Patton SN4638, 0 bei eingehenden Anrufen
win-lux
9 Feb 2008
Unsere 3CX Telefonzentrale hat einen neuren
Gateway Patten SN4638/5BIS erhalten
Software Version R4.2 2008-09-11 H323 SIP BRI
Ich möchte nun bei eingehenden Nummern ein führende 0 einfügen:
Beispiel:
eingehende Nummer heute= 0813335151
eingehende Nummer neu = 00813335151
kann mir jemand sagen wo ich den fehler gemacht habe in der config?
# SN4638/5BIS                                                    #
# R4.2 2008-09-11 H323 SIP BRI                                   #
# 2009-07-29T21:17:15                                            #
# SN/00A0BA0449AF                                                #
cli version 3.20
webserver port 80 language en
system
  ic voice 0
    low-bitrate-codec g729
system
  clock-source 1 bri 0 0
profile ppp default
profile call-progress-tone defaultDialtone
  play 1 1000 425 0
profile tone-set default
profile voip default
  codec 1 g711alaw64k rx-length 20 tx-length 20
  codec 2 g711ulaw64k rx-length 20 tx-length 20
  fax transmission 1 relay t38-udp
profile pstn default
profile sip default
  no autonomous-transitioning
profile aaa default
  method 1 local
  method 2 none
context ip router
  interface IF_IP_WAN
    ipaddress dhcp
    tcp adjust-mss rx mtu
    tcp adjust-mss tx mtu
  interface IF_IP_LAN
    ipaddress 192.168.70.101 255.255.255.0
context cs switch
  routing-table called-e164 RT_ISDN_TO_SIP_0
    route T2 dest-interface IF_SIP_0 CF_ADD_REM
  routing-table called-e164 RT_ISDN_TO_SIP_1
    route T2 dest-interface IF_SIP_1 CF_ADD_REM
  routing-table called-e164 RT_ISDN_TO_SIP_2
    route T2 dest-interface IF_SIP_2 CF_ADD_REM
  routing-table called-e164 RT_ISDN_TO_SIP_3
    route T2 dest-interface IF_SIP_3 CF_ADD_REM
  mapping-table calling-pi to calling-e164 MP_REM_CLIR
    map restricted to ""
  mapping-table called-e164 to called-e164 ADD-0
    map (.%) to 0\1
  complex-function CF_ADD_REM
    execute 1 MP_REM_CLIR
    execute 2 ADD-0
  interface isdn IF_ISDN_0
    route call dest-table RT_ISDN_TO_SIP_0
  interface isdn IF_ISDN_1
    route call dest-table RT_ISDN_TO_SIP_1
  interface isdn IF_ISDN_2
    route call dest-table RT_ISDN_TO_SIP_2
  interface isdn IF_ISDN_3
    route call dest-table RT_ISDN_TO_SIP_3
  interface sip IF_SIP_0
    bind gateway GW_SIP_0
    service default
    route call dest-interface IF_ISDN_0
    early-connect
    early-disconnect
    remote-party-id called-party
    address-translation outgoing-call request-uri user-part fix 10000 host-part to-header target-param none
    address-translation incoming-call called-e164 request-uri
  interface sip IF_SIP_1
    bind gateway GW_SIP_1
    service default
    route call dest-interface IF_ISDN_1
    early-connect
    early-disconnect
    address-translation outgoing-call request-uri user-part fix 10001 host-part to-header target-param none
  interface sip IF_SIP_2
    bind gateway GW_SIP_2
    service default
    route call dest-interface IF_ISDN_2
    early-connect
    early-disconnect
    address-translation outgoing-call request-uri user-part fix 10002 host-part to-header target-param none
  interface sip IF_SIP_3
    bind gateway GW_SIP_3
    service default
    route call dest-interface IF_ISDN_3
    early-connect
    early-disconnect
    address-translation outgoing-call request-uri user-part fix 10003 host-part to-header target-param none
context cs switch
  no shutdown
gateway sip GW_SIP_0
  bind interface IF_IP_LAN router
  service default
    domain 192.168.70.15
    defaultserver manual 192.168.70.15 loose-router
    registration-lifetime 300
    registration manual 192.168.70.15
    user 10000 authenticate password LbFCDNv4/Fk= encrypted default register
  no shutdown
gateway sip GW_SIP_1
  call-signaling-port 5062
  service default
    user 10001 authenticate password dZ8edXkjFnM= encrypted default register
  no shutdown
gateway sip GW_SIP_2
  call-signaling-port 5064
  service default
    user 10002 authenticate password iAaKwKfxX4Q= encrypted default register
  no shutdown
gateway sip GW_SIP_3
  call-signaling-port 5066
  service default
    user 10003 authenticate password ySyWxUvSc/c= encrypted default register
  no shutdown
port ethernet 0 0
  medium auto
  encapsulation ip
  bind interface IF_IP_WAN router
  no shutdown
port ethernet 0 1
  medium auto
  encapsulation ip
  no shutdown
port bri 0 0
  clock auto
  encapsulation q921
  q921
    protocol pp
    uni-side auto
    encapsulation q931
    q931
      protocol dss1
      uni-side user
      bchan-number-order ascending
      encapsulation cc-isdn
      bind interface IF_ISDN_0 switch
port bri 0 0
  no shutdown
port bri 0 1
  clock auto
  encapsulation q921
  q921
    protocol pp
    uni-side auto
    encapsulation q931
    q931
      protocol dss1
      uni-side user
      bind interface IF_ISDN_1 switch
port bri 0 1
  no shutdown
port bri 0 2
  clock auto
  encapsulation q921
  q921
    protocol pp
    uni-side auto
    encapsulation q931
    q931
      protocol dss1
      uni-side user
      bind interface IF_ISDN_2 switch
port bri 0 2
  no shutdown
port bri 0 3
  clock auto
  encapsulation q921
  q921
    protocol pp
    uni-side auto
    encapsulation q931
    q931
      protocol dss1
      uni-side user
      bind interface IF_ISDN_3 switch
port bri 0 3
  no shutdown
port bri 0 4
  clock auto
  encapsulation q921
  q921
    protocol pp
    uni-side auto
    encapsulation q931
    q931
      protocol dss1
      uni-side net
port bri 0 4
  shutdown
Edit Guard-X: Code-Tags eingefügt!
Falls es sich nicht schon erledigt hat versuch mal
map (.%) to 0\1
durch
map 0% to 00
zu ersetzen. Und mach mal ein Firmwareupdate. 4.2 ist schon steinalt.
Bbj
