Patton 4634 - Anrufe ohne DW gehen verloren
martingeorg
8 Jan 2008
Hallo !
Ich habe folgendes Problem: Wenn ich die ISDN Nummer ohne DW verwende wird der Anruf vom Patton gedropped. Sie beide Log's.
1. Log: ohne DW oder 0 - xxxx5223
18:54:08  CR    > [switch] Routing-Lookup:
18:54:08  CR    >   Execute all entries in table isdnif1-precall-service
18:54:08  CR    >   Find best-matching called-entry in table fromisdn1
18:54:08  CR    >     01: Prefix Timeout Expression: called-e164 of  incompletel
y matches ^(?:xxxx5223$)
18:54:08  CR    >     Selecting entry 1
18:54:08  CR    >   Lookup result: Route not found (incomplete address) (timeout
=0)
18:54:08  CC    > [EP router-007be238] INCOMPLETE ADDRESS, NO OVERLAP-SENDING; D
ROP CALL
18:54:08  CC    > [EP router-007be238/incoming] Drop call 009db758
2. Log mit DW 120: xxxx5223120
18:58:21  CR    > [switch] Routing-Lookup:
18:58:21  CR    >   Execute all entries in table isdnif1-precall-service
18:58:21  CR    >   Find best-matching called-entry in table fromisdn1
18:58:21  CR    >     01: Prefix Timeout Expression: called-e164 of 120 does not
 match ^(?:xxxx5223$)
18:58:21  CR    >     02: Prefix Timeout Expression: called-e164 of 120 does not
 match ^(?:10$)
18:58:21  CR    >     03: Prefix Timeout Expression: called-e164 of 120 does not
 match ^(?:712$)
18:58:21  CR    >     04: Prefix Timeout Expression: called-e164 of 120 does not
 match ^(?:713$)
18:58:21  CR    >     05: Prefix Timeout Expression: called-e164 of 120 does not
 match ^(?:716$)
18:58:21  CR    >     06: Prefix Timeout Expression: called-e164 of 120 does not
 match ^(?:722$)
18:58:21  CR    >     Selecting default entry
18:58:21  CR    >   Execute all entries in table sipif1-dest
18:58:21  CR    >   Execute all entries in table route-found-place-call
18:58:21  CR    >   Lookup result: Route found; place call (timeout=0)
18:58:21  CC    > [EP router-00d4e668] Route found; immediately place call
18:58:21  CC    > [EP router-00d4e668] Route to provider 'sipif1'
Wer kann mir einen Tipp geben?
Kannst du mal die aktuellen Settings zeigen?
Du könntest im Routing "default" verwenden, statt ein Pattern...
Ich habe nochmals nachgelesen in den Foren und siehe da, die Problemmatik mit Österreich ISDN wurde hier behandel.
Mit der Mapping Table
mapping-table called-e164 to called-e164 MT_ADD_0
map $ to 0
ersetze ich das 'Garnichts' durch eine 0 und das löst meine Probleme.
welche über folgende Aufrufe gesteuert wird
routing-table called-e164 Fax
routing-table called-e164 RT_CDPN_ISDN_2_SIP
route T dest-table Fax MT_ADD_0
hats dann auf Anhieb funktioniert - danke
holh-66
