Openvpn 2.2 build failed
µRaCoLi
22 Sep 2005
Openvpn 2.2 kompiliert bei mir nicht
/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.4.6_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc  -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64  -static -o openvpn base64.o buffer.o crypto.o dhcp.o error.o event.o fdmisc.o forward.o fragment.o gremlin.o helper.o httpdigest.o lladdr.o init.o interval.o list.o lzo.o manage.o mbuf.o misc.o mroute.o mss.o mtcp.o mtu.o mudp.o multi.o ntlm.o occ.o pkcs11.o openvpn.o options.o otime.o packet_id.o perf.o pf.o ping.o plugin.o pool.o proto.o proxy.o ieproxy.o ps.o push.o reliable.o route.o schedule.o session_id.o shaper.o sig.o socket.o socks.o ssl.o status.o tun.o win32.o cryptoapi.o   -lssl -lcrypto -ldl -llzo2
pool.o: In function `ifconfig_pool_list':
pool.c:(.text+0xc0): undefined reference to `in6addr_any'
pool.c:(.text+0xc4): undefined reference to `in6addr_any'
socket.o: In function `print_in6_addr':
socket.c:(.text+0x1234): undefined reference to `in6addr_any'
socket.c:(.text+0x1238): undefined reference to `in6addr_any'
collect2: ld returned 1 exit status
make[3]: *** [openvpn] Fehler 1
make[3]: Verlasse Verzeichnis '/usr/src/freetz-trunk/source/target-mipsel_uClibc-0.9.28/openvpn-2.2.0'
make[2]: *** [all-recursive] Fehler 1
make[2]: Verlasse Verzeichnis '/usr/src/freetz-trunk/source/target-mipsel_uClibc-0.9.28/openvpn-2.2.0'
make[1]: *** [all] Fehler 2
make[1]: Verlasse Verzeichnis '/usr/src/freetz-trunk/source/target-mipsel_uClibc-0.9.28/openvpn-2.2.0'
ERROR: Build failed.
make: *** [source/target-mipsel_uClibc-0.9.28/openvpn-2.2.0/openvpn] Fehler 1
Wenn Du ipv6 nicht benutzt, kannst Du folgende Änderung in der openvpn.mk-Datei machen und die ipv6-Patches löschen:
$(PKG)_CONFIGURE_OPTIONS += [COLOR="red"]--disable-ipv6[/COLOR]
[COLOR="red"][B]#[/B][/COLOR]$(PKG)_CONFIGURE_OPTIONS += $(if $(FREETZ_TARGET_IPV6_SUPPORT),--enable-ipv6,--disable-ipv6)
mkdir -p packages/target-mipsel_uClibc-0.9.29/openvpn-2.2.0/root/usr/sbin/; cp source/target-mipsel_uClibc-0.9.29/openvpn-2.2.0/openvpn packages/target-mipsel_uClibc-0.9.29/openvpn-2.2.0/root/usr/sbin/openvpn; /home/gm/myfreetz/freetz6862/freetz-trunk/toolchain/build/mipsel_gcc-4.4.6_uClibc-0.9.29/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-strip --remove-section={.comment,.note,.pdr} packages/target-mipsel_uClibc-0.9.29/[COLOR="red"]openvpn-2.2.0[/COLOR]/root/usr/sbin/[COLOR="red"]openvpn[/COLOR];
[B][COLOR="red"]done.[/COLOR][/B]
sollte in r6912 behoben sein, bitte testen
Factory22
