No such file or directory at tools/parse-config line 21, <> line 32.
frater
23 Nov 2008
Vor eine Woche habe ich ein 'svn update' gemacht.
Danach, wie Normal, ein 'make menuconfig'
Ich kriegte dieser Fehler:
$ make menuconfig
make: *** [Config.in.cache] Fehler 2
Jetzt, eine Woche Später ist das noch dasselbe...
Was ist Los?
Das endet so (oder brauchst du alles?):
# INCLUDE_END make/xsltproc/Config.in
# INCLUDE_BEGIN make/zabbix_agentd/Config.in
config FREETZ_PACKAGE_ZABBIX_AGENTD
        bool "Zabbix Agent 1.4"
        default n
        select FREETZ_LIB_libresolv
        help
                Zabbix was created by Alexei Vladishev, and currently is
                actively developed and supported by Zabbix SIA.
                Zabbix is an enterprise-class open source distributed monitoring
                solution.
                Zabbix is software that monitors numerous parameters of a
                network and the health and integrity of servers. Zabbix uses a
                flexible notification mechanism that allows users to configure
                e-mail based alerts for virtually any event. This allows a fast
                reaction to server problems. Zabbix offers excellent reporting
                and data visualisation features based on the stored data. This
                makes Zabbix ideal for capacity planning.
                Zabbix supports both polling and trapping. All Zabbix reports
                and statistics, as well as configuration parameters, are
                accessed through a web-based front end. A web-based front end
                ensures that the status of your network and the health of your
                servers can be assessed from any location. Properly configured,
                Zabbix can play an important role in monitoring IT
                infrastructure. This is equally true for small organisations
                with a few servers and for large companies with a multitude of
                servers.
                Zabbix is free of cost. Zabbix is written and distributed under
                the GPL General Public License version 2. It means that its
# INCLUDE_BEGIN code is freely distributed and available for the general
Wo hast du das Zabbix Paket her? Kann es sein, dass da am Ende der Config.in ein Line Feed fehlt?
Oliver
Dieser Config.in ist al dieser Zeit unverändert geblieben.
Jetzt habe ich das letzte Stück gelöscht und auch die Datei Config.in.cache
Jetzt funktioniert es wieder...
atrora
