No init found (Kernel panic)
linuxkasten
Aktives Mitglied
2 Feb 2009
Habe mir soeben eine Firmware für die 3170 (7170 Alien) mit dem aktuellen Trunk R5124 erstellt. Nach dem Flashen bleibt die Box in einer Dauerschleife hängen:
(AVM) EVA Revision: 1.190 Version: 1190
(C) Copyright 2005 AVM Date: Nov 15 2006 Time: 16:53:42 (3) 2 0-1011
[FLASH:] MACRONIX Top-Flash 4MB
[FLASH:](Eraseregion [0] 63 sectors a 64kB)
[FLASH:](Eraseregion [1] 8 sectors a 8kB)
[SYSTEM:] OHIO on 211MHz/125MHz
Eva_AVM >AVM decompress Kernel:
..................done
start kernel
[ohio_pre_init] System Clk = 62500000 Hz
)�Linux version 2.6.13.1-ohio () (gcc version 3.4.6) #1 Tue Jun 22 18:58:38 CES0
memsize=32 MByte
flashsize=4 MByte
&_end=0x94264f84 PFN_ALIGN(&_end)=0x94265000 CPHYSADDR(PFN_ALIGN(&_end))=0x14260
CPU revision is: 00018448
[ohio_gpio_init]
Determined physical RAM map:
 memory: 00265000 @ 14000000 (reserved)
 memory: 01d9b000 @ 14265000 (usable)
On node 0 totalpages: 8192
[alloc_node_mem_map] reduce size from 2883616 Bytes to  262176 Bytes
[alloc_node_mem_map]: (org) sizeof(mem_map) = 262176 mem_map=0x94268000-0x942a80
[alloc_node_mem_map]: sizeof(mem_map) = 2883616 mem_map=0x93fe8000-0x942a8020
zone=0 zone_size[j]=0x90112
realsize=8192
  DMA zone: 8192 pages, LIFO batch:3
zone=1 zone_size[j]=0x0
realsize=0
  Normal zone: 0 pages, LIFO batch:1
zone=2 zone_size[j]=0x0
realsize=0
  HighMem zone: 0 pages, LIFO batch:1
Built 1 zonelists
Kernel command line:  console=ttyS0,38400n8r
[ld_mmu_r4xx0] memcpy((void *)(CAC_BASE   + 0x100), &except_vec2_generic, 0x30)
Primary instruction cache 16kB, physically tagged, 4-way, linesize 16 bytes.
Primary data cache 8kB, 4-way, linesize 16 bytes.
Synthesized TLB refill handler (20 instructions). Base=0x9422422c
TLB synthesizer field overflow (simm)
Synthesized TLB load handler fastpath (34 instructions) Base=0x94227620.
Synthesized TLB store handler fastpath (34 instructions) Base=0x94227820.
Synthesized TLB modify handler fastpath (33 instructions) Base=0x94227a20.
PID hash table entries: 256 (order: 8, 4096 bytes)
CPU frequency 211.97 MHz
Using 105.984 MHz high precision timer.
[setup_irq]: irq 255 irqaction->handler 0x94043870 (no_action+0x0/0x8 )
[register_console] enable commandline console 0
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 29952k/30316k available (1677k kernel code, 320k reserved, 403k data, 1)
totalram_pages= 7499
Calibrating delay loop... 211.35 BogoMIPS (lpj=1056768)
loops_per_jiffy=1056768
Mount-cache hash table entries: 512
Checking for 'wait' instruction...  available.
NET: Registered protocol family 16
Can't analyze prologue code at 941a1afc
squashfs: version 3.3 (2007/10/31) Phillip Lougher
Initializing Cryptographic API
avm_net_trace: Up and running.
[avm_power]Ohio250 detected -> overclocking possible
[avm] configured: watchdog eventled enable shift register enable direct gpio
        gpio usage: reset=12 clock=13 store=10 data=9
AR7WDT: Watchdog Driver for AR7 Hardware (Version 1.0, build: Jun 22 2010 18:58)
Serial: 8250/16550 driver $Revision: 1.90 $ 1 ports, IRQ sharing disabled
[uart_add_one_port]
ttyS0 at MMIO 0x0 (irq = 15) is a OHIO_UART
[uart_add_one_port] dont register console port->type = 16
port->cons = 0x941e63b0 port->cons->flags = 0x7
[uart_add_one_port] success
io scheduler noop registered
[cpmac] Version: 1.124  -  Revision 538:916  -  Mi   9.12.2009  14:07:43
[avm_event_source_trigger]: not registered
[cpmac] [cpmac_if_register] dev cpmac0 (phy_id 0) registered
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <[email protected]>
physmap flash device: 400000 at 10000000
phys_mapped_flash: Found 1 x16 devices at 0x0 in 16-bit bank
[genprobe_ident_chips] 4 i 0 j 0
[genprobe_ident_chips] 5 i 0 j 1
 Amd/Fujitsu Extended Query Table at 0x0040
phys_mapped_flash: Swapping erase regions for broken CFI table.
number of CFI chips: 1
RedBoot partition parsing not available
Generic platform RAM MTD, (c) 2004 Simtec Electronics
Ohio flash driver (size->0x400000 mem->0x10000000)
flash_size=0x400000
flash_mask=0x7fffff
Ohio flash memory: Found 1 x16 devices at 0x0 in 16-bit bank
Ohio flash memory: Swapping erase regions for broken CFI table.
[mtd]: set to default: jffs2_size = 0x20 * 64KByte (0x200000 Bytes)
[ohio_find_hidden_filesystem]: super block found: bytes_used: 0x0/3152887
[init_ohio_flash] find hidden filesystem size=0x303500 offset=0xbcb00
[mtd] configure jffs2 partition
[mtd] fs_size=0x3b0000 max=0x0 is=0x200000 max jffs2_size value 0
[mtd] ERROR jffs2_size too big, reduce to max
[mtd] ohio_flash_map: name=Ohio flash memory bankwidth=2 virt=0xb0000000 phys=00
Creating 5 MTD partitions on "Ohio flash memory":
0x000bcb00-0x003c0000 : "filesystem"
        'nor-flash'
        'Bits can be cleared (flash)'
        'Has an erase function'
mtd: partition "filesystem" doesn't start on an erase block boundary -- force ry
0x00010000-0x003c0000 : "kernel"
        'nor-flash'
0x00000000-0x00010000 : "bootloader"
        'nor-flash'
0x003c0000-0x003e0000 : "tffs (1)"
        'nor-flash'
0x003e0000-0x00400000 : "tffs (2)"
        'nor-flash'
partition_info[0]: name=filesystem offset=bcb00 size=303500
partition_info[0]: 0xb00bcb00: 0x73717368 0x754
partition_info[1]: name=kernel offset=10000 size=3b0000
partition_info[1]: 0xb0010000: 0xfeed1281 0xaca87
partition_info[2]: name=bootloader offset=0 size=10000
partition_info[2]: 0xb0000000: 0x40809000 0x40809800
partition_info[3]: name=tffs (1) offset=3c0000 size=20000
partition_info[3]: 0xb03c0000: 0x40001 0xfeffffff
partition_info[4]: name=tffs (2) offset=3e0000 size=20000
partition_info[4]: 0xb03e0000: 0x40001 0xfeffffff
NET: Registered protocol family 2
IP route cache hash table entries: 512 (order: -1, 2048 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
TCP bic registered
mcfw: IGMPv3 fast forwarding
NET: Registered protocol family 17
NET: Registered protocol family 8
NET: Registered protocol family 20
802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
All bugs added by David S. Miller <[email protected]>
[setup_irq]: irq 1 irqaction->handler 0x94001590 (dummy_timer_irq+0x0/0x14 )
[setup_irq]: irq 6 irqaction->handler 0x940015a4 (dummy_system_irq_2+0x0/0x14 )
[ohio_late_init]
[avm_new] push_button_gpio=8 value=1 enabled
TFFS: tiny flash file system driver. GPL (c) AVM Berlin (Version 2.0)
      mount on mtd4 and mtd5 (double buffering)
Adam2 environment variables API installed.
[prepare_namespace] new mount root /dev/mtdblock1
NumProbs = 7990 / 2 -> 15980
VFS: Mounted root (squashfs filesystem) readonly.
Freeing prom memory: 0kb freed
Freeing unused kernel memory: 116k freed (7528 free)
[setup_irq]: irq 15 irqaction->handler 0x940e1f6c (serial8250_interrupt+0x0/0x1)
Call Trace:
 [<942175d3>] env_init+0xff/0x17c
 [<94024cac>] panic+0x34/0x1e8
 [<940d0874>] avm_led_load_config+0x184/0x1c4
 [<940d2e10>] avm_led_gpio_bit_driver_action+0x0/0x18
 [<94078364>] sys_dup+0x28/0x3c
 [<940006c4>] init+0x260/0x26c
 [<940006d0>] try_name+0x0/0x20c
 [<9400044c>] run_init_process+0x1c/0x34
 [<94007f6c>] kernel_thread_helper+0x10/0x18
 [<94007f5c>] kernel_thread_helper+0x0/0x18
Kernel panic - not syncing: No init found.  Try passing init= option to kernel.
 WARING: use tffs in panic mode (minor 96)
Rebooting in 5 seconds..
Dann beginnt das ganze wieder von vorne. Ich hab keine Ahnung woran das liegt... hab es auch schon mit allen Blockgrößen probiert. Mir ist bewusst, dass ich in meiner .config extrem viel ausgewählt habe... nur wenn ich sehr viel entferne funktionieren manche Images, aber mir scheint, als würde es damit zu tun haben, wie viel Platz auf dem Flash belegt ist, und ich will ja herausfinden warum es so nicht funktioniert...
.config:
# Automatically generated make config: don't edit
FREETZ_HAVE_DOT_CONFIG=y
# General --------------------------------
FREETZ_AVM_VERSION_04_80=y
# FREETZ_TYPE_300IP_AS_FON is not set
# FREETZ_TYPE_2170 is not set
# FREETZ_TYPE_FON is not set
# FREETZ_TYPE_FON_5010 is not set
# FREETZ_TYPE_FON_5050 is not set
# FREETZ_TYPE_FON_5124 is not set
# FREETZ_TYPE_FON_5140 is not set
# FREETZ_TYPE_FON_WLAN is not set
# FREETZ_TYPE_FON_WLAN_7050 is not set
# FREETZ_TYPE_FON_WLAN_7112 is not set
# FREETZ_TYPE_FON_WLAN_7113 is not set
# FREETZ_TYPE_FON_WLAN_7140 is not set
# FREETZ_TYPE_FON_WLAN_7141 is not set
# FREETZ_TYPE_FON_7150 is not set
FREETZ_TYPE_FON_WLAN_7170=y
# FREETZ_TYPE_FON_WLAN_7240 is not set
# FREETZ_TYPE_FON_WLAN_7270 is not set
# FREETZ_TYPE_FON_WLAN_7270_V3 is not set
# FREETZ_TYPE_FON_WLAN_7570 is not set
# FREETZ_TYPE_WLAN_3020 is not set
# FREETZ_TYPE_WLAN_3030 is not set
# FREETZ_TYPE_WLAN_3130 is not set
# FREETZ_TYPE_WLAN_3131 is not set
# FREETZ_TYPE_WLAN_3170 is not set
# FREETZ_TYPE_WLAN_3270 is not set
# FREETZ_TYPE_WLAN_3270_V3 is not set
# FREETZ_TYPE_SPEEDPORT_W501V is not set
# FREETZ_TYPE_CUSTOM is not set
FREETZ_TYPE_ALIEN_HARDWARE=y
# FREETZ_TYPE_SPEEDPORT_W701V_7170 is not set
# FREETZ_TYPE_SPEEDPORT_W900V_7170 is not set
# FREETZ_TYPE_SPEEDPORT_W920V_7570 is not set
FREETZ_TYPE_3170_7170=y
# FREETZ_TYPE_7113_7170 is not set
# FREETZ_TYPE_7140_7170 is not set
# FREETZ_TYPE_7141_7170 is not set
# FREETZ_TYPE_7240_7270 is not set
FREETZ_AVM_VERSION_STRING="04.80"
FREETZ_TYPE_LANG_DE=y
# FREETZ_TYPE_LANG_A_CH is not set
# FREETZ_TYPE_LANG_EN is not set
FREETZ_TYPE_LANG_STRING="de"
FREETZ_TYPE_STRING="7170"
FREETZ_TYPE_STRING2="3170_"
FREETZ_INSTALL_BASE=y
FREETZ_REPLACE_BUSYBOX=y
FREETZ_SHOW_ADVANCED=y
FREETZ_REPLACE_KERNEL_AVAILABLE=y
FREETZ_REPLACE_KERNEL=y
# FREETZ_TARGET_IPV6_SUPPORT is not set
FREETZ_TARGET_REF="8mb_26"
FREETZ_KERNEL_REF="8mb_26"
FREETZ_KERNEL_LAYOUT="ohio"
FREETZ_KERNEL_MTD_SIZE=59
FREETZ_HAS_PHONE=y
FREETZ_HAS_TAM=y
FREETZ_HAS_WLAN=y
# FREETZ_HAS_USB_CLIENT is not set
FREETZ_HAS_USB_HOST=y
# FREETZ_HAS_AVM_INETD is not set
FREETZ_HAS_LIBSSL=y
# Mod ------------------------------------
FREETZ_LANG_DE=y
# FREETZ_LANG_EN is not set
FREETZ_LANG_STRING="de"
# Patches
# Web menu patches ------------------------
# FREETZ_PATCH_VCC is not set
FREETZ_PATCH_DSL_EXPERT=y
# FREETZ_ADD_REGEXT_GUI is not set
# FREETZ_PATCH_ALARMCLOCK is not set
FREETZ_PATCH_SIGNED=y
# USB mounting ----------------------------
FREETZ_PATCH_FREETZMOUNT=y
FREETZ_PATCH_RCFTPD=y
FREETZ_USBSTORAGE_AUTOMOUNT=y
FREETZ_AUTOMOUNT_EXT2=y
# FREETZ_AUTOMOUNT_EXT3 is not set
FREETZ_AUTOMOUNT_NTFS=y
# FREETZ_AUTOMOUNT_REISER_FS is not set
FREETZ_PATCH_MAXDEVCOUNT=y
FREETZ_PATCH_MULTIPLE_PRINTERS=y
# Removings -------------------------------
FREETZ_REMOVE_ASSISTANT=y
FREETZ_REMOVE_AURA_USB=y
FREETZ_REMOVE_AVM_VPN=y
# Remove brandings
# avm and tcom branding can't be removed
FREETZ_REMOVE_BRANDING_1und1=y
FREETZ_REMOVE_BRANDING_freenet=y
FREETZ_REMOVE_CAPIOVERTCP=y
# FREETZ_REMOVE_DSLD is not set
FREETZ_REMOVE_DTRACE=y
FREETZ_REMOVE_FTPD=y
FREETZ_REMOVE_HELP=y
FREETZ_REMOVE_MEDIASRV=y
FREETZ_REMOVE_MINID=y
FREETZ_REMOVE_RUNCLOCK=y
FREETZ_REMOVE_SMBD=y
FREETZ_REMOVE_SUPPORT=y
FREETZ_REMOVE_TR069=y
FREETZ_REMOVE_TR069_FWUPDATE=y
FREETZ_REMOVE_UPNP=y
# FREETZ_REMOVE_UPNP_LIBS is not set
FREETZ_REMOVE_USERMAN=y
FREETZ_REMOVE_VOIPD=y
FREETZ_REMOVE_VOIP_ISDN=y
# FREETZ_REMOVE_WLAN is not set
# Adds -----------------------------------
# FREETZ_ENFORCE_URLADER_SETTINGS is not set
# Other stuff -----------------------------
# FREETZ_PATCH_GETCONS is not set
# Package selection
# Standard packages
# FREETZ_PACKAGE_BFTPD is not set
# FREETZ_PACKAGE_BIRD is not set
# FREETZ_PACKAGE_BRIDGE_UTILS is not set
# FREETZ_PACKAGE_CALLMONITOR is not set
# FREETZ_PACKAGE_CHECKMAILD is not set
# FREETZ_PACKAGE_CIFSMOUNT is not set
# FREETZ_PACKAGE_CPMACCFG is not set
# FREETZ_PACKAGE_CURL is not set
# FREETZ_PACKAGE_DECO is not set
# FREETZ_PACKAGE_DNS2TCP is not set
# FREETZ_PACKAGE_DNSMASQ is not set
# FREETZ_PACKAGE_DROPBEAR is not set
# FREETZ_PACKAGE_DTMFBOX is not set
# FREETZ_PACKAGE_ESPEAK is not set
# FREETZ_PACKAGE_FORTUNE is not set
# FREETZ_PACKAGE_FUSE is not set
# FREETZ_PACKAGE_INETD is not set
# FREETZ_PACKAGE_KNOCK is not set
# FREETZ_PACKAGE_MC is not set
# FREETZ_PACKAGE_MINI_FO is not set
# FREETZ_PACKAGE_MTR is not set
# FREETZ_PACKAGE_NANO is not set
# FREETZ_PACKAGE_NETCAT is not set
# FREETZ_PACKAGE_NETSNMP is not set
# FREETZ_PACKAGE_NFS_UTILS is not set
FREETZ_PACKAGE_NTFS=y
# FREETZ_PACKAGE_OPENNTPD is not set
# FREETZ_PACKAGE_OPENVPN is not set
# FREETZ_PACKAGE_PHP is not set
# FREETZ_PACKAGE_PINGTUNNEL is not set
# FREETZ_PACKAGE_PORTMAP is not set
# FREETZ_PACKAGE_PRIVOXY is not set
# FREETZ_PACKAGE_RCAPID is not set
# FREETZ_PACKAGE_SAMBA is not set
# FREETZ_PACKAGE_SCREEN is not set
# FREETZ_PACKAGE_STUNNEL is not set
# FREETZ_PACKAGE_TCPDUMP is not set
# FREETZ_PACKAGE_TOR is not set
# FREETZ_PACKAGE_TRANSMISSION is not set
# FREETZ_PACKAGE_VNSTAT is not set
# FREETZ_PACKAGE_VPNC is not set
FREETZ_PACKAGE_VSFTPD=y
# FREETZ_PACKAGE_VSFTPD_WITH_SSL is not set
# FREETZ_PACKAGE_VSFTPD_STATIC is not set
# FREETZ_PACKAGE_XMAIL is not set
# Web interfaces
FREETZ_PACKAGE_AVM_FIREWALL=y
# FREETZ_PACKAGE_CPMACCFG_CGI is not set
# FREETZ_PACKAGE_DOWNLOADER is not set
FREETZ_PACKAGE_AUTHORIZED_KEYS=y
# FREETZ_PACKAGE_NFSD_CGI is not set
# FREETZ_PACKAGE_NHIPT is not set
# FREETZ_PACKAGE_ONLINECHANGED_CGI is not set
# FREETZ_PACKAGE_PHPXMAIL is not set
# FREETZ_PACKAGE_PPP_CGI is not set
# FREETZ_PACKAGE_RRDSTATS is not set
# FREETZ_PACKAGE_SPINDOWN_CGI is not set
# FREETZ_PACKAGE_SYSLOGD_CGI is not set
# FREETZ_PACKAGE_TRANSMISSION_CGI is not set
# FREETZ_PACKAGE_VIRTUALIP_CGI is not set
# FREETZ_PACKAGE_VNSTAT_CGI is not set
# FREETZ_PACKAGE_WOL_CGI is not set
# Debug helpers
# FREETZ_PACKAGE_LDD is not set
# FREETZ_PACKAGE_LSOF is not set
# FREETZ_PACKAGE_LTRACE is not set
# FREETZ_PACKAGE_NANO_SHELL is not set
# FREETZ_PACKAGE_PCIUTILS is not set
# FREETZ_PACKAGE_STRACE is not set
# FREETZ_PACKAGE_USBUTILS is not set
# Testing
# FREETZ_PACKAGE_APACHE is not set
# FREETZ_PACKAGE_BASH is not set
# FREETZ_PACKAGE_BFUSB is not set
# FREETZ_PACKAGE_BIP is not set
# FREETZ_PACKAGE_BITTWIST is not set
# FREETZ_PACKAGE_BLUEZ_UTILS is not set
# FREETZ_PACKAGE_BR2684CTL is not set
# FREETZ_PACKAGE_CRYPTSETUP is not set
# FREETZ_PACKAGE_CTORRENT is not set
# FREETZ_PACKAGE_DAVFS2 is not set
# FREETZ_PACKAGE_DEBOOTSTRAP is not set
# FREETZ_PACKAGE_DIGITEMP is not set
# FREETZ_PACKAGE_DOSFSTOOLS is not set
# FREETZ_PACKAGE_DTACH is not set
FREETZ_PACKAGE_E2FSPROGS=y
# FREETZ_PACKAGE_E2FSPROGS_STATIC is not set
# FREETZ_PACKAGE_E2FSPROGS_E2FSCK is not set
# FREETZ_PACKAGE_E2FSPROGS_E2MAKING is not set
# FREETZ_PACKAGE_E2FSPROGS_E2TUNING is not set
# FREETZ_PACKAGE_E2FSPROGS_E2DEBUG is not set
FREETZ_PACKAGE_E2FSPROGS_BLKID=y
# FREETZ_PACKAGE_E2FSPROGS_E2FIXING is not set
# FREETZ_PACKAGE_EMPTY is not set
FREETZ_PACKAGE_FSTYP=y
# FREETZ_PACKAGE_GIT is not set
# FREETZ_PACKAGE_GNU_MAKE is not set
# FREETZ_PACKAGE_GNUTLS is not set
# FREETZ_PACKAGE_GOCR is not set
# FREETZ_PACKAGE_HD_IDLE is not set
# FREETZ_PACKAGE_HOL is not set
# FREETZ_PACKAGE_HTOP is not set
# FREETZ_PACKAGE_HTTPRY is not set
# FREETZ_PACKAGE_HTTPTUNNEL is not set
# FREETZ_PACKAGE_IGMPPROXY is not set
# FREETZ_PACKAGE_INADYN_MT is not set
# FREETZ_PACKAGE_INOTIFY_TOOLS is not set
# FREETZ_PACKAGE_IODINE is not set
# FREETZ_PACKAGE_IPTRAF is not set
# FREETZ_PACKAGE_IRSSI is not set
# FREETZ_PACKAGE_JAMVM is not set
# FREETZ_PACKAGE_LFTP is not set
FREETZ_PACKAGE_LIGHTTPD=y
FREETZ_PACKAGE_LIGHTTPD_WITH_SSL=y
# FREETZ_PACKAGE_LIGHTTPD_USE_CYASSL is not set
# FREETZ_PACKAGE_LIGHTTPD_LDD is not set
# FREETZ_PACKAGE_LIGHTTPD_WITH_LUA is not set
# lighttpd Modules
# Select the modules you want to be included in the image
FREETZ_PACKAGE_LIGHTTPD_MOD_ACCESS=y
FREETZ_PACKAGE_LIGHTTPD_MOD_INDEXFILE=y
FREETZ_PACKAGE_LIGHTTPD_MOD_STATICFILE=y
FREETZ_PACKAGE_LIGHTTPD_MOD_ACCESSLOG=y
FREETZ_PACKAGE_LIGHTTPD_MOD_ALIAS=y
FREETZ_PACKAGE_LIGHTTPD_MOD_AUTH=y
FREETZ_PACKAGE_LIGHTTPD_MOD_CGI=y
# FREETZ_PACKAGE_LIGHTTPD_MOD_COMPRESS is not set
FREETZ_PACKAGE_LIGHTTPD_MOD_DIRLISTING=y
FREETZ_PACKAGE_LIGHTTPD_MOD_EVASIVE=y
FREETZ_PACKAGE_LIGHTTPD_MOD_EVHOST=y
FREETZ_PACKAGE_LIGHTTPD_MOD_EXPIRE=y
FREETZ_PACKAGE_LIGHTTPD_MOD_EXTFORWARD=y
FREETZ_PACKAGE_LIGHTTPD_MOD_FASTCGI=y
FREETZ_PACKAGE_LIGHTTPD_MOD_FLV_STREAMING=y
FREETZ_PACKAGE_LIGHTTPD_MOD_PROXY=y
FREETZ_PACKAGE_LIGHTTPD_MOD_REDIRECT=y
FREETZ_PACKAGE_LIGHTTPD_MOD_REWRITE=y
# FREETZ_PACKAGE_LIGHTTPD_MOD_RRDTOOL is not set
# FREETZ_PACKAGE_LIGHTTPD_MOD_SCGI is not set
FREETZ_PACKAGE_LIGHTTPD_MOD_SECDOWNLOAD=y
FREETZ_PACKAGE_LIGHTTPD_MOD_SETENV=y
FREETZ_PACKAGE_LIGHTTPD_MOD_SIMPLE_VHOST=y
# FREETZ_PACKAGE_LIGHTTPD_MOD_SSI is not set
# FREETZ_PACKAGE_LIGHTTPD_MOD_STATUS is not set
# FREETZ_PACKAGE_LIGHTTPD_MOD_TRIGGER_B4_DL is not set
FREETZ_PACKAGE_LIGHTTPD_MOD_USERDIR=y
FREETZ_PACKAGE_LIGHTTPD_MOD_USERTRACK=y
# FREETZ_PACKAGE_LIGHTTPD_MOD_WEBDAV is not set
# FREETZ_PACKAGE_LYNX is not set
# FREETZ_PACKAGE_LUA is not set
# FREETZ_PACKAGE_MADPLAY is not set
# FREETZ_PACKAGE_MATRIXTUNNEL is not set
# FREETZ_PACKAGE_MCABBER is not set
# FREETZ_PACKAGE_MICROPERL is not set
# FREETZ_PACKAGE_MINI_SNMPD is not set
# FREETZ_PACKAGE_MINICOM is not set
# FREETZ_PACKAGE_MODULE_INIT_TOOLS is not set
# FREETZ_PACKAGE_NAGIOS is not set
# FREETZ_PACKAGE_NCFTP is not set
# FREETZ_PACKAGE_NETPBM is not set
# FREETZ_PACKAGE_NOIP is not set
# FREETZ_PACKAGE_NDAS is not set
# FREETZ_PACKAGE_NFSROOT is not set
# FREETZ_PACKAGE_NGIRCD is not set
# FREETZ_PACKAGE_NMAP is not set
# FREETZ_PACKAGE_OBEXFTP is not set
# FREETZ_PACKAGE_OIDENTD is not set
# FREETZ_PACKAGE_OPENCONNECT is not set
# OpenSSH
# FREETZ_PACKAGE_OPENSSH_SSHD is not set
# FREETZ_PACKAGE_OPENSSH_CLIENT is not set
# FREETZ_PACKAGE_OPENSSH_SCP is not set
# FREETZ_PACKAGE_OPENSSH_CLIENTUTILS is not set
# FREETZ_PACKAGE_OPENSSH_KEYUTILS is not set
# FREETZ_PACKAGE_OPENSSH_SFTPCLIENT is not set
# FREETZ_PACKAGE_OPENSSH_SFTP is not set
# FREETZ_PACKAGE_OWFS is not set
# FREETZ_PACKAGE_POLIPO is not set
# FREETZ_PACKAGE_PPPD_CHAT is not set
# FREETZ_PACKAGE_PPTP is not set
# FREETZ_PACKAGE_PPTPD is not set
# FREETZ_PACKAGE_QUAGGA is not set
# FREETZ_PACKAGE_RRDTOOL is not set
# FREETZ_PACKAGE_RSYNC is not set
# FREETZ_PACKAGE_RUBY is not set
# FREETZ_PACKAGE_SABLEVM_SDK is not set
# FREETZ_PACKAGE_SER2NET is not set
# FREETZ_PACKAGE_SIPROXD is not set
# FREETZ_PACKAGE_SISPMCTL is not set
# FREETZ_PACKAGE_SLANG is not set
# FREETZ_PACKAGE_SLURM is not set
# FREETZ_PACKAGE_SOCAT is not set
# FREETZ_PACKAGE_SPAWN_FCGI is not set
# FREETZ_PACKAGE_SQLITE is not set
# FREETZ_PACKAGE_SQUID is not set
# FREETZ_PACKAGE_STREAMRIPPER is not set
# FREETZ_PACKAGE_SUBVERSION is not set
# FREETZ_PACKAGE_SYNCE_DCCM is not set
# FREETZ_PACKAGE_SYNCE_SERIAL is not set
# FREETZ_PACKAGE_TCP_WRAPPERS is not set
# FREETZ_PACKAGE_TCPPROXY is not set
# FREETZ_PACKAGE_TINYPROXY is not set
# FREETZ_PACKAGE_TREE is not set
# FREETZ_PACKAGE_TRICKLE is not set
# FREETZ_PACKAGE_TMUX is not set
# FREETZ_PACKAGE_UMURMUR is not set
# FREETZ_PACKAGE_UNRAR is not set
FREETZ_PACKAGE_USBROOT=y
# FREETZ_PACKAGE_USBROOT_E2FSCK is not set
# FREETZ_PACKAGE_VIM is not set
# FREETZ_PACKAGE_VTUN is not set
# FREETZ_PACKAGE_WGET is not set
# FREETZ_PACKAGE_WOL is not set
# FREETZ_PACKAGE_WPUT is not set
# FREETZ_PACKAGE_XPDF is not set
# FREETZ_PACKAGE_XRELAYD is not set
# FREETZ_PACKAGE_XSLTPROC is not set
# FREETZ_SHOW_UNSTABLE_PACKAGES is not set
FREETZ_PACKAGE_HASERL=y
FREETZ_PACKAGE_MODCGI=y
# Advanced options
# FREETZ_DL_OVERRIDE is not set
FREETZ_DL_KERNEL_SITE="@AVM/fritz.box/fritzbox.fon_wlan_7170/x_misc/opensrc"
FREETZ_DL_KERNEL_SOURCE="fritzbox7170-source-files-04.80.tar.gz"
FREETZ_DL_KERNEL_SOURCE_MD5="6bf92b81b48a3a05efd3aae6c05fe3e2"
FREETZ_DL_SITE="@AVM/fritz.box/fritzbox.fon_wlan_7170/firmware/deutsch"
FREETZ_DL_SOURCE="FRITZ.Box_Fon_WLAN_7170.29.04.80.image"
FREETZ_DL_SOURCE_MD5="72b48986aa26a6f0a16b2a4a2bfb7bb0"
FREETZ_DL_SITE2="@AVM/fritz.box/fritzbox.wlan_3170/firmware/deutsch"
FREETZ_DL_SOURCE2="fritz.box_wlan_3170.49.04.58.image"
FREETZ_DL_SOURCE2_MD5="f08942a9679002e21c29bb2cad9ded3e"
# Freetz package download sites
FREETZ_MOD_DL_NUM_SITES="5"
# Download site #1 - default: http://freetz.3dfxatwork.de
FREETZ_MOD_DL_SITE_1="http://freetz.3dfxatwork.de"
# Download site #2 - default: http://freetz.wirsind.info
FREETZ_MOD_DL_SITE_2="http://freetz.wirsind.info"
# Download site #3 - default: http://freetz.magenbrot.net
FREETZ_MOD_DL_SITE_3="http://freetz.magenbrot.net"
# Download site #4 - default: empty (reserved for later use)
FREETZ_MOD_DL_SITE_4=""
# Download site #5 - user-defined
FREETZ_MOD_DL_SITE_5=""
FREETZ_SECURITY_LEVEL=0
FREETZ_VERBOSITY_LEVEL=2
FREETZ_FAVICON_NONE=y
# FREETZ_FAVICON_ATOMPHIL is not set
# FREETZ_FAVICON_CUMA is not set
# FREETZ_FAVICON_DSL123 is not set
# FREETZ_FAVICON_HANSOLO is not set
# FREETZ_BACKUP_CONFIG_CACHE is not set
FREETZ_CHECK_CHANGED=y
FREETZ_FAVICON_STRING="none"
FREETZ_SUBVERSION_STRING=y
FREETZ_DEVELOPER_VERSION_STRING=y
# FREETZ_STYLE_COLORED is not set
FREETZ_STYLE_GREY=y
FREETZ_STYLE="grey"
FREETZ_USER_DEFINED_COMMENT=""
# FREETZ_CUSTOM_IMAGE_NAME is not set
# Info pages
FREETZ_REMOVE_BOX_INFO=y
FREETZ_REMOVE_FREETZ_INFO=y
# FREETZ_REMOVE_DOT_CONFIG is not set
# External
# EXTERNAL_ENABLED is not set
# CAUTION: SQUASHFS blocksizes greater than 64 KB can cause extensive memory usage and lead to an unstable box.
# FREETZ_SQUASHFS_BLOCKSIZE_ORIG is not set
# FREETZ_SQUASHFS_BLOCKSIZE_65536 is not set
# FREETZ_SQUASHFS_BLOCKSIZE_131072 is not set
# FREETZ_SQUASHFS_BLOCKSIZE_262144 is not set
# FREETZ_SQUASHFS_BLOCKSIZE_524288 is not set
FREETZ_SQUASHFS_BLOCKSIZE_1048576=y
# FREETZ_REPLACE_SSL_LIBS is not set
# BusyBox options
# FREETZ_BUSYBOX_AR is not set
# FREETZ_BUSYBOX_BRCTL is not set
# FREETZ_BUSYBOX_BZIP2 is not set
# FREETZ_BUSYBOX_CHGRP is not set
# FREETZ_BUSYBOX_FEATURE_DD_IBS_OBS is not set
# FREETZ_BUSYBOX_DIFF is not set
# FREETZ_BUSYBOX_DOS2UNIX is not set
# FREETZ_BUSYBOX_ETHER_WAKE is not set
# FREETZ_BUSYBOX_FANCY_KEYS is not set
# FREETZ_BUSYBOX_FUSER is not set
# FREETZ_BUSYBOX_INETD is not set
# FREETZ_BUSYBOX_IP is not set
# FREETZ_BUSYBOX_LESS is not set
# FREETZ_BUSYBOX_LONG_OPTS is not set
# FREETZ_BUSYBOX_LS_COLOR is not set
FREETZ_BUSYBOX_MD5SUM=y
# FREETZ_BUSYBOX_MDEV is not set
# FREETZ_BUSYBOX_MOUNT_HELPERS is not set
# FREETZ_BUSYBOX_MOUNT_LABEL is not set
# FREETZ_BUSYBOX_NICE is not set
# FREETZ_BUSYBOX_PATCH is not set
# FREETZ_BUSYBOX_PSCAN is not set
FREETZ_BUSYBOX_REALPATH=y
# FREETZ_BUSYBOX_SEQ is not set
# FREETZ_BUSYBOX_SHA1SUM is not set
# FREETZ_BUSYBOX_SPLIT is not set
# FREETZ_BUSYBOX_START_STOP_DAEMON is not set
# FREETZ_BUSYBOX_TAC is not set
# FREETZ_BUSYBOX_UDHCPC is not set
# FREETZ_BUSYBOX_UDHCPD is not set
# FREETZ_BUSYBOX_UNIX2DOS is not set
# FREETZ_BUSYBOX_UNZIP is not set
# FREETZ_BUSYBOX_FEATURE_USERNAME_COMPLETION is not set
# FREETZ_BUSYBOX_VOLUMEID is not set
FREETZ_BUSYBOX_WGET=y
# FREETZ_BUSYBOX_WHOAMI is not set
# Kernel modules
# FREETZ_MODULES_ALL is not set
# block
# FREETZ_MODULE_ramzswap is not set
# FREETZ_MODULE_xvmalloc is not set
# crypto
# FREETZ_MODULE_aes is not set
# FREETZ_MODULE_arc4 is not set
# FREETZ_MODULE_sha1 is not set
# FREETZ_MODULE_sha256 is not set
# drivers
# FREETZ_MODULE_loop is not set
# FREETZ_MODULE_nbd is not set
# FREETZ_MODULE_cdrom is not set
# FREETZ_MODULE_capiconn is not set
# FREETZ_MODULE_nand is not set
# FREETZ_MODULE_ohio_nand is not set
# FREETZ_MODULE_dummy is not set
# FREETZ_MODULE_ppp_async is not set
# FREETZ_MODULE_ppp_deflate is not set
# FREETZ_MODULE_ppp_generic is not set
# FREETZ_MODULE_pppoe is not set
# FREETZ_MODULE_pppox is not set
# FREETZ_MODULE_ppp_mppe_mppc is not set
# FREETZ_MODULE_scsi_mod is not set
# FREETZ_MODULE_sd_mod is not set
# FREETZ_MODULE_sg is not set
# FREETZ_MODULE_sr_mod is not set
# FREETZ_MODULE_slhc is not set
# FREETZ_MODULE_usblp is not set
# FREETZ_MODULE_usb_storage is not set
# FREETZ_MODULE_usbmon is not set
# FREETZ_MODULE_usbcore is not set
# FREETZ_MODULE_usbip is not set
# FREETZ_MODULE_usbip_common_mod is not set
# FREETZ_MODULE_usbserial is not set
# FREETZ_MODULE_ipaq is not set
# FREETZ_MODULE_pl2303 is not set
# FREETZ_MODULE_ftdi_sio is not set
# FREETZ_MODULE_hci_usb is not set
# FREETZ_MODULE_bfusb is not set
# FREETZ_MODULE_firmware_class is not set
# FREETZ_MODULE_dm_mod is not set
# FREETZ_MODULE_dm_crypt is not set
# FREETZ_MODULE_option is not set
# fs
# FREETZ_MODULE_cifs is not set
# FREETZ_MODULE_coda is not set
# FREETZ_MODULE_ext3 is not set
FREETZ_MODULE_ext2=y
FREETZ_MODULE_fat=y
# FREETZ_MODULE_hfs is not set
# FREETZ_MODULE_hfsplus is not set
FREETZ_MODULE_fuse=y
# FREETZ_MODULE_jbd is not set
# FREETZ_MODULE_lockd is not set
# FREETZ_MODULE_mini_fo is not set
# FREETZ_MODULE_minix is not set
# ndas
# FREETZ_MODULE_ndas_block is not set
# FREETZ_MODULE_ndas_core is not set
# FREETZ_MODULE_ndas_sal is not set
# FREETZ_MODULE_nfsd is not set
# FREETZ_MODULE_exportfs is not set
# FREETZ_MODULE_nfs is not set
# FREETZ_MODULE_nls_cp437 is not set
# FREETZ_MODULE_nls_cp852 is not set
# FREETZ_MODULE_nls_iso8859_15 is not set
# FREETZ_MODULE_nls_iso8859_1 is not set
# FREETZ_MODULE_nls_utf8 is not set
# FREETZ_MODULE_ntfs is not set
# FREETZ_MODULE_reiserfs is not set
# FREETZ_MODULE_smbfs is not set
# FREETZ_MODULE_udf is not set
# FREETZ_MODULE_unionfs is not set
FREETZ_MODULE_vfat=y
FREETZ_MODULE_msdods=y
# FREETZ_MODULE_jffs2 is not set
FREETZ_MODULE_mbcache=y
# lib
# FREETZ_MODULE_crc_ccitt is not set
# FREETZ_MODULE_lzo_compress is not set
# FREETZ_MODULE_lzo_decompress is not set
# net
# FREETZ_MODULE_bluetooth is not set
# FREETZ_MODULE_bnep is not set
# FREETZ_MODULE_l2cap is not set
# FREETZ_MODULE_rfcomm is not set
# FREETZ_MODULE_sunrpc is not set
# FREETZ_MODULE_sch_cbq is not set
# FREETZ_MODULE_cls_u32 is not set
# Shared libraries
FREETZ_STRIP_LIBRARIES=y
# Libraries -------------------------------
# FREETZ_LIB_libapr is not set
# FREETZ_LIB_libaprutil is not set
# FREETZ_LIB_libdb is not set
# FREETZ_LIB_libbluetooth is not set
# FREETZ_LIB_libcapi20 is not set
# Crypto & SSL
# GMP ------------------------------------
# FREETZ_LIB_libgmp is not set
# GnuPG ----------------------------------
# FREETZ_LIB_libgpg_error is not set
# FREETZ_LIB_libgcrypt is not set
# SSL ------------------------------------
# FREETZ_LIB_libcyassl is not set
# FREETZ_LIB_libmatrixssl is not set
# FREETZ_LIB_libpolarssl is not set
FREETZ_LIB_libcrypto=y
FREETZ_LIB_libssl=y
# GnuTLS ---------------------------------
# FREETZ_LIB_libgnutls is not set
# FREETZ_LIB_libtasn1 is not set
# Data compression
# FREETZ_LIB_liblzo2 is not set
# FREETZ_LIB_libz is not set
# e2fsprogs libraries
FREETZ_LIB_libblkid=y
FREETZ_LIB_libcom_err=y
# FREETZ_LIB_libe2p is not set
FREETZ_LIB_libext2fs=y
# FREETZ_LIB_libss is not set
FREETZ_LIB_libuuid=y
FREETZ_LIB_libgcc_s=y
# GLib
# FREETZ_LIB_libglib_1 is not set
# FREETZ_LIB_libglib_2 is not set
# FREETZ_LIB_libgio_2 is not set
# FREETZ_LIB_libgobject_2 is not set
# FREETZ_LIB_libgmodule_2 is not set
# FREETZ_LIB_libgthread_2 is not set
# Graphics & fonts
# FREETZ_LIB_libfreetype is not set
# FREETZ_LIB_libart_lgpl_2 is not set
# FREETZ_LIB_libjpeg is not set
# FREETZ_LIB_libpng12 is not set
# FREETZ_LIB_libgd is not set
# FREETZ_LIB_libnetpbm is not set
# FREETZ_LIB_libatm is not set
# FREETZ_LIB_libconfig is not set
# FREETZ_LIB_libcurl is not set
# FREETZ_LIB_libdevmapper is not set
# FREETZ_LIB_libdnet is not set
# FREETZ_LIB_libelf is not set
# FREETZ_LIB_libevent is not set
# FREETZ_LIB_libftdi is not set
FREETZ_LIB_libfreetz=y
# FREETZ_LIB_libfuse is not set
# FREETZ_LIB_libiconv is not set
# FREETZ_LIB_libid3tag is not set
# FREETZ_LIB_libintl is not set
# FREETZ_LIB_liblua is not set
# FREETZ_LIB_libmad is not set
# FREETZ_LIB_libneon is not set
# FREETZ_LIB_libnet is not set
# FREETZ_LIB_libopenobex is not set
# FREETZ_LIB_libosip2 is not set
# FREETZ_LIB_libosipparser2 is not set
# FREETZ_LIB_libpcap is not set
FREETZ_LIB_libpcre=y
# FREETZ_LIB_libpcreposix is not set
# FREETZ_LIB_libpopt is not set
# FREETZ_LIB_libslang is not set
# FREETZ_LIB_libsqlite3 is not set
# FREETZ_LIB_libsynce is not set
# FREETZ_LIB_libsysfs is not set
# FREETZ_LIB_libltdl is not set
# FREETZ_LIB_libusb is not set
# ncurses
# FREETZ_LIB_libncurses is not set
# terminfo database
# Select terminfo database entries to install (see help of 'Show all items')
# FREETZ_SHARE_terminfo is not set
# FREETZ_LIB_libform is not set
# FREETZ_LIB_libmenu is not set
# FREETZ_LIB_libpanel is not set
# Ogg/Vorbis
# FREETZ_LIB_libogg is not set
# FREETZ_LIB_libvorbis is not set
# FREETZ_LIB_libvorbisenc is not set
# FREETZ_LIB_libvorbisfile is not set
# Readline
# FREETZ_LIB_libreadline is not set
# FREETZ_LIB_libhistory is not set
# uClibc
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libnsl=y
FREETZ_LIB_libpthread=y
# FREETZ_LIB_libresolv is not set
FREETZ_LIB_librt=y
# FREETZ_LIB_libthread_db is not set
FREETZ_LIB_libuClibc=y
FREETZ_LIB_libutil=y
# FREETZ_LIB_libuClibc__ is not set
# XML/XSLT
# FREETZ_LIB_libexpat is not set
# FREETZ_LIB_libxml2 is not set
# FREETZ_LIB_libxslt is not set
# FREETZ_LIB_libexslt is not set
# Compiler options
# FREETZ_DOWNLOAD_TOOLCHAIN is not set
FREETZ_BUILD_TOOLCHAIN=y
FREETZ_TARGET_ARCH="mipsel"
FREETZ_TARGET_CROSS="mipsel-linux-uclibc-"
FREETZ_TARGET_CFLAGS="-Os -pipe -march=4kc -Wa,--trap"
FREETZ_JLEVEL=6
FREETZ_KERNEL_CROSS="mipsel-unknown-linux-gnu-"
FREETZ_KERNEL_VERSION_2_6_13_1=y
# FREETZ_KERNEL_VERSION_2_6_19_2 is not set
FREETZ_KERNEL_VERSION="2.6.13.1"
FREETZ_UCLIBC_0_9_29_BASED_BOX=y
# FREETZ_TARGET_UCLIBC_VERSION_0_9_28 is not set
# FREETZ_TARGET_UCLIBC_VERSION_0_9_29 is not set
# FREETZ_TARGET_UCLIBC_VERSION_0_9_30 is not set
FREETZ_TARGET_UCLIBC_VERSION_0_9_31=y
# FREETZ_TARGET_COMPILER_GCC_4_2_4_UCLIBC_0_9_28 is not set
# FREETZ_TARGET_COMPILER_GCC_4_2_4_UCLIBC_0_9_29 is not set
# FREETZ_TARGET_COMPILER_GCC_4_3_5_UCLIBC_0_9_29 is not set
# FREETZ_TARGET_COMPILER_GCC_4_4_4_UCLIBC_0_9_29 is not set
# FREETZ_TARGET_COMPILER_GCC_4_3_5_UCLIBC_0_9_30 is not set
# FREETZ_TARGET_COMPILER_GCC_4_4_4_UCLIBC_0_9_30 is not set
FREETZ_TARGET_COMPILER_GCC_4_4_4_UCLIBC_0_9_31=y
FREETZ_TARGET_GCC_VERSION="4.4.4"
FREETZ_TARGET_UCLIBC_VERSION="0.9.31"
FREETZ_TARGET_BINUTILS_VERSION="2.20.51.0.9"
FREETZ_TARGET_UCLIBC_CONFIG_MOD=y
# FREETZ_TARGET_UCLIBC_CONFIG_8MB is not set
# FREETZ_TARGET_UCLIBC_CONFIG_4MB is not set
FREETZ_TARGET_UCLIBC_REF="mod"
# FREETZ_STATIC_TOOLCHAIN is not set
FREETZ_TARGET_GXX=y
FREETZ_TARGET_CCACHE=y
# FREETZ_TARGET_NLS is not set
FREETZ_TARGET_LFS=y
FREETZ_KERNEL_COMPILER_GCC_3_4_6=y
FREETZ_KERNEL_GCC_VERSION="3.4.6"
FREETZ_KERNEL_BINUTILS_VERSION="2.18"
# FREETZ_TARGET_TOOLCHAIN is not set
# GNU debugger (gdb)
# FREETZ_PACKAGE_GDB is not set
# FREETZ_PACKAGE_GDB_SERVER is not set
# FREETZ_PACKAGE_GDB_HOST is not set
Das ist mir bisher allerdings nur bei 3170_7170-Alien Images passiert, bei normalen 3170 Images nicht.
Zumindest sollte es nach der Stelle so weitergehen, d.h. mit den LEDs:
[setup_irq]: irq 15 irqaction->handler 0x940e1f0c (serial8250_interrupt+0x0/0x13c )
[avm_led] "tam",0 ! already defined
[avm_led] format error: "DEF Name,Instanz = low_level_driver_index, gpio_number, physical_pin_number, physical_pin_name"
[avm_led_load_config] Syntax error in led config file /etc/led.conf at "DEF tam,0 = 99,32,21"
AR7WDT: System Init UEberwachung 240 Sekunden
TFFS Name Table G
[avm_new]push_button 'Wlan-Taster', released: GPIO=8 presses=6250 key=button_key_3
Piglet: module license '
(C) Copyright 2005 by AVM
' taints kernel.
[avm_new]push_button_ctrl: gpio=6 value=0 enabled
[avm_new]push_button_ctrl:'Werkseinstellungs-Taster': enable=2 gpio=6 regaddr=00000000 button_type=1
EMIF: asize=1 ta=3 r_hold=0 w_strobe=6 r_strobe=6 ew=1
[avm_new]push_button_ctrl:'ATA-Schalter': enable=1 gpio=0 regaddr=be00002c button_type=2
JFFS2 version 2.2. (NAND) (C) 2001-2003 Red Hat, Inc.
registered device TI Avalanche SAR
Was mir noch auffiel: Du hast "FREETZ_PACKAGE_USBROOT=y" und anderes "USB-Krams" gewählt. Sucht die Box das Image nun auf dem Stick oder im internen Flash?
Und versuche doch zunächst mal ein 64k-Block Image, einfach um das auszuschließen (1MB finde ich schon extrem )...
Jörg
Die Stelle, an der USBroot einsetzt, ist noch gar nicht erreicht, denn das würde im Log stehen. Ja, klar, bei Gelegenheit werde ich das gleiche mit 64k reproduzieren.
bimbomix75
