Patton SN4554 R5.1 + Trixbox 2.4
anthonws
7 Apr 2008
Hello to all,
I'm sorry but I cannot speak/write German, even with the help of Google Translation... :P
I have a SN4554 with the latest firmware and I wanted to receive call's from my landline and route them to my trixbox server.
Patton is capable of registering in trixbox but when I make a call to the the landline number I'll get a immediate busy tone.
With version 5.1 the majority of commands are different. I've tried searching in the forum but there only exists 4.2 examples.
Please advise.
Here is my config:
# SN4554/2BIS/EUI                                                #
# R5.1 2008-01-18 SIP                                            #
# 2008-04-07T14:13:18                                            #
# SN/00A0BA037039                                                #
# Generated configuration file                                   #
cli version 3.20
dns-client server 192.168.0.33
webserver port 80 language en
sntp-client
sntp-client server primary 192.168.0.34 port 123 version 4
system
  ic voice 0
system
  clock-source 1 bri 0 0
  clock-source 2 bri 0 1
profile ppp default
profile tone-set default
profile voip default
  codec 1 g729 rx-length 20 tx-length 20
  codec 2 g711alaw64k rx-length 20 tx-length 20
  codec 3 g711ulaw64k rx-length 20 tx-length 20
  dejitter-mode static
  dejitter-max-delay 120
profile pstn default
profile sip default
profile aaa default
  method 1 local
  method 2 none
context ip router
  rtp-port-range 10000 10050
  interface IF_IP_WAN
    ipaddress 192.168.0.230 255.255.255.0
    tcp adjust-mss rx mtu
    tcp adjust-mss tx mtu
context cs switch
  routing-table called-e164 RT_TO_SIP
    route .T dest-interface IF_SIP
  interface isdn IF_S0_00
    route call dest-table RT_TO_SIP
  interface sip IF_SIP
    route call dest-service SER_HG_PSTN_FALLBACK
    remote 192.168.0.210
    local 192.168.0.230
  service hunt-group SER_HG_PSTN_FALLBACK
    drop-cause normal-unspecified
    drop-cause no-circuit-channel-available
    drop-cause network-out-of-order
    drop-cause temporary-failure
    drop-cause switching-equipment-congestion
    drop-cause access-info-discarded
    drop-cause circuit-channel-not-available
    drop-cause resources-unavailable
    route call 1 dest-interface IF_S0_00
context cs switch
  no shutdown
authentication-service SER_AUTH_OB
  username 8012 password aTQGEQSe8Vk= encrypted
location-service SER_LOC_CERT
  domain 1 192.168.0.210 5060
  identity 8012
    authentication outbound
      authenticate 1 authentication-service SER_AUTH_OB username 8012
    registration outbound
      register auto
context sip-gateway GW_SIP
  interface IF_GW_WAN
    bind interface IF_IP_WAN context router port 5060
  bind location-service SER_LOC_CERT
  no shutdown
port ethernet 0 0
  bind interface IF_IP_WAN router
  no shutdown
port bri 0 0
  clock auto
  encapsulation q921
  q921
    uni-side auto
    encapsulation q931
    q931
      protocol dss1
      uni-side user
      bchan-number-order ascending
      encapsulation cc-isdn
      bind interface IF_S0_00 switch
port bri 0 0
  no shutdown
port bri 0 1
  clock auto
  encapsulation q921
  q921
    uni-side auto
    encapsulation q931
    q931
      protocol dss1
      uni-side user
port bri 0 1
  shutdown
Best Regards,
Anthonws.
holh-66
