OpenVPN
BirdyB
21 Nov 2004
Hallo, ich habe meine FB5012 hinter einem netgear-router hängen und gemäß der anleitung auf: http://www.wehavemorefun.de/fritzbox/OpenVPN einen OpenVPN-Server eingerichtet.
Die Portweiterleitung auf Port 1194 ist auch eingerichtet.
Unter MacOS habe ich Tunnelblick installiert und tunnelblick sagt auch, dass ich mit dem OpenVPN-Server verbunden bin.
Leider habe ich weder Zugriff auf die FB, noch auf das restliche LAN.
Die Ausgabe von Tunnelblick lautet wie folgt:
Tue 07/03/07 04:32 PM: IMPORTANT: OpenVPN's default port number is now 1194
Tue 07/03/07 04:32 PM: WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Tue 07/03/07 04:32 PM: WARNING: file 'client1.key' is group or others accessible
Tue 07/03/07 04:32 PM: LZO compression initialized
Tue 07/03/07 04:32 PM: Control Channel MTU parms [ L:1544 D:140 EF:40 EB:0 ET:0 EL:0 ]
Tue 07/03/07 04:32 PM: Data Channel MTU parms [ L:1544 D:1450 EF:44 EB:135 ET:0 EL:0 AF:3/1 ]
Tue 07/03/07 04:32 PM: Local Options hash (VER=V4): '69109d17'
Tue 07/03/07 04:32 PM: Expected Remote Options hash (VER=V4): 'c0103fa8'
Tue 07/03/07 04:32 PM: Attempting to establish TCP connection with 87.234.140.155:1194
Tue 07/03/07 04:32 PM: TCP connection established with 87.234.140.155:1194
Tue 07/03/07 04:32 PM: TCPv4_CLIENT link local: [undef]
Tue 07/03/07 04:32 PM: TCPv4_CLIENT link remote: 87.234.140.155:1194
Tue 07/03/07 04:32 PM: TLS: Initial packet from 87.234.140.155:1194
Tue 07/03/07 04:32 PM: VERIFY OK: depth=1
Tue 07/03/07 04:32 PM: VERIFY OK: depth=0
Tue 07/03/07 04:32 PM: WARNING: 'dev-type' is used inconsistently
Tue 07/03/07 04:32 PM: WARNING: 'link-mtu' is used inconsistently
Tue 07/03/07 04:32 PM: WARNING: 'tun-mtu' is used inconsistently
Tue 07/03/07 04:32 PM: Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Tue 07/03/07 04:32 PM: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Tue 07/03/07 04:32 PM: Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Tue 07/03/07 04:32 PM: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Tue 07/03/07 04:32 PM: Control Channel: TLSv1
Tue 07/03/07 04:32 PM: [naw-berti.dyndns.org] Peer Connection Initiated with 87.234.140.155:1194
Tue 07/03/07 04:32 PM: SENT CONTROL [naw-berti.dyndns.org]: 'PUSH_REQUEST' (status=1)
Tue 07/03/07 04:32 PM: PUSH: Received control message: 'PUSH_REPLY
Tue 07/03/07 04:32 PM: OPTIONS IMPORT: timers and/or timeouts modified
Tue 07/03/07 04:32 PM: TUN/TAP device /dev/tun0 opened
Tue 07/03/07 04:32 PM: Initialization Sequence Completed
Tue 07/03/07 04:33 PM: write to TUN/TAP : Input/output error (code=5)
Tue 07/03/07 04:35 PM: write to TUN/TAP : Input/output error (code=5)
Hat jemand eine Idee, wie ich das Problem lösen kann?
hier hat jemand das gleiche Problem, such mal nach der Meldung "write to TUN/TAP" auf der Seite. Die Lösung verstehe ich allerdings mangels OSX Kenntnissen nicht
linus1991
