Patton 4114 FXO Config für 4 Analoganschlüsse
mp3joker
17 Dez 2006
Nachdem ich jetzt die letzten Tage mich mit meinem Patton beschäftigt habe möchte ich hier nun dass Resultat veröffentlichen. Ich hoffe dass es jemandem vielleicht weiterhilft.
Rahmendaten:
Patton 4114 mit V5.1
Asteriskserver : 172.20.0.2
DNS Server: 172.20.0.1
Gatway: 192.168.10.254
(Gatway hängt über VPN an Asterisk durch 2*Draytek)
# SN4114/JO/EUI                                                  #
# R5.1 2008-07-14 H323 SIP FXS FXO                               #
# 2008-08-25T01:38:16                                            #
# SN/00A0XXXXXXXX                                                #
# Generated configuration file                                   #
cli version 3.20
dns-client server 172.20.0.1
webserver port 80 language en
sntp-client
sntp-client server primary de.pool.ntp.org port 123 version 4
system
  ic voice 0
    low-bitrate-codec g729
profile ppp default
profile call-progress-tone defaultDialtone
  play 1 1000 425 -6
profile call-progress-tone defaultAlertingtone
  play 1 800 425 -13
  pause 2 3200
profile call-progress-tone defaultBusytone
  play 1 400 425 -7
  pause 2 400
profile call-progress-tone defaultReleasetone
  play 1 400 425 -7
  pause 2 400
profile call-progress-tone defaultCongestiontone
  play 1 400 425 -7
  pause 2 400
profile tone-set default
profile voip default
  codec 1 g711ulaw64k rx-length 20 tx-length 20
  codec 2 g711alaw64k rx-length 20 tx-length 20
  fax transmission 1 relay t38-udp
profile pstn default
profile sip default
profile aaa default
  method 1 local
  method 2 none
context ip router
  interface IF_IP_LAN
    ipaddress 192.168.10.252 255.255.255.0
    tcp adjust-mss rx mtu
    tcp adjust-mss tx mtu
context ip router
  route 0.0.0.0 0.0.0.0 192.168.10.254 0 traffic-class default
  route 0.0.0.0 0.0.0.0 192.168.10.254 0 traffic-class local-default
  route 0.0.0.0 0.0.0.0 192.168.10.254 0 traffic-class local-voice
context cs switch
  routing-table called-e164 RT_FXO_0_TO_SIP_0
    route T2 dest-service HG_FXO_0_TO_SIP_0
  routing-table called-e164 RT_FXO_1_TO_SIP_1
    route T2 dest-service HG_FXO_1_TO_SIP_1
  routing-table called-e164 RT_FXO_2_TO_SIP_2
    route T2 dest-service HG_FXO_2_TO_SIP_2
  routing-table called-e164 RT_FXO_3_TO_SIP_3
    route T2 dest-service HG_FXO_3_TO_SIP_3
  mapping-table calling-pi to called-e164 MP_REM_CLIR
  interface sip IF_SIP_0
    bind context sip-gateway GW_SIP_0
    route call dest-service HG_SIP_0_TO_FXO_0
    remote 172.20.0.2
    early-connect
    early-disconnect
    address-translation outgoing-call request-uri user-part fix 10000 host-part to-header target-param none
  interface sip IF_SIP_1
    bind context sip-gateway GW_SIP_1
    route call dest-service HG_SIP_1_TO_FXO_1
    remote 172.20.0.2
    early-connect
    early-disconnect
    address-translation outgoing-call request-uri user-part fix 10001 host-part to-header target-param none
  interface sip IF_SIP_2
    bind context sip-gateway GW_SIP_2
    route call dest-service HG_SIP_2_TO_FXO_2
    remote 172.20.0.2
    early-connect
    early-disconnect
    address-translation outgoing-call request-uri user-part fix 10002 host-part to-header target-param none
  interface sip IF_SIP_3
    bind context sip-gateway GW_SIP_3
    route call dest-service HG_SIP_3_TO_FXO_3
    remote 172.20.0.2
    early-connect
    early-disconnect
    address-translation outgoing-call request-uri user-part fix 10003 host-part to-header target-param none
  interface fxo IF_FXO_0
    route call dest-table RT_FXO_0_TO_SIP_0
    loop-break-duration min 200 max 1000
    disconnect-signal loop-break
    disconnect-signal busy-tone
    ring-number on-caller-id
    dial-after timeout 1
    mute-dialing
  interface fxo IF_FXO_1
    route call dest-table RT_FXO_1_TO_SIP_1
    mute-dialing
  interface fxo IF_FXO_2
    route call dest-table RT_FXO_2_TO_SIP_2
    mute-dialing
  interface fxo IF_FXO_3
    route call dest-table RT_FXO_3_TO_SIP_3
    mute-dialing
  service hunt-group HG_FXO_0_TO_SIP_0
    drop-cause normal-unspecified
    drop-cause no-circuit-channel-available
    drop-cause network-out-of-order
    drop-cause temporary-failure
    drop-cause switching-equipment-congestion
    drop-cause access-info-discarded
    drop-cause circuit-channel-not-available
    drop-cause resources-unavailable
    route call 1 dest-interface IF_SIP_0
  service hunt-group HG_SIP_0_TO_FXO_0
    route call 1 dest-interface IF_FXO_0
  service hunt-group HG_FXO_1_TO_SIP_1
    route call 1 dest-interface IF_SIP_1
  service hunt-group HG_SIP_1_TO_FXO_1
    route call 1 dest-interface IF_FXO_1
  service hunt-group HG_FXO_2_TO_SIP_2
    route call 1 dest-interface IF_SIP_2
  service hunt-group HG_SIP_2_TO_FXO_2
    route call 1 dest-interface IF_FXO_2
  service hunt-group HG_FXO_3_TO_SIP_3
    route call 1 dest-interface IF_SIP_3
  service hunt-group HG_SIP_3_TO_FXO_3
    route call 1 dest-interface IF_FXO_3
context cs switch
  no shutdown
authentication-service AS_ALL_LINES
  username 10000 password LbFCDNv4/Fk= encrypted
  username 10001 password dZ8edXkjFnM= encrypted
  username 10002 password iAaKwKfxX4Q= encrypted
  username 10003 password ySyWxUvSc/c= encrypted
location-service LS_10000
  domain 1 172.20.0.2
location-service LS_10001
  domain 1 172.20.0.2
location-service LS_10002
  domain 1 172.20.0.2
location-service LS_10003
  domain 1 172.20.0.2
  interface LAN
    bind interface IF_IP_LAN context router port 5060
  bind location-service LS_10000
  no shutdown
  interface LAN
    bind interface IF_IP_LAN context router port 5062
  bind location-service LS_10001
  no shutdown
  interface LAN
    bind interface IF_IP_LAN context router port 5064
  bind location-service LS_10002
  no shutdown
  interface LAN
    bind interface IF_IP_LAN context router port 5066
  bind location-service LS_10003
  no shutdown
port ethernet 0 0
  medium 10 half
  encapsulation ip
  bind interface IF_IP_LAN router
  no shutdown
port fxo 0 0
  encapsulation cc-fxo
  bind interface IF_FXO_0 switch
  no shutdown
port fxo 0 1
  bind interface IF_FXO_1 switch
  no shutdown
port fxo 0 2
  bind interface IF_FXO_2 switch
  no shutdown
port fxo 0 3
  bind interface IF_FXO_3 switch
  no shutdown
sip.conf
;Abgehende Anrufe
[10000]
type=peer
username=10000
fromuser=10000
secret=10000
host=192.168.10.252
fromdomain=192.168.10.252
insecure=very
canreinvite=no
nat=no
disallow=all
allow=ulaw
[10001]
type=peer
port=5062
username=10001
fromuser=10001
secret=10001
host=192.168.10.252
insecure=very
canreinvite=no
nat=no
disallow=all
allow=ulaw
[10002]
type=peer
port=5064
username=10002
fromuser=10002
secret=10002
host=192.168.10.252
insecure=very
canreinvite=no
nat=no
disallow=all
allow=ulaw
[10003]
type=peer
port=5066
username=10003
fromuser=10003
secret=10003
host=192.168.10.252
insecure=very
canreinvite=no
nat=no
disallow=all
allow=ulaw
; Eingehende Anrufe
[Paton_10000]
type=peer
host=192.168.10.252
disallow=all
allow=ulaw
context=ankommend
[Paton_10001]
type=peer
port=5062
host=192.168.10.252
disallow=all
allow=ulaw
context=ankommend
[Paton_10002]
type=peer
port=5064
host=192.168.10.252
disallow=all
allow=ulaw
context=ankommend
[Paton_10003]
type=peer
port=5066
host=192.168.10.252
disallow=all
allow=ulaw
context=ankommend
Sollte noch einer Verbesserungen oder Ratschläge für mich haben würde ich mich sehr darüber freuen.
Grüsse Michael
holh-66
