[Gelöst] OpenVPN mit Zertifikaten hängt beim Verbindungsaufbau
Hunter06
20 Jun 2008
Mit statischen Keys lief das schon alles super. Wollte jetzt mit Zertifikaten eine Verbindung aufbauen. Klappt aber nicht.
Server: Fritzbox 7170
Client: Windows 7
Zertifikate unter Windows mittels easy-rsa erstellt:
Server
#  OpenVPN 2.1 Config, Mon Nov 12 09:14:15 CET 2012
proto udp
dev tun
ca /tmp/flash/openvpn/ca.crt
cert /tmp/flash/openvpn/box.crt
key /tmp/flash/openvpn/box.key
dh /tmp/flash/openvpn/dh.pem
crl-verify /etc/crl.pem
tls-server
port 1194
ifconfig 10.0.0.1 10.0.0.2
mode server
ifconfig-pool 10.0.0.3 10.0.0.8
push "route 10.0.0.1"
route 10.0.0.0 255.255.255.0
tun-mtu 1500
mssfix
verb 3
daemon
cipher BF-CBC
comp-lzo
keepalive 10 120
status /var/log/openvpn.log
chroot /tmp/openvpn
user openvpn
group openvpn
persist-tun
persist-key
Client
remote meinserver
proto udp
port 1194
dev tun
ifconfig 10.0.0.2 10.0.0.1
tls-client
ca ca.crt
cert client1.crt
key client1.key
pull
tun-mtu 1500
verb 3
cipher BF-CBC
comp-lzo
persist-tun
persist-key
Verbindungsaufbau
Mon Nov 12 10:11:41 2012 OpenVPN 2.2.2 Win32-MSVC++ [SSL] [LZO2] [PKCS11] built on Dec 15 2011
Mon Nov 12 10:11:41 2012 WARNING: using --pull/--client and --ifconfig together is probably not what you want
Mon Nov 12 10:11:41 2012 WARNING: No server certificate verification method has been enabled.  See http://openvpn.net/howto.html#mitm for more info.
Mon Nov 12 10:11:41 2012 NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Mon Nov 12 10:11:42 2012 LZO compression initialized
Mon Nov 12 10:11:42 2012 Control Channel MTU parms [ L:1542 D:138 EF:38 EB:0 ET:0 EL:0 ]
Mon Nov 12 10:11:42 2012 Socket Buffers: R=[8192->8192] S=[8192->8192]
Mon Nov 12 10:11:45 2012 Data Channel MTU parms [ L:1542 D:1450 EF:42 EB:135 ET:0 EL:0 AF:3/1 ]
Mon Nov 12 10:11:45 2012 Local Options hash (VER=V4): '41690919'
Mon Nov 12 10:11:45 2012 Expected Remote Options hash (VER=V4): '530fdded'
Mon Nov 12 10:11:45 2012 UDPv4 link local (bound): [undef]:1194
Mon Nov 12 10:11:45 2012 UDPv4 link remote: xx.xx.xx.xx:1194
Mon Nov 12 10:11:45 2012 TLS: Initial packet from xx.xx.xx.xx:1194, sid=7df52940 d16962f4
Mon Nov 12 10:11:46 2012 VERIFY OK: depth=1, /C=xx/ST=xx/L=xxx/O=OpenVPN/OU=OpenVPN/CN=Wurzelzertifikat/name=xxxx/[email protected]
Mon Nov 12 10:11:46 2012 VERIFY OK: depth=0, /C=xx/ST=xx/L=xxx/O=OpenVPN/OU=OpenVPN/CN=OpenVPN-Server/name=xxxx/[email protected]
Danach kommt ein Timeout und es geht von vorne los.
Was mach ich falsch?
Hunter06
Was sagt denn der Server beim Aufbau? Stimmt dort z.B. das Datum?
Auf dem Server stimmt das Datum und die Uhrzeit:
Nov 12 11:46:42 fritz authpriv.info dropbear[2113]: Child connection from xx.xxx.xx.xxx:51879
Nov 12 11:46:44 fritz daemon.notice openvpn[2112]: OpenVPN 2.2.2 mipsel-linux [SSL] [LZO2] [MH] [IPv6 payload 20110424-2 (2.2RC2)] built on May 21 2012
Nov 12 11:46:44 fritz daemon.warn openvpn[2112]: NOTE: OpenVPN 2.1 requires '--script-security 2' or higher to call user-defined scripts or executables
Nov 12 11:46:45 fritz daemon.notice openvpn[2112]: Diffie-Hellman initialized with 1024 bit key
Nov 12 11:46:45 fritz daemon.notice openvpn[2112]: TLS-Auth MTU parms [ L:1542 D:138 EF:38 EB:0 ET:0 EL:0 ]
Nov 12 11:46:45 fritz daemon.notice openvpn[2112]: Socket Buffers: R=[110592->131072] S=[110592->131072]
Nov 12 11:46:45 fritz daemon.notice openvpn[2112]: TUN/TAP device tun0 opened
Nov 12 11:46:45 fritz daemon.notice openvpn[2112]: TUN/TAP TX queue length set to 100
Nov 12 11:46:45 fritz daemon.notice openvpn[2112]: do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Nov 12 11:46:45 fritz daemon.notice openvpn[2112]: /sbin/ifconfig tun0 10.0.0.1 pointopoint 10.0.0.2 mtu 1500
Nov 12 11:46:45 fritz daemon.notice openvpn[2112]: /sbin/route add -net 10.0.0.0 netmask 255.255.255.0 gw 10.0.0.2
Nov 12 11:46:45 fritz daemon.notice openvpn[2112]: Data Channel MTU parms [ L:1542 D:1450 EF:42 EB:135 ET:0 EL:0 AF:3/1 ]
Nov 12 11:46:45 fritz daemon.notice openvpn[2118]: chroot to '/tmp/openvpn' and cd to '/' succeeded
Nov 12 11:46:45 fritz daemon.notice openvpn[2118]: GID set to openvpn
Nov 12 11:46:45 fritz daemon.notice openvpn[2118]: UID set to openvpn
Nov 12 11:46:45 fritz daemon.notice openvpn[2118]: UDPv4 link local (bound): [undef]
Nov 12 11:46:45 fritz daemon.notice openvpn[2118]: UDPv4 link remote: [undef]
Nov 12 11:46:45 fritz daemon.notice openvpn[2118]: MULTI: multi_init called, r=256 v=256
Nov 12 11:46:45 fritz daemon.notice openvpn[2118]: IFCONFIG POOL: base=10.0.0.0 size=3, ipv6=0
Nov 12 11:46:45 fritz daemon.notice openvpn[2118]: Initialization Sequence Completed
Nov 12 11:46:45 fritz user.notice EXTERNAL: Starting openvpn ... done.
Nov 12 11:46:47 fritz user.notice EXTERNAL: Starting external finished.
Nov 12 11:46:52 fritz authpriv.notice dropbear[2113]: Pubkey auth succeeded for 'root' with key md5  from xx.xxx.xx.xxx:51879
Nov 12 11:47:02 fritz daemon.notice openvpn[2118]: MULTI: multi_create_instance called
Nov 12 11:47:02 fritz daemon.notice openvpn[2118]: xx.xxx.xx.xxx:1194 Re-using SSL/TLS context
Nov 12 11:47:02 fritz daemon.notice openvpn[2118]: xx.xxx.xx.xxx:1194 LZO compression initialized
Nov 12 11:47:02 fritz daemon.notice openvpn[2118]: xx.xxx.xx.xxx:1194 Control Channel MTU parms [ L:1542 D:138 EF:38 EB:0 ET:0 EL:0 ]
Nov 12 11:47:02 fritz daemon.notice openvpn[2118]: xx.xxx.xx.xxx:1194 Data Channel MTU parms [ L:1542 D:1450 EF:42 EB:135 ET:0 EL:0 AF:3/1 ]
Nov 12 11:47:02 fritz daemon.notice openvpn[2118]: xx.xxx.xx.xxx:1194 TLS: Initial packet from [AF_INET]xx.xxx.xx.xxx:1194, sid=4427d0ac 6c09753b
Nov 12 11:47:04 fritz daemon.err openvpn[2118]: xx.xxx.xx.xxx:1194 CRL: cannot read CRL from file /etc/crl.pem
Nov 12 11:47:04 fritz daemon.notice openvpn[2118]: xx.xxx.xx.xxx:1194 Exiting
Nov 12 11:47:04 fritz daemon.notice openvpn[2118]: xx.xxx.xx.xxx:1194 /sbin/route del -net 10.0.0.0 netmask 255.255.255.0
Nov 12 11:47:04 fritz daemon.warn openvpn[2118]: xx.xxx.xx.xxx:1194 ERROR: Linux route delete command failed: could not execute external program
Nov 12 11:47:04 fritz daemon.notice openvpn[2118]: xx.xxx.xx.xxx:1194 Closing TUN/TAP interface
Nov 12 11:47:04 fritz daemon.notice openvpn[2118]: xx.xxx.xx.xxx:1194 /sbin/ifconfig tun0 0.0.0.0
Nov 12 11:47:04 fritz daemon.warn openvpn[2118]: xx.xxx.xx.xxx:1194 Linux ip addr del failed: could not execute external program
Ich frage mich, warum er die CRL aus /etc nimmt? Ist das nicht die Datei mit den zurückgezogenen Zertifikaten? Die ist bei mir eigentlich unter /tmp/flash/openvpn/crl.pem.
Das /etc ist readonly Filesystem.
Hast du das vielleicht "von Hand" eingetragen (in den Experteneinstellungen)? Welche Freetz-Version nutzt du?
EDIT: Nee, "/etc" stimmt schon. Die Datei wird nach /tmp/openvpn/etc kopiert, weil diese Datei nach dem "chroot" eingelesen wird.
Und nach dem chroot wird etwas in "/tmp/openvpn/etc" als "/etc" angesprochen...
Prüfst du bitte mal, ob die Datei in /tmp/openvpn/etc liegt?!?
Das chroot habe ich eben auch überlesen ;-) Die Datei war da nicht drin. Hab sie jetzt manuell von /tmp/flash/openvpn rüberkopiert!.
Jetzt läuft es.
Danke!!
Gerne. Eigentlich sollte aber auch das Startskript die Datei dorthin kopieren?!?
Callendaar
