OpenVPN chroot problem
SystemR89
20 Feb 2009
Yesterday I recompiled freetz-trunk to include openvpn. I need to connect 3 computers to fritz!box so I used a certificate based configuration. For some unknown reason with fritz setting I can connect from other pc to my fritzbox, I receive the ip from "openvpn dhcp", but I can't ping or connect any machine thought the tunnel. Instead copying freetz's openvpn.conf and commenting out the line: "chroot /tmp/openvpn" solve the problem and I can use the tunnel successfully.
Why with chroot doesn't works?
Do you have a connect script?
Is there a difference in the routing tables?
No, but I found the problem.
It's not the chroot option but "bridge to LAN" that is executed in the init.d script, unmarking it everything works fine!
stego88
