 fritz user.info kernel: lan: port 3(wdsup0) entering learning state
Jan  1 01:01:16 fritz user.info kernel: lan: topology change detected, propagating
Jan  1 01:01:16 fritz user.info kernel: lan: port 3(wdsup0) entering forwarding state
Dec  2 07:27:58 fritz daemon.info ntpd[1019]: set local clock to Tue Dec  2 07:27:58 CET 2008 (offset 281514399.160359s)
Dec  2 07:27:58 fritz user.err telefon[657]: set initial telefon time from linux time to 7:27 2.12 2008!
Dec  2 07:28:00 fritz daemon.info radvd[1098]: version 1.2 started
Dec  2 07:28:12 fritz user.warn kernel: /proc/tffs: info request: success
Dec  2 07:28:28 fritz authpriv.info dropbear[1169]: Child connection from ::ffff:192.168.2.20:51040
Dec  2 07:28:32 fritz authpriv.notice dropbear[1169]: pubkey auth succeeded for 'root' with key md5 xx from ::ffff:192.168.2.20:51040
Dec  2 07:28:51 fritz user.warn kernel: [speedup] -> 62.5 MHz
Dec  2 07:29:49 fritz user.warn kernel: [speedup] -> 125 MHz
Dec  2 07:29:49 fritz user.info kernel: kjournald starting.  Commit interval 5 seconds
Dec  2 07:29:49 fritz user.info kernel: EXT3 FS on sda1, internal journal
Dec  2 07:29:49 fritz user.info kernel: EXT3-fs: recovery complete.
Dec  2 07:29:49 fritz user.info kernel: EXT3-fs: mounted filesystem with ordered data mode.
.config
# Automatically generated make config: don't edit
FREETZ_HAVE_DOT_CONFIG=y
# General --------------------------------
FREETZ_AVM_VERSION_04_57=y
# FREETZ_TYPE_300IP_AS_FON is not set
# FREETZ_TYPE_2170 is not set
# FREETZ_TYPE_FON is not set
# FREETZ_TYPE_FON_5010 is not set
# FREETZ_TYPE_FON_5050 is not set
# FREETZ_TYPE_FON_5140 is not set
# FREETZ_TYPE_FON_WLAN is not set
# FREETZ_TYPE_FON_WLAN_7050 is not set
# FREETZ_TYPE_FON_WLAN_7113 is not set
# FREETZ_TYPE_FON_WLAN_7140 is not set
# FREETZ_TYPE_FON_WLAN_7141 is not set
# FREETZ_TYPE_FON_7150 is not set
FREETZ_TYPE_FON_WLAN_7170=y
# FREETZ_TYPE_FON_WLAN_7240 is not set
# FREETZ_TYPE_FON_WLAN_7270 is not set
# FREETZ_TYPE_WLAN_3020 is not set
# FREETZ_TYPE_WLAN_3030 is not set
# FREETZ_TYPE_WLAN_3130 is not set
# FREETZ_TYPE_WLAN_3131 is not set
# FREETZ_TYPE_WLAN_3170 is not set
# FREETZ_TYPE_WLAN_3270 is not set
# FREETZ_TYPE_SPEEDPORT_W501V is not set
# FREETZ_TYPE_SPEEDPORT_W701V is not set
# FREETZ_TYPE_CUSTOM is not set
# FREETZ_TYPE_LABOR is not set
# FREETZ_TYPE_ALIEN_HARDWARE is not set
FREETZ_AVM_VERSION_STRING="04.57"
# FREETZ_TYPE_LANG_DE is not set
# FREETZ_TYPE_LANG_A_CH is not set
FREETZ_TYPE_LANG_EN=y
FREETZ_TYPE_LANG_STRING="en"
# FREETZ_TYPE_ANNEX_A is not set
FREETZ_TYPE_ANNEX_B=y
FREETZ_TYPE_STRING="7170"
FREETZ_INSTALL_BASE=y
FREETZ_REPLACE_BUSYBOX=y
FREETZ_REPLACE_KERNEL_AVAILABLE=y
FREETZ_REPLACE_KERNEL=y
FREETZ_SHOW_ADVANCED=y
FREETZ_TARGET_IPV6_SUPPORT=y
FREETZ_TARGET_REF="8mb_26"
FREETZ_KERNEL_REF="8mb_26"
FREETZ_KERNEL_LAYOUT="ohio"
FREETZ_KERNEL_MTD_SIZE=119
FREETZ_HAS_PHONE=y
FREETZ_HAS_WLAN=y
# FREETZ_HAS_USB_CLIENT is not set
FREETZ_HAS_USB_HOST=y
# FREETZ_HAS_AVM_INETD is not set
# Mod ------------------------------------
# FREETZ_LANG_DE is not set
FREETZ_LANG_EN=y
FREETZ_LANG_STRING="en"
# Patches
# Remove Brandings
# FREETZ_REMOVE_BRANDING_avme is not set
# FREETZ_REMOVE_HELP is not set
# FREETZ_REMOVE_ASSISTANT is not set
# FREETZ_REMOVE_TR069 is not set
# FREETZ_PATCH_VCC is not set
# FREETZ_PATCH_ENUM is not set
# FREETZ_PATCH_SIGNED is not set
FREETZ_PATCH_USBSTORAGE=y
FREETZ_USBSTORAGE_AUTOMOUNT=y
FREETZ_AUTOMOUNT_EXT2=y
FREETZ_AUTOMOUNT_EXT3=y
# FREETZ_AUTOMOUNT_NTFS is not set
# FREETZ_AUTOMOUNT_REISER_FS is not set
# FREETZ_AUTORUN_AUTOEND is not set
# FREETZ_PATCH_MAXDEVCOUNT is not set
# FREETZ_PATCH_GETCONS is not set
FREETZ_REMOVE_UPNP=y
# FREETZ_REMOVE_UPNP_LIBS is not set
FREETZ_REMOVE_USERMAN=y
# FREETZ_REMOVE_FTPD is not set
# FREETZ_REMOVE_MEDIASRV is not set
# FREETZ_REMOVE_MINID is not set
# FREETZ_REMOVE_AURA_USB is not set
# FREETZ_REMOVE_DSLD is not set
# FREETZ_REMOVE_CAPIOVERTCP is not set
# FREETZ_REMOVE_VOIP_ISDN is not set
# Package selection
# *** not all packages support selected language ***
# FREETZ_SELECTED_LANG_ONLY is not set
# Standard packages
# FREETZ_PACKAGE_BFTPD is not set
# FREETZ_PACKAGE_BIRD is not set
FREETZ_PACKAGE_BRIDGE_UTILS=y
FREETZ_PACKAGE_CALLMONITOR=y
# FREETZ_PACKAGE_CHECKMAILD is not set
# FREETZ_PACKAGE_CIFSMOUNT is not set
# FREETZ_PACKAGE_CPMACCFG is not set
# FREETZ_PACKAGE_CURL is not set
# FREETZ_PACKAGE_DECO is not set
# FREETZ_PACKAGE_DNSMASQ is not set
FREETZ_PACKAGE_DROPBEAR=y
# FREETZ_PACKAGE_DROPBEAR_SERVER_ONLY is not set
# FREETZ_PACKAGE_DROPBEAR_WITH_ZLIB is not set
# FREETZ_PACKAGE_DROPBEAR_SFTP_SERVER is not set
FREETZ_PACKAGE_DTMFBOX=y
# CAPI/SIP
FREETZ_PACKAGE_DTMFBOX_WITH_CAPI=y
FREETZ_PACKAGE_DTMFBOX_WITH_VOIP=y
FREETZ_PACKAGE_DTMFBOX_WITH_ICE=y
# Codecs
FREETZ_PACKAGE_DTMFBOX_WITH_G711_CODEC=y
# FREETZ_PACKAGE_DTMFBOX_WITH_SPEEX_CODEC is not set
# FREETZ_PACKAGE_DTMFBOX_WITH_GSM_CODEC is not set
# Misc
FREETZ_PACKAGE_DTMFBOX_WITH_WEBPHONE=y
FREETZ_PACKAGE_DTMFBOX_WITH_HELP=y
FREETZ_PACKAGE_DTMFBOX_WITH_ESPEAK=y
# FREETZ_PACKAGE_DTMFBOX_WITH_MADPLAY is not set
FREETZ_PACKAGE_ESPEAK=y
FREETZ_PACKAGE_ESPEAK_ALL_LANGUAGES=y
# FREETZ_PACKAGE_FUSE is not set
# FREETZ_PACKAGE_INETD is not set
# FREETZ_PACKAGE_KNOCK is not set
FREETZ_PACKAGE_MC=y
FREETZ_MC_INTERNAL_EDITOR=y
FREETZ_MC_SUBSHELL=y
FREETZ_MC_ONLINE_HELP=y
FREETZ_MC_WITH_NCURSES=y
# FREETZ_PACKAGE_MINI_FO is not set
FREETZ_PACKAGE_MTR=y
# FREETZ_PACKAGE_NANO is not set
# FREETZ_PACKAGE_NETCAT is not set
# FREETZ_PACKAGE_NETSNMP is not set
# FREETZ_PACKAGE_NTFS is not set
FREETZ_PACKAGE_OPENNTPD=y
FREETZ_PACKAGE_OPENVPN=y
# FREETZ_PACKAGE_OPENVPN_STATIC is not set
FREETZ_PACKAGE_OPENVPN_WITH_LZO=y
# FREETZ_PACKAGE_OPENVPN_WITH_MGMNT is not set
FREETZ_PACKAGE_OPENVPN_ENABLE_SMALL=y
# FREETZ_PACKAGE_PINGTUNNEL is not set
# FREETZ_PACKAGE_PRIVOXY is not set
# FREETZ_PACKAGE_RCAPID is not set
FREETZ_PACKAGE_SAMBA=y
FREETZ_PACKAGE_NMBD=y
# FREETZ_PACKAGE_SCREEN is not set
# FREETZ_PACKAGE_STUNNEL is not set
# FREETZ_PACKAGE_TCPDUMP is not set
# FREETZ_PACKAGE_TOR is not set
# FREETZ_PACKAGE_VPNC is not set
# FREETZ_PACKAGE_VSFTPD is not set
# Web interface
FREETZ_PACKAGE_AVM_FIREWALL=y
FREETZ_PACKAGE_DOWNLOADER=y
# FREETZ_PACKAGE_NFSD_CGI is not set
FREETZ_PACKAGE_RRDSTATS=y
# FREETZ_PACKAGE_SPINDOWN_CGI is not set
FREETZ_PACKAGE_SYSLOGD_CGI=y
# FREETZ_PACKAGE_VIRTUALIP_CGI is not set
# FREETZ_PACKAGE_WOL_CGI is not set
# Debug helpers
# FREETZ_PACKAGE_LDD is not set
# FREETZ_PACKAGE_LSOF is not set
# FREETZ_PACKAGE_LTRACE is not set
# FREETZ_PACKAGE_NANO_SHELL is not set
# FREETZ_PACKAGE_PCIUTILS is not set
# FREETZ_PACKAGE_STRACE is not set
# FREETZ_PACKAGE_USBUTILS is not set
# Testing
# FREETZ_GROUP_APACHE_PHP is not set
FREETZ_PACKAGE_BASH=y
# FREETZ_PACKAGE_BASH_MINIMAL is not set
# FREETZ_PACKAGE_BASH_READLINE is not set
# FREETZ_PACKAGE_BFUSB is not set
# FREETZ_PACKAGE_BIP is not set
# FREETZ_PACKAGE_BLUEZ_UTILS is not set
# FREETZ_PACKAGE_BR2684CTL is not set
# FREETZ_PACKAGE_CRYPTSETUP is not set
# FREETZ_PACKAGE_CTORRENT is not set
# FREETZ_PACKAGE_DAVFS2 is not set
# FREETZ_PACKAGE_DEBOOTSTRAP is not set
# FREETZ_PACKAGE_DIGITEMP is not set
# FREETZ_PACKAGE_DNS2TCP is not set
# FREETZ_PACKAGE_DTACH is not set
FREETZ_PACKAGE_E2FSPROGS=y
# FREETZ_PACKAGE_EMPTY is not set
FREETZ_PACKAGE_FSTYP=y
# FREETZ_PACKAGE_GNU_MAKE is not set
# FREETZ_PACKAGE_HD_IDLE is not set
# FREETZ_PACKAGE_HTTPTUNNEL is not set
# FREETZ_PACKAGE_INADYN_MT is not set
# FREETZ_PACKAGE_INOTIFY_TOOLS is not set
# FREETZ_PACKAGE_IODINE is not set
# FREETZ_PACKAGE_IRSSI is not set
# FREETZ_PACKAGE_JAMVM is not set
# FREETZ_PACKAGE_LYNX is not set
# FREETZ_PACKAGE_LUA is not set
# FREETZ_PACKAGE_MADPLAY is not set
# FREETZ_PACKAGE_MATRIXTUNNEL is not set
# FREETZ_PACKAGE_MCABBER is not set
FREETZ_PACKAGE_MDEV=y
# FREETZ_PACKAGE_MICROPERL is not set
# FREETZ_PACKAGE_MODULE_INIT_TOOLS is not set
# FREETZ_PACKAGE_NAGIOS is not set
# FREETZ_PACKAGE_NFS_UTILS is not set
# FREETZ_PACKAGE_NFSROOT is not set
# FREETZ_PACKAGE_OBEXFTP is not set
# FREETZ_PACKAGE_OPENSSH is not set
# FREETZ_PACKAGE_PORTMAP is not set
# FREETZ_PACKAGE_PPTP is not set
# FREETZ_PACKAGE_PPTPD is not set
# FREETZ_PACKAGE_QUAGGA is not set
FREETZ_PACKAGE_RRDTOOL=y
# FREETZ_PACKAGE_RUBY is not set
# FREETZ_PACKAGE_SABLEVM_SDK is not set
# FREETZ_PACKAGE_SISPMCTL is not set
# FREETZ_PACKAGE_SOCAT is not set
# FREETZ_PACKAGE_SQUID is not set
# FREETZ_PACKAGE_STREAMRIPPER is not set
# FREETZ_PACKAGE_TCP_WRAPPERS is not set
# FREETZ_PACKAGE_TCPPROXY is not set
# FREETZ_PACKAGE_TINYPROXY is not set
# FREETZ_PACKAGE_TRANSMISSION is not set
# FREETZ_PACKAGE_TREE is not set
# FREETZ_PACKAGE_USBIP is not set
# FREETZ_PACKAGE_USBROOT is not set
# FREETZ_PACKAGE_VIM is not set
# FREETZ_PACKAGE_WGET is not set
# FREETZ_PACKAGE_WOL is not set
# FREETZ_PACKAGE_WPUT is not set
# FREETZ_PACKAGE_XPDF is not set
# FREETZ_PACKAGE_XRELAYD is not set
FREETZ_SHOW_UNSTABLE_PACKAGES=y
# Unstable
# FREETZ_PACKAGE_COLLECTD is not set
# FREETZ_PACKAGE_IPTABLES is not set
# SANE
# FREETZ_PACKAGE_SANE_BACKENDS is not set
# FREETZ_PACKAGE_TINC is not set
FREETZ_PACKAGE_IPUTILS=y
# FREETZ_PACKAGE_AICCU is not set
FREETZ_PACKAGE_RADVD=y
# FREETZ_PACKAGE_GW6 is not set
FREETZ_PACKAGE_HASERL=y
FREETZ_PACKAGE_MODCGI=y
# Advanced options
# FREETZ_DL_OVERRIDE is not set
FREETZ_DL_SITE="ftp://ftp.avm.de/fritz.box/fritzbox.fon_wlan_7170/firmware/english/annex_b"
FREETZ_DL_SOURCE="FRITZ.Box_Fon_WLAN_7170.AnnexB.en.29.04.57.image"
# Freetz package download sites
FREETZ_MOD_DL_NUM_SITES="5"
# Download site #1 - default: http://freetz.3dfxatwork.de
FREETZ_MOD_DL_SITE_1="http://freetz.3dfxatwork.de"
# Download site #2 - default: http://freetz.wirsind.info
FREETZ_MOD_DL_SITE_2="http://freetz.wirsind.info"
# Download site #3 - default: http://freetz.magenbrot.net
FREETZ_MOD_DL_SITE_3="http://freetz.magenbrot.net"
# Download site #4 - default: empty (reserved for later use)
FREETZ_MOD_DL_SITE_4=""
# Download site #5 - user-defined
FREETZ_MOD_DL_SITE_5=""
FREETZ_VERBOSITY_LEVEL=2
FREETZ_FAVICON_NONE=y
# FREETZ_FAVICON_DSL123 is not set
# FREETZ_FAVICON_CUMA is not set
# FREETZ_FAVICON_HANSOLO is not set
FREETZ_FAVICON_STRING="none"
FREETZ_SUBVERSION_STRING=y
FREETZ_DEVELOPER_VERSION_STRING=y
# External
EXTERNAL_ENABLED=y
# EXTERNAL_DOWNLOADER is not set
EXTERNAL_SUBDIRS=y
EXTERNAL_CREATEPAK=y
# EXTERNAL_DIR1 is not set
# EXTERNAL_DIR2 is not set
# EXTERNAL_DIR3 is not set
EXTERNAL_CUSTOM_DIR=y
EXTERNAL_CUSTOM_DIRNAME="/var/media/ftp/uStora1/external"
EXTERNAL_DIRECTORY="/var/media/ftp/uStora1/external"
EXTERNAL_OWN_FILES=""
# packages
EXTERNAL_FREETZ_PACKAGE_BASH=y
EXTERNAL_FREETZ_PACKAGE_E2FSPROGS=y
# e2fsprogs
EXTERNAL_FREETZ_PACKAGE_E2FSPROGS_e2fsck=y
EXTERNAL_FREETZ_PACKAGE_E2FSPROGS_mke2fs=y
EXTERNAL_FREETZ_PACKAGE_E2FSPROGS_tune2fs=y
EXTERNAL_FREETZ_PACKAGE_E2FSPROGS_blkid=y
EXTERNAL_FREETZ_PACKAGE_ESPEAK=y
EXTERNAL_FREETZ_PACKAGE_MC=y
EXTERNAL_FREETZ_PACKAGE_MTR=y
EXTERNAL_FREETZ_PACKAGE_RRDTOOL=y
# services
EXTERNAL_FREETZ_PACKAGE_OPENVPN=y
EXTERNAL_FREETZ_PACKAGE_SAMBA=y
# Samba
EXTERNAL_FREETZ_PACKAGE_SAMBA_nmbd=y
EXTERNAL_FREETZ_PACKAGE_SAMBA_smbd=y
EXTERNAL_FREETZ_PACKAGE_SAMBA_smbpasswd=y
# libraries
EXTERNAL_FREETZ_LIB_libart_lgpl_2=y
# EXTERNAL_FREETZ_LIB_libcrypto is not set
EXTERNAL_FREETZ_LIB_libfreetype=y
EXTERNAL_FREETZ_LIB_libncurses=y
EXTERNAL_FREETZ_LIB_libpng12=y
# EXTERNAL_FREETZ_LIB_libresolv is not set
# FREETZ_SQUASHFS_BLOCKSIZE_ORIG is not set
# FREETZ_SQUASHFS_BLOCKSIZE_16384 is not set
# FREETZ_SQUASHFS_BLOCKSIZE_32768 is not set
FREETZ_SQUASHFS_BLOCKSIZE_65536=y
# FREETZ_SQUASHFS_BLOCKSIZE_131072 is not set
# BusyBox options
# FREETZ_BUSYBOX_AR is not set
# FREETZ_BUSYBOX_DIFF is not set
# FREETZ_BUSYBOX_INETD is not set
# FREETZ_BUSYBOX_PATCH is not set
FREETZ_BUSYBOX_START_STOP_DAEMON=y
FREETZ_BUSYBOX_WGET=y
# FREETZ_BUSYBOX_LESS is not set
# FREETZ_BUSYBOX_NICE is not set
# FREETZ_BUSYBOX_LS_COLOR is not set
# FREETZ_BUSYBOX_FASTPROC is not set
# FREETZ_BUSYBOX_KEYS is not set
# FREETZ_BUSYBOX_BRCTL is not set
# FREETZ_BUSYBOX_UDHCPD is not set
# FREETZ_BUSYBOX_SEQ is not set
FREETZ_BUSYBOX_TAC=y
FREETZ_BUSYBOX_MDEV_RENAME=y
# FREETZ_BUSYBOX_MDEV_RENAME_REGEXP is not set
# FREETZ_BUSYBOX_MOUNT_HELPERS is not set
FREETZ_BUSYBOX_MOUNT_LABEL=y
FREETZ_BUSYBOX_VOLUMEID=y
FREETZ_BUSYBOX_VOLUMEID_EXT=y
FREETZ_BUSYBOX_VOLUMEID_FAT=y
# IPv6 Options
# FREETZ_BUSYBOX_FEATURE_PREFER_IPV4_ADDRESS is not set
FREETZ_BUSYBOX_IP=y
FREETZ_BUSYBOX_FEATURE_IP_ADDRESS=y
FREETZ_BUSYBOX_FEATURE_IP_LINK=y
FREETZ_BUSYBOX_FEATURE_IP_ROUTE=y
FREETZ_BUSYBOX_FEATURE_IP_TUNNEL=y
FREETZ_BUSYBOX_FEATURE_IP_RULE=y
FREETZ_BUSYBOX_PING6=y
FREETZ_BUSYBOX_PSCAN=y
# Kernel modules
# FREETZ_MODULES_ALL is not set
# crypto
# FREETZ_MODULE_aes is not set
# FREETZ_MODULE_arc4 is not set
# FREETZ_MODULE_sha1 is not set
# FREETZ_MODULE_sha256 is not set
# drivers
# FREETZ_MODULE_loop is not set
# FREETZ_MODULE_nbd is not set
# FREETZ_MODULE_cdrom is not set
# FREETZ_MODULE_capiconn is not set
# FREETZ_MODULE_nand is not set
# FREETZ_MODULE_ohio_nand is not set
# FREETZ_MODULE_dummy is not set
# FREETZ_MODULE_ppp_async is not set
# FREETZ_MODULE_ppp_deflate is not set
# FREETZ_MODULE_ppp_generic is not set
# FREETZ_MODULE_pppoe is not set
# FREETZ_MODULE_pppox is not set
# FREETZ_MODULE_ppp_mppe_mppc is not set
# FREETZ_MODULE_scsi_mod is not set
# FREETZ_MODULE_sd_mod is not set
# FREETZ_MODULE_sg is not set
# FREETZ_MODULE_sr_mod is not set
# FREETZ_MODULE_slhc is not set
# FREETZ_MODULE_usblp is not set
# FREETZ_MODULE_usb_storage is not set
# FREETZ_MODULE_usbmon is not set
# FREETZ_MODULE_usbcore is not set
# FREETZ_MODULE_usbip is not set
# FREETZ_MODULE_usbip_common_mod is not set
# FREETZ_MODULE_usbserial is not set
# FREETZ_MODULE_pl2303 is not set
# FREETZ_MODULE_ftdi_sio is not set
# FREETZ_MODULE_hci_usb is not set
# FREETZ_MODULE_bfusb is not set
# FREETZ_MODULE_firmware_class is not set
# FREETZ_MODULE_dm_mod is not set
# FREETZ_MODULE_dm_crypt is not set
# fs
# FREETZ_MODULE_cifs is not set
# FREETZ_MODULE_coda is not set
FREETZ_MODULE_ext3=y
FREETZ_MODULE_ext2=y
# FREETZ_MODULE_fat is not set
# FREETZ_MODULE_fuse is not set
FREETZ_MODULE_jbd=y
# FREETZ_MODULE_lockd is not set
# FREETZ_MODULE_mini_fo is not set
# FREETZ_MODULE_minix is not set
# FREETZ_MODULE_nfsd is not set
# FREETZ_MODULE_exportfs is not set
# FREETZ_MODULE_nfs is not set
FREETZ_MODULE_nls_cp437=y
# FREETZ_MODULE_nls_cp852 is not set
# FREETZ_MODULE_nls_iso8859_15 is not set
FREETZ_MODULE_nls_iso8859_1=y
# FREETZ_MODULE_nls_utf8 is not set
# FREETZ_MODULE_ntfs is not set
# FREETZ_MODULE_reiserfs is not set
# FREETZ_MODULE_smbfs is not set
# FREETZ_MODULE_udf is not set
# FREETZ_MODULE_unionfs is not set
# FREETZ_MODULE_vfat is not set
# FREETZ_MODULE_msdods is not set
# FREETZ_MODULE_jffs2 is not set
FREETZ_MODULE_mbcache=y
# lib
# FREETZ_MODULE_crc_ccitt is not set
# net
# FREETZ_MODULE_bluetooth is not set
# FREETZ_MODULE_bnep is not set
FREETZ_MODULE_ipv6=y
# FREETZ_MODULE_l2cap is not set
# FREETZ_MODULE_rfcomm is not set
# FREETZ_MODULE_sunrpc is not set
# Shared libraries
# FREETZ_STRIP_LIBRARIES is not set
# Libraries -------------------------------
# FREETZ_LIB_libatm is not set
# FREETZ_LIB_libbluetooth is not set
# FREETZ_LIB_libopenobex is not set
# Crypto & SSL
# GnuPG ----------------------------------
# FREETZ_LIB_libgpg_error is not set
# FREETZ_LIB_libgcrypt is not set
# SSL ------------------------------------
# FREETZ_LIB_libcyassl is not set
# FREETZ_LIB_libmatrixssl is not set
# FREETZ_LIB_libxyssl is not set
FREETZ_LIB_libcrypto=y
FREETZ_LIB_libssl=y
# FREETZ_LIB_libavmhmac is not set
# Data compression
FREETZ_LIB_liblzo2=y
FREETZ_LIB_libz=y
# Graphics & fonts
# FREETZ_LIB_libjpeg is not set
# uClibc
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libnsl=y
FREETZ_LIB_libpthread=y
FREETZ_LIB_libresolv=y
FREETZ_LIB_librt=y
# FREETZ_LIB_libthread_db is not set
FREETZ_LIB_libuClibc=y
FREETZ_LIB_libutil=y
FREETZ_LIB_libuClibcxx=y
FREETZ_LIB_libgcc_s=y
FREETZ_LIB_libglib=y
# GLib2
# FREETZ_LIB_libglib2 is not set
# FREETZ_LIB_libgobject2 is not set
# FREETZ_LIB_libgmodule2 is not set
# FREETZ_LIB_libgthread2 is not set
# ncurses
# terminfo database
# Select terminfo database entries to install (see help of 'Show all items')
FREETZ_LIB_libterminfo=y
# FREETZ_LIB_libterminfo_showall is not set
FREETZ_LIB_libterminfo_ansi=y
FREETZ_LIB_libterminfo_gnome=y
FREETZ_LIB_libterminfo_konsole=y
FREETZ_LIB_libterminfo_linux=y
FREETZ_LIB_libterminfo_putty=y
FREETZ_LIB_libterminfo_rxvt=y
FREETZ_LIB_libterminfo_screen=y
FREETZ_LIB_libterminfo_screenminusw=y
FREETZ_LIB_libterminfo_sun=y
FREETZ_LIB_libterminfo_vt100=y
FREETZ_LIB_libterminfo_vt102=y
FREETZ_LIB_libterminfo_vt102minusnsgr=y
FREETZ_LIB_libterminfo_vt102minusw=y
FREETZ_LIB_libterminfo_vt200=y
FREETZ_LIB_libterminfo_vt220=y
FREETZ_LIB_libterminfo_vt52=y
FREETZ_LIB_libterminfo_xterm=y
FREETZ_LIB_libterminfo_xtermminuscolor=y
FREETZ_LIB_libterminfo_xtermminusxfree86=y
# FREETZ_LIB_libform is not set
# FREETZ_LIB_libmenu is not set
# FREETZ_LIB_libpanel is not set
FREETZ_LIB_libcapi20=y
# FREETZ_LIB_libcurl is not set
# FREETZ_LIB_libevent is not set
# FREETZ_LIB_libexpat is not set
# FREETZ_LIB_libid3tag is not set
# FREETZ_LIB_libltdl is not set
# FREETZ_LIB_libmad is not set
# FREETZ_LIB_libneon is not set
# FREETZ_LIB_libpcap is not set
# Readline
# FREETZ_LIB_libreadline is not set
# FREETZ_LIB_libhistory is not set
# FREETZ_LIB_libusb is not set
# FREETZ_LIB_libelf is not set
# FREETZ_LIB_libintl is not set
# FREETZ_LIB_libiconv is not set
# FREETZ_LIB_libftdi is not set
# FREETZ_LIB_libsysfs is not set
# FREETZ_LIB_libpopt is not set
# FREETZ_LIB_libdevmapper is not set
FREETZ_LIB_libfreetz=y
# Compiler options
# FREETZ_DOWNLOAD_TOOLCHAIN is not set
FREETZ_BUILD_TOOLCHAIN=y
FREETZ_TARGET_CROSS="mipsel-linux-uclibc-"
FREETZ_TARGET_CFLAGS="-Os -pipe -march=4kc -Wa,--trap"
FREETZ_JLEVEL=2
FREETZ_KERNEL_CROSS="mipsel-unknown-linux-gnu-"
FREETZ_HOSTCC="gcc"
FREETZ_KERNEL_VERSION_2_6_13_1=y
# FREETZ_KERNEL_VERSION_2_6_19_2 is not set
FREETZ_KERNEL_VERSION="2.6.13.1"
FREETZ_TARGET_UCLIBC_VERSION_0_9_28=y
# FREETZ_TARGET_UCLIBC_VERSION_0_9_29 is not set
# FREETZ_TARGET_COMPILER_GCC_4_1_0_UCLIBC_0_9_28 is not set
# FREETZ_TARGET_COMPILER_GCC_4_1_1_UCLIBC_0_9_28 is not set
# FREETZ_TARGET_COMPILER_GCC_4_1_2_UCLIBC_0_9_28 is not set
# FREETZ_TARGET_COMPILER_GCC_4_2_0_UCLIBC_0_9_28 is not set
FREETZ_TARGET_COMPILER_GCC_4_2_1_UCLIBC_0_9_28=y
# FREETZ_TARGET_COMPILER_GCC_4_2_1_UCLIBC_0_9_29 is not set
FREETZ_TARGET_GCC_VERSION="4.2.1"
FREETZ_TARGET_UCLIBC_VERSION="0.9.28"
FREETZ_TARGET_BINUTILS_VERSION="2.17.50.0.17"
FREETZ_TARGET_UCLIBC_CONFIG_MOD=y
# FREETZ_TARGET_UCLIBC_CONFIG_8MB is not set
# FREETZ_TARGET_UCLIBC_CONFIG_4MB is not set
FREETZ_TARGET_UCLIBC_REF="mod"
# FREETZ_STATIC_TOOLCHAIN is not set
FREETZ_TARGET_GXX=y
FREETZ_TARGET_CCACHE=y
# FREETZ_TARGET_NLS is not set
FREETZ_TARGET_LFS=y
FREETZ_KERNEL_COMPILER_GCC_3_4_6=y
FREETZ_KERNEL_GCC_VERSION="3.4.6"
FREETZ_KERNEL_BINUTILS_VERSION="2.17.50.0.17"
# FREETZ_TARGET_TOOLCHAIN is not set
# GNU debugger (gdb)
# FREETZ_PACKAGE_GDB is not set
# FREETZ_PACKAGE_GDB_SERVER is not set
# FREETZ_PACKAGE_GDB_HOST is not set
syslog of my other box, based on 2810 with another USB stick, which was automounted correctly:
Dec  2 18:29:34 fritz user.info kernel: kdsld: PPP led: off (value=0)
Dec  2 18:29:34 fritz user.info kernel: hub 1-0:1.0: USB hub found
Dec  2 18:29:34 fritz user.info kernel: hub 1-0:1.0: 1 port detected
Dec  2 18:29:34 fritz user.info kernel: avm_net_trace: New net trace device 'WLAN' registered with minor 0.
Dec  2 18:29:34 fritz user.info kernel: usb 1-1: new full speed USB device using ahci and address 2
Dec  2 18:29:34 fritz user.err kernel: [avm_power] : ethernet port 0 status 2
Dec  2 18:29:34 fritz user.err kernel: [avm_power] : ethernet port 1 status 1
Dec  2 18:29:34 fritz user.err kernel: [avm_power] : ethernet port 2 status 1
Dec  2 18:29:34 fritz user.err kernel: [avm_power] : ethernet port 3 status 1
Dec  2 18:29:34 fritz user.notice kernel: SCSI subsystem initialized
Dec  2 18:29:34 fritz user.info kernel: Initializing USB Mass Storage driver...
Dec  2 18:29:34 fritz user.info kernel: USB Mass Storage device (0951:1607) detected...
Dec  2 18:29:34 fritz user.info kernel: scsi0 : SCSI emulation for USB Mass Storage devices
Dec  2 18:29:34 fritz user.warn kernel: [ohio_vlynq_init] device 0
Dec  2 18:29:34 fritz user.warn kernel: [ohio_vlynq_startup_link]
Dec  2 18:29:34 fritz user.warn kernel: [setup_irq]: irq 29 irqaction->handler 0x9400592c (vlynq_interrupt+0x0/0x34 )
Dec  2 18:29:34 fritz user.warn kernel: [setup_irq]: irq 79 irqaction->handler 0xc030e39c (tiwlan_ddaVlynqIsr+0x0/0x28 [tiap] )
Dec  2 18:29:34 fritz user.debug kernel: usb-storage: device found at 2
Dec  2 18:29:34 fritz user.debug kernel: usb-storage: waiting for device to settle before scanning
Dec  2 18:29:34 fritz user.info kernel: usbcore: registered new driver usb-storage
Dec  2 18:29:34 fritz user.info kernel: USB Mass Storage support registered.
Dec  2 18:29:34 fritz user.info kernel: [avm_power]#### boostVoltage: DSP Core voltage set to 1,65 V ####
Dec  2 18:29:34 fritz user.info kernel: userman: LAN Client Internet-Accounting and Blocking
Dec  2 18:29:34 fritz user.warn kernel: userman: device registerd with major=228
Dec  2 18:29:34 fritz user.info kernel: userman: init ok
Dec  2 18:29:34 fritz user.notice kernel:   Vendor: Kingston  Model: DataTraveler 2.0  Rev: 1.00
Dec  2 18:29:34 fritz user.notice kernel:   Type:   Direct-Access                      ANSI SCSI revision: 02
Dec  2 18:29:34 fritz user.warn kernel: [setup_irq]: irq 27 irqaction->handler 0x940f1c7c (cpmac_main_isr+0x0/0x78 )
Dec  2 18:29:34 fritz user.notice kernel: SCSI device sda: 7856128 512-byte hdwr sectors (4022 MB)
Dec  2 18:29:34 fritz user.err kernel: [cpmac] cpmac_main_ioctl, unknown ioctl 35142
Dec  2 18:29:34 fritz user.info kernel: device eth0 entered promiscuous mode
Dec  2 18:29:34 fritz user.info kernel: device cpmac0 entered promiscuous mode
Dec  2 18:29:34 fritz user.info kernel: lan: port 1(eth0) entering learning state
Dec  2 18:29:34 fritz user.info kernel: lan: topology change detected, propagating
Dec  2 18:29:34 fritz user.info kernel: lan: port 1(eth0) entering forwarding state
Dec  2 18:29:34 fritz user.info kernel: device tiwlan0 entered promiscuous mode
Dec  2 18:29:34 fritz user.info kernel: lan: port 2(tiwlan0) entering learning state
Dec  2 18:29:34 fritz user.info kernel: lan: port 2(tiwlan0) entering forwarding state
Dec  2 18:29:34 fritz user.info kernel: device wdsup0 entered promiscuous mode
Dec  2 18:29:34 fritz user.info kernel: lan: port 3(wdsup0) entering learning state
Dec  2 18:29:34 fritz user.info kernel: lan: port 3(wdsup0) entering forwarding state
Dec  2 18:29:34 fritz user.info kernel: device wdsdw0 e
Dec  2 18:29:34 fritz user.info kernel: ntered promiscuous mode
Dec  2 18:29:34 fritz user.info kernel: lan: port 4(wdsdw0) entering learning state
Dec  2 18:29:34 fritz user.info kernel: lan: port 4(wdsdw0) entering forwarding state
Dec  2 18:29:34 fritz user.info kernel: device wdsdw1 entered promiscuous mode
Dec  2 18:29:34 fritz user.info kernel: lan: port 5(wdsdw1) entering learning state
Dec  2 18:29:34 fritz user.info kernel: lan: port 5(wdsdw1) entering forwarding state
Dec  2 18:29:34 fritz user.info kernel: device wdsdw2 entered promiscuous mode
Dec  2 18:29:34 fritz user.info kernel: lan: port 6(wdsdw2) entering learning state
Dec  2 18:29:34 fritz user.info kernel: lan: port 6(wdsdw2) entering forwarding state
Dec  2 18:29:34 fritz user.info kernel: device wdsdw3 entered promiscuous mode
Dec  2 18:29:34 fritz user.warn kernel: [cpmac] cpmac_main_dev_send, drop non vlan pkt (78 bytes)
Dec  2 18:29:34 fritz user.warn kernel: [cpmac] cpmac_main_dev_send, drop, 1, 0
Dec  2 18:29:34 fritz user.warn kernel: [cpmac] [cpphy_if_tx_complete] 78 bytes dropped (9)
Dec  2 18:29:34 fritz user.info kernel: lan: port 7(wdsdw3) entering learning state
Dec  2 18:29:34 fritz user.info kernel: lan: port 7(wdsdw3) entering forwarding state
Dec  2 18:29:34 fritz user.notice kernel: sda: Write Protect is off
Dec  2 18:29:34 fritz user.debug kernel: sda: Mode Sense: 23 00 00 00
Dec  2 18:29:34 fritz user.err kernel: sda: assuming drive cache: write through
Dec  2 18:29:34 fritz user.info kernel:  sda: sda1
Dec  2 18:29:34 fritz user.notice kernel: Attached scsi removable disk sda at scsi0, channel 0, id 0, lun 0
Dec  2 18:29:34 fritz user.info kernel: lan: duplicate address detected!
Dec  2 18:29:34 fritz user.notice kernel: Attached scsi generic sg0 at scsi0, channel 0, id 0, lun 0,  type 0
Dec  2 18:29:34 fritz user.debug kernel: usb-storage: device scan complete
Dec  2 18:29:34 fritz user.warn kernel: [cpmac] cpmac_main_dev_send, drop non vlan pkt (70 bytes)
Dec  2 18:29:34 fritz user.warn kernel: [cpmac] [cpphy_if_tx_complete] 70 bytes dropped (9)
Dec  2 18:29:34 fritz user.info kernel: kdsld: lan:
Dec  2 18:29:34 fritz user.info kernel: kdsld:  0: eth.proto 0x0800 ip.proto 17 udp.dport  5060 (act 1)
Dec  2 18:29:34 fritz user.info kernel: kdsld:  0: eth.proto 0x0800 ip.proto 17 udp.dport  53 (act 11)
Dec  2 18:29:34 fritz user.info kernel: kdsld:  0: eth.proto 0x0800 ip.proto 6 ip.len  <= 800 tcp.dport  80 (act 12)
Dec  2 18:29:34 fritz user.info kernel: kdsld:  0: eth.proto 0x0800 ip.proto 6 ip.len  <= 800 tcp.dport  8080 (act 12)
Dec  2 18:29:34 fritz user.info kernel: kdsld:  0: eth.proto 0x0800 ip.proto 6 ip.len  <= 800 tcp.dport  3128 (act 12)
Dec  2 18:29:34 fritz user.info kernel: kdsld:  0: eth.proto 0x0800 ip.proto 6 ip.len  <= 64 (act 10)
Dec  2 18:29:34 fritz user.info kernel: kdsld:  0: eth.proto 0x0800 ip.proto 1 (act 13)
Dec  2 18:29:34 fritz user.info kernel: kdsld: lan-optim:
Dec  2 18:29:34 fritz user.info kernel: kdsld:  0: eth.proto 0x0800 (act 1)
Dec  2 18:29:34 fritz user.info kernel: kdsld:  1:    ip.proto 17 (act 1)
Dec  2 18:29:34 fritz user.info kernel: kdsld:  2:       udp.dport  5060 (act 1)
Dec  2 18:29:34 fritz user.info kernel: kdsld:  2:       udp.dport  53 (act 11)
Dec  2 18:29:34 fritz user.info kernel: kdsld:  1:    ip.proto 6 (act 12)
Dec  2 18:29:34 fritz user.info kernel: kdsld:  2:       ip.len  <= 800 (act 12)
Dec  2 18:29:34 fritz user.info kernel: kdsld:  3:          tcp.dport  80 (act 12)
Dec  2 18:29:34 fritz user.info kernel: kdsld:  3:          tcp.dport  8080 (act 12)
Dec  2 18:29:34 fritz user.info kernel: kdsld:  3:          tcp.dport  3128 (act 12)
Dec  2 18:29:34 fritz user.info kernel: kdsld:  2:       ip.len  <= 64 (act 10)
Dec  2 18:29:34 fritz user.info kernel: kdsld:  1:    ip.proto 1 (act 13)
Dec  2 18:29:34 fritz user.warn kernel: [tiatm] DSL in Sync
Dec  2 18:29:34 fritz user.debug kernel: wdsup0: no IPv6 routers present
Dec  2 18:29:34 fritz user.debug kernel: tiwlan0: no IPv6 routers present
Dec  2 18:29:34 fritz user.info kernel: kdsld: showtime
Dec  2 18:29:34 fritz user.info kernel: kdsld: VCC 0: registered (0/35)
Dec  2 18:29:34 fritz user.info kernel: kdsld: 0:  VPI/VCI 0/35 RBE internet xxxx (24,14) mc upstream
Dec  2 18:29:34 fritz user.info kernel: kdsld: internet: set_rcv_ipaddr: xxxx
Dec  2 18:29:34 fritz user.info kernel: kdsld: dsl: registered
Dec  2 18:29:34 fritz user.info kernel: kdsld: VCC 0: iface internet dslencap RBE pcapencap ETHER llctype ether
Dec  2 18:29:34 fritz user.info kernel: kdsld: VCC 0: pcapencap RFC1843
Dec  2 18:29:34 fritz user.info kernel: kdsld: no vpnconnections configured
Dec  2 18:29:34 fritz user.info kernel: kdsld: setup done.
Dec  2 18:29:34 fritz user.info kernel: kdsld: DHCPC: internet: state init
Dec  2 18:29:34 fritz user.info kernel: kdsld: DHCPC: internet: state init, got event discover-sent
Dec  2 18:29:34 fritz user.info kernel: kdsld: DHCPC: internet: state selecting
Dec  2 18:29:34 fritz user.info kernel: kdsld_token_thread: start
Dec  2 18:29:34 fritz user.debug kernel: wdsdw1: no IPv6 routers present
Dec  2 18:29:34 fritz user.debug kernel: wdsdw0: no IPv6 routers present
Dec  2 18:29:34 fritz user.debug kernel: wdsdw2: no IPv6 routers present
Dec  2 18:29:34 fritz user.info kernel: kdsld: DHCPC: internet: state selecting, got event offer-received
Dec  2 18:29:34 fritz user.info kernel: kdsld: DHCPC: internet: state selecting, got event request-sent
Dec  2 18:29:34 fritz user.info kernel: kdsld: DHCPC: internet: state requesting
Dec  2 18:29:34 fritz user.info kernel: kdsld: DHCPC: internet: state requesting, got event ack-received
Dec  2 18:29:34 fritz user.info kernel: kdsld: DHCPC: internet: state bound (7200)
Dec  2 18:29:34 fritz user.info kernel: kdsld: internet: set_snd_ipaddr: 212.238.145.132
Dec  2 18:29:34 fritz user.info kernel: kdsld: internet: connected
Dec  2 18:29:34 fritz user.debug kernel: mcfw: forward enabled (vcc0: 00:1f:3f:b0:7f:5c, vlan 0, pppoe 0)
Dec  2 18:29:34 fritz user.info kernel: kdsld: PPP led: on (value=1)
Dec  2 18:29:34 fritz user.debug kernel: wdsdw3: no IPv6 router
Dec  2 18:29:34 fritz user.info kernel: s present
Dec  2 18:29:34 fritz user.warn kernel: AR7WDT: System Init UEberwachung abgeschlossen (194660 ms noch verfuegbar)
Dec  2 18:29:34 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_cpuclock: norm_power_rate=100 act_rate=99 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=0 mW
Dec  2 18:29:34 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_dspclock: norm_power_rate=100 act_rate=100 mul=154 div=10 offset=974 NormP=2514 mW -> SumNormP=2514 mW
Dec  2 18:29:34 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_systemclock: norm_power_rate=100 act_rate=83 mul=65 div=10 offset=1793 NormP=2443 mW -> SumNormP=4957 mW
Dec  2 18:29:34 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_wlan: norm_power_rate=100 act_rate=-2147483636 mul=84 div=10 offset=100 NormP=940 mW -> SumNormP=5897 mW
Dec  2 18:29:34 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_isdnnt: norm_power_rate=100 act_rate=-2147483648 mul=1 div=1 offset=0 NormP=100 mW -> SumNormP=5997 mW
Dec  2 18:29:34 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_isdnte: norm_power_rate=100 act_rate=0 mul=1 div=1 offset=0 NormP=100 mW -> SumNormP=6097 mW
Dec  2 18:29:34 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_analog: norm_power_rate=300 act_rate=0 mul=141 div=10 offset=100 NormP=4330 mW -> SumNormP=10427 mW
Dec  2 18:29:34 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_dect: norm_power_rate=100 act_rate=0 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=10427 mW
Dec  2 18:29:34 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_ethernet: norm_power_rate=467 act_rate=50331912 mul=1 div=1 offset=50 NormP=517 mW -> SumNormP=10944 mW
Dec  2 18:29:34 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_dsl: norm_power_rate=100 act_rate=0 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=10944 mW
Dec  2 18:29:34 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_host: norm_power_rate=500 act_rate=100 mul=55 div=10 offset=50 NormP=2800 mW -> SumNormP=13744 mW
Dec  2 18:29:34 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_usb_client: norm_power_rate=0 act_rate=0 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=13744 mW
Dec  2 18:29:34 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_charge: norm_power_rate=446 act_rate=0 mul=0 div=1 offset=0 NormP=0 mW -> SumNormP=13744 mW
Dec  2 18:29:34 fritz user.debug kernel: [avm_power] pm_ressourceinfo_scriptparse: powerdevice_loadrate: norm_power_rate=100 act_rate=99 mul=29 div=10 offset=-17 NormP=273 mW -> SumNormP=14017 mW
Dec  2 18:29:34 fritz user.info kernel: SysRq : Changing Loglevel
Dec  2 18:29:34 fritz user.warn kernel: Loglevel set to 4
Dec  2 18:29:34 fritz user.debug kernel: cpmac0: no IPv6 routers present
Dec  2 18:29:34 fritz user.warn kernel: [ubik2_debug] eof_sync =1
Dec  2 18:29:34 fritz user.debug kernel: eth0: no IPv6 routers present
Dec  2 18:29:41 fritz authpriv.info dropbear[852]: Running in background
Dec  2 18:29:43 fritz user.info kernel: lan: port 4(wdsdw0) entering disabled state
Dec  2 18:29:45 fritz user.err telefon[650]: set initial telefon time from linux time to 18:29 2.12 2008!
Dec  2 18:29:49 fritz user.info kernel: lan: port 4(wdsdw0) entering learning state
Dec  2 18:29:49 fritz user.info kernel: lan: topology change detected, propagating
Dec  2 18:29:49 fritz user.info kernel: lan: port 4(wdsdw0) entering forwarding state
Dec  2 18:29:59 fritz user.debug kernel: wdsdw0: no IPv6 routers present
Dec  2 18:30:41 fritz local0.info partition[602]: /dev/sda1: Superblock last mount time is in the future.  FIXED. /dev/sda1: Superblock last write time is in the future.  FIXED. /dev/sda1 has filesystem last checked time in the future, check forced. /dev/sda1: 39/4915
Dec  2 18:30:42 fritz user.info kernel: kjournald starting.  Commit interval 5 seconds
Dec  2 18:30:42 fritz user.warn kernel: EXT3-fs warning: checktime reached, running e2fsck is recommended
Dec  2 18:30:42 fritz user.info kernel: EXT3 FS on sda1, internal journal
Dec  2 18:30:42 fritz user.info kernel: EXT3-fs: mounted filesystem with ordered data mode.
Dec  2 18:30:42 fritz local0.info partition[602]: mounted '/dev/sda1' on '/var/media/ftp/uStora1' with 'noatime,nodiratime'
Dec  2 18:30:42 fritz local0.info partition[602]: not starting any services on '/var/media/ftp/uStora1'
Dec  2 18:31:44 fritz user.warn kernel: [speedup] -> 62.5 MHz
Dec  2 18:33:36 fritz user.warn kernel: [speedup] -> 125 MHz
Dec  2 18:34:40 fritz user.warn kernel: [speedup] -> 62.5 MHz
Dec  2 18:35:25 fritz user.warn kernel: [speedup] -> 125 MHz
Dec  2 18:36:26 fritz user.warn kernel: /proc/tffs: info request: success
Hi.
I can't test at the moment because I don't have a box. And the author has no time for support. But I'm wondering that mdev is working at all. Are there no hanging processes in ps?
Can you have a look in the folder /lib/mdev. Everythin okay here? Rights for the files...
Regards
Oliver
all files in /lib/mdev have rights 755 user root
No hanging processes in ps.
The most strange I find is that mdev worked in 2810, but not in 2825.
Hi.
I had a quick look over the changesets. For me 2812 and 2813 are suspicious. Perhaps you can revert these, "make busybox-dirclean" and try again.
Regards
Oliver
The correct order is first do "make busybox-dirclean" and then revert :).
I did a revert, and even a full rebuild, but the new 2810 image had the same problems.
I did try with the old image, and that still works on this box.
So it must be a matter of incompatible packages.
Unfortunatly I didn't store the configuration file of the working box :( , the only thing I know it had hand made patches of gw6, but I don't think they did the job.
I will retry with a lot less packages, and keep you informed.
BTW I also tried the same configuration (2825) without mdev, in that case there was also no automount, and it was less stable. (Regular reboots, and complains about sh which needed to be restarted in syslog)
Jaap
BTW I also tried the same configuration (2825) without mdev, in that case there was also no automount, and it was less stable. (Regular reboots, and complains about sh which needed to be restarted in syslog)Jaap
I did try mdev (when it was on by default) but ran into the same error messages. Was hard to get rid of them (dectivating mdev was not enough) since the device table needs to be reset as well.
Did you run a "make mdev-dirclean" after deselecting? The changes to the device table should be reverted then.
Yes, I did.
And I just created a smaller version based on R2831, where mdev is working as expected.
Now its just a matter of just adding packages, until it goes wrong again.
Jaap
The .config is packed into the tar firmware image.
Regards
Oliver
Problem solved
After creating about 20 images I found the problem :) :
When I move e2fsprogs to the external image it fails.
They are necessary by mdev to be able to mount ext2 or ext3 images.
Tonight I will file a ticket, that it should be impossible to select this combination
Which binary of e2fsprogs is needed by mdev? You can chose this in menuconfig.
The necessaray binaries are selected automatically but you musn't externalize them.
Regards
Oliver
It's possible to select single binaries to external'ize them, so we can try to figure out, which one in really needed, and which can be external'ized, if it's selected
Ralf65
