Openssl
JPAdie
20 Sep 2006
Hi there
I am having a strange issue in that a command in my debug.cfg is not executing properly (it is properly typed...)
i am trying to add an interface to the bridge using the command
cd /var/tmp/vpn
./brctl addif lan tap0
but the interface never gets added. if i telnet into the box and retype the command by hand then it works fine.
any thoughts?
Maybe you should insert a sleep-command?
Especially before the command. Try
sleep 60
cd /var/tmp/vpn
I think its dangerous to do it like this.
Maybe:
"(sleep 60; cd /var/tmp/vpn/; ./brctl addif lan tap0) &" is a better way.
Greets, Oliver
Resolved.
i was being dim.
i was loading openvpn before starting the bridge. but loaded the openvpn binary with an &w suffix.
realprogrammer
