PPPoE funktioniert nicht
streetfighter12
10 Okt 2006
Mein Problemm wie es schon oben steht ich bekomme einfach nicht PPPoE zum laufen. Mein Cisco 1760 Router ist mit einem Wic 1ENET Module bestückt und er läuft unter dem c1700-advipservicesk9 image.
Hier meine Config:
Building configuration...
Current configuration : 7527 bytes
version 12.4
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Gateway-1
boot-start-marker
boot-end-marker
no logging buffered
enable password ........................
no aaa new-model
resource policy
ip cef
ip inspect name ........................ biff
ip inspect name ........................ esmtp
ip inspect name ........................ imap
ip inspect name ........................ imaps
ip inspect name ........................ imap3
ip inspect name ........................ lotusnote
ip inspect name ........................ lotusmtap
ip inspect name ........................ pop3s
ip inspect name ........................ tcp
ip inspect name ........................ udp
ip inspect name ........................ pptp
ip inspect name ........................ l2tp
ip inspect name ........................ gtpv0
ip inspect name ........................ gtpv1
ip inspect name ........................ ddns-v3
ip inspect name ........................ dns
ip inspect name ........................ dnsix
ip inspect name ........................ ldap-admin
ip inspect name ........................ ldaps
ip inspect name ........................ netbios-ns
ip inspect name ........................ wins
ip inspect name ........................ daytime
ip inspect name ........................ ntp
ip inspect name ........................ time
ip inspect name ........................ timed
ip inspect name ........................ bgp
ip inspect name ........................ hsrp
ip inspect name ........................ router
ip inspect name ........................ icmp
ip inspect name ........................ fragment maximum 256 timeout 1
ip inspect name ........................ snmp
ip inspect name ........................ snmptrap
ip inspect name ........................ syslog
ip inspect name ........................ syslog-conn
ip inspect name ........................ tacacs
ip inspect name ........................ kerberos
ip inspect name ........................ radius
ip inspect name ........................ tacacs-ds
ip inspect name ........................ ident
ip inspect name ........................ ace-svr
ip inspect name ........................ bootpc
ip inspect name ........................ bootps
ip inspect name ........................ dhcp-failover
ip inspect name ........................ discard
ip inspect name ........................ echo
ip inspect name ........................ finger
ip inspect name ........................ gopher
ip inspect name ........................ igmpv3lite
ip inspect name ........................ ipx
ip inspect name ........................ pwdgen
ip inspect name ........................ rsvp-encap
ip inspect name ........................ rsvp_tunnel
ip inspect name ........................ socks
ip inspect name ........................ vqp
ip inspect name ........................ microsoft-ds
ip inspect name ........................ ms-cluster-net
ip inspect name ........................ ms-dotnetster
ip inspect name ........................ ms-sna
ip inspect name ........................ ms-sql
ip inspect name ........................ ms-sql-m
ip inspect name ........................ msexch-routing
ip inspect name ........................ netbios-dgm
ip inspect name ........................ netbios-ssn
ip inspect name ........................ r-winsock
ip inspect name ........................ clp
ip inspect name ........................ cisco-net-mgmt
ip inspect name ........................ cisco-sys
ip inspect name ........................ cisco-tna
ip inspect name ........................ cisco-fna
ip inspect name ........................ cisco-tdp
ip inspect name ........................ cisco-svcs
ip inspect name ........................ stun
ip inspect name ........................ tr-rsrb
ip inspect name ........................ dbcontrol_agent
ip inspect name ........................ giop
ip inspect name ........................ net8-cman
ip inspect name ........................ orasrv
ip inspect name ........................ oem-agent
ip inspect name ........................ oracle
ip inspect name ........................ oraclenames
ip inspect name ........................ oracle-em-vp
ip inspect name ........................ rdb-dbs-disp
ip inspect name ........................ rtc-pm-port
ip inspect name ........................ ttc
ip inspect name ........................ citrix
ip inspect name ........................ citriximaclient
ip inspect name ........................ ica
ip inspect name ........................ icabrowser
ip inspect name ........................ cddbp
ip inspect name ........................ dbase
ip inspect name ........................ mysql
ip inspect name ........................ sqlsrv
ip inspect name ........................ sqlserv
ip inspect name ........................ sqlnet
ip inspect name ........................ ftp
ip inspect name ........................ ftps
ip inspect name ........................ kermit
ip inspect name ........................ uucp
ip inspect name ........................ tftp
ip inspect name ........................ nfs
ip inspect name ........................ exec
ip inspect name ........................ telnet
ip inspect name ........................ telnets
ip inspect name ........................ rtelnet
ip inspect name ........................ login
ip inspect name ........................ rcmd
ip inspect name ........................ ssh
ip inspect name ........................ shell
ip inspect name ........................ sshell
ip inspect name ........................ pcanywheredata
ip inspect name ........................ pcanywherestat
ip inspect name ........................ x11
ip inspect name ........................ xdmcp
ip inspect name ........................ entrust-svcs
ip inspect name ........................ n2h2server
ip inspect name ........................ realsecure
ip inspect name ........................ creativeserver
ip inspect name ........................ creativepartnr
ip inspect name ........................ cifs
ip inspect name ........................ fcip-port
ip inspect name ........................ hp-alarm-mgr
ip inspect name ........................ hp-collector
ip inspect name ........................ hp-managed-node
ip inspect name ........................ irc
ip inspect name ........................ irc-serv
ip inspect name ........................ ircs
ip inspect name ........................ ircu
ip inspect name ........................ ipass
ip inspect name ........................ netstat
ip inspect name ........................ nntp
ip inspect name ........................ tarantella
ip inspect name ........................ iscsi-target
ip inspect name ........................ sms
ip inspect name ........................ webster
ip inspect name ........................ who
ip inspect name ........................ h323
ip inspect name ........................ h323callsigalt
ip inspect name ........................ h323gatestat
ip inspect name ........................ skinny
ip inspect name ........................ sip-tls
ip inspect name ........................ appleqtc
ip inspect name ........................ cuseeme
ip inspect name ........................ netshow
ip inspect name ........................ realaudio
ip inspect name ........................ rtsp
ip inspect name ........................ streamworks
ip inspect name ........................ vdolive
ip inspect name ........................ gdoi
ip inspect name ........................ isakmp
ip inspect name ........................ ipsec-msft
ip inspect name ........................ ssp
ip inspect name ........................ 802-11-iapp
no ip dhcp use vrf connected
ip dhcp pool 1
network 192.168.17.0 255.255.255.0
default-router 192.168.17.1
ip name-server 217.237.149.161
vpdn enable
interface Ethernet0/0
description $ETH-WAN$
no ip address
half-duplex
pppoe enable
pppoe-client dial-pool-number 1
no keepalive
interface FastEthernet0/0
description $ETH-LAN$
ip address 192.168.17.1 255.255.255.0
ip inspect ........................ in
ip inspect ........................ out
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
speed auto
interface Dialer1
description connected to Internet
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 2
ppp authentication chap pap callin
ppp chap hostname ........................
ppp chap password ........................
ppp pap sent-username ........................ password........................
router rip
version 2
passive-interface Dialer1
no auto-summary
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit 192.168.17.0 0.0.0.255
dialer-list 2 protocol ip permit
snmp-server community public RO
control-plane
line con 0
exec-timeout 0 0
login
line aux 0
line vty 0 4
login
end
vielleicht wisst ihr ja was ich flash gemmacht habe freue mich auf jede hilfe.
danke
MfG Streetfighter12
Lishheshuyg
