offtopic: squid/2.5.STABLE14-20060622 for fli4l.3.x.x
Netview
IPPF-Promi
1 Apr 2004
Hallo Netview;
ich habe den squid eben drauf gemacht. Es läuft alles prima. Was unterscheidet Deine "selbst gebastelte" Version von der vorherigen? Wäre schon interessant zu wissen. :-)
ähhm - das steht groß und breit beim download dabei!
Ich poste hier nochmals den Ausschnitt:
Änderungen gegenüber squid-2.5.STABLE12 (12 Mar 2006)
	- [Minor] Fails to compile on Solaris and some other platforms
	  with undefined reference to setenv (Bug #1435)
	- [Cosmetic] Added WebDAV REPORT method to know HTTP methods list
	- [Minor] Squid ntlm_auth (not the Samba provided one) giving
	  odd results if --enable-ntlm-fail-open is used (Bug #1022)
	- [Minor] wbinfo_group.pl doesn't work with Samba 3.0.21 and later
	  (Bug #1472)
	- [Minor] Squid crash when asyncio function counters url accessed
	  from Cachemgr CGI (Bug #1464)
	- [Cosmetic] Linix compile warning about prctl called with too few
 	  arguments (Bug #1483)
	- [Minor] Wrong timezone declaration for 64 bit Irix (Bug #1479)
	- [Minor] Some 206 responses logged incorrectly (Bug #1511)
	- [Minor] Issues in processing ranges on objects >2GB (Bug #437)
	- [Cosmetic] Segmentation fault on empty proxy_auth ACLs (Bug #1414)
	- [Minor] Ident access lists don't work in delay_access statements
	  (Bug #1428)
	- [Minor] Some clients support NTLM even if not initially negotiating
	  persistent connections (Bug #1447)
	- [Medium] 504 Gateway Time-out on FTP uploads (Bug #1459)
	- [Medium] delay pools given too much bandwidht after "-k reconfigure"
	  (Bug #1481)
	- [Cosmetic] New persistent_connection_after_error configuration
	  directive (Bug #1482)
	- [Cosmetic] Hangs at 100% CPU if /dev/null is not accessible (Bug
	  #1484)
	- [Minor] Fails to compile on Fedora Core 5 test 2 x86_64 (Bug #1492)
	- [Cosmetic] Typo in ftp.c (Bug #1507)
	- [Cosmetic] Error in FTP listings of files with -> in their name
	  (Bug #1508)
	- [Cosmetic] With Squid-2.5 there is no more the DUPLICATE IP logging
 	  in cache.log (Bug #779)
	- [Minor] Fails to process long host names (Bug #1434)
	- [Cosmetic] Azerbaijani errors translation (Bug #1454)
	- [Cosmetic] misleading error message message for bad/unresolveable
	  cache_peer name (Bug #1504)
	- [Cosmetic] confusing statistics on stateful helpers (NTLM auth)
	  (Bug #1506)
	- [Major] connstate memory leak (Bug #1522)
Die wichtigste Änderung ist die Beseitung eines memory-leaks s.o.
Nun ich hatte heute mal Zeit mir eine fli4l-3.0.x Wartungsumgebung zu erstellen (uclib) und habe dies mal am opt squid ausprobiert. Ich kann also zusätzlich jetzt nicht nur gegen die glibc (wie für asterisk) kompilieren sondern auch gegen die uclibc von fli4l-3.0.x!
Entschuldigung, das habe ich beim Download glatt überlesen. :-)
Jetzt muss ich nur noch vor den Squid den Privoxy klemmen; geht ja alles dank Deinem geteilten Asterisk völlig problemlos hochzuladen.
EDIT:
Das mit dem privoxy funktioniert zwar prächtig, aber leider kann ich so nicht mehr hier ins Board schreiben. Konsequenz: MS Internet-Explorer mit proxy; Firefox ohne und damit hier am Board einloggen. ;-)
Hab nochmals aufgefrischt (squid/2.5.STABLE13-20060428 ):
Changes to squid-2.5.STABLE13 (28 Apr 2006)
-	- [Minor] Issues in processing ranges on objects >2GB (Bug #437)
+	- [Minor] Issues in processing ranges on objects >2GB (Bug #437)
 	  (Bug #1428)
Hallo Netview;
Dein squid läuft solo und vor sowie hinter privoxy (inclusive tor) ausgezeichnet. Ich kann keine Fehler feststellen. Eventuell kannst du mir ja noch hier schreiben, was ich wie und wo nachsehen soll. :-)
Neu: "Delete Log files/rekonfigure" - über diese Funktion können wieder in der Weboberfläche des squid die logs-files manuell rotiert werden und anschliessend erfolgt ein rekonfigure!
Hallo Netview;
auf die Weboberföäche des privoxy kommt man mit h**p://p.p. ; wie kommt man auf die des squid? Ich sehe die Oberfläche des Squid immer nur, wenn ein Fehler beim Seite laden erfolgt ist...
Im fli4l-menu (IP-des fli4l eingeben, dann login)!
Hab auch mal den neuen eXtremail 2.1.1 draufgeworfen (jetzt geht wenigstens der smarthost wieder - in der 1.5.11 konnte man kein CRAM-MD5 machen was besonders ärgerlich war da 1&1 dies mal umgestellt hat) - link:
http://extremail.monsterserver.de/t...tyleid=1&sid=18eaf020877e4169821a9b097a41fb6e
fli4l 3.0.1 # smtpd
bad command given
Usage: smtpd [-f <configuration_file>] start | stop | restart | reload | status | version | login <password>
fli4l 3.0.1 # smtpd status
eXtremail server running ...
Process ID: 6363
fli4l 3.0.1 # smtpd version
eXtremail server version 2.1 release 1 - Linux (Intel) -
fli4l 3.0.1 #
Blöde Frage von mir:
Wohin "draufgeworfen"? Sicherlich auf Deinen Fli, aber woher hast Du das Teil geholt?
Hallo Netview;
Macht es großen Konfigurationsaufwand, diesen Mail-Server in den Fli einzubauen? Ich habe da ein opt-extemail auf www.fli4l.nl gefunden, kann man das verwenden? Ein eigener mail-Server, das hat schon was.... :-)
ploieel schrieb:
Hallo Netview;
Nimm am besten diese beiden Pakete (habe ich für fli4l-3.0.1 überarbeitet!)
http://www.ip-phone-forum.de/showpost.php?p=514736&postcount=31
ist allerdings die 1.5-11 (wie auf www.fli4l.nl auch!) und hat Probleme mit dem smarthost wenn dieser nicht mit plain-text sonder z.B. mit CRAM-MD5 arbeitet soll (einige Provider verlangen beim Senden von mails eine besondere Autentifizierung z.B. 1und1 seit ca. einem Jahr!).
Hallo Netview,
kannst Du bitte noch eine Zeile für den Firewall-Paketfilter posten, mit der der Telnet-Port 4501 von außen gesperrt wird? Ich kann in der Doku nichts richtiges finden, sie ist wohl schon etwas älter.
ploieel schrieb:
Hallo Netview,
Wieso von Außen?
Im eigenen LAN ist der port erreichbar, außer du hast eine firewall unter XP aktiv.
Zum Einrichten würde ich folgendes tool verwenden:
http://www.svera-tools.de/download.php?view.7
Ein sehr gutes Tool, das spart den ganzen telnet-Kommandozeilen-Kram. :-)
Hallo Netview,
e-mails senden per fetchmail funktioniert bereits. Der Thunderbird hat ein Konto, woraus der email senden kann.
Nur e-mail empfangen per extremail geht noch nicht. Ich weiß nicht so recht, was ich in die Maske des Konfigurationstools eintragen soll. Eine Hilfe gibts ja in dem Tool nicht, aber vielleicht einen link, wo ich etwas nachlesen darüber nachlesen kann?
Schau mal ins \doc\deutsch\opt-Verzeichnis dort steht ein pdf-Dokument!
Habe alles gelesen, viel probiert, bin bis jetzt noch nicht zum Erfolg gekommen.
Delivery to the following recipient failed permanently:
     [email protected]
Technical details of permanent failure:
PERM_FAILURE: SMTP Error (state 9): 550 <[email protected]>: invalid address
Na gut; morgen ist auch noch ein Tag.
IchBinEsDoch
