ich wollte versuchen ein Nortel 1140E Telefon mit der SIP Version SIP1140e02.02.21.00 an Sipgate.de anzubinden. Das ganze hat sich doch für schwerer als erwartet herausgestellt.
Ich habe bei der Konfigdatei, einige Probleme und wollte Fragen ob hier schon einer ein 1140E oder 1120E an SIPGATE anbinden konnte.
hier meine Konfigdatei für das Telefon.
# See NN43112-300
# Proxy Settings
# 5 can be configured only 1 is needed
# each proxy can have 2 ip addresses associated
# for redundancy
DNS_DOMAIN sipgate.de
SIP_DOMAIN1 sipgate.de
SERVER_IP1_1 217.10.79.2
SERVER_IP1_2 192.100.1.104
SERVER_PORT1_1 5060
SERVER_PORT1_2 5060
SERVER_RETRIES1 3
SERVER_RETRIES2 3
DEF_USER1 user1
# Adhoc Conference settings
# CS1000 settings to enable adhoc conferencing
# ENABLE_SERVICE_PACKAGE NO
# CONFERENCE_URI1 [email protected]
# ADHOC_ENABLED1 YES
# MAX_ADHOC_PORTS1 6
# MCS / A2E settings where service package is provided
ENABLE_SERVICE_PACKAGE YES
# Local (on phone) conferncing
# allow phone to host a 3-way conference without support of
# a conference server
ENABLE_3WAY_CALL YES
# Call handling settings
TRANSFER_TYPE STANDARD
# STANDARD/MCS MCS will make use of a conference server
REDIRECT_TYPE MCS
# RFC3261 / MCS see admin documentation for detailed explanation
# Device Settings
FORCE_BANNER YES
BANNER NORTEL IP Phone
UPDATE_USERS NO
# Network Parameters
ENABLE_UPDATE YES
ENABLE_PRACK YES
RTP_MIN_PORT 50000
RTP_MAX_PORT 50100
SIP_PING YES
#The SIP_PING configuration value is used to
#maintain server heartbeat detection and to keep a firewall pinhole
#open
# User Preferences
AUTOLOGIN_ENABLE YES
DEF_LANG English
# DEF_LANG French_0202
# to set another language the parameter must match the file name
# without the extention
# User Voice Mail number
VMAIL 2300
VMAIL_DELAY 300
# Accessory settings
EXP_MODULE_ENABLE YES
ENABLE_BT YES
# - enables BlueTooth on 1140E
# - BT headset must be paired and headset BT headse must be selected
# to make use of a Bluetooth headset
# Time configuration
DST_ENABLED YES
TIMEZONE_OFFSET 3600
# (GMT-10:00) Hawaii -36000
# (GMT-09:00) Alaska -32400
# (GMT-08:00) Pacific time (US and Canada) -28800
# (GMT-07:00) Mountain time (US and Canada) -25200
# (GMT-06:00) Central time (US and Canada) -21600
# (GMT-05:00) Eastern time (US and Canada) -18000
# (GMT-04:00) Atlantic time (US and Canada) -14400
# (GMT-03:00) Brasilia, Buenos Aires -10800
# (GMT+00:00) Greenwich, Dublin, London 0
# (GMT+01:00) Amsterdam, Madrid, Paris 3600
# (GMT+02:00) Athens, Istanbul 7200
# (GMT+03:00) Moscow, St. Petersburg 10800
# (GMT+05:30) Bombay, Calcutta, Madras 18000
# (GMT+08:00) Beijing, Chongqing, Hong Kong 28800
# (GMT+09:00) Osaka, Sapporo, Tokyo, Seoul 32400
# (GMT+10:00) Canberra, Melbourne, Sydney 36000
# (GMT+12:00) Auckland, Wellington 43200
# Network time protocol
SNTP_ENABLE YES
SNTP_SERVER ntp-toronto-3.ca.nortel.com
# Config File update settings
# allows phone to aytomatically contac the Prov
# server every 24 hours to check for updates
AUTO_UPDATE YES
# 48600 = 1:30pm
# 3600 = 1:00am
#28800 = 8:00am 29700
#54900 = 3:15pm
AUTO_UPDATE_TIME 3600
AUTO_UPDATE_RANGE 1
# Caller list Settings
MAX_INBOX_ENTRIES 50
MAX_OUTBOX_ENTRIES 50
# Call Message Settings
MAX_REJECTREASONS 5
MAX_CALLSUBJECT 5
# Instant Messaging Settings
IM_NOTIFY YES
IM_MODE DISABLED
DEF_DISPLAY_IM NO
# enables or disables the display of
# instant messages (IM). The default setting is NO.
MAX_IM_ENTRIES 20
# Address Book Settings
MAX_ADDR_BOOK_ENTRIES 50
# is used to configure the maximum
# number of entries in the address book and takes a number as a
#parameter. The default limit is 100.
ADDR_BOOK_MODE BOTH
#is a command
#to choose the address book that is used to search for other users. The
#default setting is NETWORK.
#— NETWORK - downloads the user’s address book from the network
#(MCS). New address book entries are uploaded to the network.
#— LOCAL - creates a user address book and stores it locally on the
#IP Phone
#— BOTH - attempts to download a network address book and keep a
#copy on the IP Phone. If a network address book is available, the
#IP Phone 1120E functions as if NETWORK mode is selected.
# Debug level
RECOVERY_LEVEL 0
# error condition for which phone will reboot
# 0 - no conditions will cause software to reset phone
# 1 - critical
# 2 - major
# 3 - minor
# Codec Presference list
# allows Admin to define allowed codecs
# order defines codec negotiation priority
# for new users
AUDIO_CODEC1 PCMA standard a-law
AUDIO_CODEC2 PCMU standard u-law
AUDIO_CODEC3 G729 729 codec
AUDIO_CODEC4 G723 high-compression codec
# Admin Settings
ADMIN_PASSWORD 26567*738
DISABLE_PRIVACY_UI YES
# is a flag to disable the privacy
# setting in UI menus. Disabling the privacy setting in UI menus disables
# the user ability to configure privacy options.
LOGOUT_WITHOUT_PASSWORD NO
# allows the user to log
# off without authentication of the password if the administrator enables
# t he LOGOUT_WITHOUT_PASSWORD feature through the Device
# Configuration file.
# NAT/STUN Settings
NAT_SIGNALING STUN
# indicates the type of
# protocol used for NAT traversal in the signaling port. The IP Phone
# 1120E with SIP Firmware supports two methods of NAT traversal of
# the signaling path: SIP_PING and STUN.
# — NONE - If the value is not configured as None, this parameter
# overrides the value of the parameter SIP_PING in the device
# configuration file.
# — SIP_PING - a Nortel proprietary NAT traversal protocol. Note that
# SIP_PING only supports NAT traversal in the signaling port.
# — STUN - the most common NAT traversal method.
NAT_MEDIA STUN
NAT_TTL 120
STUN_SERVER_IP1 217.10.79.2
STUN_SERVER_PORT1 10000
# please refer to admin doc for following settings if NAT or STUN is required
# NAT_TTL[x] is used to set the NAT Time-to-live (TTL), the binding
# STUN_SERVER_IP1[ip_address] NAT traversal using STUN protocol
# STUN_SERVER IP2[ip_address] NAT traversal using STUN protocol
# STUN_SERVER_PORT1[port_number] is the port number used
# STUN_SERVER_PORT2[port_number] is the port number used
# See NN43112-300
# Proxy Settings
# for redundancy
SERVER_PORT1_1 5060
SERVER_PORT1_2 5060
SERVER_RETRIES1 3
SERVER_RETRIES2 3
DEF_USER1 user1
REDIRECT_TYPE MCS
# Device Settings
FORCE_BANNER YES
UPDATE_USERS NO
ENABLE_UPDATE YES
ENABLE_PRACK YES
RTP_MIN_PORT 50000
RTP_MAX_PORT 50100
SIP_PING YES
#open
# User Preferences
DEF_LANG English
VMAIL 2300
VMAIL_DELAY 300
ENABLE_BT YES
DST_ENABLED YES
SNTP_ENABLE YES
AUTO_UPDATE YES
# 48600 = 1:30pm
# 3600 = 1:00am
#54900 = 3:15pm
AUTO_UPDATE_RANGE 1
MAX_REJECTREASONS 5
MAX_CALLSUBJECT 5
IM_NOTIFY YES
IM_MODE DISABLED
DEF_DISPLAY_IM NO
MAX_IM_ENTRIES 20
ADDR_BOOK_MODE BOTH
#is a command
#IP Phone
# Debug level
RECOVERY_LEVEL 0
# 1 - critical
# 2 - major
# 3 - minor
# for new users
# Admin Settings
# NAT/STUN Settings
NAT_SIGNALING STUN
NAT_MEDIA STUN
NAT_TTL 120
