[PATCH] tor-0.2.2.10-alpha
make
15 Feb 2008
Anbei ein Patch auf die aktuelle Tor-Version. Der Patch ist gegen die aktuelle Trunk-Revision (4496).
Das Changelog listet folgende Änderungen:
Changes in version 0.2.2.10-alpha - 2010-03-07
  o Major bugfixes:
    - Fix a regression from our patch for bug 1244 that caused relays
      to guess their IP address incorrectly if they didn't set Address
      in their torrc and/or their address fails to resolve. Bugfix on
      0.2.2.9-alpha; fixes bug 1269.
  o Major features (performance):
    - Directory authorities now compute consensus weightings that instruct
      clients how to weight relays flagged as Guard, Exit, Guard+Exit,
      and no flag. Clients that use these weightings will distribute
      network load more evenly across these different relay types. The
      weightings are in the consensus so we can change them globally in
      the future. Extra thanks to "outofwords" for finding some nasty
      security bugs in the first implementation of this feature.
  o Minor features (performance):
    - Always perform router selections using weighted relay bandwidth,
      even if we don't need a high capacity circuit at the time. Non-fast
      circuits now only differ from fast ones in that they can use relays
      not marked with the Fast flag. This "feature" could turn out to
      be a horrible bug; we should investigate more before it goes into
      a stable release.
  o Minor features:
    - Allow disabling building of the manpages. Skipping the manpage
      speeds up the build considerably.
  o Minor bugfixes (on 0.2.2.x):
    - Fix a memleak in the EXTENDCIRCUIT logic. Spotted by coverity.
      Bugfix on 0.2.2.9-alpha.
    - Disallow values larger than INT32_MAX for PerConnBWRate|Burst
      config option. Bugfix on 0.2.2.7-alpha.
    - Ship the asciidoc-helper file in the tarball, so that people can
      build from source if they want to, and touching the .1.txt files
      doesn't break the build. Bugfix on 0.2.2.9-alpha.
  o Minor bugfixes (on 0.2.1.x or earlier):
    - Fix a dereference-then-NULL-check sequence when publishing
      descriptors. Bugfix on 0.2.1.5-alpha. Discovered by ekir; fixes
      bug 1255.
    - Fix another dereference-then-NULL-check sequence. Bugfix on
      0.2.1.14-rc. Discovered by ekir; fixes bug 1256.
    - Make sure we treat potentially not NUL-terminated strings correctly.
      Bugfix on 0.1.1.13-alpha. Discovered by rieo; fixes bug 1257.
  o Code simplifications and refactoring:
    - Fix some urls in the exit notice file and make it XHTML1.1 strict
      compliant. Based on a patch from Christian Kujau.
    - Don't use sed in asciidoc-helper anymore.
    - Make the build process fail if asciidoc cannot be found and
      building with asciidoc isn't disabled.
Lassen wir die manpages mitbauen?
MfG Oliver
In der neuen Version definitiv nicht. Die Option dafür, --disable-asciidoc, wird im Patch in tor.mk gesetzt.
rehe992
