openvpn build failed
µRaCoLi
22 Sep 2005
hi,
building failed with enabling lzo. it worked without lzo perfectly.
'make openvpn-dirclean' didn't help. any solution without 'make distclean'?
$ make menuconfig
# configuration written to .config
*** End of the configuration.
*** Execute 'make' to start the build or try 'make help'.
timo@kasten:~/privat/freetz-trunk$ make
---> library/lzo: preparing... tools/gunzip -c dl/lzo-2.06.tar.gz | tar -C source/target-mipsel_uClibc-0.9.28 -x
set -e; shopt -s nullglob; for i in make/libs/lzo/patches/*.lzo.patch; do tools/freetz_patch source/target-mipsel_uClibc-0.9.28/lzo-2.06 $i; done
configuring... (conf_cmd() { ./configure  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } }; cd source/target-mipsel_uClibc-0.9.28/lzo-2.06;   rm -f config.{cache,status};    PATH=""/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin:/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-3.4.6/mipsel-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games"" CC="/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc" CXX="/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper" CFLAGS="-march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" CXXFLAGS="-march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" LDFLAGS="" PKG_CONFIG_PATH="/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/../lib/pkgconfig" PKG_CONFIG_LIBDIR="/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/../lib/pkgconfig" GLOBAL_LIBDIR=/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/usr/lib  FREETZ_TARGET_LFS="y" CONFIG_SITE=/usr/src/freetz-trunk/include/site/mipsel-linux-uclibc conf_cmd   --cache-file=/usr/src/freetz-trunk/source/target-mipsel_uClibc-0.9.28/config.cache --target=mipsel-linux --host=mipsel-linux --build=x86_64-pc-linux-gnu --program-prefix="" --program-suffix="" --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --datadir=/usr/share --includedir=/usr/include --infodir=/usr/share/info --libdir=/usr/lib --libexecdir=/usr/lib --localstatedir=/var --mandir=/usr/share/man --sbindir=/usr/sbin --sysconfdir=/etc --with-gnu-ld --disable-nls  --enable-static --enable-shared --disable-asm    )
configure: WARNING: unrecognized options: --disable-nls
configure: loading site script /usr/src/freetz-trunk/include/site/mipsel-linux-uclibc
configure: loading cache /usr/src/freetz-trunk/source/target-mipsel_uClibc-0.9.28/config.cache
configure: Configuring LZO 2.06
checking build system type... (cached) x86_64-pc-linux-gnu
checking host system type... (cached) mipsel-unknown-linux-gnu
checking target system type... (cached) mipsel-unknown-linux-gnu
checking whether to enable maintainer-specific portions of Makefiles... no
checking for mipsel-linux-gcc... (cached) /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... yes
checking for suffix of object files... (cached) o
checking whether we are using the GNU C compiler... (cached) yes
checking whether /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc accepts -g... (cached) yes
checking for /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc option to accept ISO C89... (cached) none needed
checking whether /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc and cc understand -c and -o together... (cached) yes
checking for style of include used by make... GNU
checking dependency style of /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc... gcc3
checking how to run the C preprocessor... (cached) /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc -E
checking whether the C preprocessor needs special flags... none needed
checking for an ANSI C-conforming const... (cached) yes
checking for grep that handles long lines and -e... (cached) /bin/grep
checking for egrep... (cached) /bin/grep -E
checking for ANSI C header files... (cached) yes
checking for sys/types.h... (cached) yes
checking for sys/stat.h... (cached) yes
checking for stdlib.h... (cached) yes
checking for string.h... (cached) yes
checking for memory.h... (cached) yes
checking for strings.h... (cached) yes
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking for unistd.h... (cached) yes
checking whether byte ordering is bigendian... (cached) no
checking for special C compiler options needed for large files... no
checking for _FILE_OFFSET_BITS value needed for large files... no
checking for a BSD-compatible install... (cached) /usr/bin/install -c
checking whether build environment is sane... yes
checking for mipsel-linux-strip... (cached) mipsel-linux-strip
checking for a thread-safe mkdir -p... (cached) /bin/mkdir -p
checking for gawk... (cached) gawk
checking whether make sets $(MAKE)... (cached) yes
checking dependency style of /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc... (cached) gcc3
checking how to print strings... printf
checking for a sed that does not truncate output... (cached) /bin/sed
checking for fgrep... (cached) /bin/grep -F
checking for ld used by /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc... (cached) /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld
checking if the linker (/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld) is GNU ld... (cached) yes
checking for BSD- or MS-compatible name lister (nm)... (cached) /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-nm -B
checking the name lister (/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-nm -B) interface... (cached) BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... (cached) 3458764513820540925
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking for /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld option to reload object files... (cached) -r
checking for mipsel-linux-objdump... (cached) mipsel-linux-objdump
checking how to recognize dependent libraries... (cached) pass_all
checking for mipsel-linux-ar... (cached) /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-ar
checking for mipsel-linux-ranlib... (cached) /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-ranlib
checking command to parse /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-nm -B output from /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc object... (cached) ok
checking for dlfcn.h... (cached) yes
checking for objdir... (cached) .libs
checking if /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc supports -fno-rtti -fno-exceptions... (cached) no
checking for /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc option to produce PIC... -fPIC -DPIC
checking if /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc PIC flag -fPIC -DPIC works... (cached) yes
checking if /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc static flag -static works... (cached) yes
checking if /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc supports -c -o file.o... (cached) yes
checking whether the /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc linker (/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/mipsel-linux-uclibc/bin/ld) supports shared libraries... yes
checking whether -lc should be explicitly linked in... (cached) no
checking dynamic linker characteristics... (cached) GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking whether time.h and sys/time.h may both be included... (cached) yes
checking assert.h usability... yes
checking assert.h presence... yes
checking for assert.h... yes
checking for ctype.h... (cached) yes
checking dirent.h usability... yes
checking dirent.h presence... yes
checking for dirent.h... yes
checking for errno.h... (cached) yes
checking for fcntl.h... (cached) yes
checking float.h usability... yes
checking float.h presence... yes
checking for float.h... yes
checking for limits.h... (cached) yes
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking setjmp.h usability... yes
checking setjmp.h presence... yes
checking for setjmp.h... yes
checking for signal.h... (cached) yes
checking for stdarg.h... (cached) yes
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for stdio.h... (cached) yes
checking for time.h... (cached) yes
checking utime.h usability... yes
checking utime.h presence... yes
checking for utime.h... yes
checking for sys/mman.h... (cached) yes
checking sys/resource.h usability... yes
checking sys/resource.h presence... yes
checking for sys/resource.h... yes
checking for sys/time.h... (cached) yes
checking for sys/wait.h... (cached) yes
checking whether limits.h is sane... yes
checking for off_t... (cached) yes
checking for ptrdiff_t... (cached) yes
checking for size_t... (cached) yes
checking return type of signal handlers... (cached) void
checking size of short... (cached) 2
checking size of int... (cached) 4
checking size of long... (cached) 4
checking size of long long... (cached) 8
checking size of __int16... 0
checking size of __int32... 0
checking size of __int64... 0
checking size of void *... (cached) 4
checking size of size_t... (cached) 4
checking size of ptrdiff_t... (cached) 4
checking size of __int32... (cached) 0
checking size of intmax_t... 8
checking size of uintmax_t... 8
checking size of intptr_t... 4
checking size of uintptr_t... 4
checking size of float... 4
checking size of double... 8
checking size of long double... 8
checking size of dev_t... 8
checking size of fpos_t... (cached) 24
checking size of mode_t... 4
checking size of off_t... (cached) 8
checking size of ssize_t... (cached) 4
checking size of time_t... 4
checking for access... (cached) yes
checking for alloca... no
checking for atexit... yes
checking for atoi... yes
checking for atol... yes
checking for chmod... yes
checking for chown... yes
checking for clock_getcpuclockid... no
checking for clock_getres... yes
checking for clock_gettime... yes
checking for ctime... (cached) yes
checking for difftime... yes
checking for fstat... yes
checking for getenv... yes
checking for getpagesize... yes
checking for getrusage... yes
checking for gettimeofday... (cached) yes
checking for gmtime... yes
checking for isatty... yes
checking for localtime... yes
checking for longjmp... yes
checking for lstat... (cached) yes
checking for memcmp... yes
checking for memcpy... yes
checking for memmove... yes
checking for memset... (cached) yes
checking for mkdir... yes
checking for mktime... yes
checking for mmap... yes
checking for mprotect... yes
checking for munmap... yes
checking for qsort... yes
checking for raise... yes
checking for rmdir... yes
checking for setjmp... yes
checking for signal... yes
checking for snprintf... yes
checking for strcasecmp... (cached) yes
checking for strchr... yes
checking for strdup... (cached) yes
checking for strerror... (cached) yes
checking for strftime... (cached) yes
checking for stricmp... no
checking for strncasecmp... (cached) yes
checking for strnicmp... no
checking for strrchr... yes
checking for strstr... (cached) yes
checking for time... (cached) yes
checking for umask... (cached) yes
checking for utime... yes
checking for vsnprintf... (cached) yes
checking whether to build assembly versions... no
checking whether your compiler passes the ACC conformance test... yes
configure: updating cache /usr/src/freetz-trunk/source/target-mipsel_uClibc-0.9.28/config.cache
configure: creating ./config.status
config.status: creating Makefile
config.status: creating config.h
config.status: executing depfiles commands
config.status: executing libtool commands
   LZO configuration summary
   LZO version                : 2.06
   configured for host        : mipsel-unknown-linux-gnu
   source code location       : .
   compiler                   : /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc
   preprocessor definitions   : -DLZO_HAVE_CONFIG_H=1
   preprocessor flags         :
   compiler flags             : -march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64
   build static library       : yes
   build shared library       : yes
   enable i386 assembly code  : no
   LZO 2.06 configured.
   Copyright (C) 1996-2011 Markus Franz Xaver Johannes Oberhumer
   All Rights Reserved.
   The LZO library is free software; you can redistribute it and/or
   modify it under the terms of the GNU General Public License as
   published by the Free Software Foundation; either version 2 of
   the License, or (at your option) any later version.
   The LZO library is distributed in the hope that it will be useful,
   but WITHOUT ANY WARRANTY; without even the implied warranty of
   MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
   GNU General Public License for more details.
   Markus F.X.J. Oberhumer
   <[email protected]>
   http://www.oberhumer.com/opensource/lzo/
Type `make' to build LZO. Type `make install' to install LZO.
After installing LZO, please read the accompanied documentation.
cmd() { PATH="/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin:/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-3.4.6/mipsel-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games" LD_RUN_PATH="/usr/lib/freetz" make -j4  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } }; 	if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/target-mipsel_uClibc-0.9.28/lzo-2.06
building... make[1]: Betrete Verzeichnis '/usr/src/freetz-trunk/source/target-mipsel_uClibc-0.9.28/lzo-2.06'
make  all-am
make[2]: Betrete Verzeichnis '/usr/src/freetz-trunk/source/target-mipsel_uClibc-0.9.28/lzo-2.06'
  CC     src/lzo1.lo
  CC     src/lzo1_99.lo
  CC     src/lzo1a.lo
  CC     src/lzo1a_99.lo
  CC     src/lzo1b_1.lo
  CC     src/lzo1b_2.lo
  CC     src/lzo1b_3.lo
  CC     src/lzo1b_4.lo
  CC     src/lzo1b_5.lo
  CC     src/lzo1b_6.lo
  CC     src/lzo1b_7.lo
  CC     src/lzo1b_8.lo
  CC     src/lzo1b_9.lo
  CC     src/lzo1b_99.lo
  CC     src/lzo1b_9x.lo
  CC     src/lzo1b_cc.lo
  CC     src/lzo1b_d1.lo
  CC     src/lzo1b_d2.lo
  CC     src/lzo1b_rr.lo
  CC     src/lzo1b_xx.lo
  CC     src/lzo1c_1.lo
  CC     src/lzo1c_2.lo
  CC     src/lzo1c_3.lo
  CC     src/lzo1c_4.lo
  CC     src/lzo1c_5.lo
  CC     src/lzo1c_6.lo
  CC     src/lzo1c_7.lo
  CC     src/lzo1c_8.lo
  CC     src/lzo1c_9.lo
  CC     src/lzo1c_99.lo
  CC     src/lzo1c_9x.lo
  CC     src/lzo1c_cc.lo
  CC     src/lzo1c_d1.lo
  CC     src/lzo1c_d2.lo
  CC     src/lzo1c_rr.lo
  CC     src/lzo1c_xx.lo
  CC     src/lzo1f_1.lo
  CC     src/lzo1f_9x.lo
  CC     src/lzo1f_d1.lo
  CC     src/lzo1f_d2.lo
  CC     src/lzo1x_1.lo
  CC     src/lzo1x_1k.lo
  CC     src/lzo1x_1l.lo
  CC     src/lzo1x_1o.lo
  CC     src/lzo1x_9x.lo
  CC     src/lzo1x_d1.lo
  CC     src/lzo1x_d2.lo
  CC     src/lzo1x_d3.lo
  CC     src/lzo1x_o.lo
  CC     src/lzo1y_1.lo
  CC     src/lzo1y_9x.lo
  CC     src/lzo1y_d1.lo
  CC     src/lzo1y_d2.lo
  CC     src/lzo1y_d3.lo
  CC     src/lzo1y_o.lo
  CC     src/lzo1z_9x.lo
  CC     src/lzo1z_d1.lo
  CC     src/lzo1z_d2.lo
  CC     src/lzo1z_d3.lo
  CC     src/lzo2a_9x.lo
  CC     src/lzo2a_d1.lo
  CC     src/lzo2a_d2.lo
  CC     src/lzo_crc.lo
  CC     src/lzo_init.lo
  CC     src/lzo_ptr.lo
  CC     src/lzo_str.lo
  CC     src/lzo_util.lo
  CC     examples/dict.o
  CC     examples/lzopack.o
  CC     examples/overlap.o
  CC     examples/precomp.o
  CC     examples/precomp2.o
  CC     examples/simple.o
  CC     lzotest/lzotest.o
  CC     tests/align.o
  CC     tests/chksum.o
  CC     tests/promote.o
  CC     tests/sizes.o
  CC     minilzo/t-testmini.o
  CC     minilzo/t-minilzo.o
  CCLD   src/liblzo2.la
  CCLD   tests/promote
  CCLD   tests/sizes
  CCLD   examples/dict
  CCLD   examples/lzopack
  CCLD   examples/overlap
  CCLD   examples/precomp
  CCLD   examples/precomp2
  CCLD   examples/simple
  CCLD   tests/align
  CCLD   tests/chksum
  CCLD   minilzo/testmini
  CCLD   lzotest/lzotest
make[2]: Verlasse Verzeichnis '/usr/src/freetz-trunk/source/target-mipsel_uClibc-0.9.28/lzo-2.06'
make[1]: Verlasse Verzeichnis '/usr/src/freetz-trunk/source/target-mipsel_uClibc-0.9.28/lzo-2.06'
cmd() { PATH="/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin:/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-3.4.6/mipsel-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games" LD_RUN_PATH="/usr/lib/freetz" make -j4  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } }; 	if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/target-mipsel_uClibc-0.9.28/lzo-2.06 \
		DESTDIR="/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc" \
		install
test -z "/usr/share/doc/lzo" || /bin/mkdir -p "/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/usr/share/doc/lzo"
test -z "/usr/include/lzo" || /bin/mkdir -p "/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/usr/include/lzo"
 /usr/bin/install -c -m 644 AUTHORS COPYING NEWS THANKS doc/LZO.FAQ doc/LZO.TXT doc/LZOAPI.TXT '/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/usr/share/doc/lzo'
 /usr/bin/install -c -m 644 include/lzo/lzo1.h include/lzo/lzo1a.h include/lzo/lzo1b.h include/lzo/lzo1c.h include/lzo/lzo1f.h include/lzo/lzo1x.h include/lzo/lzo1y.h include/lzo/lzo1z.h include/lzo/lzo2a.h include/lzo/lzo_asm.h include/lzo/lzoconf.h include/lzo/lzodefs.h include/lzo/lzoutil.h '/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/usr/include/lzo'
test -z "/usr/lib" || /bin/mkdir -p "/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/usr/lib"
 /bin/bash ./libtool   --mode=install /usr/bin/install -c   src/liblzo2.la '/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/usr/lib'
libtool: install: /usr/bin/install -c src/.libs/liblzo2.so.2.0.0 /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/usr/lib/liblzo2.so.2.0.0
libtool: install: (cd /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/usr/lib && { ln -s -f liblzo2.so.2.0.0 liblzo2.so.2 || { rm -f liblzo2.so.2 && ln -s liblzo2.so.2.0.0 liblzo2.so.2; }; })
libtool: install: (cd /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/usr/lib && { ln -s -f liblzo2.so.2.0.0 liblzo2.so || { rm -f liblzo2.so && ln -s liblzo2.so.2.0.0 liblzo2.so; }; })
libtool: install: /usr/bin/install -c src/.libs/liblzo2.lai /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/usr/lib/liblzo2.la
libtool: install: /usr/bin/install -c src/.libs/liblzo2.a /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/usr/lib/liblzo2.a
libtool: install: chmod 644 /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/usr/lib/liblzo2.a
libtool: install: /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-ranlib /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/usr/lib/liblzo2.a
libtool: install: warning: remember to run `libtool --finish /usr/lib'
sed -i -r -e "s,^(libdir=)(['"'"'"]?)([^'"'"'"]*)(\2)$,\1\2/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc\3\4,g" -e "s,^(includedir=)(['"'"'"]?)([^'"'"'"]*)(\2)$,\1\2/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc\3\4,g" -e "s,^(prefix=)(['"'"'"]?)([^'"'"'"]*)(\2)$,\1\2/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc\3\4,g" -e "s,^(exec_prefix=)(['"'"'"]?)([^'"'"'"]*)(\2)$,\1\2/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc\3\4,g" -e "/^dependency_libs/s,[ \t],  ,g;s,([ '])((/usr)?/lib/[^ /]+[.]la)([ ']),\1/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc\2\4,g;s, +, ,g" \
chmod 755 /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/usr/lib/liblzo2.so.2.0.0; mkdir -p packages/target-mipsel_uClibc-0.9.28/root/usr/lib/freetz/; cp -a /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/usr/lib/liblzo2.so* packages/target-mipsel_uClibc-0.9.28/root/usr/lib/freetz/; /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-strip --remove-section={.comment,.note,.pdr} packages/target-mipsel_uClibc-0.9.28/root/usr/lib/freetz/liblzo2.so.2.0.0;
done.
Dateien /usr/src/freetz-trunk/source/target-mipsel_uClibc-0.9.28/.openvpn_config.temp und /usr/src/freetz-trunk/source/target-mipsel_uClibc-0.9.28/.openvpn_config sind verschieden.
mkdir -p packages/target-mipsel_uClibc-0.9.28/openvpn-2.3.0/root
if test -d make/openvpn/files; then tar -c -C make/openvpn/files --exclude=.svn . | tar -x -C packages/target-mipsel_uClibc-0.9.28/openvpn-2.3.0 ; fi
---> package/openvpn: preparing... tools/gunzip -c dl/openvpn-2.3.0.tar.gz | tar -C source/target-mipsel_uClibc-0.9.28 -x
set -e; shopt -s nullglob; for i in make/openvpn/patches/*.patch make/openvpn/patches/2.3.0/*.patch; do tools/freetz_patch source/target-mipsel_uClibc-0.9.28/openvpn-2.3.0 $i; done
    applying patch file make/openvpn/patches/2.3.0/200-no_in6addr_any_in_libc_without_IPv6_fix.patch
    patching file src/openvpn/pool.c
    patching file src/openvpn/socket.c
    applying patch file make/openvpn/patches/2.3.0/210-disable_epoll_poll_use_select.patch
    patching file configure
configuring... (conf_cmd() { ./configure  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } }; cd source/target-mipsel_uClibc-0.9.28/openvpn-2.3.0;   rm -f config.{cache,status}; cp -a ./configure ./configure.before_rpath_fix; sed -i -r -e "s|(runpath_var=)[$]runpath_var|\1|g" -e "s|(hardcode_into_libs=).+$|\1no|g" -e '/hardcode_libdir_flag_spec[_A-Za-z0-9]*=/s/[$][{]wl[}]-?-rpath(,| [$][{]wl[}])[$]libdir/-D__SOMETHING_NON_EMPTY_TO_FOOL_LIBTOOL__/g' -e 's/(hardcode_libdir_flag_spec(_ld)?=)[$]lt_([[][]]_LT_AC_TAGVAR[(])?hardcode_libdir_flag_spec[_A-Za-z0-9]*(, *[$]1[)])?/\1/g' ./configure; sed -i -r -e 's/ac(_cv(_('"lib_polarssl_ssl_init|lib_polarssl_aes_crypt_cbc"')))/'"openvpn"'\2/g' ./configure; sed -i -r -e 's/ac(_cv(_('"path_IFCONFIG|path_IPROUTE|path_ROUTE"')))/'"openvpn"'\2/g' ./configure; find /usr/src/freetz-trunk/source/target-mipsel_uClibc-0.9.28/openvpn-2.3.0 -name Makefile.in -type f -exec sed -i -r -e 's,^((C|LD)FLAGS|LIBS)[ \t]*=[ \t]*@\1@,& $(EXTRA_\1),' \{\} \+;   PATH=""/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin:/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-3.4.6/mipsel-unknown-linux-gnu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games"" CC="/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc" CXX="/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-g++-wrapper" CFLAGS="-march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" CXXFLAGS="-march=4kc -Os -pipe -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64" LDFLAGS="" PKG_CONFIG_PATH="/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/../lib/pkgconfig" PKG_CONFIG_LIBDIR="/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/../lib/pkgconfig" GLOBAL_LIBDIR=/usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/usr/lib openvpn_path_IFCONFIG=/sbin/ifconfig openvpn_path_IPROUTE=/bin/ip openvpn_path_ROUTE=/sbin/route FREETZ_TARGET_LFS="y" CONFIG_SITE=/usr/src/freetz-trunk/include/site/mipsel-linux-uclibc conf_cmd   --cache-file=/usr/src/freetz-trunk/source/target-mipsel_uClibc-0.9.28/config.cache --target=mipsel-linux --host=mipsel-linux --build=x86_64-pc-linux-gnu --program-prefix="" --program-suffix="" --prefix=/usr --exec-prefix=/usr --bindir=/usr/bin --datadir=/usr/share --includedir=/usr/include --infodir=/usr/share/info --libdir=/usr/lib --libexecdir=/usr/lib --localstatedir=/var --mandir=/usr/share/man --sbindir=/usr/sbin --sysconfdir=/etc --with-gnu-ld --disable-nls  --sysconfdir=/mod/etc/openvpn --enable-lzo --disable-debug --disable-plugins --disable-management --disable-pkcs11 --disable-socks --enable-password-save --with-crypto-library=polarssl  --enable-small --enable-ipv6    )
configure: WARNING: unrecognized options: --disable-nls, --enable-ipv6
checking for minix/config.h... (cached) no
checking whether it is safe to define __EXTENSIONS__... (cached) yes
checking for mipsel-linux-pkg-config... no
checking for pkg-config... (cached) /usr/bin/pkg-config
checking pkg-config is at least version 0.9.0... yes
checking how to run the C preprocessor... /usr/src/freetz-trunk/toolchain/build/mipsel_gcc-4.6.3_uClibc-0.9.28/mipsel-linux-uclibc/bin/mipsel-linux-uclibc-gcc -E
checking for ifconfig... (cached) /sbin/ifconfig
checking for route... (cached) /sbin/route
checking for ip... (cached) /bin/ip
checking for netstat... (cached) netstat
checking for man2html... no
checking for git... (cached) git
checking for mipsel-linux-windres... no
checking for windres... no
checking for inline... (cached) inline
checking for working volatile... (cached) yes
checking for pid_t... (cached) yes
checking for uid_t in sys/types.h... (cached) yes
checking for int8_t... (cached) yes
checking for int16_t... (cached) yes
checking for int32_t... (cached) yes
checking for int64_t... (cached) yes
checking for uint8_t... (cached) yes
checking for uint16_t... (cached) yes
checking for uint32_t... (cached) yes
checking for uint64_t... (cached) yes
checking for ISO C 1999 vararg macro support... (cached) yes
checking for GNU GCC vararg macro support... (cached) yes
checking for socklen_t... (cached) yes
checking for C compiler empty array size... (cached) 0
checking size of unsigned int... (cached) 4
checking size of unsigned long... (cached) 4
checking for stdbool.h... (cached) yes
checking for io.h... (cached) no
checking for direct.h... (cached) no
checking for sys/socket.h... (cached) yes
checking for netinet/in.h... (cached) yes
checking for netinet/in_systm.h... (cached) yes
checking for netinet/tcp.h... (cached) yes
checking for arpa/inet.h... (cached) yes
checking for netdb.h... (cached) yes
checking for windows.h... (cached) no
checking for winsock2.h... (cached) no
checking for ws2tcpip.h... (cached) no
checking for sys/ioctl.h... (cached) yes
checking for sys/file.h... (cached) yes
checking for libgen.h... (cached) yes
checking for stropts.h... (cached) no
checking for syslog.h... (cached) yes
checking for pwd.h... (cached) yes
checking for grp.h... (cached) yes
checking for sys/sockio.h... (cached) no
checking for sys/uio.h... (cached) yes
checking for linux/sockios.h... (cached) yes
checking for linux/types.h... (cached) yes
checking for err.h... (cached) yes
checking for net/if.h... (cached) yes
checking for netinet/ip.h... (cached) yes
checking for netinet/if_ether.h... (cached) yes
checking for resolv.h... (cached) yes
checking for sys/un.h... (cached) yes
checking for in_addr_t... (cached) yes
checking for struct iphdr... (cached) yes
checking for struct sock_extended_err... (cached) no
checking for struct msghdr... (cached) yes
checking for struct cmsghdr... (cached) yes
checking for struct in_pktinfo... (cached) yes
checking for struct sockaddr_in6... (cached) yes
checking whether SO_MARK is declared... (cached) no
checking whether SIGHUP is declared... (cached) yes
checking whether SIGINT is declared... (cached) yes
checking whether SIGUSR1 is declared... (cached) yes
checking whether SIGUSR2 is declared... (cached) yes
checking whether SIGTERM is declared... (cached) yes
checking for vfork.h... (cached) no
checking for fork... (cached) yes
checking for vfork... (cached) yes
checking for working fork... (cached) yes
checking for working vfork... (cached) yes
checking for daemon... (cached) yes
checking for chroot... (cached) yes
checking for getpwnam... (cached) yes
checking for setuid... (cached) yes
checking for nice... (cached) yes
checking for system... (cached) yes
checking for getpid... (cached) yes
checking for dup... (cached) yes
checking for dup2... (cached) yes
checking for getpass... (cached) yes
checking for syslog... (cached) yes
checking for openlog... (cached) yes
checking for mlockall... (cached) yes
checking for getgrnam... (cached) yes
checking for setgid... (cached) yes
checking for setgroups... (cached) yes
checking for stat... (cached) yes
checking for flock... (cached) yes
checking for readv... (cached) yes
checking for writev... (cached) yes
checking for setsid... (cached) yes
checking for chdir... (cached) yes
checking for putenv... (cached) yes
checking for getpeername... (cached) yes
checking for unlink... (cached) yes
checking for chsize... (cached) no
checking for ftruncate... (cached) yes
checking for execve... (cached) yes
checking for getpeereid... (cached) no
checking for basename... (cached) yes
checking for dirname... (cached) yes
checking for dlopen in -ldl... (cached) yes
checking for inet_ntoa in -lnsl... (cached) no
checking for socket in -lsocket... (cached) no
checking for gethostbyname in -lresolv... (cached) no
checking for sendmsg... (cached) yes
checking for recvmsg... (cached) yes
checking for inet_ntop... (cached) yes
checking for inet_pton... (cached) yes
checking for res_init... (cached) no
checking for socket... (cached) yes
checking for recv... (cached) yes
checking for recvfrom... (cached) yes
checking for send... (cached) yes
checking for sendto... (cached) yes
checking for listen... (cached) yes
checking for accept... (cached) yes
checking for connect... (cached) yes
checking for bind... (cached) yes
checking for select... (cached) yes
checking for gethostbyname... (cached) yes
checking for inet_ntoa... (cached) yes
checking for setsockopt... (cached) yes
checking for getsockopt... (cached) yes
checking for getsockname... (cached) yes
checking for net/if_tun.h... (cached) no
checking for net/tun/if_tun.h... (cached) no
checking for linux/if_tun.h... (cached) yes
checking for tap-windows.h... (cached) no
checking whether TUNSETPERSIST is declared... (cached) yes
checking for setcon in -lselinux... (cached) no
checking for pam_start in -lpam... (cached) no
checking for OPENSSL_CRYPTO... no
checking for RSA_new in -lcrypto... (cached) no
checking for OPENSSL_SSL... no
checking for SSL_CTX_new in -lssl... (cached) no
checking for ssl_init in -lpolarssl... yes
checking polarssl version... ok
checking for lzo1x_1_15_compress in -llzo2... (cached) no
checking for lzo1x_1_15_compress in -llzo... (cached) no
checking for PKCS11_HELPER... no
checking git checkout... no
configure: error: lzo enabled but missing
make: *** [source/target-mipsel_uClibc-0.9.28/openvpn-2.3.0/.configured] Fehler 1
timo@kasten:~/privat/freetz-trunk$ make lzo-precompile
make: *** Keine Regel, um »lzo-precompile« zu erstellen.  Schluss.
timo@kasten:~/privat/freetz-trunk$ make lzo2-precompile
make: *** Keine Regel, um »lzo2-precompile« zu erstellen.  Schluss.
# Automatically generated file; DO NOT EDIT.
# Freetz Configuration
FREETZ_HAVE_DOT_CONFIG=y
# Hardware/Firmware ----------------------
# FREETZ_TYPE_300IP is not set
# FREETZ_TYPE_FON is not set
# FREETZ_TYPE_WLAN is not set
# FREETZ_TYPE_W501V is not set
# FREETZ_TYPE_2170 is not set
# FREETZ_TYPE_3020 is not set
# FREETZ_TYPE_3030 is not set
# FREETZ_TYPE_3130 is not set
# FREETZ_TYPE_3131 is not set
# FREETZ_TYPE_3170 is not set
# FREETZ_TYPE_3270_V2 is not set
# FREETZ_TYPE_3270_V3 is not set
# FREETZ_TYPE_3370 is not set
# FREETZ_TYPE_5010 is not set
# FREETZ_TYPE_5050 is not set
# FREETZ_TYPE_5124 is not set
# FREETZ_TYPE_5140 is not set
FREETZ_TYPE_7050=y
# FREETZ_TYPE_7112 is not set
# FREETZ_TYPE_7113 is not set
# FREETZ_TYPE_7140 is not set
# FREETZ_TYPE_7141 is not set
# FREETZ_TYPE_7150 is not set
# FREETZ_TYPE_7170 is not set
# FREETZ_TYPE_7240 is not set
# FREETZ_TYPE_7270_V1 is not set
# FREETZ_TYPE_7270_V2 is not set
# FREETZ_TYPE_7270_V3 is not set
# FREETZ_TYPE_7312 is not set
# FREETZ_TYPE_7320 is not set
# FREETZ_TYPE_7330_XL is not set
# FREETZ_TYPE_7330_SL is not set
# FREETZ_TYPE_7340 is not set
# FREETZ_TYPE_7360_XL is not set
# FREETZ_TYPE_7360_SL is not set
# FREETZ_TYPE_7390 is not set
# FREETZ_TYPE_7570 is not set
# FREETZ_TYPE_6810 is not set
# FREETZ_TYPE_6840 is not set
# FREETZ_TYPE_CUSTOM is not set
FREETZ_TYPE_LANG_DE=y
FREETZ_TYPE_FINAL=y
FREETZ_TYPE_LANGUAGE="de"
# Menuconfig -----------------------------
FREETZ_SHOW_ADVANCED=y
FREETZ_SHOW_UNSTABLE_PACKAGES=y
# Original components --------------------
FREETZ_TARGET_IPV6_SUPPORT=y
FREETZ_REPLACE_KERNEL=y
# Removal patches
# Removal patches ------------------------
# Remove piglet
FREETZ_REMOVE_ASSISTANT=y
# FREETZ_REMOVE_ASSISTANT_SIP is not set
FREETZ_REMOVE_USB_MODULE=y
FREETZ_REMOVE_WEBSRV=y
# Remove brandings
# FREETZ_REMOVE_BRANDING_1und1 is not set
# FREETZ_REMOVE_BRANDING_avm is not set
FREETZ_REMOVE_CAPIOVERTCP=y
# FREETZ_REMOVE_DSLD is not set
# FREETZ_REMOVE_SHOWDSLDSTAT is not set
FREETZ_REMOVE_HELP=y
FREETZ_REMOVE_RUNCLOCK=y
FREETZ_REMOVE_SUPPORT=y
FREETZ_REMOVE_SUPPORT_EVENTSDUMP=y
FREETZ_REMOVE_TR069=y
FREETZ_REMOVE_UPNP=y
FREETZ_REMOVE_UPNP_LIBS=y
FREETZ_REMOVE_KIDS=y
# FREETZ_REMOVE_QOS is not set
# FREETZ_REMOVE_VOIPD is not set
# FREETZ_REMOVE_TELEPHONY is not set
# FREETZ_REMOVE_WLAN is not set
# Other patches
# Web menu patches -----------------------
FREETZ_PATCH_VCC=y
FREETZ_PATCH_ATA=y
FREETZ_PATCH_ENUM=y
FREETZ_PATCH_SIGNED=y
# Replacement patches --------------------
# Replace OpenSSL libraries (not available, requires openssl-0.9.8)
FREETZ_REPLACE_ONLINECHANGED=y
# Additional patches ---------------------
# FREETZ_ADD_ETCSERVICES is not set
# FREETZ_ENFORCE_URLADER_SETTINGS is not set
# Misc patches ---------------------------
# FREETZ_DISABLE_SERIAL_CONSOLE is not set
# AVM daemons ----------------------------
FREETZ_AVMDAEMON_DISABLE_IGD=y
# FREETZ_AVMDAEMON_DISABLE_NTP is not set
# FREETZ_AVMDAEMON_DISABLE_IGM is not set
FREETZ_AVMDAEMON_DISABLE_TR069=y
# FREETZ_AVMDAEMON_DISABLE_MULTIDPORTS is not set
# Additional components ------------------
# Packages
# Debug helpers
# FREETZ_PACKAGE_GDB is not set
# FREETZ_PACKAGE_INOTIFY_TOOLS is not set
# FREETZ_PACKAGE_LDD is not set
# FREETZ_PACKAGE_LSOF is not set
# FREETZ_PACKAGE_LTRACE is not set
# FREETZ_PACKAGE_NANO_SHELL is not set
# FREETZ_PACKAGE_PCIUTILS is not set
# FREETZ_PACKAGE_STRACE is not set
# FREETZ_PACKAGE_USBUTILS is not set
# Standard packages
FREETZ_PACKAGE_AICCU=y
# FREETZ_PACKAGE_BFTPD is not set
# FREETZ_PACKAGE_BIRD is not set
# FREETZ_PACKAGE_BRIDGE_UTILS is not set
# FREETZ_PACKAGE_CALLMONITOR is not set
# FREETZ_PACKAGE_CHECKMAILD is not set
# FREETZ_PACKAGE_CIFSMOUNT is not set
# FREETZ_PACKAGE_CURL is not set
# FREETZ_PACKAGE_DECO is not set
# FREETZ_PACKAGE_DNS2TCP is not set
# FREETZ_PACKAGE_DNSMASQ is not set
# FREETZ_PACKAGE_DROPBEAR is not set
# FREETZ_PACKAGE_ESPEAK is not set
# FREETZ_PACKAGE_FORTUNE is not set
# FREETZ_PACKAGE_FUSE is not set
FREETZ_PACKAGE_HASERL=y
# FREETZ_PACKAGE_HASERL_WITH_LUA is not set
# FREETZ_PACKAGE_INETD is not set
# FREETZ_PACKAGE_KNOCK is not set
# FREETZ_PACKAGE_MC is not set
# FREETZ_PACKAGE_MTR is not set
# FREETZ_PACKAGE_NANO is not set
# FREETZ_PACKAGE_NETCAT is not set
# FREETZ_PACKAGE_NC6 is not set
# FREETZ_PACKAGE_NETSNMP is not set
# FREETZ_PACKAGE_NFS_UTILS is not set
# FREETZ_PACKAGE_NTFS is not set
# FREETZ_PACKAGE_OPENNTPD is not set
FREETZ_PACKAGE_OPENVPN=y
FREETZ_PACKAGE_OPENVPN_VERSION_2_3=y
# FREETZ_PACKAGE_OPENVPN_VERSION_2_2 is not set
# FREETZ_PACKAGE_OPENVPN_OPENSSL is not set
FREETZ_PACKAGE_OPENVPN_POLARSSL=y
FREETZ_PACKAGE_OPENVPN_STATIC=y
FREETZ_PACKAGE_OPENVPN_WITH_LZO=y
# FREETZ_PACKAGE_OPENVPN_WITH_MGMNT is not set
FREETZ_PACKAGE_OPENVPN_ENABLE_SMALL=y
# FREETZ_PACKAGE_OPENVPN_USE_IPROUTE is not set
# FREETZ_PACKAGE_PHP is not set
# FREETZ_PACKAGE_PINGTUNNEL is not set
# FREETZ_PACKAGE_PORTMAP is not set
# Point-to-Point
# FREETZ_PACKAGE_PPPD is not set
# FREETZ_PACKAGE_PPPD_CHAT is not set
# FREETZ_PACKAGE_PPTP is not set
# FREETZ_PACKAGE_PPTPD is not set
# FREETZ_PACKAGE_PRIVOXY is not set
FREETZ_PACKAGE_RADVD=y
# FREETZ_PACKAGE_RCAPID is not set
# FREETZ_PACKAGE_SAMBA is not set
# FREETZ_PACKAGE_SCREEN is not set
# FREETZ_PACKAGE_STUNNEL is not set
# FREETZ_PACKAGE_TCPDUMP is not set
# FREETZ_PACKAGE_TINYPROXY is not set
# FREETZ_PACKAGE_TOR is not set
# FREETZ_PACKAGE_TRANSMISSION is not set
# FREETZ_PACKAGE_VNSTAT is not set
# FREETZ_PACKAGE_VPNC is not set
# FREETZ_PACKAGE_VSFTPD is not set
# FREETZ_PACKAGE_XMAIL is not set
# Testing
# FREETZ_PACKAGE_APACHE is not set
# FREETZ_PACKAGE_APACHE2 is not set
# FREETZ_PACKAGE_AUTOFS is not set
# FREETZ_PACKAGE_AVAHI is not set
# FREETZ_PACKAGE_BASH is not set
# FREETZ_PACKAGE_BFUSB is not set
# FREETZ_PACKAGE_BIND is not set
# FREETZ_PACKAGE_BIP is not set
# FREETZ_PACKAGE_BITTWIST is not set
# FREETZ_PACKAGE_BLUEZ_UTILS is not set
# FREETZ_PACKAGE_BR2684CTL is not set
# FREETZ_PACKAGE_CCID is not set
# FREETZ_PACKAGE_CLASSPATH is not set
# FREETZ_PACKAGE_CRYPTSETUP is not set
# FREETZ_PACKAGE_CTORRENT is not set
# FREETZ_PACKAGE_DANTE is not set
# FREETZ_PACKAGE_DAVFS2 is not set
# FREETZ_PACKAGE_DBUS is not set
# FREETZ_PACKAGE_DEBOOTSTRAP is not set
# FREETZ_PACKAGE_DIGITEMP is not set
# FREETZ_PACKAGE_DOSFSTOOLS is not set
# FREETZ_PACKAGE_DTACH is not set
# FREETZ_PACKAGE_DVBSNOOP is not set
# FREETZ_PACKAGE_DVBSTREAM is not set
# FREETZ_PACKAGE_DVBTUNE is not set
# FREETZ_PACKAGE_E2FSPROGS is not set
# FREETZ_PACKAGE_EMPTY is not set
# FREETZ_PACKAGE_FFMPEG is not set
# FREETZ_PACKAGE_FOWSR is not set
# FREETZ_PACKAGE_FSTYP is not set
# FREETZ_PACKAGE_GHOSTSCRIPT_FONTS is not set
# FREETZ_PACKAGE_GIT is not set
# FREETZ_PACKAGE_GNU_MAKE is not set
# FREETZ_PACKAGE_GNUTLS is not set
# FREETZ_PACKAGE_GOCR is not set
# FREETZ_PACKAGE_HAPROXY is not set
# FREETZ_PACKAGE_HOL is not set
# FREETZ_PACKAGE_HTOP is not set
# FREETZ_PACKAGE_HTPDATE is not set
# FREETZ_PACKAGE_HTTPRY is not set
# FREETZ_PACKAGE_HTTPTUNNEL is not set
# FREETZ_PACKAGE_IFSTAT is not set
# FREETZ_PACKAGE_IFTOP is not set
# FREETZ_PACKAGE_IGMPPROXY is not set
# FREETZ_PACKAGE_IMAGEMAGICK is not set
# FREETZ_PACKAGE_INADYN_MT is not set
# FREETZ_PACKAGE_INADYN_OPENDNS is not set
# FREETZ_PACKAGE_IODINE is not set
# FREETZ_PACKAGE_IPTRAF is not set
# FREETZ_PACKAGE_IPUTILS is not set
# FREETZ_PACKAGE_IRSSI is not set
# FREETZ_PACKAGE_JAMVM is not set
# FREETZ_PACKAGE_LFTP is not set
# FREETZ_PACKAGE_LIGHTTPD is not set
# FREETZ_PACKAGE_LYNX is not set
# FREETZ_PACKAGE_LUA is not set
# FREETZ_PACKAGE_MADPLAY is not set
# FREETZ_PACKAGE_MATRIXTUNNEL is not set
# FREETZ_PACKAGE_MCABBER is not set
# FREETZ_PACKAGE_MEDIATOMB is not set
# FREETZ_PACKAGE_MICROPERL is not set
# FREETZ_PACKAGE_MINI_SNMPD is not set
# FREETZ_PACKAGE_MINICOM is not set
# FREETZ_PACKAGE_MINIDLNA is not set
# FREETZ_PACKAGE_MODULE_INIT_TOOLS is not set
# FREETZ_PACKAGE_NAGIOS is not set
# FREETZ_PACKAGE_NCFTP is not set
# FREETZ_PACKAGE_NETATALK is not set
# FREETZ_PACKAGE_NETPBM is not set
# FREETZ_PACKAGE_NOIP is not set
# FREETZ_PACKAGE_NDAS is not set
# FREETZ_PACKAGE_NFSROOT is not set
# FREETZ_PACKAGE_NGIRCD is not set
# FREETZ_PACKAGE_NMAP is not set
# FREETZ_PACKAGE_OBEXFTP is not set
# FREETZ_PACKAGE_OIDENTD is not set
# FREETZ_PACKAGE_OPENCONNECT is not set
# FREETZ_PACKAGE_OPENDD is not set
# OpenSSH
# FREETZ_PACKAGE_OPENSSH_sshd is not set
# FREETZ_PACKAGE_OPENSSH_ssh is not set
# FREETZ_PACKAGE_OPENSSH_scp is not set
# FREETZ_PACKAGE_OPENSSH_CLIENTUTILS is not set
# FREETZ_PACKAGE_OPENSSH_KEYUTILS is not set
# FREETZ_PACKAGE_OPENSSH_sftp is not set
# FREETZ_PACKAGE_OPENSSH_sftp_server is not set
# FREETZ_PACKAGE_OWFS is not set
# FREETZ_PACKAGE_PCSC_LITE is not set
# FREETZ_PACKAGE_POLIPO is not set
# FREETZ_PACKAGE_PYTHON is not set
# FREETZ_PACKAGE_QUAGGA is not set
# FREETZ_PACKAGE_RIPMIME is not set
# FREETZ_PACKAGE_RRDTOOL is not set
# FREETZ_PACKAGE_RSYNC is not set
# FREETZ_PACKAGE_RUBY is not set
# FREETZ_PACKAGE_RUSH is not set
# FREETZ_PACKAGE_SABLEVM_SDK is not set
# FREETZ_PACKAGE_SER2NET is not set
# FREETZ_PACKAGE_SHELLINABOX is not set
# FREETZ_PACKAGE_SIPROXD is not set
# FREETZ_PACKAGE_SISPMCTL is not set
# FREETZ_PACKAGE_SLANG is not set
# FREETZ_PACKAGE_SLURM is not set
# FREETZ_PACKAGE_SMARTMONTOOLS is not set
# FREETZ_PACKAGE_SMSTOOLS3 is not set
# FREETZ_PACKAGE_SMUSBUTIL is not set
# FREETZ_PACKAGE_SOCAT is not set
# FREETZ_PACKAGE_SPAWN_FCGI is not set
# FREETZ_PACKAGE_SQLITE is not set
# FREETZ_PACKAGE_SSHFS_FUSE is not set
# FREETZ_PACKAGE_STREAMRIPPER is not set
# FREETZ_PACKAGE_SUBVERSION is not set
# FREETZ_PACKAGE_SUNDTEK is not set
# FREETZ_PACKAGE_SYNCE_DCCM is not set
# FREETZ_PACKAGE_SYNCE_SERIAL is not set
# FREETZ_PACKAGE_TCP_WRAPPERS is not set
# FREETZ_PACKAGE_TCPPROXY is not set
# FREETZ_PACKAGE_TREE is not set
# FREETZ_PACKAGE_TRICKLE is not set
# FREETZ_PACKAGE_TMUX is not set
# FREETZ_PACKAGE_UDPXY is not set
# FREETZ_PACKAGE_UMURMUR is not set
# FREETZ_PACKAGE_UNFS3 is not set
# FREETZ_PACKAGE_UNRAR is not set
# FREETZ_PACKAGE_USBIP is not set
# FREETZ_PACKAGE_UTIL_LINUX_NG is not set
# FREETZ_PACKAGE_VIM is not set
# FREETZ_PACKAGE_VTUN is not set
# FREETZ_PACKAGE_WGET is not set
# FREETZ_PACKAGE_WOL is not set
# FREETZ_PACKAGE_WPUT is not set
# FREETZ_PACKAGE_XPDF is not set
# FREETZ_PACKAGE_XRELAYD is not set
# FREETZ_PACKAGE_XSLTPROC is not set
# Web interfaces
# FREETZ_PACKAGE_AUTHORIZED_KEYS is not set
FREETZ_PACKAGE_AVM_FIREWALL=y
# FREETZ_PACKAGE_DNSD_CGI is not set
# FREETZ_PACKAGE_DOWNLOADER is not set
# FREETZ_PACKAGE_NFSD_CGI is not set
# FREETZ_PACKAGE_ONLINECHANGED_CGI is not set
# FREETZ_PACKAGE_PHPXMAIL is not set
# FREETZ_PACKAGE_RRDSTATS is not set
# FREETZ_PACKAGE_SPINDOWN_CGI is not set
FREETZ_PACKAGE_SYSLOGD_CGI=y
# FREETZ_PACKAGE_TRANSMISSION_CGI is not set
# FREETZ_PACKAGE_VNSTAT_CGI is not set
# FREETZ_PACKAGE_WOL_CGI is not set
# Unstable packages
# FREETZ_PACKAGE_COLLECTD is not set
# FREETZ_PACKAGE_DTMFBOX is not set
# FREETZ_PACKAGE_GW6 is not set
# FREETZ_PACKAGE_HP_UTILS is not set
# FREETZ_PACKAGE_HPLIP is not set
FREETZ_PACKAGE_IPTABLES=y
FREETZ_PACKAGE_IPTABLES_IS_SELECTABLE=y
# FREETZ_PACKAGE_IPTABLES_SAVE_RESTORE is not set
# FREETZ_PACKAGE_IPTABLES_STATIC is not set
# FREETZ_PACKAGE_IPTABLES_CGI is not set
# FREETZ_PACKAGE_NHIPT is not set
# FREETZ_PACKAGE_IPTABLES_STANDARD_MODULES is not set
# FREETZ_PACKAGE_IPTABLES_KERNEL_MODULES is not set
# FREETZ_PACKAGE_IPTABLES_SHARED_LIBS is not set
# FREETZ_PACKAGE_MINI_FO is not set
# SANE
# FREETZ_PACKAGE_SANE_BACKENDS is not set
# FREETZ_PACKAGE_SQUID is not set
# FREETZ_PACKAGE_TINC is not set
# truecrypt (not available, needs at least kernel 2.6.28)
# FREETZ_PACKAGE_VIRTUALIP_CGI is not set
FREETZ_PACKAGE_MOD=y
# FREETZ_PACKAGE_MOD_ETCSERVICES is not set
FREETZ_PACKAGE_MODCGI=y
# Shared libraries
# Apache Portable Runtime libs
# FREETZ_LIB_libapr is not set
# FREETZ_LIB_libapr_WITH_DSO is not set
# FREETZ_LIB_libaprutil is not set
# FREETZ_LIB_libaprutil_WITH_LIBDB is not set
# Avahi libraries
# FREETZ_LIB_libavahi_common is not set
# FREETZ_LIB_libavahi_core is not set
# FREETZ_LIB_libavahi_client is not set
# C++
# FREETZ_LIB_STDCXXLIB is not set
# FREETZ_LIB_STDCXXLIB_WITH_WCHAR is not set
# FREETZ_LIB_libstdc__ is not set
# FREETZ_LIB_libuClibc__ is not set
# FREETZ_LIB_libuClibc__WITH_WCHAR is not set
# Charsets & Internationalization
# FREETZ_LIB_libiconv is not set
# FREETZ_LIB_libintl is not set
# Crypto & SSL
# GnuPG ----------------------------------
# FREETZ_LIB_libgpg_error is not set
# FREETZ_LIB_libgcrypt is not set
# Digests ---
# Symmetric ciphers ---
# Asymmetric ciphers ---
# GnuTLS ---------------------------------
# FREETZ_LIB_libgnutls is not set
# FREETZ_LIB_libtasn1 is not set
# SSL ------------------------------------
# FREETZ_LIB_libcyassl is not set
# FREETZ_LIB_libmatrixssl is not set
# FREETZ_LIB_libpolarssl is not set
# FREETZ_LIB_libcrypto is not set
# FREETZ_OPENSSL_VERSION_PROMPT is not set
# Data compression
# FREETZ_LIB_liblzo2 is not set
# FREETZ_LIB_libz is not set
# Database
# FREETZ_LIB_libdb is not set
# FREETZ_LIB_libsqlite3 is not set
# File systems
# e2fsprogs libraries
# FREETZ_LIB_libblkid is not set
# FREETZ_LIB_libcom_err is not set
# FREETZ_LIB_libe2p is not set
# FREETZ_LIB_libext2fs is not set
# FREETZ_LIB_libss is not set
# FREETZ_LIB_libuuid is not set
# FREETZ_LIB_libfuse is not set
# FREETZ_LIB_libntfs is not set
# GLib
# FREETZ_LIB_libglib_2 is not set
# FREETZ_LIB_libgio_2 is not set
# FREETZ_LIB_libgobject_2 is not set
# FREETZ_LIB_libgmodule_2 is not set
# FREETZ_LIB_libgthread_2 is not set
# Graphics & fonts
# FREETZ_LIB_libfreetype is not set
# FREETZ_LIB_libart_lgpl_2 is not set
# FREETZ_LIB_libexif is not set
# FREETZ_LIB_libjpeg is not set
# FREETZ_LIB_libpng12 is not set
# FREETZ_LIB_libgd is not set
# FREETZ_LIB_libopenjpeg is not set
# FREETZ_LIB_libtiff is not set
# FREETZ_LIB_libnetpbm is not set
# Multi precision arithmetic libs
# FREETZ_LIB_libgmp is not set
# FREETZ_LIB_libmpfr is not set
# FREETZ_LIB_libmpc is not set
# Multimedia
# Audio and video codecs
# Audio codecs
# FREETZ_LIB_libFLAC is not set
# FREETZ_LIB_libmad is not set
# FREETZ_LIB_libogg is not set
# FFmpeg libraries
# FREETZ_LIB_libavcodec is not set
# FREETZ_LIB_libavdevice is not set
# FREETZ_LIB_libavfilter is not set
# FREETZ_LIB_libavformat is not set
# FREETZ_LIB_libavutil is not set
# FREETZ_LIB_libpostproc is not set
# FREETZ_LIB_libswresample is not set
# FREETZ_LIB_libswscale is not set
# Video codecs
# Vorbis video codec ---------------------
# FREETZ_LIB_libvorbis is not set
# FREETZ_LIB_libvorbisenc is not set
# FREETZ_LIB_libvorbisfile is not set
# ID3 tag reading libs
# FREETZ_LIB_libid3tag is not set
# FREETZ_LIB_libtag is not set
# ncurses
# FREETZ_LIB_libncurses is not set
# terminfo database
# Select terminfo database entries to install (see help of 'Show all items')
# FREETZ_SHARE_terminfo is not set
# FREETZ_LIB_libform is not set
# FREETZ_LIB_libmenu is not set
# FREETZ_LIB_libpanel is not set
# Networking
# ATM ------------------------------------
# FREETZ_LIB_libatm is not set
# Bluetooth ------------------------------
# FREETZ_LIB_libbluetooth is not set
# FREETZ_LIB_libopenobex is not set
# ISDN & CAPI ----------------------------
# FREETZ_LIB_libcapi20 is not set
# Misc networking ------------------------
# FREETZ_LIB_libdnet is not set
# FREETZ_LIB_libpcap is not set
# FREETZ_LIB_libnet is not set
# FREETZ_LIB_liboping is not set
# FREETZ_LIB_libosip2 is not set
# FREETZ_LIB_libosipparser2 is not set
# Readline
# FREETZ_LIB_libreadline is not set
# FREETZ_LIB_libhistory is not set
# Regular expressions
# FREETZ_LIB_libpcre is not set
# FREETZ_LIB_libpcreposix is not set
# uClibc
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libpthread=y
FREETZ_LIB_librt=y
# FREETZ_LIB_libthread_db is not set
FREETZ_LIB_libuClibc=y
# FREETZ_LIB_libutil is not set
# USB & FTDI
# FREETZ_LIB_libusb is not set
# FREETZ_LIB_libusb_1 is not set
# FREETZ_LIB_libftdi is not set
# Web and WebDAV
# FREETZ_LIB_libcurl is not set
# FREETZ_LIB_libcurl_WITH_ZLIB is not set
# FREETZ_LIB_libjs is not set
# FREETZ_LIB_libneon is not set
# FREETZ_LIB_libneon_WITH_SSL is not set
# FREETZ_LIB_libneon_WITH_ZLIB is not set
# XML & XSLT
# FREETZ_LIB_libexpat is not set
# FREETZ_LIB_libxml2 is not set
# FREETZ_LIB_libxml2_WITH_HTML is not set
# FREETZ_LIB_libxslt is not set
# FREETZ_LIB_libexslt is not set
# FREETZ_LIB_libattr is not set
# FREETZ_LIB_libdbus is not set
FREETZ_LIB_libgcc_s=y
# FREETZ_LIB_libconfig is not set
# FREETZ_LIB_libdaemon is not set
# FREETZ_LIB_libdevmapper is not set
# FREETZ_LIB_libelf is not set
# FREETZ_LIB_libevent is not set
# FREETZ_LIB_libffi is not set
# FREETZ_LIB_libmultid is not set
# FREETZ_LIB_libltdl is not set
# FREETZ_LIB_liblua is not set
# FREETZ_LIB_libpopt is not set
# FREETZ_LIB_libprotobuf_c is not set
# FREETZ_LIB_librrd is not set
# FREETZ_LIB_librrd_th is not set
# FREETZ_LIB_libslang is not set
# FREETZ_LIB_libsynce is not set
# FREETZ_LIB_libsysfs is not set
# FREETZ_LIB_libwx_baseu is not set
# FREETZ_LIB_libyaml is not set
FREETZ_KERNEL_VERSION_2_6_13=y
# FREETZ_KERNEL_VERSION_2_6_19 is not set
# FREETZ_KERNEL_VERSION_2_6_28 is not set
# FREETZ_KERNEL_VERSION_2_6_32 is not set
FREETZ_KERNEL_VERSION="2.6.13.1"
FREETZ_KERNEL_VERSION_2_6_13_MIN=y
# FREETZ_KERNEL_VERSION_2_6_19_MIN is not set
# FREETZ_KERNEL_VERSION_2_6_28_MIN is not set
# FREETZ_KERNEL_VERSION_2_6_32_MIN is not set
FREETZ_KERNEL_VERSION_2_6_13_MAX=y
FREETZ_KERNEL_VERSION_2_6_19_MAX=y
FREETZ_KERNEL_VERSION_2_6_28_MAX=y
FREETZ_KERNEL_VERSION_2_6_32_MAX=y
FREETZ_KERNEL_LAYOUT_AR7=y
FREETZ_KERNEL_LAYOUT="ar7"
FREETZ_MODULES_KVER="2.6.13.1-ar7"
# Kernel modules
# FREETZ_MODULES_ALL is not set
# block
# FREETZ_MODULE_mtdblk is not set
# FREETZ_MODULE_block2mtd is not set
# ndas
# FREETZ_MODULE_ndas_block is not set
# FREETZ_MODULE_ndas_core is not set
# FREETZ_MODULE_ndas_sal is not set
# crypto
# FREETZ_MODULE_aes is not set
# FREETZ_MODULE_arc4 is not set
# FREETZ_MODULE_sha1 is not set
# FREETZ_MODULE_sha256 is not set
# drivers
# FREETZ_MODULE_loop is not set
# FREETZ_MODULE_nbd is not set
# FREETZ_MODULE_cdrom is not set
# FREETZ_MODULE_capiconn is not set
# FREETZ_MODULE_nand is not set
# FREETZ_MODULE_ohio_nand is not set
# FREETZ_MODULE_dummy is not set
# FREETZ_MODULE_ppp_async is not set
# FREETZ_MODULE_ppp_deflate is not set
# FREETZ_MODULE_ppp_generic is not set
# FREETZ_MODULE_pppoe is not set
# FREETZ_MODULE_pppox is not set
# FREETZ_MODULE_ppp_mppe_mppc is not set
# FREETZ_MODULE_scsi_mod is not set
# FREETZ_MODULE_sd_mod is not set
# FREETZ_MODULE_sg is not set
# FREETZ_MODULE_sr_mod is not set
# FREETZ_MODULE_slhc is not set
# FREETZ_MODULE_usblp is not set
# FREETZ_MODULE_usb_storage is not set
# FREETZ_MODULE_usbmon is not set
# FREETZ_MODULE_usbcore is not set
# FREETZ_MODULE_usbip is not set
# FREETZ_MODULE_usbip_common_mod is not set
# FREETZ_MODULE_usbserial is not set
# FREETZ_MODULE_ipaq is not set
# FREETZ_MODULE_pl2303 is not set
# FREETZ_MODULE_ftdi_sio is not set
# FREETZ_MODULE_hci_usb is not set
# FREETZ_MODULE_bfusb is not set
# FREETZ_MODULE_firmware_class is not set
# FREETZ_MODULE_dm_mod is not set
# FREETZ_MODULE_dm_crypt is not set
# FREETZ_MODULE_option is not set
# fs
# FREETZ_MODULE_autofs4 is not set
# FREETZ_MODULE_cifs is not set
# FREETZ_MODULE_coda is not set
# FREETZ_MODULE_ext2 is not set
# FREETZ_MODULE_ext3 is not set
# FREETZ_MODULE_fat is not set
# FREETZ_MODULE_hfs is not set
# FREETZ_MODULE_hfsplus is not set
# FREETZ_MODULE_fuse is not set
# FREETZ_MODULE_iso9660 is not set
# FREETZ_MODULE_jbd is not set
# FREETZ_MODULE_lockd is not set
# FREETZ_MODULE_mini_fo is not set
# FREETZ_MODULE_minix is not set
# FREETZ_MODULE_nfsd is not set
# FREETZ_MODULE_exportfs is not set
# FREETZ_MODULE_nfs is not set
# FREETZ_MODULE_nls_cp437 is not set
# FREETZ_MODULE_nls_cp852 is not set
# FREETZ_MODULE_nls_iso8859_15 is not set
# FREETZ_MODULE_nls_iso8859_1 is not set
# FREETZ_MODULE_nls_utf8 is not set
# FREETZ_MODULE_reiserfs is not set
# FREETZ_MODULE_udf is not set
# FREETZ_MODULE_unionfs is not set
# FREETZ_MODULE_vfat is not set
# FREETZ_MODULE_msdos is not set
# FREETZ_MODULE_jffs2 is not set
# FREETZ_MODULE_mbcache is not set
# lib
# FREETZ_MODULE_crc_ccitt is not set
# FREETZ_MODULE_lzo_compress is not set
# FREETZ_MODULE_lzo_decompress is not set
# net
# FREETZ_MODULE_bluetooth is not set
# FREETZ_MODULE_bnep is not set
# FREETZ_MODULE_cls_u32 is not set
FREETZ_MODULE_ipv6=y
# FREETZ_MODULE_l2cap is not set
# network scheduler
# FREETZ_MODULE_sch_cbq is not set
# FREETZ_MODULE_sch_htb is not set
# FREETZ_MODULE_sch_llq is not set
# FREETZ_MODULE_sch_sfq is not set
# FREETZ_MODULE_sch_tbf is not set
# FREETZ_MODULE_rfcomm is not set
# FREETZ_MODULE_sunrpc is not set
# Busybox applets
FREETZ_BUSYBOX__MANDATORY=y
FREETZ_BUSYBOX__IPV6_UTILS=y
# FREETZ_BUSYBOX__PACKER is not set
# FREETZ_BUSYBOX__NETWORK is not set
# FREETZ_BUSYBOX__TERMINAL is not set
# FREETZ_BUSYBOX__DEVELOPER is not set
FREETZ_BUSYBOX_HAVE_DOT_CONFIG=y
# Busybox Settings
# General Configuration
# FREETZ_BUSYBOX_DESKTOP is not set
# FREETZ_BUSYBOX_EXTRA_COMPAT is not set
# FREETZ_BUSYBOX_INCLUDE_SUSv2 is not set
# FREETZ_BUSYBOX_USE_PORTABLE_CODE is not set
FREETZ_BUSYBOX_PLATFORM_LINUX=y
FREETZ_BUSYBOX_FEATURE_BUFFERS_USE_MALLOC=y
# FREETZ_BUSYBOX_FEATURE_BUFFERS_GO_ON_STACK is not set
# FREETZ_BUSYBOX_FEATURE_BUFFERS_GO_IN_BSS is not set
FREETZ_BUSYBOX_SHOW_USAGE=y
FREETZ_BUSYBOX_FEATURE_VERBOSE_USAGE=y
# FREETZ_BUSYBOX_FEATURE_COMPRESS_USAGE is not set
# FREETZ_BUSYBOX_FEATURE_INSTALLER is not set
# FREETZ_BUSYBOX_INSTALL_NO_USR is not set
# FREETZ_BUSYBOX_LOCALE_SUPPORT is not set
# FREETZ_BUSYBOX_UNICODE_SUPPORT is not set
# FREETZ_BUSYBOX_LONG_OPTS is not set
FREETZ_BUSYBOX_FEATURE_DEVPTS=y
# FREETZ_BUSYBOX_FEATURE_CLEAN_UP is not set
# FREETZ_BUSYBOX_FEATURE_UTMP is not set
FREETZ_BUSYBOX_FEATURE_PIDFILE=y
FREETZ_BUSYBOX_FEATURE_SUID=y
# FREETZ_BUSYBOX_FEATURE_SUID_CONFIG is not set
# FREETZ_BUSYBOX_SELINUX is not set
FREETZ_BUSYBOX_FEATURE_PREFER_APPLETS=y
FREETZ_BUSYBOX_BUSYBOX_EXEC_PATH="/bin/busybox"
FREETZ_BUSYBOX_FEATURE_SYSLOG=y
FREETZ_BUSYBOX_FEATURE_HAVE_RPC=y
# Build Options
# FREETZ_BUSYBOX_STATIC is not set
# FREETZ_BUSYBOX_PIE is not set
# FREETZ_BUSYBOX_NOMMU is not set
FREETZ_BUSYBOX_LFS=y
FREETZ_BUSYBOX_CROSS_COMPILER_PREFIX=""
FREETZ_BUSYBOX_SYSROOT=""
FREETZ_BUSYBOX_EXTRA_CFLAGS=""
FREETZ_BUSYBOX_EXTRA_LDFLAGS=""
FREETZ_BUSYBOX_EXTRA_LDLIBS=""
# Debugging Options
# FREETZ_BUSYBOX_DEBUG is not set
# FREETZ_BUSYBOX_WERROR is not set
FREETZ_BUSYBOX_NO_DEBUG_LIB=y
# FREETZ_BUSYBOX_DMALLOC is not set
# FREETZ_BUSYBOX_EFENCE is not set
# Installation Options ("make install" behavior)
FREETZ_BUSYBOX_INSTALL_APPLET_SYMLINKS=y
# FREETZ_BUSYBOX_INSTALL_APPLET_HARDLINKS is not set
# FREETZ_BUSYBOX_INSTALL_APPLET_SCRIPT_WRAPPERS is not set
# FREETZ_BUSYBOX_INSTALL_APPLET_DONT is not set
FREETZ_BUSYBOX_PREFIX="./_install"
# Busybox Library Tuning
# FREETZ_BUSYBOX_FEATURE_SYSTEMD is not set
# FREETZ_BUSYBOX_FEATURE_RTMINMAX is not set
FREETZ_BUSYBOX_PASSWORD_MINLEN=6
FREETZ_BUSYBOX_MD5_SMALL=1
# FREETZ_BUSYBOX_FEATURE_FAST_TOP is not set
# FREETZ_BUSYBOX_FEATURE_ETC_NETWORKS is not set
FREETZ_BUSYBOX_FEATURE_USE_TERMIOS=y
FREETZ_BUSYBOX_FEATURE_EDITING=y
FREETZ_BUSYBOX_FEATURE_EDITING_MAX_LEN=1024
# FREETZ_BUSYBOX_FEATURE_EDITING_VI is not set
FREETZ_BUSYBOX_FEATURE_EDITING_HISTORY=255
# FREETZ_BUSYBOX_FEATURE_EDITING_SAVEHISTORY is not set
FREETZ_BUSYBOX_FEATURE_TAB_COMPLETION=y
# FREETZ_BUSYBOX_FEATURE_USERNAME_COMPLETION is not set
FREETZ_BUSYBOX_FEATURE_EDITING_FANCY_PROMPT=y
# FREETZ_BUSYBOX_FEATURE_EDITING_ASK_TERMINAL is not set
FREETZ_BUSYBOX_FEATURE_NON_POSIX_CP=y
# FREETZ_BUSYBOX_FEATURE_VERBOSE_CP_MESSAGE is not set
FREETZ_BUSYBOX_FEATURE_COPYBUF_KB=64
FREETZ_BUSYBOX_FEATURE_SKIP_ROOTFS=y
FREETZ_BUSYBOX_MONOTONIC_SYSCALL=y
FREETZ_BUSYBOX_IOCTL_HEX2STR_ERROR=y
FREETZ_BUSYBOX_FEATURE_HWIB=y
# Applets
# Archival Utilities
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_XZ is not set
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_LZMA is not set
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_BZ2 is not set
FREETZ_BUSYBOX_FEATURE_SEAMLESS_GZ=y
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_Z is not set
# FREETZ_BUSYBOX_AR is not set
# FREETZ_BUSYBOX_BUNZIP2 is not set
# FREETZ_BUSYBOX_BZIP2 is not set
# FREETZ_BUSYBOX_CPIO is not set
# FREETZ_BUSYBOX_DPKG is not set
# FREETZ_BUSYBOX_DPKG_DEB is not set
FREETZ_BUSYBOX_GUNZIP=y
FREETZ_BUSYBOX_GZIP=y
FREETZ_BUSYBOX_GZIP_FAST=0
# FREETZ_BUSYBOX_LZOP is not set
# FREETZ_BUSYBOX_RPM2CPIO is not set
# FREETZ_BUSYBOX_RPM is not set
FREETZ_BUSYBOX_TAR=y
FREETZ_BUSYBOX_FEATURE_TAR_CREATE=y
# FREETZ_BUSYBOX_FEATURE_TAR_AUTODETECT is not set
FREETZ_BUSYBOX_FEATURE_TAR_FROM=y
# FREETZ_BUSYBOX_FEATURE_TAR_OLDGNU_COMPATIBILITY is not set
# FREETZ_BUSYBOX_FEATURE_TAR_OLDSUN_COMPATIBILITY is not set
FREETZ_BUSYBOX_FEATURE_TAR_GNU_EXTENSIONS=y
# FREETZ_BUSYBOX_FEATURE_TAR_UNAME_GNAME is not set
# FREETZ_BUSYBOX_FEATURE_TAR_NOPRESERVE_TIME is not set
# FREETZ_BUSYBOX_UNCOMPRESS is not set
# FREETZ_BUSYBOX_UNLZMA is not set
FREETZ_BUSYBOX_UNXZ=y
# FREETZ_BUSYBOX_XZ is not set
# FREETZ_BUSYBOX_UNZIP is not set
# Coreutils
FREETZ_BUSYBOX_BASENAME=y
FREETZ_BUSYBOX_CAT=y
FREETZ_BUSYBOX_DATE=y
FREETZ_BUSYBOX_FEATURE_DATE_ISOFMT=y
# FREETZ_BUSYBOX_FEATURE_DATE_NANO is not set
FREETZ_BUSYBOX_FEATURE_DATE_COMPAT=y
# FREETZ_BUSYBOX_HOSTID is not set
FREETZ_BUSYBOX_ID=y
# FREETZ_BUSYBOX_GROUPS is not set
FREETZ_BUSYBOX_TEST=y
# FREETZ_BUSYBOX_FEATURE_TEST_64 is not set
FREETZ_BUSYBOX_TOUCH=y
FREETZ_BUSYBOX_FEATURE_TOUCH_SUSV3=y
FREETZ_BUSYBOX_TR=y
FREETZ_BUSYBOX_FEATURE_TR_CLASSES=y
FREETZ_BUSYBOX_FEATURE_TR_EQUIV=y
# FREETZ_BUSYBOX_BASE64 is not set
# FREETZ_BUSYBOX_CAL is not set
# FREETZ_BUSYBOX_CATV is not set
FREETZ_BUSYBOX_CHGRP=y
FREETZ_BUSYBOX_CHMOD=y
FREETZ_BUSYBOX_CHOWN=y
FREETZ_BUSYBOX_CHROOT=y
# FREETZ_BUSYBOX_CKSUM is not set
# FREETZ_BUSYBOX_COMM is not set
FREETZ_BUSYBOX_CP=y
FREETZ_BUSYBOX_CUT=y
FREETZ_BUSYBOX_DD=y
FREETZ_BUSYBOX_FEATURE_DD_SIGNAL_HANDLING=y
# FREETZ_BUSYBOX_FEATURE_DD_THIRD_STATUS_LINE is not set
# FREETZ_BUSYBOX_FEATURE_DD_IBS_OBS is not set
FREETZ_BUSYBOX_DF=y
# FREETZ_BUSYBOX_FEATURE_DF_FANCY is not set
FREETZ_BUSYBOX_DIRNAME=y
# FREETZ_BUSYBOX_DOS2UNIX is not set
FREETZ_BUSYBOX_DU=y
FREETZ_BUSYBOX_FEATURE_DU_DEFAULT_BLOCKSIZE_1K=y
FREETZ_BUSYBOX_ECHO=y
FREETZ_BUSYBOX_FEATURE_FANCY_ECHO=y
FREETZ_BUSYBOX_ENV=y
# FREETZ_BUSYBOX_EXPAND is not set
FREETZ_BUSYBOX_EXPR=y
# FREETZ_BUSYBOX_EXPR_MATH_SUPPORT_64 is not set
FREETZ_BUSYBOX_FALSE=y
# FREETZ_BUSYBOX_FOLD is not set
# FREETZ_BUSYBOX_FSYNC is not set
FREETZ_BUSYBOX_HEAD=y
FREETZ_BUSYBOX_FEATURE_FANCY_HEAD=y
# FREETZ_BUSYBOX_INSTALL is not set
FREETZ_BUSYBOX_LN=y
FREETZ_BUSYBOX_LOGNAME=y
FREETZ_BUSYBOX_LS=y
FREETZ_BUSYBOX_FEATURE_LS_FILETYPES=y
FREETZ_BUSYBOX_FEATURE_LS_FOLLOWLINKS=y
FREETZ_BUSYBOX_FEATURE_LS_RECURSIVE=y
FREETZ_BUSYBOX_FEATURE_LS_SORTFILES=y
FREETZ_BUSYBOX_FEATURE_LS_TIMESTAMPS=y
FREETZ_BUSYBOX_FEATURE_LS_USERNAME=y
FREETZ_BUSYBOX_MD5SUM=y
FREETZ_BUSYBOX_MKDIR=y
FREETZ_BUSYBOX_MKFIFO=y
FREETZ_BUSYBOX_MKNOD=y
FREETZ_BUSYBOX_MV=y
# FREETZ_BUSYBOX_NICE is not set
FREETZ_BUSYBOX_NOHUP=y
# FREETZ_BUSYBOX_OD is not set
# FREETZ_BUSYBOX_PRINTENV is not set
FREETZ_BUSYBOX_PRINTF=y
FREETZ_BUSYBOX_PWD=y
# FREETZ_BUSYBOX_READLINK is not set
FREETZ_BUSYBOX_REALPATH=y
FREETZ_BUSYBOX_RM=y
FREETZ_BUSYBOX_RMDIR=y
# FREETZ_BUSYBOX_SEQ is not set
# FREETZ_BUSYBOX_SHA1SUM is not set
# FREETZ_BUSYBOX_SHA256SUM is not set
# FREETZ_BUSYBOX_SHA512SUM is not set
FREETZ_BUSYBOX_SLEEP=y
FREETZ_BUSYBOX_FEATURE_FANCY_SLEEP=y
# FREETZ_BUSYBOX_FEATURE_FLOAT_SLEEP is not set
FREETZ_BUSYBOX_SORT=y
# FREETZ_BUSYBOX_FEATURE_SORT_BIG is not set
# FREETZ_BUSYBOX_SPLIT is not set
FREETZ_BUSYBOX_STAT=y
FREETZ_BUSYBOX_FEATURE_STAT_FORMAT=y
FREETZ_BUSYBOX_STTY=y
# FREETZ_BUSYBOX_SUM is not set
FREETZ_BUSYBOX_SYNC=y
# FREETZ_BUSYBOX_TAC is not set
FREETZ_BUSYBOX_TAIL=y
FREETZ_BUSYBOX_FEATURE_FANCY_TAIL=y
FREETZ_BUSYBOX_TEE=y
FREETZ_BUSYBOX_FEATURE_TEE_USE_BLOCK_IO=y
FREETZ_BUSYBOX_TRUE=y
FREETZ_BUSYBOX_TTY=y
FREETZ_BUSYBOX_UNAME=y
# FREETZ_BUSYBOX_UNEXPAND is not set
FREETZ_BUSYBOX_UNIQ=y
FREETZ_BUSYBOX_USLEEP=y
# FREETZ_BUSYBOX_UUDECODE is not set
# FREETZ_BUSYBOX_UUENCODE is not set
FREETZ_BUSYBOX_WC=y
# FREETZ_BUSYBOX_FEATURE_WC_LARGE is not set
# FREETZ_BUSYBOX_WHOAMI is not set
FREETZ_BUSYBOX_YES=y
# Common options for cp and mv
# FREETZ_BUSYBOX_FEATURE_PRESERVE_HARDLINKS is not set
# Common options for ls, more and telnet
FREETZ_BUSYBOX_FEATURE_AUTOWIDTH=y
# Common options for df, du, ls
FREETZ_BUSYBOX_FEATURE_HUMAN_READABLE=y
# Common options for md5sum, sha1sum, sha256sum, sha512sum
FREETZ_BUSYBOX_FEATURE_MD5_SHA1_SUM_CHECK=y
# Console Utilities
# FREETZ_BUSYBOX_CHVT is not set
# FREETZ_BUSYBOX_FGCONSOLE is not set
FREETZ_BUSYBOX_CLEAR=y
# FREETZ_BUSYBOX_DEALLOCVT is not set
# FREETZ_BUSYBOX_DUMPKMAP is not set
# FREETZ_BUSYBOX_KBD_MODE is not set
# FREETZ_BUSYBOX_LOADFONT is not set
# FREETZ_BUSYBOX_LOADKMAP is not set
# FREETZ_BUSYBOX_OPENVT is not set
FREETZ_BUSYBOX_RESET=y
# FREETZ_BUSYBOX_RESIZE is not set
FREETZ_BUSYBOX_SETCONSOLE=y
# FREETZ_BUSYBOX_SETFONT is not set
# FREETZ_BUSYBOX_SETKEYCODES is not set
FREETZ_BUSYBOX_SETLOGCONS=y
# FREETZ_BUSYBOX_SHOWKEY is not set
# Debian Utilities
# FREETZ_BUSYBOX_MKTEMP is not set
# FREETZ_BUSYBOX_PIPE_PROGRESS is not set
# FREETZ_BUSYBOX_RUN_PARTS is not set
# FREETZ_BUSYBOX_START_STOP_DAEMON is not set
FREETZ_BUSYBOX_WHICH=y
# Editors
# FREETZ_BUSYBOX_PATCH is not set
FREETZ_BUSYBOX_VI=y
FREETZ_BUSYBOX_FEATURE_VI_MAX_LEN=1024
FREETZ_BUSYBOX_FEATURE_VI_8BIT=y
FREETZ_BUSYBOX_FEATURE_VI_COLON=y
FREETZ_BUSYBOX_FEATURE_VI_YANKMARK=y
FREETZ_BUSYBOX_FEATURE_VI_SEARCH=y
# FREETZ_BUSYBOX_FEATURE_VI_REGEX_SEARCH is not set
FREETZ_BUSYBOX_FEATURE_VI_USE_SIGNALS=y
FREETZ_BUSYBOX_FEATURE_VI_DOT_CMD=y
FREETZ_BUSYBOX_FEATURE_VI_READONLY=y
FREETZ_BUSYBOX_FEATURE_VI_SETOPTS=y
FREETZ_BUSYBOX_FEATURE_VI_SET=y
FREETZ_BUSYBOX_FEATURE_VI_WIN_RESIZE=y
FREETZ_BUSYBOX_FEATURE_VI_ASK_TERMINAL=y
FREETZ_BUSYBOX_FEATURE_VI_OPTIMIZE_CURSOR=y
FREETZ_BUSYBOX_AWK=y
# FREETZ_BUSYBOX_FEATURE_AWK_LIBM is not set
FREETZ_BUSYBOX_CMP=y
# FREETZ_BUSYBOX_DIFF is not set
# FREETZ_BUSYBOX_ED is not set
FREETZ_BUSYBOX_SED=y
FREETZ_BUSYBOX_FEATURE_ALLOW_EXEC=y
# Finding Utilities
FREETZ_BUSYBOX_FIND=y
FREETZ_BUSYBOX_FEATURE_FIND_PRINT0=y
FREETZ_BUSYBOX_FEATURE_FIND_MTIME=y
FREETZ_BUSYBOX_FEATURE_FIND_MMIN=y
FREETZ_BUSYBOX_FEATURE_FIND_PERM=y
FREETZ_BUSYBOX_FEATURE_FIND_TYPE=y
FREETZ_BUSYBOX_FEATURE_FIND_XDEV=y
FREETZ_BUSYBOX_FEATURE_FIND_MAXDEPTH=y
FREETZ_BUSYBOX_FEATURE_FIND_NEWER=y
FREETZ_BUSYBOX_FEATURE_FIND_INUM=y
FREETZ_BUSYBOX_FEATURE_FIND_EXEC=y
FREETZ_BUSYBOX_FEATURE_FIND_USER=y
FREETZ_BUSYBOX_FEATURE_FIND_GROUP=y
FREETZ_BUSYBOX_FEATURE_FIND_NOT=y
FREETZ_BUSYBOX_FEATURE_FIND_DEPTH=y
FREETZ_BUSYBOX_FEATURE_FIND_PAREN=y
FREETZ_BUSYBOX_FEATURE_FIND_SIZE=y
FREETZ_BUSYBOX_FEATURE_FIND_PRUNE=y
# FREETZ_BUSYBOX_FEATURE_FIND_DELETE is not set
FREETZ_BUSYBOX_FEATURE_FIND_PATH=y
FREETZ_BUSYBOX_FEATURE_FIND_REGEX=y
# FREETZ_BUSYBOX_FEATURE_FIND_LINKS is not set
FREETZ_BUSYBOX_GREP=y
FREETZ_BUSYBOX_FEATURE_GREP_EGREP_ALIAS=y
FREETZ_BUSYBOX_FEATURE_GREP_FGREP_ALIAS=y
FREETZ_BUSYBOX_FEATURE_GREP_CONTEXT=y
FREETZ_BUSYBOX_XARGS=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_CONFIRMATION=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_QUOTES=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_TERMOPT=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_ZERO_TERM=y
# Init Utilities
# FREETZ_BUSYBOX_BOOTCHARTD is not set
FREETZ_BUSYBOX_HALT=y
FREETZ_BUSYBOX_INIT=y
FREETZ_BUSYBOX_FEATURE_USE_INITTAB=y
FREETZ_BUSYBOX_FEATURE_KILL_REMOVED=y
FREETZ_BUSYBOX_FEATURE_KILL_DELAY=0
# FREETZ_BUSYBOX_FEATURE_INIT_SCTTY is not set
FREETZ_BUSYBOX_FEATURE_INIT_SYSLOG=y
# FREETZ_BUSYBOX_FEATURE_EXTRA_QUIET is not set
# FREETZ_BUSYBOX_FEATURE_INIT_COREDUMPS is not set
# FREETZ_BUSYBOX_FEATURE_INITRD is not set
FREETZ_BUSYBOX_INIT_TERMINAL_TYPE="linux"
# FREETZ_BUSYBOX_MESG is not set
# Login/Password Management Utilities
# FREETZ_BUSYBOX_ADD_SHELL is not set
# FREETZ_BUSYBOX_REMOVE_SHELL is not set
FREETZ_BUSYBOX_FEATURE_SHADOWPASSWDS=y
# FREETZ_BUSYBOX_USE_BB_PWD_GRP is not set
FREETZ_BUSYBOX_USE_BB_CRYPT=y
# FREETZ_BUSYBOX_USE_BB_CRYPT_SHA is not set
FREETZ_BUSYBOX_ADDUSER=y
# FREETZ_BUSYBOX_FEATURE_CHECK_NAMES is not set
FREETZ_BUSYBOX_FIRST_SYSTEM_ID=100
FREETZ_BUSYBOX_LAST_SYSTEM_ID=999
FREETZ_BUSYBOX_ADDGROUP=y
FREETZ_BUSYBOX_FEATURE_ADDUSER_TO_GROUP=y
FREETZ_BUSYBOX_DELUSER=y
FREETZ_BUSYBOX_DELGROUP=y
FREETZ_BUSYBOX_FEATURE_DEL_USER_FROM_GROUP=y
# FREETZ_BUSYBOX_GETTY is not set
FREETZ_BUSYBOX_LOGIN=y
# FREETZ_BUSYBOX_LOGIN_SESSION_AS_CHILD is not set
# FREETZ_BUSYBOX_PAM is not set
# FREETZ_BUSYBOX_LOGIN_SCRIPTS is not set
# FREETZ_BUSYBOX_FEATURE_NOLOGIN is not set
# FREETZ_BUSYBOX_FEATURE_SECURETTY is not set
FREETZ_BUSYBOX_PASSWD=y
FREETZ_BUSYBOX_FEATURE_PASSWD_WEAK_CHECK=y
FREETZ_BUSYBOX_CRYPTPW=y
# FREETZ_BUSYBOX_CHPASSWD is not set
FREETZ_BUSYBOX_FEATURE_DEFAULT_PASSWD_ALGO="des"
# FREETZ_BUSYBOX_SU is not set
# FREETZ_BUSYBOX_SULOGIN is not set
# FREETZ_BUSYBOX_VLOCK is not set
# Linux Ext2 FS Progs
# FREETZ_BUSYBOX_CHATTR is not set
# FREETZ_BUSYBOX_FSCK is not set
# FREETZ_BUSYBOX_LSATTR is not set
# FREETZ_BUSYBOX_TUNE2FS is not set
# Linux Module Utilities
# FREETZ_BUSYBOX_MODINFO is not set
# FREETZ_BUSYBOX_MODPROBE_SMALL is not set
FREETZ_BUSYBOX_INSMOD=y
FREETZ_BUSYBOX_RMMOD=y
FREETZ_BUSYBOX_LSMOD=y
FREETZ_BUSYBOX_FEATURE_LSMOD_PRETTY_2_6_OUTPUT=y
FREETZ_BUSYBOX_MODPROBE=y
# FREETZ_BUSYBOX_FEATURE_MODPROBE_BLACKLIST is not set
# FREETZ_BUSYBOX_DEPMOD is not set
# Options common to multiple modutils
# FREETZ_BUSYBOX_FEATURE_2_4_MODULES is not set
# FREETZ_BUSYBOX_FEATURE_INSMOD_TRY_MMAP is not set
FREETZ_BUSYBOX_FEATURE_CHECK_TAINTED_MODULE=y
# FREETZ_BUSYBOX_FEATURE_MODUTILS_ALIAS is not set
# FREETZ_BUSYBOX_FEATURE_MODUTILS_SYMBOLS is not set
FREETZ_BUSYBOX_DEFAULT_MODULES_DIR="/lib/modules"
FREETZ_BUSYBOX_DEFAULT_DEPMOD_FILE="modules.dep"
# Linux System Utilities
# FREETZ_BUSYBOX_BLOCKDEV is not set
# FREETZ_BUSYBOX_MDEV is not set
# FREETZ_BUSYBOX_REV is not set
# FREETZ_BUSYBOX_ACPID is not set
# FREETZ_BUSYBOX_BLKID is not set
FREETZ_BUSYBOX_DMESG=y
FREETZ_BUSYBOX_FEATURE_DMESG_PRETTY=y
# FREETZ_BUSYBOX_FBSET is not set
# FREETZ_BUSYBOX_FDFLUSH is not set
# FREETZ_BUSYBOX_FDFORMAT is not set
# FREETZ_BUSYBOX_FDISK is not set
# FREETZ_BUSYBOX_FINDFS is not set
# FREETZ_BUSYBOX_FLOCK is not set
# FREETZ_BUSYBOX_FREERAMDISK is not set
# FREETZ_BUSYBOX_FSCK_MINIX is not set
# FREETZ_BUSYBOX_MKFS_EXT2 is not set
# FREETZ_BUSYBOX_MKFS_MINIX is not set
# FREETZ_BUSYBOX_MKFS_REISER is not set
# FREETZ_BUSYBOX_MKFS_VFAT is not set
FREETZ_BUSYBOX_GETOPT=y
FREETZ_BUSYBOX_FEATURE_GETOPT_LONG=y
# FREETZ_BUSYBOX_HEXDUMP is not set
# FREETZ_BUSYBOX_HWCLOCK is not set
# FREETZ_BUSYBOX_IPCRM is not set
# FREETZ_BUSYBOX_IPCS is not set
# FREETZ_BUSYBOX_LOSETUP is not set
# FREETZ_BUSYBOX_LSPCI is not set
# FREETZ_BUSYBOX_LSUSB is not set
FREETZ_BUSYBOX_MKSWAP=y
# FREETZ_BUSYBOX_FEATURE_MKSWAP_UUID is not set
FREETZ_BUSYBOX_MORE=y
FREETZ_BUSYBOX_MOUNT=y
# FREETZ_BUSYBOX_FEATURE_MOUNT_FAKE is not set
FREETZ_BUSYBOX_FEATURE_MOUNT_VERBOSE=y
# FREETZ_BUSYBOX_FEATURE_MOUNT_HELPERS is not set
# FREETZ_BUSYBOX_FEATURE_MOUNT_LABEL is not set
FREETZ_BUSYBOX_FEATURE_MOUNT_NFS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_CIFS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_FLAGS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_FSTAB=y
FREETZ_BUSYBOX_PIVOT_ROOT=y
# FREETZ_BUSYBOX_RDATE is not set
# FREETZ_BUSYBOX_RDEV is not set
# FREETZ_BUSYBOX_READPROFILE is not set
# FREETZ_BUSYBOX_RTCWAKE is not set
# FREETZ_BUSYBOX_SCRIPT is not set
# FREETZ_BUSYBOX_SCRIPTREPLAY is not set
# FREETZ_BUSYBOX_SETARCH is not set
FREETZ_BUSYBOX_SWAPONOFF=y
# FREETZ_BUSYBOX_FEATURE_SWAPON_PRI is not set
# FREETZ_BUSYBOX_SWITCH_ROOT is not set
FREETZ_BUSYBOX_UMOUNT=y
FREETZ_BUSYBOX_FEATURE_UMOUNT_ALL=y
# Common options for mount/umount
FREETZ_BUSYBOX_FEATURE_MOUNT_LOOP=y
FREETZ_BUSYBOX_FEATURE_MOUNT_LOOP_CREATE=y
# FREETZ_BUSYBOX_FEATURE_MTAB_SUPPORT is not set
# FREETZ_BUSYBOX_VOLUMEID is not set
# Miscellaneous Utilities
# FREETZ_BUSYBOX_CONSPY is not set
# FREETZ_BUSYBOX_LESS is not set
# FREETZ_BUSYBOX_NANDWRITE is not set
# FREETZ_BUSYBOX_NANDDUMP is not set
# FREETZ_BUSYBOX_SETSERIAL is not set
# FREETZ_BUSYBOX_UBIATTACH is not set
# FREETZ_BUSYBOX_UBIDETACH is not set
# FREETZ_BUSYBOX_UBIMKVOL is not set
# FREETZ_BUSYBOX_UBIRMVOL is not set
# FREETZ_BUSYBOX_UBIRSVOL is not set
# FREETZ_BUSYBOX_UBIUPDATEVOL is not set
FREETZ_BUSYBOX_ADJTIMEX=y
# FREETZ_BUSYBOX_BBCONFIG is not set
# FREETZ_BUSYBOX_BEEP is not set
# FREETZ_BUSYBOX_CHAT is not set
# FREETZ_BUSYBOX_CHRT is not set
FREETZ_BUSYBOX_CROND=y
# FREETZ_BUSYBOX_FEATURE_CROND_D is not set
# FREETZ_BUSYBOX_FEATURE_CROND_CALL_SENDMAIL is not set
FREETZ_BUSYBOX_FEATURE_CROND_DIR="/var/spool/cron"
FREETZ_BUSYBOX_CRONTAB=y
# FREETZ_BUSYBOX_DC is not set
# FREETZ_BUSYBOX_DEVFSD is not set
# FREETZ_BUSYBOX_FEATURE_DEVFS is not set
# FREETZ_BUSYBOX_DEVMEM is not set
# FREETZ_BUSYBOX_EJECT is not set
# FREETZ_BUSYBOX_FBSPLASH is not set
# FREETZ_BUSYBOX_FLASHCP is not set
# FREETZ_BUSYBOX_FLASH_LOCK is not set
# FREETZ_BUSYBOX_FLASH_UNLOCK is not set
# FREETZ_BUSYBOX_FLASH_ERASEALL is not set
# FREETZ_BUSYBOX_IONICE is not set
# FREETZ_BUSYBOX_INOTIFYD is not set
# FREETZ_BUSYBOX_HDPARM is not set
FREETZ_BUSYBOX_MAKEDEVS=y
# FREETZ_BUSYBOX_FEATURE_MAKEDEVS_LEAF is not set
FREETZ_BUSYBOX_FEATURE_MAKEDEVS_TABLE=y
# FREETZ_BUSYBOX_MAN is not set
# FREETZ_BUSYBOX_MICROCOM is not set
# FREETZ_BUSYBOX_MOUNTPOINT is not set
# FREETZ_BUSYBOX_MT is not set
# FREETZ_BUSYBOX_RAIDAUTORUN is not set
# FREETZ_BUSYBOX_READAHEAD is not set
# FREETZ_BUSYBOX_RFKILL is not set
# FREETZ_BUSYBOX_RX is not set
# FREETZ_BUSYBOX_SETSID is not set
# FREETZ_BUSYBOX_STRINGS is not set
# FREETZ_BUSYBOX_TASKSET is not set
FREETZ_BUSYBOX_TIME=y
# FREETZ_BUSYBOX_TIMEOUT is not set
# FREETZ_BUSYBOX_TTYSIZE is not set
# FREETZ_BUSYBOX_VOLNAME is not set
# FREETZ_BUSYBOX_WATCHDOG is not set
# Networking Utilities
# FREETZ_BUSYBOX_NAMEIF is not set
# FREETZ_BUSYBOX_NBDCLIENT is not set
# FREETZ_BUSYBOX_NC is not set
FREETZ_BUSYBOX_PING=y
FREETZ_BUSYBOX_PING6=y
FREETZ_BUSYBOX_FEATURE_FANCY_PING=y
FREETZ_BUSYBOX_STUN_IP=y
FREETZ_BUSYBOX_WHOIS=y
FREETZ_BUSYBOX_FEATURE_IPV6=y
# FREETZ_BUSYBOX_FEATURE_UNIX_LOCAL is not set
FREETZ_BUSYBOX_FEATURE_PREFER_IPV4_ADDRESS=y
# FREETZ_BUSYBOX_VERBOSE_RESOLUTION_ERRORS is not set
FREETZ_BUSYBOX_ARP=y
FREETZ_BUSYBOX_ARPING=y
FREETZ_BUSYBOX_BRCTL=y
# FREETZ_BUSYBOX_FEATURE_BRCTL_FANCY is not set
# FREETZ_BUSYBOX_DNSD is not set
FREETZ_BUSYBOX_ETHER_WAKE=y
# FREETZ_BUSYBOX_FAKEIDENTD is not set
# FREETZ_BUSYBOX_FTPD is not set
# FREETZ_BUSYBOX_FTPGET is not set
# FREETZ_BUSYBOX_FTPPUT is not set
FREETZ_BUSYBOX_HOSTNAME=y
FREETZ_BUSYBOX_HTTPD=y
# FREETZ_BUSYBOX_FEATURE_HTTPD_RANGES is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_USE_SENDFILE is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_SETUID is not set
FREETZ_BUSYBOX_FEATURE_HTTPD_BASIC_AUTH=y
FREETZ_BUSYBOX_FEATURE_HTTPD_AUTH_MD5=y
FREETZ_BUSYBOX_FEATURE_HTTPD_CGI=y
FREETZ_BUSYBOX_FEATURE_HTTPD_CONFIG_WITH_SCRIPT_INTERPR=y
# FREETZ_BUSYBOX_FEATURE_HTTPD_SET_REMOTE_PORT_TO_ENV is not set
FREETZ_BUSYBOX_FEATURE_HTTPD_ENCODE_URL_STR=y
# FREETZ_BUSYBOX_FEATURE_HTTPD_ERROR_PAGES is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_PROXY is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_GZIP is not set
FREETZ_BUSYBOX_IFCONFIG=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_STATUS=y
# FREETZ_BUSYBOX_FEATURE_IFCONFIG_SLIP is not set
# FREETZ_BUSYBOX_FEATURE_IFCONFIG_MEMSTART_IOADDR_IRQ is not set
FREETZ_BUSYBOX_FEATURE_IFCONFIG_HW=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_BROADCAST_PLUS=y
# FREETZ_BUSYBOX_IFENSLAVE is not set
# FREETZ_BUSYBOX_IFPLUGD is not set
FREETZ_BUSYBOX_IFUPDOWN=y
FREETZ_BUSYBOX_IFUPDOWN_IFSTATE_PATH="/var/run/ifstate"
# FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IP is not set
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IFCONFIG_BUILTIN=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IPV4=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IPV6=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_MAPPING=y
# FREETZ_BUSYBOX_FEATURE_IFUPDOWN_EXTERNAL_DHCP is not set
# FREETZ_BUSYBOX_INETD is not set
FREETZ_BUSYBOX_IP=y
FREETZ_BUSYBOX_FEATURE_IP_ADDRESS=y
FREETZ_BUSYBOX_FEATURE_IP_LINK=y
FREETZ_BUSYBOX_FEATURE_IP_ROUTE=y
FREETZ_BUSYBOX_FEATURE_IP_TUNNEL=y
FREETZ_BUSYBOX_FEATURE_IP_RULE=y
# FREETZ_BUSYBOX_FEATURE_IP_SHORT_FORMS is not set
# FREETZ_BUSYBOX_FEATURE_IP_RARE_PROTOCOLS is not set
# FREETZ_BUSYBOX_IPCALC is not set
FREETZ_BUSYBOX_NETSTAT=y
# FREETZ_BUSYBOX_FEATURE_NETSTAT_WIDE is not set
FREETZ_BUSYBOX_FEATURE_NETSTAT_PRG=y
# FREETZ_BUSYBOX_NSLOOKUP is not set
# FREETZ_BUSYBOX_NTPD is not set
# FREETZ_BUSYBOX_PSCAN is not set
FREETZ_BUSYBOX_ROUTE=y
# FREETZ_BUSYBOX_SLATTACH is not set
# FREETZ_BUSYBOX_TCPSVD is not set
FREETZ_BUSYBOX_TELNET=y
FREETZ_BUSYBOX_FEATURE_TELNET_TTYPE=y
FREETZ_BUSYBOX_FEATURE_TELNET_AUTOLOGIN=y
FREETZ_BUSYBOX_TELNETD=y
FREETZ_BUSYBOX_FEATURE_TELNETD_STANDALONE=y
# FREETZ_BUSYBOX_FEATURE_TELNETD_INETD_WAIT is not set
FREETZ_BUSYBOX_TFTP=y
# FREETZ_BUSYBOX_TFTPD is not set
# Common options for tftp/tftpd
FREETZ_BUSYBOX_FEATURE_TFTP_GET=y
FREETZ_BUSYBOX_FEATURE_TFTP_PUT=y
FREETZ_BUSYBOX_FEATURE_TFTP_BLOCKSIZE=y
# FREETZ_BUSYBOX_FEATURE_TFTP_PROGRESS_BAR is not set
# FREETZ_BUSYBOX_TFTP_DEBUG is not set
FREETZ_BUSYBOX_TRACEROUTE=y
FREETZ_BUSYBOX_TRACEROUTE6=y
FREETZ_BUSYBOX_FEATURE_TRACEROUTE_VERBOSE=y
FREETZ_BUSYBOX_FEATURE_TRACEROUTE_SOURCE_ROUTE=y
FREETZ_BUSYBOX_FEATURE_TRACEROUTE_USE_ICMP=y
# FREETZ_BUSYBOX_TUNCTL is not set
# FREETZ_BUSYBOX_UDHCPC6 is not set
# FREETZ_BUSYBOX_UDHCPD is not set
# FREETZ_BUSYBOX_UDHCPC is not set
# FREETZ_BUSYBOX_UDPSVD is not set
FREETZ_BUSYBOX_VCONFIG=y
FREETZ_BUSYBOX_WGET=y
# FREETZ_BUSYBOX_FEATURE_WGET_STATUSBAR is not set
# FREETZ_BUSYBOX_FEATURE_WGET_AUTHENTICATION is not set
# FREETZ_BUSYBOX_FEATURE_WGET_TIMEOUT is not set
# FREETZ_BUSYBOX_ZCIP is not set
# Print Utilities
# FREETZ_BUSYBOX_LPD is not set
# FREETZ_BUSYBOX_LPR is not set
# FREETZ_BUSYBOX_LPQ is not set
# Mail Utilities
# FREETZ_BUSYBOX_MAKEMIME is not set
# FREETZ_BUSYBOX_POPMAILDIR is not set
# FREETZ_BUSYBOX_REFORMIME is not set
# FREETZ_BUSYBOX_SENDMAIL is not set
# Process Utilities
# FREETZ_BUSYBOX_IOSTAT is not set
# FREETZ_BUSYBOX_LSOF is not set
# FREETZ_BUSYBOX_MPSTAT is not set
# FREETZ_BUSYBOX_NMETER is not set
# FREETZ_BUSYBOX_PMAP is not set
# FREETZ_BUSYBOX_POWERTOP is not set
# FREETZ_BUSYBOX_PSTREE is not set
# FREETZ_BUSYBOX_PWDX is not set
# FREETZ_BUSYBOX_SMEMCAP is not set
FREETZ_BUSYBOX_UPTIME=y
FREETZ_BUSYBOX_FREE=y
# FREETZ_BUSYBOX_FUSER is not set
FREETZ_BUSYBOX_KILL=y
FREETZ_BUSYBOX_KILLALL=y
# FREETZ_BUSYBOX_KILLALL5 is not set
# FREETZ_BUSYBOX_PGREP is not set
FREETZ_BUSYBOX_PIDOF=y
FREETZ_BUSYBOX_FEATURE_PIDOF_SINGLE=y
FREETZ_BUSYBOX_FEATURE_PIDOF_OMIT=y
# FREETZ_BUSYBOX_PKILL is not set
FREETZ_BUSYBOX_PS=y
FREETZ_BUSYBOX_FEATURE_PS_WIDE=y
FREETZ_BUSYBOX_FEATURE_PS_LONG=y
# FREETZ_BUSYBOX_RENICE is not set
FREETZ_BUSYBOX_BB_SYSCTL=y
FREETZ_BUSYBOX_TOP=y
FREETZ_BUSYBOX_FEATURE_TOP_CPU_USAGE_PERCENTAGE=y
FREETZ_BUSYBOX_FEATURE_TOP_CPU_GLOBAL_PERCENTS=y
# FREETZ_BUSYBOX_FEATURE_TOP_SMP_CPU is not set
# FREETZ_BUSYBOX_FEATURE_TOP_DECIMALS is not set
# FREETZ_BUSYBOX_FEATURE_TOP_SMP_PROCESS is not set
# FREETZ_BUSYBOX_FEATURE_TOPMEM is not set
# FREETZ_BUSYBOX_FEATURE_SHOW_THREADS is not set
# FREETZ_BUSYBOX_WATCH is not set
# Runit Utilities
# FREETZ_BUSYBOX_RUNSV is not set
# FREETZ_BUSYBOX_RUNSVDIR is not set
# FREETZ_BUSYBOX_SV is not set
# FREETZ_BUSYBOX_SVLOGD is not set
# FREETZ_BUSYBOX_CHPST is not set
# FREETZ_BUSYBOX_SETUIDGID is not set
# FREETZ_BUSYBOX_ENVUIDGID is not set
# FREETZ_BUSYBOX_ENVDIR is not set
# FREETZ_BUSYBOX_SOFTLIMIT is not set
# Shells
FREETZ_BUSYBOX_ASH=y
FREETZ_BUSYBOX_ASH_BASH_COMPAT=y
# FREETZ_BUSYBOX_ASH_IDLE_TIMEOUT is not set
FREETZ_BUSYBOX_ASH_JOB_CONTROL=y
FREETZ_BUSYBOX_ASH_ALIAS=y
FREETZ_BUSYBOX_ASH_GETOPTS=y
FREETZ_BUSYBOX_ASH_BUILTIN_ECHO=y
FREETZ_BUSYBOX_ASH_BUILTIN_PRINTF=y
FREETZ_BUSYBOX_ASH_BUILTIN_TEST=y
FREETZ_BUSYBOX_ASH_CMDCMD=y
# FREETZ_BUSYBOX_ASH_MAIL is not set
FREETZ_BUSYBOX_ASH_OPTIMIZE_FOR_SIZE=y
# FREETZ_BUSYBOX_ASH_RANDOM_SUPPORT is not set
FREETZ_BUSYBOX_ASH_EXPAND_PRMT=y
# FREETZ_BUSYBOX_CTTYHACK is not set
# FREETZ_BUSYBOX_HUSH is not set
# FREETZ_BUSYBOX_MSH is not set
FREETZ_BUSYBOX_FEATURE_SH_IS_ASH=y
# FREETZ_BUSYBOX_FEATURE_SH_IS_NONE is not set
# FREETZ_BUSYBOX_FEATURE_BASH_IS_ASH is not set
FREETZ_BUSYBOX_FEATURE_BASH_IS_NONE=y
FREETZ_BUSYBOX_SH_MATH_SUPPORT=y
# FREETZ_BUSYBOX_SH_MATH_SUPPORT_64 is not set
# FREETZ_BUSYBOX_FEATURE_SH_EXTRA_QUIET is not set
FREETZ_BUSYBOX_FEATURE_SH_STANDALONE=y
FREETZ_BUSYBOX_FEATURE_SH_NOFORK=y
# FREETZ_BUSYBOX_FEATURE_SH_HISTFILESIZE is not set
# System Logging Utilities
FREETZ_BUSYBOX_SYSLOGD=y
FREETZ_BUSYBOX_FEATURE_ROTATE_LOGFILE=y
FREETZ_BUSYBOX_FEATURE_REMOTE_LOG=y
# FREETZ_BUSYBOX_FEATURE_SYSLOGD_DUP is not set
# FREETZ_BUSYBOX_FEATURE_SYSLOGD_CFG is not set
FREETZ_BUSYBOX_FEATURE_SYSLOGD_READ_BUFFER_SIZE=256
FREETZ_BUSYBOX_FEATURE_IPC_SYSLOG=y
FREETZ_BUSYBOX_FEATURE_IPC_SYSLOG_BUFFER_SIZE=16
FREETZ_BUSYBOX_LOGREAD=y
FREETZ_BUSYBOX_FEATURE_LOGREAD_REDUCED_LOCKING=y
FREETZ_BUSYBOX_KLOGD=y
FREETZ_BUSYBOX_FEATURE_KLOGD_KLOGCTL=y
FREETZ_BUSYBOX_LOGGER=y
# External processing
# EXTERNAL_ENABLED is not set
# Mod customizations ---------------------
# Web Interface
FREETZ_LANG_DE=y
# FREETZ_LANG_EN is not set
FREETZ_LANG_STRING="de"
FREETZ_SECURITY_LEVEL=0
FREETZ_STYLE_COLORED=y
# FREETZ_STYLE_GREY is not set
FREETZ_STYLE="colored"
# Freetz skins
FREETZ_SKIN_legacy=y
# FREETZ_SKIN_newfreetz is not set
# FREETZ_SKIN_phoenix is not set
FREETZ_FAVICON_NONE=y
# FREETZ_FAVICON_ATOMPHIL is not set
# FREETZ_FAVICON_CUMA is not set
# FREETZ_FAVICON_DSL123 is not set
# FREETZ_FAVICON_HANSOLO is not set
FREETZ_FAVICON_STRING="none"
FREETZ_TAGGING_NONE=y
# FREETZ_TAGGING_CUMA is not set
FREETZ_TAGGING_STRING="none"
# Additional image/box information
# FREETZ_REMOVE_BOX_INFO is not set
# FREETZ_REMOVE_FREETZ_INFO is not set
FREETZ_DEVELOPER_VERSION_STRING=y
# FREETZ_MODIFY_AVM_VERSION is not set
FREETZ_USER_DEFINED_COMMENT=""
# FREETZ_CUSTOM_IMAGE_NAME is not set
# FREETZ_CUSTOM_IMAGE_NAME_PREFIX is not set
FREETZ_CREATE_SEPARATE_OPTIONS_CFG=y
FREETZ_REMOVE_DOT_CONFIG=y
# Build system ---------------------------
# Toolchain options
# FREETZ_DOWNLOAD_TOOLCHAIN is not set
FREETZ_BUILD_TOOLCHAIN=y
FREETZ_GCC_3_4_COMPILED_KERNEL=y
# FREETZ_GCC_4_6_COMPILED_KERNEL is not set
FREETZ_UCLIBC_0_9_28_BASED_BOX=y
# FREETZ_UCLIBC_0_9_29_BASED_BOX is not set
# FREETZ_UCLIBC_0_9_32_BASED_BOX is not set
# Kernel toolchain options ----------------------------------
FREETZ_KERNEL_COMPILER_GCC_3_4=y
FREETZ_KERNEL_GCC_VERSION="3.4.6"
FREETZ_KERNEL_BINUTILS_VERSION="2.18"
# Target toolchain options ----------------------------------
FREETZ_TARGET_UCLIBC_VERSION_0_9_28=y
FREETZ_TARGET_COMPILER_GCC_4_6=y
# FREETZ_TARGET_COMPILER_GCC_4_7 is not set
FREETZ_STDCXXLIB_USE_UCLIBCXX=y
# FREETZ_STDCXXLIB_USE_GNULIBSTDCXX is not set
FREETZ_TARGET_UCLIBC_VERSION="0.9.28"
FREETZ_TARGET_GCC_VERSION="4.6.3"
FREETZ_GNULIBSTDCXX_VERSION="6.0.16"
FREETZ_STDCXXLIB="uclibcxx"
FREETZ_TARGET_BINUTILS_VERSION="2.22"
FREETZ_TARGET_UCLIBC_REF="mod"
FREETZ_TARGET_CFLAGS="-Os -pipe -Wa,--trap"
# FREETZ_TARGET_TOOLCHAIN_AVM_COMPATIBLE is not set
# FREETZ_TARGET_UCLIBC_REDUCED_LOCALE_SET is not set
# FREETZ_TARGET_NLS is not set
FREETZ_TARGET_LFS=y
# FREETZ_TARGET_TOOLCHAIN is not set
# Both kernel and target toolchain related options ----------
FREETZ_TOOLCHAIN_MINIMIZE_REQUIRED_GLIBC_VERSION=y
# FREETZ_TOOLCHAIN_32BIT is not set
FREETZ_TOOLCHAIN_CCACHE=y
# Build system options
FREETZ_VERBOSITY_LEVEL=2
FREETZ_SIZEINFO_COMPRESSED=y
FREETZ_SIZEINFO_UNCOMPRESSED=y
FREETZ_JLEVEL=4
FREETZ_CHECK_CHANGED=y
# FREETZ_BACKUP_CONFIG_CACHE is not set
# Firmware packaging (fwmod) options
# FREETZ_FWMOD_SKIP_UNPACK is not set
# FREETZ_FWMOD_SKIP_MODIFY is not set
# FREETZ_FWMOD_SKIP_PACK is not set
# FREETZ_FWMOD_SDK is not set
# FREETZ_FWMOD_USBROOT is not set
# FREETZ_FWMOD_NFSROOT is not set
# Other ----------------------------------
# Strip options
FREETZ_STRIP_BINARIES=y
FREETZ_STRIP_LIBRARIES=y
# FREETZ_STRIP_MODULES_NONE is not set
# FREETZ_STRIP_MODULES_FREETZ is not set
FREETZ_STRIP_MODULES_ALL=y
FREETZ_STRIP_SCRIPTS=y
# SquashFS options
# CAUTION: SquashFS block sizes >64 KB can cause an unstable box due to extensive memory usage
# FREETZ_SQUASHFS_BLOCKSIZE_ORIG is not set
# FREETZ_SQUASHFS_BLOCKSIZE_65536 is not set
FREETZ_SQUASHFS_BLOCKSIZE_131072=y
# FREETZ_SQUASHFS_BLOCKSIZE_262144 is not set
# FREETZ_SQUASHFS_BLOCKSIZE_524288 is not set
# FREETZ_SQUASHFS_BLOCKSIZE_1048576 is not set
FREETZ_SQUASHFS_BLOCKSIZE=131072
# Override options
FREETZ_DL_SITE_USER=""
# FREETZ_DL_OVERRIDE is not set
FREETZ_DL_KERNEL_SITE=""
FREETZ_DL_KERNEL_SOURCE="${FREETZ_AVM_VERSION_STRING}-release_kernel.tar.xz"
FREETZ_DL_KERNEL_SOURCE_MD5="b86ab70776619055a24947013f6b581c"
FREETZ_DL_SITE="@AVM/fritzbox.fon_wlan_7050/firmware"
FREETZ_DL_SOURCE="fritz.box_fon_wlan_7050.14.04.33.image"
FREETZ_DL_SOURCE_MD5="7fabbf13889cf66b6f2dd47fe472a265"
# FREETZ_HAS_AVM_LABOR is not set
# FREETZ_HAS_AVM_PIGLET is not set
FREETZ_HAS_AVM_PTY_SUPPORT=y
# FREETZ_HAS_AVM_CDROM_ISO is not set
# FREETZ_HAS_AVM_AURA_USB is not set
# FREETZ_HAS_AVM_MINID is not set
# FREETZ_HAS_AVM_NTFS is not set
# FREETZ_HAS_AVM_IPV6 is not set
# FREETZ_HAS_AVM_WEBDAV is not set
# FREETZ_HAS_AVM_INETD is not set
# FREETZ_HAS_AVM_EXT3 is not set
FREETZ_HAS_AVM_TR069=y
# FREETZ_HAS_AVM_TR069_FWUPDATE is not set
# FREETZ_HAS_AVM_CHRONYD is not set
# FREETZ_HAS_AVM_DECT is not set
# FREETZ_HAS_AVM_OPENSSL_LIBS is not set
# FREETZ_HAS_AVM_LSOF is not set
# FREETZ_HAS_AVM_SOCAT is not set
# FREETZ_HAS_AVM_NAS is not set
# FREETZ_HAS_AVM_MYFRITZ is not set
FREETZ_HAS_AVM_PHONE=y
# FREETZ_HAS_AVM_STRACE is not set
# FREETZ_HAS_AVM_TAM is not set
# FREETZ_HAS_AVM_UDEV is not set
# FREETZ_HAS_UPDATE_FILESYSTEM_IMAGE is not set
FREETZ_HAS_USB_CLIENT=y
# FREETZ_HAS_AVM_USB_HOST is not set
# FREETZ_HAS_AVM_E2FSPROGS is not set
FREETZ_HAS_AVM_WLAN=y
# FREETZ_HAS_AVM_UMTS is not set
# FREETZ_HAS_AVM_JFFS2 is not set
# FREETZ_HAS_AVM_JUNK_BYTES is not set
# FREETZ_HAS_AVM_MICROVOIP_DSL is not set
# FREETZ_HAS_AVM_ANNEX_A_AND_B is not set
# FREETZ_HAS_AVM_MULTI_ANNEX is not set
# FREETZ_HAS_AVM_RAMZSWAP is not set
# FREETZ_HAS_AVM_AHA is not set
FREETZ_INSTALL_BASE=y
FREETZ_REPLACE_BUSYBOX=y
FREETZ_KERNEL_REF_4MB=y
FREETZ_KERNEL_REF="4mb"
FREETZ_TARGET_ARCH_LE=y
FREETZ_TARGET_ARCH="mipsel"
FREETZ_TARGET_CROSS="mipsel-linux-uclibc-"
FREETZ_KERNEL_CROSS="mipsel-unknown-linux-gnu-"
FREETZ_FILESYSTEM_MTD_SIZE=0
FREETZ_REPLACE_KERNEL_AVAILABLE=y
FREETZ_AVM_VERSION_04_33=y
FREETZ_AVM_VERSION_STRING="04.33"
FREETZ_TYPE_PREFIX="7050"
Ich denke, es ist dies hier:
checking for lzo1x_1_15_compress in -llzo2... [B](cached)[/B] no
checking for lzo1x_1_15_compress in -llzo... [B](cached)[/B] no
Lösch mal den cache "/usr/src/freetz-trunk/source/target-mipsel_uClibc-0.9.28/config.cache". Hilft das?
Try removing config.cache (hammer-style) or remove liblzo related lines from it.
figo12
