Patton sn4552 + isdn + pbx + router
Tecia
28 Sep 2007
Hi, i need help for my configuration.
I have a patton sn4552 connect by BRI 0/1 Phone to ISDN
Eth 0/1 in patton is connect to switch (for internet we use a router)
A pbx conect to the switch
patton is 192.168.0.151
pbx is 192.168.0.150
router is 192.168.0.1
All the phone (GPX-2000 and BT-200) are connect to lan.
My configuration in patton is:
# SN4552/2BIS/EUI                                                #
# R3.21 2007-05-14 SIP                                           #
# 2007-12-05T09:33:44                                            #
# Generated configuration file                                   #
cli version 3.20
gui type basic
administrator admin password MtMEIhgUMpET5CJB7J3JQA== encrypted
dns-relay
webserver port 80 language en
sntp-client
sntp-client server primary 192.168.0.150 port 123 version 4
system
  ic voice 0
    low-bitrate-codec g729
profile ppp default
profile call-progress-tone IT_Dialtone
  play 1 200 425 -12
  pause 2 200
  play 3 600 425 -12
  pause 4 1000
profile call-progress-tone IT_Alertingtone
  play 1 1000 425 -12
  pause 2 4000
profile call-progress-tone IT_Busytone
  play 1 500 425 -12
  pause 2 500
profile tone-set default
profile tone-set IT
  map call-progress-tone dial-tone IT_Dialtone
  map call-progress-tone ringback-tone IT_Alertingtone
  map call-progress-tone busy-tone IT_Busytone
  map call-progress-tone release-tone IT_Busytone
  map call-progress-tone congestion-tone IT_Busytone
profile voip default
  codec 1 g711alaw64k rx-length 20 tx-length 20
  codec 2 g711ulaw64k rx-length 20 tx-length 20
profile voip NBLADE
  codec 1 g729 rx-length 20 tx-length 20
  codec 2 g711alaw64k rx-length 20 tx-length 20
  codec 3 g711ulaw64k rx-length 20 tx-length 20
profile voip VOIP
profile pstn default
profile sip default
profile sip nblade
profile dhcp-server DHCPS_LAN
  network 192.168.0.151 255.255.255.0
  lease 2 hours
  default-router 1 192.168.0.1
  domain-name patton.com
  domain-name-server 1 192.168.0.1
profile aaa default
  method 1 local
  method 2 none
context ip router
  interface IF_IP_WAN
    ipaddress dhcp
    no napt-inside
  interface IF_IP_LAN
    ipaddress 192.168.0.151 255.255.255.0
    icmp router-discovery
context cs switch
  digit-collection timeout 4
  national-prefix 0
  international-prefix 00
  routing-table called-e164 RT_2_ISDN
    route .%T dest-service HUNTING MT_ITC
  routing-table called-e164 RT_ISDN_2_SIP
    route 99[1-9].T3 dest-interface IF_S0_PSTN
    route 0[1-9].T3 dest-service SER_HUNT_OUT
    route 00[1-9].T3 dest-service SER_HUNT_OUT
    route default dest-service SER_HUNT_OUT
  mapping-table itc to itc MT_ITC
    map default to speech
  interface isdn IF_S0_PSTN
    route call dest-interface IF_S0_PHONE2
    dtmf-dialing
  interface isdn IF_S0_PHONE1
    route call dest-table RT_ISDN_2_SIP
    dtmf-dialing
    use profile tone-set IT
  interface isdn IF_S0_PHONE2
    dtmf-dialing
  interface isdn IF_S0_PHONE3
    dtmf-dialing
  interface isdn IF_S0_PHONE4
    dtmf-dialing
  interface isdn IF_S0_01
  interface sip IF_SIP_NBLADE
    bind gateway GW-NBLADE
    service default
    route call dest-table RT_2_ISDN
    early-disconnect
    remote-party-id called-party
    remote-party-id calling-party
    address-translation outgoing-call from-header user-part fix 210 host-part call
    use profile voip NBLADE
  interface sip IF_SIP_SERVICE
    service default
    address-translation outgoing-call from-header user-part fix patton host-part call
  service hunt-group SER_HUNT_OUT
    timeout 6
    drop-cause normal-unspecified
    drop-cause no-circuit-channel-available
    drop-cause network-out-of-order
    drop-cause temporary-failure
    drop-cause switching-equipment-congestion
    drop-cause access-info-discarded
    drop-cause circuit-channel-not-available
    drop-cause resources-unavailable
    route call 1 dest-interface IF_SIP_NBLADE
    route call 2 dest-interface IF_S0_PSTN
  service hunt-group HUNTING
    drop-cause user-busy
    route call 1 dest-interface IF_S0_PHONE1
    route call 2 dest-interface IF_S0_PHONE2
    route call 3 dest-interface IF_S0_PHONE3
    route call 4 dest-interface IF_S0_PHONE4
  service hunt-group SER_HG_PSTN_FALLBACK
    route call 1 dest-interface IF_SIP_SERVICE
context cs switch
  no shutdown
gateway sip GW-NBLADE
  bind interface IF_IP_LAN router
  service default
    domain 192.168.0.150
    defaultserver manual 192.168.0.150 loose-router
    registration-lifetime 1200
    registration manual 192.168.0.150
    user patton authenticate password MtMEIhgUMpET5CJB7J3JQA== encrypted
  no shutdown
gateway sip GW_SIP
  call-signaling-port 5062
  service default
    user patton register
gateway sip GW_SIP
  no shutdown
port ethernet 0 0
  encapsulation ip
  bind interface IF_IP_WAN router
  no shutdown
port ethernet 0 1
  encapsulation ip
  no shutdown
port bri 0 0
  clock auto
  encapsulation q921
  q921
    protocol pp
    uni-side auto
    encapsulation q931
    q931
      protocol dss1
      uni-side user
      encapsulation cc-isdn
      bind interface IF_S0_PHONE1 switch
port bri 0 0
  no shutdown
port bri 0 1
  clock auto
  encapsulation q921
  q921
    protocol pmp
    uni-side auto
    encapsulation q931
    q931
      protocol dss1
      uni-side net
      bind interface IF_S0_PSTN switch
port bri 0 1
  no shutdown
In my pbx i have:
host= dynamic
from domain= 192.168.0.150
username= patton
password= *****
auth= plaintext
type= friend
nat= no
lax2 encryption= no
qualify= yes
register= no
But don't work.
Can someone help me?
holh-66
