[Problem] OpenVPN: Verbindung zu Server wird nicht aufgebaut
cmonty14
22 Jan 2007
Hallo!
Ich beschäftige mich mit dem Problem, dass keine Verbindung zum OpenVPN-Server aufgebaut wird.
Im Aufruf-Protokoll des Clients finde ich:
user@pc1-gigabyte /etc/openvpn $ openvpn client.conf
Tue Nov 12 22:28:14 2013 OpenVPN 2.3.2 i486-pc-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [eurephia] [MH] [IPv6] built on Jun 21 2013
Tue Nov 12 22:28:14 2013 WARNING: file 'pc1-gigabyte.key' is group or others accessible
Tue Nov 12 22:28:14 2013 Socket Buffers: R=[180224->131072] S=[180224->131072]
Tue Nov 12 22:28:14 2013 UDPv4 link local: [undef]
Tue Nov 12 22:28:14 2013 UDPv4 link remote: [AF_INET]91.89.254.147:1194
Tue Nov 12 22:29:14 2013 TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Tue Nov 12 22:29:14 2013 TLS Error: TLS handshake failed
Tue Nov 12 22:29:14 2013 SIGUSR1[soft,tls-error] received, process restarting
Tue Nov 12 22:29:14 2013 Restart pause, 2 second(s)
Tue Nov 12 22:29:16 2013 Socket Buffers: R=[180224->131072] S=[180224->131072]
Tue Nov 12 22:29:16 2013 UDPv4 link local: [undef]
Tue Nov 12 22:29:16 2013 UDPv4 link remote: [AF_INET]91.89.254.147:1194
^CTue Nov 12 22:29:38 2013 event_wait : Interrupted system call (code=4)
Tue Nov 12 22:29:38 2013 SIGINT[hard,] received, process exiting
Auf dem Server, der im Debug-Modus läuft, finde ich:
root@net2-FB7390:/var/mod/root# cat /var/tmp/debug_openvpn.out
Tue Nov 12 22:29:16 2013 TLS Error: cannot locate HMAC in incoming packet from [AF_INET]91.89.254.147:41751
Tue Nov 12 22:29:18 2013 TLS Error: cannot locate HMAC in incoming packet from [AF_INET]91.89.254.147:41751
Tue Nov 12 22:29:22 2013 TLS Error: cannot locate HMAC in incoming packet from [AF_INET]91.89.254.147:41751
Tue Nov 12 22:29:30 2013 TLS Error: cannot locate HMAC in incoming packet from [AF_INET]91.89.254.147:41751
Hier noch eine Beschreibung der Netzwerk-Architektur:
WAN <---> FB7570 <---> FB7390 <---> LAN
Auf der FB7570 ist ein Port-Forwarding von Port 1194 auf FB7390 eingerichtet.
Muss auf der FB7570 auch eine Firewall-Regel vorhanden sein, die den Port 1194 freigibt?
Auf der FB7390 ist ein Port-Forwarding von Port 1194 auf sich selbst eingerichtet und eine Firewall-Regel vorhanden.
Wie kann ich die Ursache des Fehlers weiter analysieren?
MIch würde zunächst interessieren, bis zu welchem Netzwerk-Gerät die Kommunikation vom Client funktioniert.
THX
Trivial: Die Fehlermeldung bei Google eingeben -> 1. Treffer ein Verweis auf dieses Forum -> Fehler beheben (TLS Auth dürfte der Fehler sein).
In der Zukunft: Poste bitte nicht nur die Fehlermeldung sondern vor allem die Configs, die zu einem Fehler führen, damit dir jemand helfen kann.
Dein Hinweis zur Fehlerursache trifft mit hoher Wahrscheinlichkeit zu.
Nach meinem Verständnis muss die Schlüsseldatei "static.key" auf dem Client verfügbar sein und in der client.conf zur TLS-Authentifizierung berücksichtigt werden.
Oder man deaktiviert TLS-Authentifizierung auf dem Server.
Ist dies soweit korrekt?
Welchen Vorteil bietet die Aktivierung von TLS-Authentifizierung?
THX
vapep43913
