opt_asterisk300V1.3-fuer-fli4l-3.x.x/3.1.x-i586
Netview
IPPF-Promi
1 Apr 2004
Neu:
bristuff-1q
0.3.0-PRE-1p
    - updated to asterisk 1.2.9.1
    - libpri fix for P2P BRI in Belgium
    - fixed clip/clir in libgsmat
    - fixed uniquename asterisk.conf option
0.3.0-PRE-1p
    - fixed answer confirmation for chan_zap (Dial(ZAP/g1c/...)
      (DTMF detection was disabled.)
    - added ztpty to zaptel
asterisk 1.2.9.1
libpri 1.2.3
zaptel 1.2.6
chan-capi-cm rev. 339
chan-sccp vom 8.4.06
Neu:
bristuff-1s
0.3.0-PRE-1s
    - added "FASTBUSYONBUSY" Makefile option to libpri
    - fixed "BAD CRC" error on layer 1 activation in TE mode
    - added hardware bridging support to qozap
    - moved debugging messages in qozap to debug > 0
    - updated to asterisk 1.2.10
    - libgsmat fix for "network registration rejected"
    - removed "callstate fix"
    - autoanswer "exception flag" fix
    - MG2 is now the default echo canceler (zaptel)
    - audio will not pass through userspace if transfercapablity is digital (app_dial)
    - hangup cause fix when using priindication=passthrough
0.3.0-PRE-1r
    - fixed devicestates for peer register/unregister
    - moved extensionstates to AMI privilege "extensionstatus"
    - added "Hint:" to extensionstatus event (AMI)
    - added "gsm [no] debug channel <channel>" to chan_zap
    - modified autoanswer to re-register dynamic extensions on reload
    - fixed drivers to compile with latest 2.6 kernels
    - improved libpri/chan_zap communication for BRI_CPE and BRI_CPE_PTMP
asterisk 1.2.10
libpri 1.2.3
zaptel 1.2.6
chan-capi-cm rev. 381
Neu: opt_asterisk300V1.1-fuer-fli4l-3.x.x / bristuff-0.3.0-PRE-1u
0.3.0-PRE-1u asterisk 1.2.13
0.3.0-PRE-1t
    - fixed "removed "callstate fix" fix
    - added experimental support to display the correct callerid on a SNOM phone
      after making an attended transfer to that phone
    - introducing res_esel (Extension State Export Logic)
    - updated to asterisk 1.2.12.1, zaptel 1.2.9.1
0.3.0-PRE-1s
0.3.0-PRE-1r
asterisk 1.2.13
libpri 1.2.4
zaptel 1.2.10
zaphfc-florz-12-patch
chan-capi-cm rev. 393
openssl.0.9.8d
Könnte ich von Euch mal ein feedback zu 'opt_asterisk300V1.1-fuer-fli4l-3.x.x/3.1.x-i586' erhalten - läuft alles soweit?
Hallo Netview,
läuft leider nicht wie gewünscht.
intern (HFC) kann gewählt werden.
extern (Fritzclassic) leider rauswärts nicht, reinwärts nicht.
habe ein paar Daten angehängt.
was könnte ich beitragen
Router Fli4l-3.0.1
ISDN: Fritz!Classic
ISDN2: ACER HFC
asterisk.txt
OPT_ASTERISK='yes'
ASTERISK_CAPI='yes'
ASTERISK_GENERATE_CAPI='yes'
ASTERISK_CAPI_MSN='5125362'
ASTERISK_HFC='yes'
ASTERISK_X100P='no'
ASTERISK_X100P_NUM='1'
ASTERISK_GENERATE_ZAP='yes'
ASTERISK_GETCALLERID='no'
ASTERISK_GENERATE_MODULES='yes'
ASTERISK_GENERATE_SIP='no'
ASTERISK_EXTERNHOST='test.dyndns.org'
ASTERISK_IP_NET='192.168.227.2 255.255.255.0'
ASTERISK_SIP_N='0'
ASTERISK_SIP_1_PROVIDER='1und1'
ASTERISK_SIP_1_USER='test1'
ASTERISK_SIP_1_PASSWORD='test1'
ASTERISK_SIP_1_HOSTNAME='sip.1und1.de'
ASTERISK_SIP_2_PROVIDER='sipgate'
ASTERISK_SIP_2_USER='test2'
ASTERISK_SIP_2_PASSWORD='test2'
ASTERISK_SIP_2_HOSTNAME='sip.sipgate.de'
ASTERISK_GENERATE_EXTENSIONS='yes'
ASTERISK_INT_MSN_N='1'
ASTERISK_INT_1_MSN='9999'
ASTERISK_INT_1_VM_PASSWORD='4711'
ASTERISK_INT_2_MSN='5678'
ASTERISK_INT_2_VM_PASSWORD='911'
BOOT:
Starting Asterisk ... (/etc/rc.d/rc997.asterisk)
device /dev/hda1 is already mounted rw as /boot
device /dev/hda2 found, remounting rw as /opt
EXT3 FS 2.4-0.9.19, 19 August 2002 on ide0(3,2), internal journal
ln: /var/lib/asterisk/sounds/vm: No such file or directory
In: /var/lib/asterisk/sounds/voicemail: No such file or directory
ln: /var/lib/asterisk/astdb: No such file or directory
Zapata Telephony Interface Registered on major 196
Zaptel Version: 1.2.10 Echo Canceller: MG2
Using /lib/modules/2.4.32/kernel/misc/zaptel.o
zaphfc: jitterbuffer size: 1
PCI: Found IRQ 10 for device 00:0d.0
PCI: Sharing IRQ 10 with 01:00.0
zaphfc: CCD/Billion/Asuscom 2BD0 configured at mem 0xd0a02800 fifo 0xcd968000(0x
d968000) IRQ 10 HZ 100
zaphfc: Card 0 configured for NT mode
zaphfc: Card 0 configured for master mode
zaphfc: 1 hfc-pci card(s) in this box.
Using /lib/modules/2.4.32/kernel/misc/zaphfc.o
/dev/hda:
setting unmaskirq to 1 (on)
unmaskirq = 1 (on)
Zaptel ConfiguraRegistered tone zone 3 (Netherlands)
tion
SPAN 1: CCS/ AMI Build-out: 399-533 feet (DSX-1)
Channel map:
Channel 01: Clear channel (Default) (Slaves: 01)
Channel 02: Clear channel (Default) (Slaves: 02)
Channel 03: D-channel (Default) (Slaves: 03)
3 channels configured.
Changing signalling on channel 1 from Unused to Clear channel
Changing signalling on channel 2 from Unused to Clear channel
Changing signalling on channel 3 from Unused to HDLC with FCS check
remounting device /dev/hda2 ro on /opt
Starting link
finished Starting Asterisk ... (/etc/rc.d/rc997.asterisk)
erneuter Reboot
device /dev/hda2 found, already mounted rw as /boot
/etc/rc.d/rc997.asterisk: 1: cannot create /usr/local/bin/asterisk: Read-only fi
le system
chmod: /usr/local/bin/asterisk: Read-only file system
le system
le system
le system
/etc/rc.d/rc997.asterisk: 1: cannot create /usr/local/bin/register: Read-only fi
le system
chmod: /usr/local/bin/register: Read-only file system
le system
le system
le system
chmod: /etc/asterisk/asterisk.conf: Read-only file system
zaphfc: CCD/Billion/Asuscom 2BD0 configured at mem 0xd0a02800 fifo 0xcf5d0000(0x
f5d0000) IRQ 10 HZ 100
/dev/hda:
unmaskirq = 1 (on)
Zaptel Configuration
Channel map:
Channel 01: Registered tone zone 3 (Netherlands)
Was sagt 'capi info' im cli?
wie sieht deine capi.conf aus?
Dir ist bekannt, dass in der extensions.conf bei der chan-capi so gewählt werden muss:
exten => _.,1,Set(CALLERID(number)=12345) ; 12345 abghehende MSN
exten => _.,2,Dial(Capi/contr1/$exten,,,)
Hallo Netview,
capi info sagt ->
Contr1: 2 B channels total, 2 B channels free.
capi conf sieht folgendermaßen aus ->
[general]
nationalprefix=0
internationalprefix=00
rxgain=0.8
txgain=0.8
language=de
[ISDN1]
isdnmode=did
incomingmsn=*
controller=1
softdtmf=on
accountcode=
context=default
devices=2
extensions.conf ausschnitt ->
[external-ISDN]
exten => _9.,1,Set(CALLERID(number)=5125362)
exten => _9.,2,Dial(CAPI/contr1/${EXTEN:1},,Tt)
exten => _9.,3,Congestion
(5125362 ist die abgehende msn)
sieht alles ziemlich normal aus!
starte asterisk mal mit 'asterisk -dddvvvr' und poste mal den debug-output!
Hallo Netview,
asterisk im debug-modus ...
router 3.0.1 # asterisk -dddvvvr
Parsing /etc/asterisk/asterisk.conf
Parsing /etc/asterisk/extconfig.conf
== Parsing '/etc/asterisk/asterisk.conf': Found
== Parsing '/etc/asterisk/extconfig.conf': Found
Asterisk 1.2.13-BRIstuffed-0.3.0-PRE-1u, Copyright (C) 1999 - 2006 Digium, Inc. and others.
Created by Mark Spencer <[email protected]>
Asterisk comes with ABSOLUTELY NO WARRANTY; type 'show warranty' for details.
This is free software, with components licensed under the GNU General Public
License version 2 and other licenses; you are welcome to redistribute it under
certain conditions. Type 'show license' for details.
Connected to Asterisk 1.2.13-BRIstuffed-0.3.0-PRE-1u currently running on router (pid = 5482)
Verbosity is at least 3
Core debug was 0 and is now 3
router*CLI>
nun externruf
-- Starting simple switch on 'Zap/2-1'
-- Accepting overlap voice call from '9999' to '<unspecified>' on channel 0/2, span 1
-- Executing Set("Zap/2-1", "CALLERID(number)=5125362") in new stack
-- Executing Dial("Zap/2-1", "CAPI/contr1/0160handy||Tt") in new stack
-- Called contr1/0160handy
habe so langsam den verdacht die ISA Fritzclassic ist K.O.
werde dass mal überprüfen, bevor ich dich länger beanspruche.
Tja - im Moment kann ich auch nicht mehr dazu sagen, als dass ich bereits einige positive Rückmeldungen erhalten habe bzgl. der Funktionsfähigkeit des opts!
Es kann daher eigentlich wirklich nur die Hardware sein?!
Hast du mal eine manuelle Einwahl via ISDN probiert, oder hast du das opt faxrcv zum Testen?
Gruss
Netview
Und Junghanns hat schon wieder einen fix nachgeschoben:
bristuff-0.3.0-PRE-1v
    - fixed segfault introduced by 0.3.0-PRE-1u in chan_sip
opt bereits upgedated - bitte neu downloaden!
Hallo Holger,
habe noch eine kleine Unschönheit gefunden.
Ich wollte die aktuellste Version wegen des segfalut fixes einspielen, bin aber schon beim entpacken gescheitert.
Diverse Dateien (z.B. register.exe) sind rechtemäßig nur auf read gesetzt. Damit darf man auch ale Eigentümer die Datei nicht ersetzen.
Also erst mal ein chmod u+w über das Verzeichnis jagen, und dann entpacken.
Wäre schön, wenn du die Rechte gleich im Download auf rw setzen würdest ;)
Die Laufzeitrechte werden ja ohnehin auf dem fli4l gesteuert.
Gruß Henning
Hallo Henning!
Kann ich nicht ganz nachvollziehen!
Die Recht sind auf 555 gesetzt und normalerweise wird das opt mit mkfli4l erstellt und hochgeladen - hat eigentlich immer funktioniert!
Machst du das anders?
Gruss
Holger
PS: bin gerade beim backen der kernel-2.6 Treiber und habe allerdings damit Probleme (dazu gibt es in der fli4l.dev-Gruppe schon eine Anfrage).
Vielleicht hast du ja eine Idee dazu?
Hallo Holger,
es geht bei dem Rechteproblem nicht um den Betrieb auf dem fli4l. Das erzeugen mit mkfli4l funktioniert problemlos und richtig.
Ich setzte aber auch auf dem Rechner, auf dem ich fli4l baue Linux ein. Dabei befinden sich die entpackten Dateien meinetwegen unter /home/henning/fli4l. Wenn ich das erste Mal das opt_asterisk entpacke läuft noch alles problemlos.
Im Falle des Patches, bzw. des aktualisierten Gesamtpaketes gibt es dann die Probleme. Bei ersten entpacken wurden einige Dateien nur mit read Recht angelegt. Wenn ich jetzt das neue Paket in das vorhandene Verzeichnis entpacke, werden die 'alten' Dateien normalerweise ja einfach überschrieben.
Da einige Dateien (wegen der Vorgängerversion) aber nur read Rechte besitzen, können sie natürlich nicht überschrieben werden.
Als Konsequenz muss man sich erst mal als root anmelden, dann die betroffenen Dateien entweder löschen oder mit chmod u+w um Schreibrechte ergänzen.
Danach kann man die neue Version wie gewünscht drüber bügeln.
Es müssten also nur die Dateirechte im opt_asterisk alle um 'writeable' erweitert werden, und das Problem taucht (beim nächsten Mal) nicht mehr auf.
Hoffe ich das dieses Mal verständlicher rüber bringen konnte.
Gruß Henning
Hallo Henning!
Ok - hab es jetzt kapiert und die Rechte alle korrigiert!
Gruss
Holger
Hallo Netview,
ich habe Schwierigkeiten, das opt zu installieren.
Habe eine fli4l 3.1.1 neu installiert, mit dem Kernel 2.6
Es ist eine HFC Karte und eine Fritz Karte eingebaut.
Wenn der fli4 nach der Installation des Asterisk opt neu gestartet wird
fällt der beim Auspacken des opts während des boots in eine Endlosschleife,
Produziert dabei jede Menge Zeilen.
Das passiert bei extract opt from tar.
Wo kann ich da wohl suchen?
Habe schon mal versucht CAPI und HFC in der astertsik.txt auf no zu setzen,
brachte keine Änderung.
Da nach so einem Test neu installiert werden muß, dauern die Versuche..
Es würde mich auch sehr interessieren, wie du für den fli das komplieren des
Asterisk machst.
MFG
Ro
Du müsstest mal diese Meldungen per imonc im syslog einfangen und hier posten sonst kann ich dazu nichts sagen :-(
molto22
