[Problem] Privoxy als transparenter AdBlock Proxy
SuB-ZEro
27 Feb 2008
ich möchte eine FritzBox 7270v3+2GB USB-Stick zu einem transparenten Proxy umrüsten, um alle Clients automatisch Filtern zu können.
Meine aktuelle Konfiguration:
7270_v3_06.06-freetz-devel-13980.de
# Automatically generated file; DO NOT EDIT.
# Freetz Configuration
FREETZ_HAVE_DOT_CONFIG=y
# User competence ------------------------
# FREETZ_USER_LEVEL_BEGINNER is not set
# FREETZ_USER_LEVEL_ADVANCED is not set
FREETZ_USER_LEVEL_EXPERT=y
FREETZ_SHOW_ADVANCED=y
FREETZ_SHOW_EXPERT=y
# Hardware/Firmware ----------------------
# FREETZ_TYPE_300IP is not set
# FREETZ_TYPE_FON is not set
# FREETZ_TYPE_WLAN is not set
# FREETZ_TYPE_W501V is not set
# FREETZ_TYPE_2170 is not set
# WLAN
# FREETZ_TYPE_3020 is not set
# FREETZ_TYPE_3030 is not set
# FREETZ_TYPE_3130 is not set
# FREETZ_TYPE_3131 is not set
# FREETZ_TYPE_3170 is not set
# FREETZ_TYPE_3270_V2 is not set
# FREETZ_TYPE_3270_V3 is not set
# FREETZ_TYPE_3272 is not set
# FREETZ_TYPE_3370 is not set
# FREETZ_TYPE_3390 is not set
# FREETZ_TYPE_3490 is not set
# WAN
# FREETZ_TYPE_4020 is not set
# Fon
# FREETZ_TYPE_5010 is not set
# FREETZ_TYPE_5050 is not set
# FREETZ_TYPE_5124 is not set
# FREETZ_TYPE_5140 is not set
# LTE
# FREETZ_TYPE_6810 is not set
# FREETZ_TYPE_6820 is not set
# FREETZ_TYPE_6840 is not set
# FREETZ_TYPE_6842 is not set
# Fon WLAN
# FREETZ_TYPE_7050 is not set
# FREETZ_TYPE_7112 is not set
# FREETZ_TYPE_7113 is not set
# FREETZ_TYPE_7140 is not set
# FREETZ_TYPE_7141 is not set
# FREETZ_TYPE_7150 is not set
# FREETZ_TYPE_7170 is not set
# FREETZ_TYPE_7240 is not set
# FREETZ_TYPE_7270_V1 is not set
# FREETZ_TYPE_7270_V2 is not set
FREETZ_TYPE_7270_V3=y
# FREETZ_TYPE_7272 is not set
# FREETZ_TYPE_7312 is not set
# FREETZ_TYPE_7320 is not set
# FREETZ_TYPE_7330_XL is not set
# FREETZ_TYPE_7330_SL is not set
# FREETZ_TYPE_7340 is not set
# FREETZ_TYPE_7360_V1 is not set
# FREETZ_TYPE_7360_V2 is not set
# FREETZ_TYPE_7360_SL is not set
# FREETZ_TYPE_7362 is not set
# FREETZ_TYPE_7369 is not set
# FREETZ_TYPE_7390 is not set
# FREETZ_TYPE_7412 is not set
# FREETZ_TYPE_7430 is not set
# FREETZ_TYPE_7490 is not set
# VDSL
# FREETZ_TYPE_7570 is not set
# Custom
# FREETZ_TYPE_CUSTOM is not set
FREETZ_TYPE_LANG_DE=y
# FREETZ_TYPE_LANG_EN is not set
# FREETZ_TYPE_FIRMWARE_05_2X is not set
# FREETZ_TYPE_FIRMWARE_05_5X is not set
FREETZ_TYPE_FIRMWARE_06_0X=y
FREETZ_TYPE_FIRMWARE_FINAL=y
# FREETZ_TYPE_FIRMWARE_VULNERABLE is not set
FREETZ_TYPE_LANGUAGE="de"
# FREETZ_TYPE_ALIEN_HARDWARE is not set
FREETZ_TYPE_7270=y
FREETZ_TYPE_7270_16=y
# Original components --------------------
FREETZ_TARGET_IPV6_SUPPORT=y
FREETZ_REPLACE_KERNEL=y
FREETZ_REPLACE_KERNEL_IMPL=y
# Removal patches
# Removal patches ------------------------
# FREETZ_REMOVE_MULTI_ANNEX_FIRMWARE_DIFFS is not set
# FREETZ_REMOVE_PIGLET_V1_AVAILABLE is not set
# FREETZ_REMOVE_PIGLET_V2_AVAILABLE is not set
# FREETZ_REMOVE_PIGLET_ISDN_AVAILABLE is not set
# FREETZ_REMOVE_PIGLET_POTS_AVAILABLE is not set
# FREETZ_REMOVE_ASSISTANT is not set
# FREETZ_REMOVE_AHA is not set
# FREETZ_REMOVE_AURA_USB is not set
# FREETZ_REMOVE_MEDIASRV is not set
# FREETZ_REMOVE_NAS is not set
# FREETZ_REMOVE_MYFRITZ is not set
# FREETZ_REMOVE_FHEM is not set
# FREETZ_REMOVE_AVM_VPN is not set
# Remove brandings
# FREETZ_REMOVE_BRANDING_1und1 is not set
# FREETZ_REMOVE_BRANDING_avm is not set
# FREETZ_REMOVE_BRANDING_otwo is not set
# FREETZ_REMOVE_CAPIOVERTCP is not set
# FREETZ_REMOVE_CHRONYD is not set
# FREETZ_REMOVE_DECT is not set
# FREETZ_REMOVE_DSLD is not set
# FREETZ_REMOVE_SHOWDSLDSTAT is not set
FREETZ_REMOVE_DTRACE=y
# FREETZ_REMOVE_FTPD is not set
# FREETZ_REMOVE_HELP is not set
# FREETZ_REMOVE_JFFS2 is not set
# FREETZ_REMOVE_RAMZSWAP is not set
# FREETZ_REMOVE_LSOF is not set
# FREETZ_REMOVE_NTFS is not set
# FREETZ_REMOVE_PRINTSERV is not set
# FREETZ_REMOVE_RUNCLOCK is not set
# FREETZ_REMOVE_SAMBA is not set
# FREETZ_REMOVE_SUPPORT is not set
# FREETZ_REMOVE_TR069 is not set
# FREETZ_REMOVE_UMTSD is not set
# FREETZ_REMOVE_UPNP is not set
# FREETZ_REMOVE_KIDS is not set
# FREETZ_REMOVE_QOS is not set
FREETZ_REMOVE_AVM_E2FSPROGS=y
# FREETZ_REMOVE_VOIPD is not set
# FREETZ_REMOVE_TELEPHONY is not set
# FREETZ_REMOVE_WEBDAV is not set
# FREETZ_REMOVE_WLAN is not set
# Other patches
# Web menu patches -----------------------
# FREETZ_PATCH_ATA is not set
# FREETZ_PATCH_GSMVOICE is not set
FREETZ_PATCH_SIGNED=y
# FREETZ_ENABLE_LED_DEACTIVATION is not set
# USB patches --------------------
FREETZ_PATCH_FREETZMOUNT=y
FREETZ_USBSTORAGE_AUTOMOUNT=y
# FREETZ_AUTOMOUNT_EXT2 is not set
FREETZ_AUTOMOUNT_EXT3=y
# FREETZ_AUTOMOUNT_EXT4 is not set
FREETZ_AUTOMOUNT_FAT=y
# FREETZ_AUTOMOUNT_HFS is not set
# FREETZ_AUTOMOUNT_HFS_PLUS is not set
# FREETZ_AUTOMOUNT_LUKS is not set
FREETZ_AUTOMOUNT_NTFS=y
# FREETZ_AUTOMOUNT_REISER_FS is not set
# FREETZ_AUTOMOUNT_LINUXSWAP is not set
# FREETZ_PATCH_MAXDEVCOUNT is not set
# FREETZ_MODIFY_UMTSD is not set
# FREETZ_CUSTOM_UDEV_RULES is not set
# Replacement patches --------------------
# Replace OpenSSL libraries (not available, requires openssl-0.9.8)
# FREETZ_REPLACE_DTRACE is not set
# FREETZ_REPLACE_ONLINECHANGED is not set
# Additional patches ---------------------
FREETZ_ADD_ETCSERVICES=y
# FREETZ_ENFORCE_URLADER_SETTINGS is not set
# Misc patches ---------------------------
# FREETZ_DISABLE_SERIAL_CONSOLE is not set
FREETZ_RESTORE_DEBUG_CFG_SUPPORT=y
# FREETZ_ASYNCHRONOUS_DEBUG_CFG is not set
# AVM daemons ----------------------------
# FREETZ_AVMDAEMON_DISABLE_IGD is not set
FREETZ_AVMDAEMON_DISABLE_NTP=y
# FREETZ_AVMDAEMON_DISABLE_IGM is not set
# FREETZ_AVMDAEMON_DISABLE_TR069 is not set
# FREETZ_AVMDAEMON_DISABLE_MULTIDPORTS is not set
# Additional components ------------------
# Packages
# Debug helpers
# FREETZ_PACKAGE_GDB is not set
# FREETZ_PACKAGE_INOTIFY_TOOLS is not set
# FREETZ_PACKAGE_LDD is not set
# FREETZ_PACKAGE_LSOF is not set
# FREETZ_PACKAGE_LTRACE is not set
# FREETZ_PACKAGE_NANO_SHELL is not set
# FREETZ_PACKAGE_PCIUTILS is not set
# FREETZ_PACKAGE_STRACE is not set
# FREETZ_PACKAGE_TARGET_TESTER is not set
# FREETZ_PACKAGE_USBUTILS is not set
# Packages
# FREETZ_PACKAGE_AICCU is not set
# FREETZ_PACKAGE_APACHE is not set
# FREETZ_PACKAGE_APACHE2 is not set
# FREETZ_PACKAGE_AUTOFS is not set
# FREETZ_PACKAGE_AUTOSSH is not set
# FREETZ_PACKAGE_AVAHI is not set
# FREETZ_PACKAGE_BASH is not set
# FREETZ_PACKAGE_BFTPD is not set
# FREETZ_PACKAGE_BFUSB is not set
# FREETZ_PACKAGE_BIND is not set
# FREETZ_PACKAGE_BIP is not set
# FREETZ_PACKAGE_BIRD is not set
# FREETZ_PACKAGE_BITTWIST is not set
# FREETZ_PACKAGE_BLUEZ_UTILS is not set
# FREETZ_PACKAGE_BR2684CTL is not set
# FREETZ_PACKAGE_BRIDGE_UTILS is not set
# FREETZ_PACKAGE_BVI is not set
# FREETZ_PACKAGE_CALLMONITOR is not set
# FREETZ_PACKAGE_CCID is not set
# FREETZ_PACKAGE_CHECKMAILD is not set
# FREETZ_PACKAGE_CIFSMOUNT is not set
# FREETZ_PACKAGE_CLASSPATH is not set
# FREETZ_PACKAGE_CNTLM is not set
# FREETZ_PACKAGE_COMGT is not set
# FREETZ_PACKAGE_CRYPTSETUP is not set
# FREETZ_PACKAGE_CTORRENT is not set
# FREETZ_PACKAGE_CURL is not set
# FREETZ_PACKAGE_DANTE is not set
# FREETZ_PACKAGE_DAVFS2 is not set
# FREETZ_PACKAGE_DBUS is not set
# FREETZ_PACKAGE_DEBOOTSTRAP is not set
# FREETZ_PACKAGE_DECO is not set
# FREETZ_PACKAGE_DECRYPT_FRITZOS_CFG is not set
# FREETZ_PACKAGE_DIGITEMP is not set
# FREETZ_PACKAGE_DNS2TCP is not set
# FREETZ_PACKAGE_DNSMASQ is not set
# FREETZ_PACKAGE_DOSFSTOOLS is not set
# FREETZ_PACKAGE_DROPBEAR is not set
# FREETZ_PACKAGE_DTACH is not set
# FREETZ_PACKAGE_DVBSNOOP is not set
# FREETZ_PACKAGE_DVBSTREAM is not set
# FREETZ_PACKAGE_DVBTUNE is not set
# FREETZ_PACKAGE_E2FSPROGS is not set
# E-MailRelay (not available, needs libstdc++ as Standard C++ Library)
# FREETZ_PACKAGE_EMPTY is not set
# FREETZ_PACKAGE_ESPEAK is not set
# FREETZ_PACKAGE_FFMPEG is not set
# FREETZ_PACKAGE_FORTUNE is not set
# FREETZ_PACKAGE_FOWSR is not set
# FREETZ_PACKAGE_FSTYP is not set
# FREETZ_PACKAGE_FUSE is not set
# FREETZ_PACKAGE_GHOSTSCRIPT_FONTS is not set
# FREETZ_PACKAGE_GIT is not set
# FREETZ_PACKAGE_GNTPSEND is not set
# FREETZ_PACKAGE_GNU_MAKE is not set
# FREETZ_PACKAGE_GNUTLS is not set
# FREETZ_PACKAGE_GOCR is not set
# FREETZ_PACKAGE_GW6 is not set
# FREETZ_PACKAGE_HAPROXY is not set
FREETZ_PACKAGE_HASERL=y
# FREETZ_PACKAGE_HASERL_WITH_LUA is not set
# FREETZ_PACKAGE_HD_IDLE is not set
# FREETZ_PACKAGE_HOL is not set
# FREETZ_PACKAGE_HTML2TEXT is not set
# FREETZ_PACKAGE_HTOP is not set
# FREETZ_PACKAGE_HTPDATE is not set
# FREETZ_PACKAGE_HTTPRY is not set
# FREETZ_PACKAGE_HTTPTUNNEL is not set
# FREETZ_PACKAGE_ICONV is not set
# FREETZ_PACKAGE_IFSTAT is not set
# FREETZ_PACKAGE_IFTOP is not set
# FREETZ_PACKAGE_IGMPPROXY is not set
# FREETZ_PACKAGE_IMAGEMAGICK is not set
# FREETZ_PACKAGE_INADYN_MT is not set
# FREETZ_PACKAGE_INADYN_OPENDNS is not set
FREETZ_PACKAGE_INETD=y
# FREETZ_PACKAGE_INETD_TIME is not set
# FREETZ_PACKAGE_IODINE is not set
# FREETZ_PACKAGE_IPSEC_TOOLS is not set
# FREETZ_PACKAGE_IPTRAF is not set
# FREETZ_PACKAGE_IPUTILS is not set
# FREETZ_PACKAGE_IRSSI is not set
# FREETZ_PACKAGE_ISC_DHCP is not set
# FREETZ_PACKAGE_JAMVM is not set
# FREETZ_PACKAGE_JS is not set
# FREETZ_PACKAGE_KNOCK is not set
# FREETZ_PACKAGE_LFTP is not set
# FREETZ_PACKAGE_LIGHTTPD is not set
# FREETZ_PACKAGE_LUA is not set
# FREETZ_PACKAGE_LYNX is not set
# FREETZ_PACKAGE_MADPLAY is not set
# FREETZ_PACKAGE_MATRIXTUNNEL is not set
# FREETZ_PACKAGE_MC is not set
# FREETZ_PACKAGE_MCABBER is not set
# FREETZ_PACKAGE_MEDIATOMB is not set
# FREETZ_PACKAGE_MICROPERL is not set
# FREETZ_PACKAGE_MINICOM is not set
# FREETZ_PACKAGE_MINIDLNA is not set
# FREETZ_PACKAGE_MINI_SNMPD is not set
FREETZ_PACKAGE_MOD=y
FREETZ_PACKAGE_MOD_ETCSERVICES=y
FREETZ_PACKAGE_MODCGI=y
# FREETZ_PACKAGE_MODULE_INIT_TOOLS is not set
# FREETZ_PACKAGE_MTR is not set
# FREETZ_PACKAGE_NAGIOS is not set
# FREETZ_PACKAGE_NANO is not set
# FREETZ_PACKAGE_NC6 is not set
# FREETZ_PACKAGE_NCFTP is not set
# FREETZ_PACKAGE_NDAS is not set
# FREETZ_PACKAGE_NETATALK is not set
# FREETZ_PACKAGE_NETCAT is not set
# FREETZ_PACKAGE_NETPBM is not set
# FREETZ_PACKAGE_NETSNMP is not set
# FREETZ_PACKAGE_NFSROOT is not set
# FREETZ_PACKAGE_NFS_UTILS is not set
# FREETZ_PACKAGE_NGIRCD is not set
# FREETZ_PACKAGE_NMAP is not set
# FREETZ_PACKAGE_NOIP is not set
# FREETZ_PACKAGE_NZBGET is not set
# FREETZ_PACKAGE_OBEXFTP is not set
# FREETZ_PACKAGE_OIDENTD is not set
# FREETZ_PACKAGE_OPENCONNECT is not set
# FREETZ_PACKAGE_OPENDD is not set
# FREETZ_PACKAGE_OPENNTPD is not set
# OpenSSH
# FREETZ_PACKAGE_OPENSSH_sshd is not set
# FREETZ_PACKAGE_OPENSSH_ssh is not set
# FREETZ_PACKAGE_OPENSSH_scp is not set
# FREETZ_PACKAGE_OPENSSH_CLIENTUTILS is not set
# FREETZ_PACKAGE_OPENSSH_KEYUTILS is not set
# FREETZ_PACKAGE_OPENSSH_sftp is not set
# FREETZ_PACKAGE_OPENSSH_sftp_server is not set
# FREETZ_PACKAGE_OPENSSL is not set
# FREETZ_PACKAGE_OPENVPN is not set
# FREETZ_PACKAGE_OWFS is not set
# FREETZ_PACKAGE_PCSC_LITE is not set
# FREETZ_PACKAGE_PHONEBOOK_TOOLS is not set
# FREETZ_PACKAGE_PHP is not set
# FREETZ_PACKAGE_PINGTUNNEL is not set
# FREETZ_PACKAGE_POLIPO is not set
# FREETZ_PACKAGE_PORTMAP is not set
# FREETZ_PACKAGE_PPP is not set
FREETZ_BOX_CERTIFICATE_SUPPORT_AVAILABLE=y
# FREETZ_PACKAGE_PRIVATEKEYPASSWORD is not set
FREETZ_PACKAGE_PRIVOXY=y
FREETZ_PACKAGE_PRIVOXY_WITH_ADBLOCK=y
FREETZ_PACKAGE_PRIVOXY_WITH_SHARED_PCRE=y
FREETZ_PACKAGE_PRIVOXY_WITH_ZLIB=y
# FREETZ_PACKAGE_PYLOAD is not set
# FREETZ_PACKAGE_PYTHON is not set
# FREETZ_PACKAGE_QUAGGA is not set
# FREETZ_PACKAGE_RADVD is not set
# FREETZ_PACKAGE_RCAPID is not set
# FREETZ_PACKAGE_RIPMIME is not set
# FREETZ_PACKAGE_RRDTOOL is not set
# FREETZ_PACKAGE_RSYNC is not set
# FREETZ_PACKAGE_RTMPDUMP is not set
# FREETZ_PACKAGE_RUBY is not set
# FREETZ_PACKAGE_RUSH is not set
# FREETZ_PACKAGE_SABLEVM_SDK is not set
# FREETZ_PACKAGE_SAMBA is not set
# FREETZ_PACKAGE_SCREEN is not set
# FREETZ_PACKAGE_SER2NET is not set
# FREETZ_PACKAGE_SFK is not set
# FREETZ_PACKAGE_SHELLINABOX is not set
# FREETZ_PACKAGE_SIPROXD is not set
# FREETZ_PACKAGE_SISPMCTL is not set
# FREETZ_PACKAGE_SLANG is not set
# FREETZ_PACKAGE_SLURM is not set
# FREETZ_PACKAGE_SMARTMONTOOLS is not set
# FREETZ_PACKAGE_SMSTOOLS3 is not set
# FREETZ_PACKAGE_SMUSBUTIL is not set
# FREETZ_PACKAGE_SOCAT is not set
# FREETZ_PACKAGE_SPAWN_FCGI is not set
# FREETZ_PACKAGE_SQLITE is not set
# FREETZ_PACKAGE_SQUASHFS3 is not set
# FREETZ_PACKAGE_SQUASHFS4 is not set
# FREETZ_PACKAGE_SSHFS_FUSE is not set
# FREETZ_PACKAGE_SSLH is not set
# FREETZ_PACKAGE_STREAMRIPPER is not set
# FREETZ_PACKAGE_STUNNEL is not set
# FREETZ_PACKAGE_SUBVERSION is not set
# FREETZ_PACKAGE_SUDO is not set
# FREETZ_PACKAGE_SUNDTEK is not set
# FREETZ_PACKAGE_SYNCE_DCCM is not set
# FREETZ_PACKAGE_SYNCE_SERIAL is not set
# FREETZ_PACKAGE_TCPDUMP is not set
# FREETZ_PACKAGE_TCPPROXY is not set
# FREETZ_PACKAGE_TCP_WRAPPERS is not set
# Tesseract OCR (not available, needs libstdc++ as Standard C++ Library)
# FREETZ_PACKAGE_TICHKSUM is not set
# FREETZ_PACKAGE_TIFF is not set
# FREETZ_PACKAGE_TINC is not set
# FREETZ_PACKAGE_TINYPROXY is not set
# FREETZ_PACKAGE_TMUX is not set
# FREETZ_PACKAGE_TOR is not set
# FREETZ_PACKAGE_TRANSMISSION is not set
# FREETZ_PACKAGE_TRANSMISSION_WITH_OPENSSL is not set
# FREETZ_PACKAGE_TRANSMISSION_WITH_POLARSSL is not set
# FREETZ_PACKAGE_TREE is not set
# FREETZ_PACKAGE_TRICKLE is not set
# FREETZ_PACKAGE_UDPXY is not set
# FREETZ_PACKAGE_UMURMUR is not set
# FREETZ_PACKAGE_UNFS3 is not set
# FREETZ_PACKAGE_UNRAR is not set
# FREETZ_PACKAGE_USBIDS is not set
# FREETZ_PACKAGE_UTIL_LINUX is not set
# FREETZ_PACKAGE_VIM is not set
# FREETZ_PACKAGE_VNSTAT is not set
# FREETZ_PACKAGE_VPNC is not set
# FREETZ_PACKAGE_VSFTPD is not set
# FREETZ_PACKAGE_VTUN is not set
FREETZ_WGET=y
FREETZ_PACKAGE_WGET=y
FREETZ_PACKAGE_WGET_WITH_SSL=y
FREETZ_PACKAGE_WGET_OPENSSL=y
# FREETZ_PACKAGE_WGET_GNUTLS is not set
# FREETZ_PACKAGE_WGET_STATIC is not set
# FREETZ_PACKAGE_WOL is not set
# FREETZ_PACKAGE_WPUT is not set
# FREETZ_PACKAGE_XMAIL is not set
# FREETZ_PACKAGE_XPDF is not set
# FREETZ_PACKAGE_XRELAYD is not set
# FREETZ_PACKAGE_XSLTPROC is not set
# FREETZ_PACKAGE_XZ is not set
# Unstable
# FREETZ_PACKAGE_ASTERISK is not set
# FREETZ_PACKAGE_COLLECTD is not set
# FREETZ_PACKAGE_DTMFBOX is not set
# FREETZ_PACKAGE_GPTFDISK is not set
# FREETZ_PACKAGE_HPLIP is not set
# FREETZ_PACKAGE_HP_UTILS is not set
FREETZ_PACKAGE_IPTABLES=y
FREETZ_PACKAGE_IPTABLES_IS_SELECTABLE=y
FREETZ_PACKAGE_IPTABLES_SAVE_RESTORE=y
# FREETZ_PACKAGE_IPTABLES_XML is not set
# FREETZ_PACKAGE_IPTABLES_STATIC is not set
FREETZ_PACKAGE_IPTABLES_CGI=y
# FREETZ_PACKAGE_NHIPT is not set
FREETZ_PACKAGE_IPTABLES_STANDARD_MODULES=y
FREETZ_PACKAGE_IPTABLES_KERNEL_MODULES=y
# Select kernel modules (IPv4)
# FREETZ_MODULE_nf_conntrack is not set
# FREETZ_MODULE_nf_conntrack_ftp is not set
# FREETZ_MODULE_nf_conntrack_h323 is not set
# FREETZ_MODULE_nf_conntrack_irc is not set
# FREETZ_MODULE_nf_conntrack_ipv4 is not set
# FREETZ_MODULE_nf_conntrack_pptp is not set
# FREETZ_MODULE_nf_conntrack_proto_gre is not set
# FREETZ_MODULE_nf_conntrack_tftp is not set
# FREETZ_MODULE_nf_defrag_ipv4 is not set
# FREETZ_MODULE_nf_nat is not set
# FREETZ_MODULE_nf_nat_ftp is not set
# FREETZ_MODULE_nf_nat_h323 is not set
# FREETZ_MODULE_nf_nat_irc is not set
# FREETZ_MODULE_nf_nat_pptp is not set
# FREETZ_MODULE_nf_nat_tftp is not set
FREETZ_MODULE_iptable_filter=y
# FREETZ_MODULE_iptable_mangle is not set
FREETZ_MODULE_iptable_nat=y
# FREETZ_MODULE_iptable_raw is not set
FREETZ_MODULE_ip_tables=y
FREETZ_MODULE_ipt_LOG=y
FREETZ_MODULE_ipt_REJECT=y
# FREETZ_MODULE_ipt_ttl is not set
# FREETZ_MODULE_ipt_TTL is not set
# x_tables (both IPv4 and IPv6)
FREETZ_MODULE_x_tables=y
# FREETZ_MODULE_xt_CLASSIFY is not set
# FREETZ_MODULE_xt_comment is not set
# FREETZ_MODULE_xt_esp is not set
FREETZ_MODULE_xt_length=y
FREETZ_MODULE_xt_limit=y
FREETZ_MODULE_xt_mac=y
FREETZ_MODULE_xt_multiport=y
FREETZ_MODULE_xt_mark=y
FREETZ_MODULE_xt_MARK=y
# FREETZ_MODULE_xt_NFQUEUE is not set
FREETZ_MODULE_xt_iprange=y
FREETZ_MODULE_xt_pkttype=y
FREETZ_MODULE_xt_physdev=y
# FREETZ_MODULE_xt_quota is not set
# FREETZ_MODULE_xt_realm is not set
# FREETZ_MODULE_xt_statistic is not set
# FREETZ_MODULE_xt_string is not set
FREETZ_MODULE_xt_tcpudp=y
# FREETZ_MODULE_xt_tcpmss is not set
# FREETZ_MODULE_xt_time is not set
# Select kernel modules (IPv6)
# FREETZ_MODULE_ip6_queue is not set
# FREETZ_MODULE_ip6_tables is not set
# FREETZ_MODULE_nf_conntrack_ipv6 is not set
FREETZ_PACKAGE_IPTABLES_SHARED_LIBS=y
# Select shared libraries (IPv4)
FREETZ_LIB_libipt_addrtype=y
# FREETZ_LIB_libipt_ah is not set
# FREETZ_LIB_libipt_CLUSTERIP is not set
FREETZ_LIB_libipt_DNAT=y
# FREETZ_LIB_libipt_ecn is not set
# FREETZ_LIB_libipt_ECN is not set
FREETZ_LIB_libipt_icmp=y
FREETZ_LIB_libipt_LOG=y
FREETZ_LIB_libipt_MASQUERADE=y
# FREETZ_LIB_libipt_MIRROR is not set
# FREETZ_LIB_libipt_NETMAP is not set
# FREETZ_LIB_libipt_realm is not set
FREETZ_LIB_libipt_REDIRECT=y
FREETZ_LIB_libipt_REJECT=y
# FREETZ_LIB_libipt_SAME is not set
FREETZ_LIB_libipt_SNAT=y
# FREETZ_LIB_libipt_ttl is not set
# FREETZ_LIB_libipt_TTL is not set
FREETZ_LIB_libipt_ULOG=y
# FREETZ_LIB_libipt_unclean is not set
# Select shared libraries (both IPv4 and IPv6)
FREETZ_LIB_libxt_CLASSIFY=y
# FREETZ_LIB_libxt_comment is not set
FREETZ_LIB_libxt_connbytes=y
FREETZ_LIB_libxt_connmark=y
FREETZ_LIB_libxt_CONNMARK=y
# FREETZ_LIB_libxt_CONNSECMARK is not set
# FREETZ_LIB_libxt_conntrack is not set
# FREETZ_LIB_libxt_dscp is not set
# FREETZ_LIB_libxt_DSCP is not set
# FREETZ_LIB_libxt_esp is not set
# FREETZ_LIB_libxt_hashlimit is not set
# FREETZ_LIB_libxt_helper is not set
FREETZ_LIB_libxt_iprange=y
FREETZ_LIB_libxt_length=y
FREETZ_LIB_libxt_limit=y
FREETZ_LIB_libxt_mac=y
FREETZ_LIB_libxt_mark=y
FREETZ_LIB_libxt_MARK=y
FREETZ_LIB_libxt_multiport=y
# FREETZ_LIB_libxt_NFLOG is not set
# FREETZ_LIB_libxt_NFQUEUE is not set
# FREETZ_LIB_libxt_NOTRACK is not set
# FREETZ_LIB_libxt_owner is not set
FREETZ_LIB_libxt_physdev=y
FREETZ_LIB_libxt_pkttype=y
# FREETZ_LIB_libxt_quota is not set
# FREETZ_LIB_libxt_rateest is not set
# FREETZ_LIB_libxt_RATEEST is not set
# FREETZ_LIB_libxt_sctp is not set
# FREETZ_LIB_libxt_SECMARK is not set
FREETZ_LIB_libxt_standard=y
FREETZ_LIB_libxt_state=y
# FREETZ_LIB_libxt_statistic is not set
# FREETZ_LIB_libxt_string is not set
# FREETZ_LIB_libxt_tcpmss is not set
FREETZ_LIB_libxt_TCPMSS=y
FREETZ_LIB_libxt_tcp=y
# FREETZ_LIB_libxt_time is not set
# FREETZ_LIB_libxt_tos is not set
# FREETZ_LIB_libxt_TOS is not set
# FREETZ_LIB_libxt_TRACE is not set
# FREETZ_LIB_libxt_u32 is not set
FREETZ_LIB_libxt_udp=y
# Select shared libraries (IPv6)
# FREETZ_LIB_libip6t_ah is not set
# FREETZ_LIB_libip6t_dst is not set
# FREETZ_LIB_libip6t_eui64 is not set
# FREETZ_LIB_libip6t_frag is not set
# FREETZ_LIB_libip6t_hbh is not set
# FREETZ_LIB_libip6t_hl is not set
# FREETZ_LIB_libip6t_HL is not set
FREETZ_LIB_libip6t_icmp6=y
# FREETZ_LIB_libip6t_ipv6header is not set
# FREETZ_LIB_libip6t_LOG is not set
# FREETZ_LIB_libip6t_mh is not set
# FREETZ_LIB_libip6t_REJECT is not set
# FREETZ_LIB_libip6t_rt is not set
# FREETZ_PACKAGE_MINI_FO is not set
# SANE
# FREETZ_PACKAGE_SANE_BACKENDS is not set
# SCANBUTTOND
# FREETZ_PACKAGE_SCANBUTTOND is not set
# FREETZ_PACKAGE_SQUID is not set
# truecrypt (not available, needs libstdc++ as the Standard C++ Library)
# FREETZ_PACKAGE_USBIP is not set
# FREETZ_PACKAGE_USBROOT is not set
# FREETZ_PACKAGE_VIRTUALIP_CGI is not set
# FREETZ_PACKAGE_ZABBIX is not set
# Web interfaces
# FREETZ_PACKAGE_AUTHORIZED_KEYS is not set
# FREETZ_PACKAGE_AVM_FORWARDING is not set
# FREETZ_PACKAGE_DNSD_CGI is not set
# FREETZ_PACKAGE_DOWNLOADER is not set
# FREETZ_PACKAGE_NFSD_CGI is not set
# FREETZ_PACKAGE_ONLINECHANGED_CGI is not set
# FREETZ_PACKAGE_PHPXMAIL is not set
# FREETZ_PACKAGE_RRDSTATS is not set
# FREETZ_PACKAGE_SPINDOWN_CGI is not set
FREETZ_PACKAGE_SYSLOGD_CGI=y
# FREETZ_PACKAGE_TRANSMISSION_CGI is not set
# FREETZ_PACKAGE_VNSTAT_CGI is not set
# FREETZ_PACKAGE_WOL_CGI is not set
# Shared libraries
# Apache Portable Runtime libs
# FREETZ_LIB_libapr is not set
# FREETZ_LIB_libapr_WITH_DSO is not set
# FREETZ_LIB_libaprutil is not set
# FREETZ_LIB_libaprutil_WITH_LIBDB is not set
# Avahi libraries
# FREETZ_LIB_libavahi_common is not set
# FREETZ_LIB_libavahi_core is not set
# FREETZ_LIB_libavahi_client is not set
# C++
# FREETZ_LIB_STDCXXLIB is not set
# FREETZ_LIB_STDCXXLIB_WITH_WCHAR is not set
# FREETZ_LIB_libstdc__ is not set
FREETZ_LIB_libuClibc__=y
# FREETZ_LIB_libuClibc__WITH_WCHAR is not set
# Charsets & Internationalization
# FREETZ_LIB_libiconv is not set
# FREETZ_LIB_libintl is not set
# Crypto & SSL
# GnuPG ----------------------------------
# FREETZ_LIB_libgpg_error is not set
# FREETZ_LIB_libgcrypt is not set
# Digests ---
# FREETZ_LIB_libgcrypt_WITH_DIGEST_crc is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_gostr3411_94 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_md4 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_md5 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_rmd160 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_sha1 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_sha256 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_sha512 is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_stribog is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_tiger is not set
# FREETZ_LIB_libgcrypt_WITH_DIGEST_whirlpool is not set
# Symmetric ciphers ---
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_aes is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_arcfour is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_blowfish is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_camellia is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_cast5 is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_des is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_gost28147 is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_idea is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_rfc2268 is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_salsa20 is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_seed is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_serpent is not set
# FREETZ_LIB_libgcrypt_WITH_SYMMETRIC_CIPHER_twofish is not set
# Asymmetric ciphers ---
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_dsa is not set
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_ecc is not set
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_elgamal is not set
# FREETZ_LIB_libgcrypt_WITH_ASYMMETRIC_CIPHER_rsa is not set
# GnuTLS ---------------------------------
# FREETZ_LIB_libgnutls is not set
# FREETZ_LIB_libtasn1 is not set
# Nettle ---------------------------------
# FREETZ_LIB_libnettle is not set
# FREETZ_LIB_libhogweed is not set
# SSL ------------------------------------
# FREETZ_LIB_libmatrixssl is not set
# FREETZ_LIB_libpolarssl12 is not set
# FREETZ_LIB_libpolarssl12_WITH_BLOWFISH is not set
# FREETZ_LIB_libpolarssl12_WITH_GENRSA is not set
# FREETZ_LIB_libpolarssl13 is not set
# FREETZ_LIB_libpolarssl13_WITH_BLOWFISH is not set
# FREETZ_LIB_libpolarssl13_WITH_GENRSA is not set
FREETZ_LIB_libcrypto=y
FREETZ_LIB_libssl=y
FREETZ_OPENSSL_VERSION_PROMPT=y
# FREETZ_OPENSSL_VERSION_1_REQUIRED is not set
# FREETZ_OPENSSL_VERSION_0 is not set
FREETZ_OPENSSL_VERSION_1=y
# FREETZ_OPENSSL_VERSION_1_LTS is not set
FREETZ_OPENSSL_SHLIB_VERSION="1.0.0"
# OpenSSL configuration
# FREETZ_LIB_libcrypto_WITH_EC is not set
# FREETZ_LIB_libcrypto_WITH_RC4 is not set
FREETZ_OPENSSL_SMALL_FOOTPRINT=y
FREETZ_OPENSSL_CONFIG_DIR="/mod/etc/ssl"
# Data compression
# FREETZ_LIB_liblzma is not set
# FREETZ_LIB_liblzo2 is not set
FREETZ_LIB_libz=y
# Database
# FREETZ_LIB_libdb is not set
# FREETZ_LIB_libsqlite3 is not set
# File systems
# e2fsprogs libraries
# FREETZ_LIB_libblkid is not set
# FREETZ_LIB_libcom_err is not set
# FREETZ_LIB_libe2p is not set
# FREETZ_LIB_libext2fs is not set
# FREETZ_LIB_libss is not set
# FREETZ_LIB_libuuid is not set
# FREETZ_LIB_libfuse is not set
# FREETZ_LIB_libntfs is not set
# GLib
# FREETZ_LIB_libglib_2 is not set
# FREETZ_LIB_libgio_2 is not set
# FREETZ_LIB_libgobject_2 is not set
# FREETZ_LIB_libgmodule_2 is not set
# FREETZ_LIB_libgthread_2 is not set
# Graphics & fonts
# FREETZ_LIB_libfreetype is not set
# FREETZ_LIB_libart_lgpl_2 is not set
# FREETZ_LIB_libexif is not set
# FREETZ_LIB_libjpeg is not set
# FREETZ_LIB_liblept is not set
# FREETZ_LIB_libpng12 is not set
# FREETZ_LIB_libgd is not set
# FREETZ_LIB_libopenjpeg is not set
# FREETZ_LIB_libtiff is not set
# FREETZ_LIB_libtiffxx is not set
# FREETZ_LIB_libnetpbm is not set
# Multi precision arithmetic libs
# FREETZ_LIB_libgmp is not set
# FREETZ_LIB_libmpfr is not set
# FREETZ_LIB_libmpc is not set
# Multimedia
# Audio and video codecs
# Audio codecs
# FREETZ_LIB_libFLAC is not set
# FREETZ_LIB_libmad is not set
# FREETZ_LIB_libogg is not set
# FREETZ_LIB_libopus is not set
# FREETZ_LIB_libspeex is not set
# FREETZ_LIB_libspeexdsp is not set
# FFmpeg libraries
# FREETZ_LIB_libavcodec is not set
# FREETZ_LIB_libavdevice is not set
# FREETZ_LIB_libavfilter is not set
# FREETZ_LIB_libavformat is not set
# FREETZ_LIB_libavutil is not set
# FREETZ_LIB_libpostproc is not set
# FREETZ_LIB_libswresample is not set
# FREETZ_LIB_libswscale is not set
# Video codecs
# Vorbis video codec ---------------------
# FREETZ_LIB_libvorbis is not set
# FREETZ_LIB_libvorbisenc is not set
# FREETZ_LIB_libvorbisfile is not set
# ID3 tag reading libs
# FREETZ_LIB_libid3tag is not set
# FREETZ_LIB_libtag is not set
# ncurses
# FREETZ_LIB_libncurses is not set
# terminfo database
# Select terminfo database entries to install (see help of 'Show all items')
# FREETZ_SHARE_terminfo is not set
# FREETZ_LIB_libform is not set
# FREETZ_LIB_libmenu is not set
# FREETZ_LIB_libpanel is not set
# Networking
# ATM ------------------------------------
# FREETZ_LIB_libatm is not set
# Bluetooth ------------------------------
# FREETZ_LIB_libbluetooth is not set
# FREETZ_LIB_libopenobex is not set
# ISDN & CAPI ----------------------------
# FREETZ_LIB_libcapi20 is not set
# Misc networking ------------------------
# FREETZ_LIB_libdnet is not set
# FREETZ_LIB_libgsm is not set
# FREETZ_LIB_libiksemel is not set
# FREETZ_LIB_libpcap is not set
# FREETZ_LIB_libnet is not set
# FREETZ_LIB_liboping is not set
# FREETZ_LIB_libosip2 is not set
# FREETZ_LIB_libosipparser2 is not set
# FREETZ_LIB_libspandsp is not set
# FREETZ_LIB_libsrtp is not set
# PJ Project
# FREETZ_LIB_libpj is not set
# FREETZ_LIB_libpjlib_util is not set
# FREETZ_LIB_libpjmedia is not set
# FREETZ_LIB_libpjmedia_audiodev is not set
# FREETZ_LIB_libpjmedia_codec is not set
# FREETZ_LIB_libpjmedia_videodev is not set
# FREETZ_LIB_libpjnath is not set
# FREETZ_LIB_libpjsip is not set
# FREETZ_LIB_libpjsip_simple is not set
# FREETZ_LIB_libpjsip_ua is not set
# FREETZ_LIB_libpjsua is not set
# 3rdparty libraries
# FREETZ_LIB_libg7221codec is not set
# FREETZ_LIB_libilbccodec is not set
# FREETZ_LIB_libmilenage is not set
# Readline
# FREETZ_LIB_libreadline is not set
# FREETZ_LIB_libhistory is not set
# Regular expressions
FREETZ_LIB_libpcre=y
FREETZ_LIB_libpcreposix=y
# uClibc
FREETZ_LIB_ld_uClibc=y
FREETZ_LIB_libcrypt=y
FREETZ_LIB_libdl=y
FREETZ_LIB_libm=y
FREETZ_LIB_libpthread=y
FREETZ_LIB_librt=y
# FREETZ_LIB_libthread_db is not set
FREETZ_LIB_libuClibc=y
# FREETZ_LIB_libutil is not set
# USB & FTDI
# FREETZ_LIB_libusb_0 is not set
# FREETZ_LIB_libusb_1 is not set
# FREETZ_LIB_libftdi is not set
# Web and WebDAV
# FREETZ_LIB_libcurl is not set
# FREETZ_LIB_libcurl_WITH_ZLIB is not set
# FREETZ_LIB_libjansson is not set
# FREETZ_LIB_libjs is not set
# FREETZ_LIB_libneon is not set
# FREETZ_LIB_libneon_WITH_SSL is not set
# FREETZ_LIB_libneon_WITH_ZLIB is not set
# FREETZ_LIB_libserf is not set
# XML & XSLT
# FREETZ_LIB_libexpat is not set
# FREETZ_LIB_libxml2 is not set
# FREETZ_LIB_libxml2_WITH_HTML is not set
# FREETZ_LIB_libxslt is not set
# FREETZ_LIB_libexslt is not set
# FREETZ_LIB_libattr is not set
# FREETZ_LIB_libcap is not set
# FREETZ_LIB_libdbus is not set
FREETZ_LIB_libgcc_s=y
# FREETZ_LIB_libconfig is not set
# FREETZ_LIB_libdaemon is not set
# FREETZ_LIB_libdevmapper is not set
# FREETZ_LIB_libelf is not set
# FREETZ_LIB_libev is not set
# FREETZ_LIB_libevent is not set
# FREETZ_LIB_libffi is not set
# FREETZ_LIB_libfakefile is not set
FREETZ_LIB_libctlmgr=y
# FREETZ_LIB_libmultid is not set
# FREETZ_LIB_libltdl is not set
# FREETZ_LIB_liblua is not set
# FREETZ_LIB_libpcsclite is not set
# FREETZ_LIB_libpopt is not set
# FREETZ_LIB_libprivatekeypassword is not set
# FREETZ_LIB_libprotobuf_c is not set
# FREETZ_LIB_librrd is not set
# FREETZ_LIB_librrd_th is not set
# FREETZ_LIB_libslang is not set
# FREETZ_LIB_libsynce is not set
# FREETZ_LIB_libsysfs is not set
# FREETZ_LIB_libwx_baseu is not set
# FREETZ_LIB_libyaml is not set
# Kernel modules
# FREETZ_MODULES_ALL is not set
# block
# FREETZ_MODULE_block2mtd is not set
# ndas
# FREETZ_MODULE_ndas_block is not set
# FREETZ_MODULE_ndas_core is not set
# FREETZ_MODULE_ndas_sal is not set
# crypto
# FREETZ_MODULE_arc4 is not set
# FREETZ_MODULE_aead is not set
# FREETZ_MODULE_cbc is not set
# FREETZ_MODULE_crypto_blkcipher is not set
# FREETZ_MODULE_crypto_hash is not set
# FREETZ_MODULE_crypto_wq is not set
# FREETZ_MODULE_cryptomgr is not set
# FREETZ_MODULE_rng is not set
# FREETZ_MODULE_sha1_generic is not set
# FREETZ_MODULE_sha256_generic is not set
# drivers
# FREETZ_MODULE_loop is not set
# FREETZ_MODULE_nbd is not set
# FREETZ_MODULE_cdrom is not set
# FREETZ_MODULE_capiconn is not set
# FREETZ_MODULE_nand is not set
# FREETZ_MODULE_ohio_nand is not set
# FREETZ_MODULE_dummy is not set
# FREETZ_MODULE_ppp_async is not set
# FREETZ_MODULE_ppp_deflate is not set
# FREETZ_MODULE_ppp_generic is not set
# FREETZ_MODULE_pppoe is not set
# FREETZ_MODULE_pppox is not set
# FREETZ_MODULE_ppp_mppe_mppc is not set
# FREETZ_MODULE_scsi_mod is not set
# FREETZ_MODULE_sd_mod is not set
# FREETZ_MODULE_sg is not set
# FREETZ_MODULE_sr_mod is not set
# FREETZ_MODULE_slhc is not set
# FREETZ_MODULE_usblp is not set
# FREETZ_MODULE_usb_storage is not set
# FREETZ_MODULE_usbmon is not set
# FREETZ_MODULE_usbcore is not set
# FREETZ_MODULE_usbip is not set
# FREETZ_MODULE_usbip_common_mod is not set
# FREETZ_MODULE_usbserial is not set
# FREETZ_MODULE_ipaq is not set
# FREETZ_MODULE_cp210x is not set
# FREETZ_MODULE_pl2303 is not set
# FREETZ_MODULE_ftdi_sio is not set
# FREETZ_MODULE_bfusb is not set
# FREETZ_MODULE_btusb is not set
# FREETZ_MODULE_firmware_class is not set
# FREETZ_MODULE_dm_mod is not set
# FREETZ_MODULE_dm_crypt is not set
# FREETZ_MODULE_option is not set
# fs
# FREETZ_MODULE_autofs4 is not set
# FREETZ_MODULE_cifs is not set
# FREETZ_MODULE_coda is not set
# FREETZ_MODULE_ext4 is not set
FREETZ_MODULE_fat=y
# FREETZ_MODULE_hfs is not set
# FREETZ_MODULE_hfsplus is not set
FREETZ_MODULE_fuse=y
# FREETZ_MODULE_iso9660 is not set
# FREETZ_MODULE_jbd2 is not set
# FREETZ_MODULE_lockd is not set
# FREETZ_MODULE_mini_fo is not set
# FREETZ_MODULE_minix is not set
# FREETZ_MODULE_nfsd is not set
# FREETZ_MODULE_exportfs is not set
# FREETZ_MODULE_nfs is not set
# FREETZ_MODULE_reiserfs is not set
# FREETZ_MODULE_udf is not set
# FREETZ_MODULE_unionfs is not set
FREETZ_MODULE_vfat=y
FREETZ_MODULE_msdos=y
FREETZ_MODULE_jffs2=y
# FREETZ_MODULE_mbcache is not set
# lib
# FREETZ_MODULE_crc16 is not set
# FREETZ_MODULE_crc_ccitt is not set
# FREETZ_MODULE_lzo_compress is not set
# FREETZ_MODULE_lzo_decompress is not set
# net
# FREETZ_MODULE_bluetooth is not set
# FREETZ_MODULE_bnep is not set
# FREETZ_MODULE_cls_u32 is not set
# FREETZ_MODULE_l2cap is not set
# network scheduler
# FREETZ_MODULE_sch_cbq is not set
# FREETZ_MODULE_sch_htb is not set
# FREETZ_MODULE_sch_llq is not set
# FREETZ_MODULE_sch_sfq is not set
# FREETZ_MODULE_sch_tbf is not set
# FREETZ_MODULE_rfcomm is not set
# FREETZ_MODULE_sunrpc is not set
# Busybox applets
FREETZ_BUSYBOX__MANDATORY=y
FREETZ_BUSYBOX__MANDATORY_05_XX=y
FREETZ_BUSYBOX__IPV6_UTILS=y
# FREETZ_BUSYBOX__PACKER is not set
# FREETZ_BUSYBOX__NETWORK is not set
# FREETZ_BUSYBOX__TERMINAL is not set
# FREETZ_BUSYBOX__DEVELOPER is not set
FREETZ_BUSYBOX_HAVE_DOT_CONFIG=y
# Busybox Settings
# General Configuration
# FREETZ_BUSYBOX_EXTRA_COMPAT is not set
# FREETZ_BUSYBOX_INCLUDE_SUSv2 is not set
# FREETZ_BUSYBOX_USE_PORTABLE_CODE is not set
FREETZ_BUSYBOX_PLATFORM_LINUX=y
# FREETZ_BUSYBOX_FEATURE_BUFFERS_USE_MALLOC is not set
FREETZ_BUSYBOX_FEATURE_BUFFERS_GO_ON_STACK=y
# FREETZ_BUSYBOX_FEATURE_BUFFERS_GO_IN_BSS is not set
FREETZ_BUSYBOX_SHOW_USAGE=y
FREETZ_BUSYBOX_FEATURE_VERBOSE_USAGE=y
# FREETZ_BUSYBOX_FEATURE_COMPRESS_USAGE is not set
# FREETZ_BUSYBOX_FEATURE_INSTALLER is not set
# FREETZ_BUSYBOX_INSTALL_NO_USR is not set
# FREETZ_BUSYBOX_LOCALE_SUPPORT is not set
# FREETZ_BUSYBOX_UNICODE_SUPPORT is not set
# FREETZ_BUSYBOX_PAM is not set
# FREETZ_BUSYBOX_LONG_OPTS is not set
FREETZ_BUSYBOX_FEATURE_DEVPTS=y
# FREETZ_BUSYBOX_FEATURE_CLEAN_UP is not set
# FREETZ_BUSYBOX_FEATURE_UTMP is not set
FREETZ_BUSYBOX_FEATURE_PIDFILE=y
FREETZ_BUSYBOX_PID_FILE_PATH="/var/run"
FREETZ_BUSYBOX_FEATURE_SUID=y
# FREETZ_BUSYBOX_FEATURE_SUID_CONFIG is not set
# FREETZ_BUSYBOX_SELINUX is not set
FREETZ_BUSYBOX_FEATURE_PREFER_APPLETS=y
FREETZ_BUSYBOX_BUSYBOX_EXEC_PATH="/bin/busybox"
FREETZ_BUSYBOX_FEATURE_SYSLOG=y
FREETZ_BUSYBOX_FEATURE_HAVE_RPC=y
# Build Options
# FREETZ_BUSYBOX_STATIC is not set
# FREETZ_BUSYBOX_PIE is not set
# FREETZ_BUSYBOX_NOMMU is not set
FREETZ_BUSYBOX_LFS=y
FREETZ_BUSYBOX_CROSS_COMPILER_PREFIX=""
FREETZ_BUSYBOX_SYSROOT=""
FREETZ_BUSYBOX_EXTRA_CFLAGS=""
FREETZ_BUSYBOX_EXTRA_LDFLAGS=""
FREETZ_BUSYBOX_EXTRA_LDLIBS=""
# Debugging Options
# FREETZ_BUSYBOX_DEBUG is not set
# FREETZ_BUSYBOX_UNIT_TEST is not set
# FREETZ_BUSYBOX_WERROR is not set
FREETZ_BUSYBOX_NO_DEBUG_LIB=y
# FREETZ_BUSYBOX_DMALLOC is not set
# FREETZ_BUSYBOX_EFENCE is not set
# Installation Options ("make install" behavior)
FREETZ_BUSYBOX_INSTALL_APPLET_SYMLINKS=y
# FREETZ_BUSYBOX_INSTALL_APPLET_HARDLINKS is not set
# FREETZ_BUSYBOX_INSTALL_APPLET_SCRIPT_WRAPPERS is not set
# FREETZ_BUSYBOX_INSTALL_APPLET_DONT is not set
FREETZ_BUSYBOX_PREFIX="./_install"
# Busybox Library Tuning
# FREETZ_BUSYBOX_FEATURE_SYSTEMD is not set
# FREETZ_BUSYBOX_FEATURE_RTMINMAX is not set
FREETZ_BUSYBOX_PASSWORD_MINLEN=6
FREETZ_BUSYBOX_MD5_SMALL=1
FREETZ_BUSYBOX_SHA3_SMALL=1
# FREETZ_BUSYBOX_FEATURE_FAST_TOP is not set
# FREETZ_BUSYBOX_FEATURE_ETC_NETWORKS is not set
FREETZ_BUSYBOX_FEATURE_USE_TERMIOS=y
FREETZ_BUSYBOX_FEATURE_EDITING=y
FREETZ_BUSYBOX_FEATURE_EDITING_MAX_LEN=1024
# FREETZ_BUSYBOX_FEATURE_EDITING_VI is not set
FREETZ_BUSYBOX_FEATURE_EDITING_HISTORY=255
# FREETZ_BUSYBOX_FEATURE_EDITING_SAVEHISTORY is not set
FREETZ_BUSYBOX_FEATURE_TAB_COMPLETION=y
# FREETZ_BUSYBOX_FEATURE_USERNAME_COMPLETION is not set
FREETZ_BUSYBOX_FEATURE_EDITING_FANCY_PROMPT=y
# FREETZ_BUSYBOX_FEATURE_EDITING_ASK_TERMINAL is not set
FREETZ_BUSYBOX_FEATURE_NON_POSIX_CP=y
# FREETZ_BUSYBOX_FEATURE_VERBOSE_CP_MESSAGE is not set
FREETZ_BUSYBOX_FEATURE_COPYBUF_KB=64
FREETZ_BUSYBOX_FEATURE_SKIP_ROOTFS=y
FREETZ_BUSYBOX_MONOTONIC_SYSCALL=y
FREETZ_BUSYBOX_IOCTL_HEX2STR_ERROR=y
FREETZ_BUSYBOX_FEATURE_HWIB=y
# Applets
# Archival Utilities
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_XZ is not set
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_LZMA is not set
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_BZ2 is not set
FREETZ_BUSYBOX_FEATURE_SEAMLESS_GZ=y
# FREETZ_BUSYBOX_FEATURE_SEAMLESS_Z is not set
# FREETZ_BUSYBOX_AR is not set
# FREETZ_BUSYBOX_UNCOMPRESS is not set
FREETZ_BUSYBOX_GUNZIP=y
FREETZ_BUSYBOX_BUNZIP2=y
# FREETZ_BUSYBOX_UNLZMA is not set
FREETZ_BUSYBOX_UNXZ=y
FREETZ_BUSYBOX_XZ=y
FREETZ_BUSYBOX_BZIP2=y
# FREETZ_BUSYBOX_CPIO is not set
# FREETZ_BUSYBOX_DPKG is not set
# FREETZ_BUSYBOX_DPKG_DEB is not set
FREETZ_BUSYBOX_GZIP=y
FREETZ_BUSYBOX_GZIP_FAST=0
# FREETZ_BUSYBOX_FEATURE_GZIP_LEVELS is not set
# FREETZ_BUSYBOX_LZOP is not set
# FREETZ_BUSYBOX_RPM2CPIO is not set
# FREETZ_BUSYBOX_RPM is not set
FREETZ_BUSYBOX_TAR=y
FREETZ_BUSYBOX_FEATURE_TAR_CREATE=y
# FREETZ_BUSYBOX_FEATURE_TAR_AUTODETECT is not set
FREETZ_BUSYBOX_FEATURE_TAR_FROM=y
FREETZ_BUSYBOX_FEATURE_TAR_OLDGNU_COMPATIBILITY=y
# FREETZ_BUSYBOX_FEATURE_TAR_OLDSUN_COMPATIBILITY is not set
FREETZ_BUSYBOX_FEATURE_TAR_GNU_EXTENSIONS=y
# FREETZ_BUSYBOX_FEATURE_TAR_UNAME_GNAME is not set
# FREETZ_BUSYBOX_FEATURE_TAR_NOPRESERVE_TIME is not set
FREETZ_BUSYBOX_UNZIP=y
# Coreutils
FREETZ_BUSYBOX_BASENAME=y
FREETZ_BUSYBOX_CAT=y
FREETZ_BUSYBOX_DATE=y
FREETZ_BUSYBOX_FEATURE_DATE_ISOFMT=y
# FREETZ_BUSYBOX_FEATURE_DATE_NANO is not set
FREETZ_BUSYBOX_FEATURE_DATE_COMPAT=y
FREETZ_BUSYBOX_DD=y
FREETZ_BUSYBOX_FEATURE_DD_SIGNAL_HANDLING=y
# FREETZ_BUSYBOX_FEATURE_DD_THIRD_STATUS_LINE is not set
FREETZ_BUSYBOX_FEATURE_DD_IBS_OBS=y
# FREETZ_BUSYBOX_FEATURE_DD_STATUS is not set
# FREETZ_BUSYBOX_HOSTID is not set
FREETZ_BUSYBOX_ID=y
FREETZ_BUSYBOX_GROUPS=y
# FREETZ_BUSYBOX_SHUF is not set
FREETZ_BUSYBOX_SYNC=y
# FREETZ_BUSYBOX_FEATURE_SYNC_FANCY is not set
FREETZ_BUSYBOX_TEST=y
# FREETZ_BUSYBOX_FEATURE_TEST_64 is not set
FREETZ_BUSYBOX_TOUCH=y
# FREETZ_BUSYBOX_FEATURE_TOUCH_NODEREF is not set
FREETZ_BUSYBOX_FEATURE_TOUCH_SUSV3=y
FREETZ_BUSYBOX_TR=y
FREETZ_BUSYBOX_FEATURE_TR_CLASSES=y
FREETZ_BUSYBOX_FEATURE_TR_EQUIV=y
# FREETZ_BUSYBOX_TRUNCATE is not set
# FREETZ_BUSYBOX_UNLINK is not set
# FREETZ_BUSYBOX_BASE64 is not set
# FREETZ_BUSYBOX_CAL is not set
# FREETZ_BUSYBOX_CATV is not set
FREETZ_BUSYBOX_CHGRP=y
FREETZ_BUSYBOX_CHMOD=y
FREETZ_BUSYBOX_CHOWN=y
FREETZ_BUSYBOX_CHROOT=y
# FREETZ_BUSYBOX_CKSUM is not set
# FREETZ_BUSYBOX_COMM is not set
FREETZ_BUSYBOX_CP=y
FREETZ_BUSYBOX_CUT=y
FREETZ_BUSYBOX_DF=y
# FREETZ_BUSYBOX_FEATURE_DF_FANCY is not set
FREETZ_BUSYBOX_DIRNAME=y
# FREETZ_BUSYBOX_DOS2UNIX is not set
FREETZ_BUSYBOX_DU=y
FREETZ_BUSYBOX_FEATURE_DU_DEFAULT_BLOCKSIZE_1K=y
FREETZ_BUSYBOX_ECHO=y
FREETZ_BUSYBOX_FEATURE_FANCY_ECHO=y
FREETZ_BUSYBOX_ENV=y
# FREETZ_BUSYBOX_EXPAND is not set
FREETZ_BUSYBOX_EXPR=y
# FREETZ_BUSYBOX_EXPR_MATH_SUPPORT_64 is not set
FREETZ_BUSYBOX_FALSE=y
# FREETZ_BUSYBOX_FOLD is not set
# FREETZ_BUSYBOX_FSYNC is not set
FREETZ_BUSYBOX_HEAD=y
FREETZ_BUSYBOX_FEATURE_FANCY_HEAD=y
# FREETZ_BUSYBOX_INSTALL is not set
FREETZ_BUSYBOX_LN=y
FREETZ_BUSYBOX_LOGNAME=y
FREETZ_BUSYBOX_LS=y
FREETZ_BUSYBOX_FEATURE_LS_FILETYPES=y
FREETZ_BUSYBOX_FEATURE_LS_FOLLOWLINKS=y
FREETZ_BUSYBOX_FEATURE_LS_RECURSIVE=y
FREETZ_BUSYBOX_FEATURE_LS_SORTFILES=y
FREETZ_BUSYBOX_FEATURE_LS_TIMESTAMPS=y
FREETZ_BUSYBOX_FEATURE_LS_USERNAME=y
FREETZ_BUSYBOX_MD5SUM=y
FREETZ_BUSYBOX_MKDIR=y
FREETZ_BUSYBOX_MKFIFO=y
FREETZ_BUSYBOX_MKNOD=y
FREETZ_BUSYBOX_MV=y
FREETZ_BUSYBOX_NICE=y
FREETZ_BUSYBOX_NOHUP=y
# FREETZ_BUSYBOX_OD is not set
FREETZ_BUSYBOX_PRINTENV=y
FREETZ_BUSYBOX_PRINTF=y
FREETZ_BUSYBOX_PWD=y
FREETZ_BUSYBOX_READLINK=y
FREETZ_BUSYBOX_FEATURE_READLINK_FOLLOW=y
FREETZ_BUSYBOX_REALPATH=y
FREETZ_BUSYBOX_RM=y
FREETZ_BUSYBOX_RMDIR=y
FREETZ_BUSYBOX_SEQ=y
# FREETZ_BUSYBOX_SHA1SUM is not set
# FREETZ_BUSYBOX_SHA256SUM is not set
# FREETZ_BUSYBOX_SHA512SUM is not set
# FREETZ_BUSYBOX_SHA3SUM is not set
FREETZ_BUSYBOX_SLEEP=y
FREETZ_BUSYBOX_FEATURE_FANCY_SLEEP=y
# FREETZ_BUSYBOX_FEATURE_FLOAT_SLEEP is not set
FREETZ_BUSYBOX_SORT=y
# FREETZ_BUSYBOX_FEATURE_SORT_BIG is not set
# FREETZ_BUSYBOX_SPLIT is not set
FREETZ_BUSYBOX_STAT=y
FREETZ_BUSYBOX_FEATURE_STAT_FORMAT=y
FREETZ_BUSYBOX_STTY=y
# FREETZ_BUSYBOX_SUM is not set
# FREETZ_BUSYBOX_TAC is not set
FREETZ_BUSYBOX_TAIL=y
FREETZ_BUSYBOX_FEATURE_FANCY_TAIL=y
FREETZ_BUSYBOX_TEE=y
FREETZ_BUSYBOX_FEATURE_TEE_USE_BLOCK_IO=y
FREETZ_BUSYBOX_TRUE=y
FREETZ_BUSYBOX_TTY=y
FREETZ_BUSYBOX_UNAME=y
FREETZ_BUSYBOX_UNAME_OSNAME="GNU/Linux"
# FREETZ_BUSYBOX_UNEXPAND is not set
FREETZ_BUSYBOX_UNIQ=y
# FREETZ_BUSYBOX_USLEEP is not set
FREETZ_BUSYBOX_UUDECODE=y
# FREETZ_BUSYBOX_UUENCODE is not set
FREETZ_BUSYBOX_WC=y
# FREETZ_BUSYBOX_FEATURE_WC_LARGE is not set
# FREETZ_BUSYBOX_WHOAMI is not set
FREETZ_BUSYBOX_YES=y
# Common options
# FREETZ_BUSYBOX_FEATURE_VERBOSE is not set
# Common options for cp and mv
# FREETZ_BUSYBOX_FEATURE_PRESERVE_HARDLINKS is not set
# Common options for ls, more and telnet
FREETZ_BUSYBOX_FEATURE_AUTOWIDTH=y
# Common options for df, du, ls
FREETZ_BUSYBOX_FEATURE_HUMAN_READABLE=y
# Common options for md5sum, sha1sum, sha256sum, sha512sum, sha3sum
FREETZ_BUSYBOX_FEATURE_MD5_SHA1_SUM_CHECK=y
# Console Utilities
# FREETZ_BUSYBOX_CHVT is not set
FREETZ_BUSYBOX_FGCONSOLE=y
# FREETZ_BUSYBOX_CLEAR is not set
# FREETZ_BUSYBOX_DEALLOCVT is not set
# FREETZ_BUSYBOX_DUMPKMAP is not set
# FREETZ_BUSYBOX_KBD_MODE is not set
# FREETZ_BUSYBOX_LOADFONT is not set
# FREETZ_BUSYBOX_LOADKMAP is not set
# FREETZ_BUSYBOX_OPENVT is not set
FREETZ_BUSYBOX_RESET=y
# FREETZ_BUSYBOX_RESIZE is not set
FREETZ_BUSYBOX_SETCONSOLE=y
# FREETZ_BUSYBOX_SETFONT is not set
# FREETZ_BUSYBOX_SETKEYCODES is not set
# FREETZ_BUSYBOX_SETLOGCONS is not set
# FREETZ_BUSYBOX_SHOWKEY is not set
# Debian Utilities
# FREETZ_BUSYBOX_MKTEMP is not set
# FREETZ_BUSYBOX_PIPE_PROGRESS is not set
# FREETZ_BUSYBOX_RUN_PARTS is not set
# FREETZ_BUSYBOX_START_STOP_DAEMON is not set
FREETZ_BUSYBOX_WHICH=y
# Editors
FREETZ_BUSYBOX_AWK=y
# FREETZ_BUSYBOX_FEATURE_AWK_LIBM is not set
# FREETZ_BUSYBOX_FEATURE_AWK_GNU_EXTENSIONS is not set
FREETZ_BUSYBOX_CMP=y
# FREETZ_BUSYBOX_DIFF is not set
# FREETZ_BUSYBOX_ED is not set
# FREETZ_BUSYBOX_PATCH is not set
FREETZ_BUSYBOX_SED=y
FREETZ_BUSYBOX_VI=y
FREETZ_BUSYBOX_FEATURE_VI_MAX_LEN=1024
FREETZ_BUSYBOX_FEATURE_VI_8BIT=y
FREETZ_BUSYBOX_FEATURE_VI_COLON=y
FREETZ_BUSYBOX_FEATURE_VI_YANKMARK=y
FREETZ_BUSYBOX_FEATURE_VI_SEARCH=y
# FREETZ_BUSYBOX_FEATURE_VI_REGEX_SEARCH is not set
FREETZ_BUSYBOX_FEATURE_VI_USE_SIGNALS=y
FREETZ_BUSYBOX_FEATURE_VI_DOT_CMD=y
FREETZ_BUSYBOX_FEATURE_VI_READONLY=y
FREETZ_BUSYBOX_FEATURE_VI_SETOPTS=y
FREETZ_BUSYBOX_FEATURE_VI_SET=y
FREETZ_BUSYBOX_FEATURE_VI_WIN_RESIZE=y
FREETZ_BUSYBOX_FEATURE_VI_ASK_TERMINAL=y
# FREETZ_BUSYBOX_FEATURE_VI_UNDO is not set
FREETZ_BUSYBOX_FEATURE_ALLOW_EXEC=y
# Finding Utilities
FREETZ_BUSYBOX_FIND=y
FREETZ_BUSYBOX_FEATURE_FIND_PRINT0=y
FREETZ_BUSYBOX_FEATURE_FIND_MTIME=y
FREETZ_BUSYBOX_FEATURE_FIND_MMIN=y
FREETZ_BUSYBOX_FEATURE_FIND_PERM=y
FREETZ_BUSYBOX_FEATURE_FIND_TYPE=y
FREETZ_BUSYBOX_FEATURE_FIND_XDEV=y
FREETZ_BUSYBOX_FEATURE_FIND_MAXDEPTH=y
FREETZ_BUSYBOX_FEATURE_FIND_NEWER=y
FREETZ_BUSYBOX_FEATURE_FIND_INUM=y
FREETZ_BUSYBOX_FEATURE_FIND_EXEC=y
# FREETZ_BUSYBOX_FEATURE_FIND_EXEC_PLUS is not set
FREETZ_BUSYBOX_FEATURE_FIND_USER=y
FREETZ_BUSYBOX_FEATURE_FIND_GROUP=y
FREETZ_BUSYBOX_FEATURE_FIND_NOT=y
FREETZ_BUSYBOX_FEATURE_FIND_DEPTH=y
FREETZ_BUSYBOX_FEATURE_FIND_PAREN=y
FREETZ_BUSYBOX_FEATURE_FIND_SIZE=y
FREETZ_BUSYBOX_FEATURE_FIND_PRUNE=y
# FREETZ_BUSYBOX_FEATURE_FIND_DELETE is not set
FREETZ_BUSYBOX_FEATURE_FIND_PATH=y
FREETZ_BUSYBOX_FEATURE_FIND_REGEX=y
# FREETZ_BUSYBOX_FEATURE_FIND_LINKS is not set
FREETZ_BUSYBOX_GREP=y
FREETZ_BUSYBOX_FEATURE_GREP_EGREP_ALIAS=y
FREETZ_BUSYBOX_FEATURE_GREP_FGREP_ALIAS=y
FREETZ_BUSYBOX_FEATURE_GREP_CONTEXT=y
FREETZ_BUSYBOX_XARGS=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_CONFIRMATION=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_QUOTES=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_TERMOPT=y
FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_ZERO_TERM=y
# FREETZ_BUSYBOX_FEATURE_XARGS_SUPPORT_REPL_STR is not set
# Init Utilities
# FREETZ_BUSYBOX_BOOTCHARTD is not set
FREETZ_BUSYBOX_HALT=y
FREETZ_BUSYBOX_INIT=y
FREETZ_BUSYBOX_FEATURE_USE_INITTAB=y
FREETZ_BUSYBOX_FEATURE_KILL_REMOVED=y
FREETZ_BUSYBOX_FEATURE_KILL_DELAY=0
# FREETZ_BUSYBOX_FEATURE_INIT_SCTTY is not set
FREETZ_BUSYBOX_FEATURE_INIT_SYSLOG=y
# FREETZ_BUSYBOX_FEATURE_EXTRA_QUIET is not set
# FREETZ_BUSYBOX_FEATURE_INIT_COREDUMPS is not set
# FREETZ_BUSYBOX_FEATURE_INITRD is not set
FREETZ_BUSYBOX_INIT_TERMINAL_TYPE="linux"
# FREETZ_BUSYBOX_MESG is not set
# Login/Password Management Utilities
# FREETZ_BUSYBOX_ADD_SHELL is not set
# FREETZ_BUSYBOX_REMOVE_SHELL is not set
FREETZ_BUSYBOX_FEATURE_SHADOWPASSWDS=y
# FREETZ_BUSYBOX_USE_BB_PWD_GRP is not set
FREETZ_BUSYBOX_USE_BB_CRYPT=y
# FREETZ_BUSYBOX_USE_BB_CRYPT_SHA is not set
FREETZ_BUSYBOX_ADDUSER=y
# FREETZ_BUSYBOX_FEATURE_CHECK_NAMES is not set
FREETZ_BUSYBOX_LAST_ID=60000
FREETZ_BUSYBOX_FIRST_SYSTEM_ID=100
FREETZ_BUSYBOX_LAST_SYSTEM_ID=999
FREETZ_BUSYBOX_ADDGROUP=y
FREETZ_BUSYBOX_FEATURE_ADDUSER_TO_GROUP=y
FREETZ_BUSYBOX_DELUSER=y
FREETZ_BUSYBOX_DELGROUP=y
FREETZ_BUSYBOX_FEATURE_DEL_USER_FROM_GROUP=y
# FREETZ_BUSYBOX_GETTY is not set
FREETZ_BUSYBOX_LOGIN=y
# FREETZ_BUSYBOX_LOGIN_SESSION_AS_CHILD is not set
# FREETZ_BUSYBOX_LOGIN_SCRIPTS is not set
# FREETZ_BUSYBOX_FEATURE_NOLOGIN is not set
# FREETZ_BUSYBOX_FEATURE_SECURETTY is not set
FREETZ_BUSYBOX_PASSWD=y
FREETZ_BUSYBOX_FEATURE_PASSWD_WEAK_CHECK=y
FREETZ_BUSYBOX_CRYPTPW=y
# FREETZ_BUSYBOX_CHPASSWD is not set
FREETZ_BUSYBOX_FEATURE_DEFAULT_PASSWD_ALGO="des"
# FREETZ_BUSYBOX_SU is not set
# FREETZ_BUSYBOX_SULOGIN is not set
# FREETZ_BUSYBOX_VLOCK is not set
# Linux Ext2 FS Progs
# FREETZ_BUSYBOX_CHATTR is not set
# FREETZ_BUSYBOX_FSCK is not set
# FREETZ_BUSYBOX_LSATTR is not set
# FREETZ_BUSYBOX_TUNE2FS is not set
# Linux Module Utilities
# FREETZ_BUSYBOX_MODINFO is not set
# FREETZ_BUSYBOX_MODPROBE_SMALL is not set
FREETZ_BUSYBOX_INSMOD=y
FREETZ_BUSYBOX_RMMOD=y
FREETZ_BUSYBOX_LSMOD=y
FREETZ_BUSYBOX_FEATURE_LSMOD_PRETTY_2_6_OUTPUT=y
FREETZ_BUSYBOX_MODPROBE=y
# FREETZ_BUSYBOX_FEATURE_MODPROBE_BLACKLIST is not set
# FREETZ_BUSYBOX_DEPMOD is not set
# Options common to multiple modutils
# FREETZ_BUSYBOX_FEATURE_2_4_MODULES is not set
# FREETZ_BUSYBOX_FEATURE_INSMOD_TRY_MMAP is not set
FREETZ_BUSYBOX_FEATURE_CHECK_TAINTED_MODULE=y
# FREETZ_BUSYBOX_FEATURE_MODUTILS_ALIAS is not set
# FREETZ_BUSYBOX_FEATURE_MODUTILS_SYMBOLS is not set
FREETZ_BUSYBOX_DEFAULT_MODULES_DIR="/lib/modules"
FREETZ_BUSYBOX_DEFAULT_DEPMOD_FILE="modules.dep"
# Linux System Utilities
# FREETZ_BUSYBOX_BLOCKDEV is not set
# FREETZ_BUSYBOX_FATATTR is not set
# FREETZ_BUSYBOX_FSTRIM is not set
# FREETZ_BUSYBOX_MDEV is not set
FREETZ_BUSYBOX_MOUNT=y
# FREETZ_BUSYBOX_FEATURE_MOUNT_FAKE is not set
FREETZ_BUSYBOX_FEATURE_MOUNT_VERBOSE=y
# FREETZ_BUSYBOX_FEATURE_MOUNT_HELPERS is not set
# FREETZ_BUSYBOX_FEATURE_MOUNT_LABEL is not set
FREETZ_BUSYBOX_FEATURE_MOUNT_NFS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_CIFS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_FLAGS=y
FREETZ_BUSYBOX_FEATURE_MOUNT_FSTAB=y
# FREETZ_BUSYBOX_FEATURE_MOUNT_OTHERTAB is not set
# FREETZ_BUSYBOX_REV is not set
# FREETZ_BUSYBOX_UEVENT is not set
# FREETZ_BUSYBOX_ACPID is not set
FREETZ_BUSYBOX_BLKID=y
FREETZ_BUSYBOX_FEATURE_BLKID_TYPE=y
FREETZ_BUSYBOX_DMESG=y
FREETZ_BUSYBOX_FEATURE_DMESG_PRETTY=y
# FREETZ_BUSYBOX_FBSET is not set
# FREETZ_BUSYBOX_FDFLUSH is not set
# FREETZ_BUSYBOX_FDFORMAT is not set
# FREETZ_BUSYBOX_FDISK is not set
# FREETZ_BUSYBOX_FINDFS is not set
FREETZ_BUSYBOX_FLOCK=y
# FREETZ_BUSYBOX_FREERAMDISK is not set
# FREETZ_BUSYBOX_FSCK_MINIX is not set
# FREETZ_BUSYBOX_MKFS_EXT2 is not set
# FREETZ_BUSYBOX_MKFS_MINIX is not set
# FREETZ_BUSYBOX_MKFS_REISER is not set
# FREETZ_BUSYBOX_MKFS_VFAT is not set
FREETZ_BUSYBOX_GETOPT=y
FREETZ_BUSYBOX_FEATURE_GETOPT_LONG=y
# FREETZ_BUSYBOX_HEXDUMP is not set
# FREETZ_BUSYBOX_HWCLOCK is not set
# FREETZ_BUSYBOX_IPCRM is not set
# FREETZ_BUSYBOX_IPCS is not set
# FREETZ_BUSYBOX_LOSETUP is not set
# FREETZ_BUSYBOX_LSPCI is not set
# FREETZ_BUSYBOX_LSUSB is not set
FREETZ_BUSYBOX_MKSWAP=y
# FREETZ_BUSYBOX_FEATURE_MKSWAP_UUID is not set
FREETZ_BUSYBOX_MORE=y
FREETZ_BUSYBOX_PIVOT_ROOT=y
# FREETZ_BUSYBOX_RDATE is not set
# FREETZ_BUSYBOX_RDEV is not set
# FREETZ_BUSYBOX_READPROFILE is not set
# FREETZ_BUSYBOX_RTCWAKE is not set
# FREETZ_BUSYBOX_SCRIPT is not set
# FREETZ_BUSYBOX_SCRIPTREPLAY is not set
# FREETZ_BUSYBOX_SETARCH is not set
FREETZ_BUSYBOX_SWAPONOFF=y
# FREETZ_BUSYBOX_FEATURE_SWAPON_DISCARD is not set
# FREETZ_BUSYBOX_FEATURE_SWAPON_PRI is not set
FREETZ_BUSYBOX_SWITCH_ROOT=y
FREETZ_BUSYBOX_UMOUNT=y
FREETZ_BUSYBOX_FEATURE_UMOUNT_ALL=y
# Common options for mount/umount
FREETZ_BUSYBOX_FEATURE_MOUNT_LOOP=y
FREETZ_BUSYBOX_FEATURE_MOUNT_LOOP_CREATE=y
# FREETZ_BUSYBOX_FEATURE_MTAB_SUPPORT is not set
FREETZ_BUSYBOX_VOLUMEID=y
# Filesystem/Volume identification
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_BTRFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_CRAMFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_EXFAT is not set
FREETZ_BUSYBOX_FEATURE_VOLUMEID_EXT=y
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_F2FS is not set
FREETZ_BUSYBOX_FEATURE_VOLUMEID_FAT=y
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_HFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_ISO9660 is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_JFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_LINUXRAID is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_LINUXSWAP is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_LUKS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_NILFS is not set
FREETZ_BUSYBOX_FEATURE_VOLUMEID_NTFS=y
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_OCFS2 is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_REISERFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_ROMFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_SQUASHFS is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_SYSV is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_UDF is not set
# FREETZ_BUSYBOX_FEATURE_VOLUMEID_XFS is not set
# Miscellaneous Utilities
# FREETZ_BUSYBOX_CONSPY is not set
FREETZ_BUSYBOX_CROND=y
# FREETZ_BUSYBOX_FEATURE_CROND_D is not set
# FREETZ_BUSYBOX_FEATURE_CROND_CALL_SENDMAIL is not set
# FREETZ_BUSYBOX_FEATURE_CROND_ROOT_NOLOG is not set
FREETZ_BUSYBOX_FEATURE_CROND_DIR="/var/spool/cron"
# FREETZ_BUSYBOX_I2CGET is not set
# FREETZ_BUSYBOX_I2CSET is not set
# FREETZ_BUSYBOX_I2CDUMP is not set
# FREETZ_BUSYBOX_I2CDETECT is not set
# FREETZ_BUSYBOX_LESS is not set
# FREETZ_BUSYBOX_NANDWRITE is not set
# FREETZ_BUSYBOX_NANDDUMP is not set
# FREETZ_BUSYBOX_RFKILL is not set
FREETZ_BUSYBOX_SETSERIAL=y
# FREETZ_BUSYBOX_TASKSET is not set
# FREETZ_BUSYBOX_UBIATTACH is not set
# FREETZ_BUSYBOX_UBIDETACH is not set
# FREETZ_BUSYBOX_UBIMKVOL is not set
# FREETZ_BUSYBOX_UBIRMVOL is not set
# FREETZ_BUSYBOX_UBIRSVOL is not set
# FREETZ_BUSYBOX_UBIUPDATEVOL is not set
# FREETZ_BUSYBOX_ADJTIMEX is not set
# FREETZ_BUSYBOX_BBCONFIG is not set
# FREETZ_BUSYBOX_BEEP is not set
# FREETZ_BUSYBOX_CHAT is not set
# FREETZ_BUSYBOX_CHRT is not set
FREETZ_BUSYBOX_CRONTAB=y
# FREETZ_BUSYBOX_DC is not set
# FREETZ_BUSYBOX_DEVFSD is not set
# FREETZ_BUSYBOX_FEATURE_DEVFS is not set
# FREETZ_BUSYBOX_DEVMEM is not set
# FREETZ_BUSYBOX_EJECT is not set
# FREETZ_BUSYBOX_FBSPLASH is not set
# FREETZ_BUSYBOX_FLASHCP is not set
# FREETZ_BUSYBOX_FLASH_LOCK is not set
# FREETZ_BUSYBOX_FLASH_UNLOCK is not set
# FREETZ_BUSYBOX_FLASH_ERASEALL is not set
# FREETZ_BUSYBOX_IONICE is not set
# FREETZ_BUSYBOX_INOTIFYD is not set
# FREETZ_BUSYBOX_HDPARM is not set
FREETZ_BUSYBOX_MAKEDEVS=y
# FREETZ_BUSYBOX_FEATURE_MAKEDEVS_LEAF is not set
FREETZ_BUSYBOX_FEATURE_MAKEDEVS_TABLE=y
# FREETZ_BUSYBOX_MAN is not set
# FREETZ_BUSYBOX_MICROCOM is not set
# FREETZ_BUSYBOX_MOUNTPOINT is not set
# FREETZ_BUSYBOX_MT is not set
# FREETZ_BUSYBOX_RAIDAUTORUN is not set
# FREETZ_BUSYBOX_READAHEAD is not set
# FREETZ_BUSYBOX_RX is not set
# FREETZ_BUSYBOX_SETSID is not set
# FREETZ_BUSYBOX_STRINGS is not set
FREETZ_BUSYBOX_TIME=y
# FREETZ_BUSYBOX_TIMEOUT is not set
# FREETZ_BUSYBOX_TTYSIZE is not set
# FREETZ_BUSYBOX_VOLNAME is not set
# FREETZ_BUSYBOX_WATCHDOG is not set
# Networking Utilities
# FREETZ_BUSYBOX_NAMEIF is not set
FREETZ_BUSYBOX_NBDCLIENT=y
FREETZ_BUSYBOX_NC=y
# FREETZ_BUSYBOX_NC_SERVER is not set
FREETZ_BUSYBOX_NC_EXTRA=y
# FREETZ_BUSYBOX_NC_110_COMPAT is not set
FREETZ_BUSYBOX_PING=y
FREETZ_BUSYBOX_PING6=y
FREETZ_BUSYBOX_FEATURE_FANCY_PING=y
FREETZ_BUSYBOX_STUN_IP=y
FREETZ_BUSYBOX_WHOIS=y
FREETZ_BUSYBOX_FEATURE_IPV6=y
# FREETZ_BUSYBOX_FEATURE_UNIX_LOCAL is not set
FREETZ_BUSYBOX_FEATURE_PREFER_IPV4_ADDRESS=y
# FREETZ_BUSYBOX_VERBOSE_RESOLUTION_ERRORS is not set
FREETZ_BUSYBOX_ARP=y
FREETZ_BUSYBOX_ARPING=y
FREETZ_BUSYBOX_BRCTL=y
FREETZ_BUSYBOX_FEATURE_BRCTL_FANCY=y
FREETZ_BUSYBOX_FEATURE_BRCTL_SHOW=y
# FREETZ_BUSYBOX_DNSD is not set
FREETZ_BUSYBOX_ETHER_WAKE=y
# FREETZ_BUSYBOX_FAKEIDENTD is not set
# FREETZ_BUSYBOX_FTPD is not set
FREETZ_BUSYBOX_FTPGET=y
FREETZ_BUSYBOX_FTPPUT=y
FREETZ_BUSYBOX_HOSTNAME=y
FREETZ_BUSYBOX_HTTPD=y
# FREETZ_BUSYBOX_FEATURE_HTTPD_RANGES is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_SETUID is not set
FREETZ_BUSYBOX_FEATURE_HTTPD_BASIC_AUTH=y
FREETZ_BUSYBOX_FEATURE_HTTPD_AUTH_MD5=y
FREETZ_BUSYBOX_FEATURE_HTTPD_CGI=y
FREETZ_BUSYBOX_FEATURE_HTTPD_CONFIG_WITH_SCRIPT_INTERPR=y
# FREETZ_BUSYBOX_FEATURE_HTTPD_SET_REMOTE_PORT_TO_ENV is not set
FREETZ_BUSYBOX_FEATURE_HTTPD_ENCODE_URL_STR=y
# FREETZ_BUSYBOX_FEATURE_HTTPD_ERROR_PAGES is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_PROXY is not set
# FREETZ_BUSYBOX_FEATURE_HTTPD_GZIP is not set
FREETZ_BUSYBOX_IFCONFIG=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_STATUS=y
# FREETZ_BUSYBOX_FEATURE_IFCONFIG_SLIP is not set
# FREETZ_BUSYBOX_FEATURE_IFCONFIG_MEMSTART_IOADDR_IRQ is not set
FREETZ_BUSYBOX_FEATURE_IFCONFIG_HW=y
FREETZ_BUSYBOX_FEATURE_IFCONFIG_BROADCAST_PLUS=y
# FREETZ_BUSYBOX_IFENSLAVE is not set
# FREETZ_BUSYBOX_IFPLUGD is not set
FREETZ_BUSYBOX_IFUPDOWN=y
FREETZ_BUSYBOX_IFUPDOWN_IFSTATE_PATH="/var/run/ifstate"
# FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IP is not set
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IFCONFIG_BUILTIN=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IPV4=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_IPV6=y
FREETZ_BUSYBOX_FEATURE_IFUPDOWN_MAPPING=y
# FREETZ_BUSYBOX_FEATURE_IFUPDOWN_EXTERNAL_DHCP is not set
FREETZ_BUSYBOX_INETD=y
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_ECHO is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_DISCARD is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_TIME is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_DAYTIME is not set
# FREETZ_BUSYBOX_FEATURE_INETD_SUPPORT_BUILTIN_CHARGEN is not set
# FREETZ_BUSYBOX_FEATURE_INETD_RPC is not set
FREETZ_BUSYBOX_IP=y
FREETZ_BUSYBOX_FEATURE_IP_ADDRESS=y
FREETZ_BUSYBOX_FEATURE_IP_LINK=y
FREETZ_BUSYBOX_FEATURE_IP_ROUTE=y
FREETZ_BUSYBOX_FEATURE_IP_ROUTE_DIR="/etc/iproute2"
FREETZ_BUSYBOX_FEATURE_IP_TUNNEL=y
FREETZ_BUSYBOX_FEATURE_IP_RULE=y
FREETZ_BUSYBOX_FEATURE_IP_SHORT_FORMS=y
# FREETZ_BUSYBOX_FEATURE_IP_RARE_PROTOCOLS is not set
# FREETZ_BUSYBOX_IPADDR is not set
# FREETZ_BUSYBOX_IPLINK is not set
# FREETZ_BUSYBOX_IPROUTE is not set
# FREETZ_BUSYBOX_IPTUNNEL is not set
# FREETZ_BUSYBOX_IPRULE is not set
# FREETZ_BUSYBOX_IPCALC is not set
FREETZ_BUSYBOX_NETSTAT=y
# FREETZ_BUSYBOX_FEATURE_NETSTAT_WIDE is not set
FREETZ_BUSYBOX_FEATURE_NETSTAT_PRG=y
FREETZ_BUSYBOX_NSLOOKUP=y
# FREETZ_BUSYBOX_NTPD is not set
# FREETZ_BUSYBOX_PSCAN is not set
FREETZ_BUSYBOX_ROUTE=y
# FREETZ_BUSYBOX_SLATTACH is not set
# FREETZ_BUSYBOX_TCPSVD is not set
# FREETZ_BUSYBOX_TELNET is not set
FREETZ_BUSYBOX_TELNETD=y
FREETZ_BUSYBOX_FEATURE_TELNETD_STANDALONE=y
# FREETZ_BUSYBOX_FEATURE_TELNETD_INETD_WAIT is not set
FREETZ_BUSYBOX_TFTP=y
# FREETZ_BUSYBOX_TFTPD is not set
# Common options for tftp/tftpd
FREETZ_BUSYBOX_FEATURE_TFTP_GET=y
FREETZ_BUSYBOX_FEATURE_TFTP_PUT=y
# FREETZ_BUSYBOX_FEATURE_TFTP_BLOCKSIZE is not set
# FREETZ_BUSYBOX_TFTP_DEBUG is not set
FREETZ_BUSYBOX_TRACEROUTE=y
# FREETZ_BUSYBOX_TRACEROUTE6 is not set
# FREETZ_BUSYBOX_FEATURE_TRACEROUTE_VERBOSE is not set
# FREETZ_BUSYBOX_FEATURE_TRACEROUTE_SOURCE_ROUTE is not set
# FREETZ_BUSYBOX_FEATURE_TRACEROUTE_USE_ICMP is not set
# FREETZ_BUSYBOX_TUNCTL is not set
# FREETZ_BUSYBOX_UDHCPC6 is not set
# FREETZ_BUSYBOX_UDHCPD is not set
# FREETZ_BUSYBOX_UDHCPC is not set
# FREETZ_BUSYBOX_UDPSVD is not set
FREETZ_BUSYBOX_VCONFIG=y
# FREETZ_BUSYBOX_ZCIP is not set
# Print Utilities
# FREETZ_BUSYBOX_LPD is not set
# FREETZ_BUSYBOX_LPR is not set
# FREETZ_BUSYBOX_LPQ is not set
# Mail Utilities
# FREETZ_BUSYBOX_MAKEMIME is not set
# FREETZ_BUSYBOX_POPMAILDIR is not set
# FREETZ_BUSYBOX_REFORMIME is not set
# FREETZ_BUSYBOX_SENDMAIL is not set
# Process Utilities
FREETZ_BUSYBOX_IOSTAT=y
# FREETZ_BUSYBOX_LSOF is not set
FREETZ_BUSYBOX_MPSTAT=y
# FREETZ_BUSYBOX_NMETER is not set
FREETZ_BUSYBOX_PMAP=y
# FREETZ_BUSYBOX_POWERTOP is not set
FREETZ_BUSYBOX_PSTREE=y
FREETZ_BUSYBOX_PWDX=y
FREETZ_BUSYBOX_SMEMCAP=y
FREETZ_BUSYBOX_TOP=y
FREETZ_BUSYBOX_FEATURE_TOP_CPU_USAGE_PERCENTAGE=y
FREETZ_BUSYBOX_FEATURE_TOP_CPU_GLOBAL_PERCENTS=y
# FREETZ_BUSYBOX_FEATURE_TOP_SMP_CPU is not set
# FREETZ_BUSYBOX_FEATURE_TOP_DECIMALS is not set
# FREETZ_BUSYBOX_FEATURE_TOP_SMP_PROCESS is not set
# FREETZ_BUSYBOX_FEATURE_TOPMEM is not set
FREETZ_BUSYBOX_UPTIME=y
FREETZ_BUSYBOX_FREE=y
# FREETZ_BUSYBOX_FUSER is not set
FREETZ_BUSYBOX_KILL=y
FREETZ_BUSYBOX_KILLALL=y
FREETZ_BUSYBOX_KILLALL5=y
# FREETZ_BUSYBOX_PGREP is not set
FREETZ_BUSYBOX_PIDOF=y
FREETZ_BUSYBOX_FEATURE_PIDOF_SINGLE=y
FREETZ_BUSYBOX_FEATURE_PIDOF_OMIT=y
# FREETZ_BUSYBOX_PKILL is not set
FREETZ_BUSYBOX_PS=y
FREETZ_BUSYBOX_FEATURE_PS_WIDE=y
FREETZ_BUSYBOX_FEATURE_PS_LONG=y
FREETZ_BUSYBOX_RENICE=y
FREETZ_BUSYBOX_BB_SYSCTL=y
# FREETZ_BUSYBOX_FEATURE_SHOW_THREADS is not set
# FREETZ_BUSYBOX_WATCH is not set
# Runit Utilities
# FREETZ_BUSYBOX_RUNSV is not set
# FREETZ_BUSYBOX_RUNSVDIR is not set
# FREETZ_BUSYBOX_SV is not set
# FREETZ_BUSYBOX_SVLOGD is not set
# FREETZ_BUSYBOX_CHPST is not set
# FREETZ_BUSYBOX_SETUIDGID is not set
# FREETZ_BUSYBOX_ENVUIDGID is not set
# FREETZ_BUSYBOX_ENVDIR is not set
# FREETZ_BUSYBOX_SOFTLIMIT is not set
# Shells
FREETZ_BUSYBOX_ASH=y
FREETZ_BUSYBOX_ASH_BASH_COMPAT=y
# FREETZ_BUSYBOX_ASH_IDLE_TIMEOUT is not set
FREETZ_BUSYBOX_ASH_JOB_CONTROL=y
FREETZ_BUSYBOX_ASH_ALIAS=y
FREETZ_BUSYBOX_ASH_GETOPTS=y
FREETZ_BUSYBOX_ASH_BUILTIN_ECHO=y
FREETZ_BUSYBOX_ASH_BUILTIN_PRINTF=y
FREETZ_BUSYBOX_ASH_BUILTIN_TEST=y
# FREETZ_BUSYBOX_ASH_HELP is not set
FREETZ_BUSYBOX_ASH_CMDCMD=y
# FREETZ_BUSYBOX_ASH_MAIL is not set
FREETZ_BUSYBOX_ASH_OPTIMIZE_FOR_SIZE=y
# FREETZ_BUSYBOX_ASH_RANDOM_SUPPORT is not set
FREETZ_BUSYBOX_ASH_EXPAND_PRMT=y
# FREETZ_BUSYBOX_CTTYHACK is not set
# FREETZ_BUSYBOX_HUSH is not set
# FREETZ_BUSYBOX_MSH is not set
FREETZ_BUSYBOX_FEATURE_SH_IS_ASH=y
# FREETZ_BUSYBOX_FEATURE_SH_IS_NONE is not set
# FREETZ_BUSYBOX_FEATURE_BASH_IS_ASH is not set
FREETZ_BUSYBOX_FEATURE_BASH_IS_NONE=y
FREETZ_BUSYBOX_SH_MATH_SUPPORT=y
# FREETZ_BUSYBOX_SH_MATH_SUPPORT_64 is not set
# FREETZ_BUSYBOX_FEATURE_SH_EXTRA_QUIET is not set
FREETZ_BUSYBOX_FEATURE_SH_STANDALONE=y
FREETZ_BUSYBOX_FEATURE_SH_NOFORK=y
# FREETZ_BUSYBOX_FEATURE_SH_HISTFILESIZE is not set
# System Logging Utilities
FREETZ_BUSYBOX_SYSLOGD=y
FREETZ_BUSYBOX_FEATURE_ROTATE_LOGFILE=y
FREETZ_BUSYBOX_FEATURE_REMOTE_LOG=y
FREETZ_BUSYBOX_FEATURE_SYSLOGD_DUP=y
# FREETZ_BUSYBOX_FEATURE_SYSLOGD_CFG is not set
FREETZ_BUSYBOX_FEATURE_SYSLOGD_READ_BUFFER_SIZE=256
FREETZ_BUSYBOX_FEATURE_IPC_SYSLOG=y
FREETZ_BUSYBOX_FEATURE_IPC_SYSLOG_BUFFER_SIZE=16
FREETZ_BUSYBOX_LOGREAD=y
FREETZ_BUSYBOX_FEATURE_LOGREAD_REDUCED_LOCKING=y
# FREETZ_BUSYBOX_FEATURE_KMSG_SYSLOG is not set
FREETZ_BUSYBOX_KLOGD=y
FREETZ_BUSYBOX_FEATURE_KLOGD_KLOGCTL=y
FREETZ_BUSYBOX_LOGGER=y
# External processing
# EXTERNAL_ENABLED is not set
# Mod customizations ---------------------
# Web Interface
FREETZ_LANG_DE=y
# FREETZ_LANG_EN is not set
FREETZ_LANG_STRING="de"
FREETZ_SECURITY_LEVEL=0
FREETZ_STYLE_COLORED=y
# FREETZ_STYLE_GREY is not set
FREETZ_STYLE="colored"
# Freetz skins
FREETZ_SKIN_legacy=y
# FREETZ_SKIN_newfreetz is not set
# FREETZ_SKIN_phoenix is not set
FREETZ_FAVICON_NONE=y
# FREETZ_FAVICON_ATOMPHIL is not set
# FREETZ_FAVICON_CUMA is not set
# FREETZ_FAVICON_DSL123 is not set
# FREETZ_FAVICON_HANSOLO is not set
FREETZ_FAVICON_STRING="none"
FREETZ_TAGGING_NONE=y
# FREETZ_TAGGING_CUMA is not set
FREETZ_TAGGING_STRING="none"
# Additional image/box information
# FREETZ_REMOVE_BOX_INFO is not set
# FREETZ_REMOVE_FREETZ_INFO is not set
# FREETZ_MODIFY_AVM_VERSION is not set
FREETZ_USER_DEFINED_COMMENT=""
# FREETZ_CUSTOM_IMAGE_NAME is not set
FREETZ_CREATE_SEPARATE_OPTIONS_CFG=y
# FREETZ_REMOVE_DOT_CONFIG is not set
# Build system ---------------------------
# Toolchain options
FREETZ_DOWNLOAD_TOOLCHAIN=y
# FREETZ_BUILD_TOOLCHAIN is not set
# Kernel toolchain options ----------------------------------
FREETZ_KERNEL_BINUTILS_2_22=y
FREETZ_KERNEL_GCC_4_6=y
FREETZ_KERNEL_BINUTILS_VERSION="2.22"
FREETZ_KERNEL_GCC_VERSION="4.6.4"
# Target toolchain options ----------------------------------
FREETZ_TARGET_UCLIBC_0_9_32=y
# FREETZ_TARGET_UCLIBC_0_9_33 is not set
# FREETZ_TARGET_UCLIBC_SUPPORTS_libubacktrace is not set
FREETZ_TARGET_BINUTILS_2_22=y
FREETZ_TARGET_GCC_4_6=y
FREETZ_TARGET_GCC_DEFAULT_AS_NEEDED=y
FREETZ_STDCXXLIB_USE_UCLIBCXX=y
# FREETZ_STDCXXLIB_USE_GNULIBSTDCXX is not set
FREETZ_TARGET_UCLIBC_VERSION="0.9.32.1"
FREETZ_TARGET_BINUTILS_VERSION="2.22"
FREETZ_TARGET_GCC_MAJOR_VERSION="4.6"
FREETZ_TARGET_GCC_MINOR_VERSION="4"
FREETZ_TARGET_GCC_VERSION="${FREETZ_TARGET_GCC_MAJOR_VERSION}.${FREETZ_TARGET_GCC_MINOR_VERSION}"
FREETZ_GNULIBSTDCXX_VERSION="6.0.16"
FREETZ_STDCXXLIB="uclibcxx"
FREETZ_TARGET_CFLAGS="-Os -pipe -Wa,--trap"
FREETZ_RPATH="/usr/lib/freetz"
FREETZ_TARGET_UCLIBC_REDUCED_LOCALE_SET=y
# FREETZ_TARGET_NLS is not set
FREETZ_TARGET_LFS=y
# FREETZ_TARGET_TOOLCHAIN is not set
# Both kernel and target toolchain related options ----------
FREETZ_TOOLCHAIN_MINIMIZE_REQUIRED_GLIBC_VERSION=y
# FREETZ_TOOLCHAIN_32BIT is not set
# FREETZ_TOOLCHAIN_CCACHE is not set
# Build system options
FREETZ_VERBOSITY_LEVEL=2
FREETZ_SIZEINFO_COMPRESSED=y
# FREETZ_SIZEINFO_UNCOMPRESSED is not set
FREETZ_JLEVEL=2
FREETZ_CHECK_CHANGED=y
# FREETZ_BACKUP_CONFIG_CACHE is not set
# Firmware packaging (fwmod) options
# FREETZ_FWMOD_SKIP_UNPACK is not set
# FREETZ_FWMOD_SKIP_MODIFY is not set
# FREETZ_FWMOD_SKIP_PACK is not set
# FREETZ_FWMOD_FORCE_PACK is not set
# FREETZ_FWMOD_SIGN is not set
# FREETZ_FWMOD_USBROOT is not set
# FREETZ_FWMOD_NFSROOT is not set
# SquashFS options
# FREETZ_SQUASHFS_BLOCKSIZE_ORIG is not set
FREETZ_SQUASHFS_BLOCKSIZE_65536=y
FREETZ_SQUASHFS_BLOCKSIZE=65536
# Strip options
FREETZ_STRIP_BINARIES=y
# FREETZ_STRIP_LIBRARIES is not set
# FREETZ_STRIP_MODULES_NONE is not set
FREETZ_STRIP_MODULES_FREETZ=y
# FREETZ_STRIP_MODULES_ALL is not set
# FREETZ_STRIP_SCRIPTS is not set
# Override options
FREETZ_DL_SITE_USER=""
# FREETZ_DL_TOOLCHAIN_OVERRIDE is not set
FREETZ_DL_TOOLCHAIN_SITE=""
FREETZ_DL_KERNEL_TOOLCHAIN_VERSION="r13747"
FREETZ_DL_KERNEL_TOOLCHAIN_MD5="196314ea34c6c8385f5ec9992c4ebf1f"
FREETZ_DL_TARGET_TOOLCHAIN_VERSION="r13747"
FREETZ_DL_TARGET_TOOLCHAIN_MD5="d1d958aa6a18100cc58641f29b79106d"
FREETZ_DL_TOOLCHAIN_SUFFIX="shared-glibc"
# FREETZ_DL_OVERRIDE is not set
FREETZ_DL_KERNEL_SITE=""
FREETZ_DL_KERNEL_SOURCE_ID="7270_06.05"
FREETZ_DL_KERNEL_SOURCE="${FREETZ_DL_KERNEL_SOURCE_ID}-release_kernel.tar.xz"
FREETZ_DL_KERNEL_SOURCE_MD5="52d0d1bbcefd49834ff3e8e23f1277a4"
FREETZ_DL_SITE="@AVM/fritzbox.fon_wlan_7270_v3/firmware/deutsch,@1&1/7270v3"
FREETZ_DL_SOURCE="FRITZ.Box_Fon_WLAN_7270_v3.74.06.06.image"
FREETZ_DL_SOURCE_MD5="481362d9fc24549204d26252a8b12e4a"
FREETZ_DL_SOURCE_CONTAINER=""
FREETZ_DL_SOURCE_CONTAINER_MD5=""
# FREETZ_AVM_HAS_FIRMWARE_04_XX is not set
FREETZ_AVM_HAS_FIRMWARE_05_2X=y
# FREETZ_AVM_HAS_FIRMWARE_05_5X_VULNERABLE is not set
FREETZ_AVM_HAS_FIRMWARE_05_5X=y
# FREETZ_AVM_HAS_FIRMWARE_EWE_05_5X is not set
FREETZ_AVM_HAS_FIRMWARE_06_0X=y
# FREETZ_AVM_HAS_FIRMWARE_EWE_06_0X is not set
# FREETZ_AVM_HAS_FIRMWARE_06_2X is not set
# FREETZ_AVM_HAS_FIRMWARE_06_5X is not set
# FREETZ_AVM_HAS_FIRMWARE_LABOR is not set
FREETZ_AVM_HAS_LANG_DE=y
# FREETZ_AVM_HAS_LANG_A_CH is not set
FREETZ_AVM_HAS_LANG_EN=y
# FREETZ_AVM_HAS_LANG_EN_BE is not set
# FREETZ_AVM_HAS_LANG_IT is not set
FREETZ_AVM_HAS_AHA=y
FREETZ_AVM_HAS_DECT=y
FREETZ_AVM_HAS_FHEM=y
FREETZ_AVM_HAS_MYFRITZ=y
FREETZ_AVM_HAS_MULTI_ANNEX=y
# FREETZ_AVM_HAS_ANNEX_A_AND_B is not set
FREETZ_AVM_HAS_NAS=y
FREETZ_AVM_HAS_NTFS=y
FREETZ_AVM_HAS_PHONE=y
# FREETZ_AVM_HAS_PLUGINS_UPDATE is not set
FREETZ_AVM_HAS_TAM=y
# FREETZ_AVM_HAS_TEMPERATURE_SENSOR is not set
FREETZ_AVM_HAS_TR069=y
FREETZ_AVM_HAS_TR069_FWUPDATE=y
FREETZ_AVM_HAS_UDEV=y
FREETZ_AVM_HAS_UMTS=y
FREETZ_AVM_HAS_USB_HOST=y
# FREETZ_AVM_HAS_USB_HOST_AHCI is not set
FREETZ_AVM_HAS_AURA_USB=y
# FREETZ_AVM_HAS_ETHERNET_OVER_USB is not set
FREETZ_AVM_HAS_WEBDAV=y
FREETZ_AVM_HAS_WLAN=y
FREETZ_AVM_HAS_IPV6=y
FREETZ_AVM_HAS_PTY_SUPPORT=y
FREETZ_AVM_HAS_PRINTK=y
FREETZ_AVM_HAS_EXT2_BUILTIN=y
FREETZ_AVM_HAS_EXT3_BUILTIN=y
# FREETZ_AVM_HAS_EXT4_BUILTIN is not set
FREETZ_AVM_HAS_NLS_CP437_BUILTIN=y
FREETZ_AVM_HAS_NLS_ISO8859_1_BUILTIN=y
FREETZ_AVM_HAS_NLS_ISO8859_15_BUILTIN=y
FREETZ_AVM_HAS_NLS_UTF8_BUILTIN=y
# FREETZ_AVM_HAS_ISOFS is not set
FREETZ_AVM_HAS_JFFS2_MODULE=y
# FREETZ_AVM_HAS_JFFS2_BUILTIN is not set
FREETZ_AVM_HAS_RAMZSWAP=y
FREETZ_AVM_HAS_CRYPTO_ALGAPI_BUILTIN=y
# FREETZ_AVM_HAS_CRYPTO_AEAD_BUILTIN is not set
FREETZ_AVM_HAS_CRYPTO_AES_BUILTIN=y
# FREETZ_AVM_HAS_CRYPTO_ARC4_BUILTIN is not set
# FREETZ_AVM_HAS_CRYPTO_BLKCIPHER_BUILTIN is not set
# FREETZ_AVM_HAS_CRYPTO_CBC_BUILTIN is not set
# FREETZ_AVM_HAS_CRYPTO_HASH_BUILTIN is not set
# FREETZ_AVM_HAS_CRYPTO_MANAGER_BUILTIN is not set
FREETZ_AVM_HAS_CRYPTO_PCOMP_BUILTIN=y
# FREETZ_AVM_HAS_CRYPTO_RNG_BUILTIN is not set
# FREETZ_AVM_HAS_CRYPTO_SHA1_BUILTIN is not set
# FREETZ_AVM_HAS_CRYPTO_SHA256_BUILTIN is not set
# FREETZ_AVM_HAS_CRYPTO_WORKQUEUE_BUILTIN is not set
# FREETZ_AVM_HAS_CDROM_ISO is not set
FREETZ_AVM_HAS_CHRONYD=y
FREETZ_AVM_HAS_E2FSPROGS=y
FREETZ_AVM_HAS_INETD=y
FREETZ_AVM_HAS_LSOF=y
# FREETZ_AVM_HAS_MICROVOIP_DSL is not set
# FREETZ_AVM_HAS_MINID is not set
FREETZ_AVM_HAS_OPENSSL=y
FREETZ_AVM_HAS_OPENSSL_VERSION_0=y
# FREETZ_AVM_HAS_OPENSSL_VERSION_1 is not set
# FREETZ_AVM_HAS_PIGLET_POTS is not set
# FREETZ_AVM_HAS_PIGLET_ISDN is not set
# FREETZ_AVM_HAS_SOCAT is not set
# FREETZ_AVM_HAS_STRACE is not set
FREETZ_AVM_HAS_AR7CFG_V12_MIN=y
# FREETZ_AVM_HAS_ALLCFGCONV_WITH_DECRYPTION_SUPPORT is not set
# FREETZ_AVM_HAS_DEBUG_CFG_SUPPORT is not set
FREETZ_AVM_HAS_MULTID_LEASES_FORMAT_V2=y
FREETZ_AVM_SQUASHFS_VERSION=3
FREETZ_SQUASHFS_VERSION=3
FREETZ_AVM_SQUASHFS_COMPRESSION="lzma"
# FREETZ_AVM_HAS_NMI_VECTOR is not set
# FREETZ_AVM_HAS_UPDATE_FILESYSTEM_IMAGE is not set
# FREETZ_AVM_HAS_EXT2_PACKAGING_SCHEME is not set
FREETZ_AVM_VERSION_06_0X=y
FREETZ_AVM_VERSION_04_XX_MIN=y
FREETZ_AVM_VERSION_05_2X_MIN=y
FREETZ_AVM_VERSION_05_5X_MIN=y
FREETZ_AVM_VERSION_06_0X_MIN=y
# FREETZ_AVM_VERSION_06_2X_MIN is not set
# FREETZ_AVM_VERSION_06_5X_MIN is not set
# FREETZ_AVM_VERSION_04_XX_MAX is not set
# FREETZ_AVM_VERSION_05_2X_MAX is not set
# FREETZ_AVM_VERSION_05_5X_MAX is not set
FREETZ_AVM_VERSION_06_0X_MAX=y
FREETZ_AVM_VERSION_06_2X_MAX=y
FREETZ_AVM_VERSION_06_5X_MAX=y
FREETZ_TARGET_ARCH_LE=y
FREETZ_TARGET_ARCH="mipsel"
FREETZ_TARGET_CROSS="${FREETZ_TARGET_ARCH}-linux-uclibc-"
FREETZ_KERNEL_CROSS="${FREETZ_TARGET_ARCH}-unknown-linux-gnu-"
# FREETZ_AVM_GCC_3_4 is not set
FREETZ_AVM_GCC_4_6=y
# FREETZ_AVM_GCC_4_7 is not set
# FREETZ_AVM_GCC_4_8 is not set
# FREETZ_AVM_GCC_4_9 is not set
FREETZ_AVM_GCC_3_4_MIN=y
FREETZ_AVM_GCC_4_6_MIN=y
# FREETZ_AVM_GCC_4_7_MIN is not set
# FREETZ_AVM_GCC_4_8_MIN is not set
# FREETZ_AVM_GCC_4_9_MIN is not set
# FREETZ_AVM_GCC_3_4_MAX is not set
FREETZ_AVM_GCC_4_6_MAX=y
FREETZ_AVM_GCC_4_7_MAX=y
FREETZ_AVM_GCC_4_8_MAX=y
FREETZ_AVM_GCC_4_9_MAX=y
# FREETZ_KERNEL_VERSION_2_6_13 is not set
# FREETZ_KERNEL_VERSION_2_6_19 is not set
# FREETZ_KERNEL_VERSION_2_6_28 is not set
# FREETZ_KERNEL_VERSION_2_6_32_41 is not set
FREETZ_KERNEL_VERSION_2_6_32_60=y
# FREETZ_KERNEL_VERSION_2_6_32_61 is not set
FREETZ_KERNEL_VERSION_2_6_32=y
# FREETZ_KERNEL_VERSION_3_10_73 is not set
# FREETZ_KERNEL_VERSION_3_10 is not set
FREETZ_KERNEL_VERSION="2.6.32"
FREETZ_KERNEL_VERSION_MAJOR="2.6.32"
FREETZ_KERNEL_VERSION_2_6_13_MIN=y
FREETZ_KERNEL_VERSION_2_6_19_MIN=y
FREETZ_KERNEL_VERSION_2_6_28_MIN=y
FREETZ_KERNEL_VERSION_2_6_32_MIN=y
# FREETZ_KERNEL_VERSION_3_10_MIN is not set
# FREETZ_KERNEL_VERSION_2_6_13_MAX is not set
# FREETZ_KERNEL_VERSION_2_6_19_MAX is not set
# FREETZ_KERNEL_VERSION_2_6_28_MAX is not set
FREETZ_KERNEL_VERSION_2_6_32_MAX=y
FREETZ_KERNEL_VERSION_3_10_MAX=y
FREETZ_KERNEL_LAYOUT_UR8=y
FREETZ_KERNEL_LAYOUT="ur8"
FREETZ_MODULES_KVER="2.6.32.60"
FREETZ_KERNEL_PATCHES="2.6.32.60"
# FREETZ_AVM_UCLIBC_0_9_28 is not set
# FREETZ_AVM_UCLIBC_0_9_29 is not set
FREETZ_AVM_UCLIBC_0_9_32=y
# FREETZ_AVM_UCLIBC_0_9_33 is not set
# FREETZ_AVM_UCLIBC_NPTL_ENABLED is not set
FREETZ_AVM_SOURCE_7270_06_05=y
FREETZ_AVM_SOURCE_ID="7270_06.05"
FREETZ_AVM_SOURCE_FOR_KERNEL_LAYOUT_UR8=y
FREETZ_GCC_ABI="32"
FREETZ_GCC_ARCH="mips32"
FREETZ_GCC_TUNE="4kc"
FREETZ_GCC_FLOAT_ABI="soft"
FREETZ_REPLACE_KERNEL_AVAILABLE=y
FREETZ_REPLACE_KERNEL_EXPERIMENTAL=y
FREETZ_REPLACE_MODULE_AVAILABLE=y
FREETZ_TYPE_PREFIX="7270_v3"
FREETZ_TYPE_PREFIX_SERIES_SUBDIR="06_0X"
FREETZ_INSTALL_BASE=y
FREETZ_REPLACE_BUSYBOX=y
FREETZ_CIFS_SUPPORT_NEEDS_REPLACE_KERNEL=y
FREETZ_CIFS_SUPPORT_AVAILABLE=y
# FREETZ_NFS_SUPPORT_NEEDS_REPLACE_KERNEL is not set
FREETZ_NFS_SUPPORT_AVAILABLE=y
FREETZ_NFS_SUPPORT_AVAILABLE_AS_MODULE=y
Quellen:
http://freetz.org/wiki/packages/privoxy
http://freetz.org/wiki/packages/iptables
https://www.zebradem.com/wiki/index.php?title=Privoxy
Module in "make menuconfig"
Level of user competence -> Expert
Replace kernel
Other patches -> Patch web menu signed message
Packages -> Packages -> Privoxy (komplett)
Packages -> Unstable -> Iptables/Iptables-CGI
Packages -> Unstable -> Iptables kernel modules -> Select kernel modules (IPv4) -> iptable_nat.ko
Web Interface -> Freetz security level -> 0
rc.custom:
modprobe ip_tables
modprobe iptable_filter
modprobe x_tables
modprobe xt_tcpudp
modprobe ipt_REDIRECT
modprobe ip_nat
modprobe iptable_nat
iptables -t nat -A PREROUTING -p tcp -i lan --dport 80 -j REDIRECT --to 8118
[ -z "$(grep accept-intercepted-requests /var/mod/etc/privoxy/config)" ] && echo "accept-intercepted-requests 1" >> /var/mod/etc/privoxy/config
Externes Verzeichnis für Privoxy Filterdateien: /var/media/ftp/uStor01/privoxy
URL zur Adblock Plus Filterliste: https://easylist-downloads.adblockplus.org/easylistgermany+easylist.txt
Meine Probleme:
1. die Umleitung per iptables funktioniert nicht
alle Befehle die in der rc.custom sind, bringen nach den Anpassungen in der menuconfig keine Fehler mehr, aber auch keinen Erfolg
merkwürdig finde ich das in der /var/mod/etc/privoxy/config folgendes steht:
confdir /mod/etc/privoxy
actionsfile match-all.action
actionsfile default.action
filterfile default.filter
enable-edit-actions 0
tolerate-pipelining 1
logdir /var/log
logfile privoxy.log
debug 12288
actionsfile /var/media/ftp/uStor01/privoxy/user.action
filterfile /var/media/ftp/uStor01/privoxy/user.filter
toggle 1
enable-remote-toggle 0
enforce-blocks 1
allow-cgi-request-crunching 0
listen-address 0.0.0.0:8118
Merkwürdig weil in der rc.custom per "echo "accept-intercepted-requests 1" >> /var/mod/etc/privoxy/config" die config geändert wird und "accept-intercepted-requests 1" danach enthalten sein müsste.
2. der AdBlock Filter schrottet die user.action und user.filter, danach verweigert privoxy generell den Zugriff auf das Internet
privoxy-log:
Privoxy version 3.0.26
2016-11-30 13:50:04.993 00000400 Info: Program name: privoxy
2016-11-30 13:50:04.994 00000400 Info: Loading filter file: /mod/etc/privoxy/default.filter
2016-11-30 13:50:05.115 00000400 Info: Loading filter file: /var/media/ftp/uStor01/privoxy/user.filter
2016-11-30 13:50:05.283 00000400 Error: Adding re_filter job 'input[onclick[/&:?=_]="window\.open('http://www\.firstload\.de/affiliate/"]' to filter easylistgermany+easylist failed: (pcrs:) Syntax error while parsing command
2016-11-30 13:50:05.787 00000400 Error: Adding re_filter job 's|<([a-zA-Z0-9]+)\s+.*id=.?\5f _mom_ad_12.*>.*</\1>||g' to filter easylistgermany+easylist failed: Error code 49. For details, check the pcre documentation.
2016-11-30 13:50:05.789 00000400 Error: Adding re_filter job 's|<([a-zA-Z0-9]+)\s+.*id=.?\5f _mom_ad_2.*>.*</\1>||g' to filter easylistgermany+easylist failed: Error code 48. For details, check the pcre documentation.
2016-11-30 13:51:38.942 00000400 Error: Adding re_filter job 'A[href*="=Adtracker"]' to filter easylistgermany+easylist failed: (pcrs:) Syntax error while parsing command
2016-11-30 13:51:38.981 00000400 Error: Adding re_filter job 'A[href[/&:?=_]="http://duckcash\.eu/AF_"]' to filter easylistgermany+easylist failed: (pcrs:) Syntax error while parsing command
2016-11-30 13:51:38.987 00000400 Error: Adding re_filter job '[lazy-ad="lefttop_banner"]' to filter easylistgermany+easylist failed: (pcrs:) Syntax error while parsing command
2016-11-30 13:51:39.000 00000400 Error: Adding re_filter job 's|onclick[/&:?=_]="window\.open('http://adultfriendfinder\.com/search/">||g' to filter easylistgermany+easylist failed: Error code 70. For details, check the pcre documentation.
2016-11-30 13:51:40.307 00000400 Error: Adding re_filter job 's|<a.*href[/&:?=_]="http://games\.ucoz\.ru/"][target="_blank".*>.*</a>||g' to filter easylistgermany+easylist failed: Error code 68. For details, check the pcre documentation.
2016-11-30 13:51:40.916 00000400 Error: Adding re_filter job 's|<a.*href[/&:?=_]="http://taboola-"][href*="/redirect\.php?app\.type=".*>.*</a>||g' to filter easylistgermany+easylist failed: Error code 78. For details, check the pcre documentation.
2016-11-30 13:51:42.136 00000400 Error: Adding re_filter job 's|<a.*onmousedown[/&:?=_]="this\.href='http://paid\.outbrain\.com/network/redir?"][target="_blank".*>.*</a>||g' to filter easylistgermany+easylist failed: Error code 105. For details, check the pcre documentation.
2016-11-30 13:51:42.148 00000400 Error: Adding re_filter job 's|<a.*onmousedown[/&:?=_]="this\.href='http://paid\.outbrain\.com/network/redir?"][target="_blank".*>.*</a>||g + \.ob_source' to filter easylistgermany+easylist failed: Error code 105. For details, check the pcre documentation.
2016-11-30 13:51:42.155 00000400 Error: Adding re_filter job 's|<a.*onmousedown[/&:?=_]="this\.href='http://staffpicks\.outbrain\.com/network/redir?"][target="_blank".*>.*</a>||g' to filter easylistgermany+easylist failed: Error code 111. For details, check the pcre documentation.
2016-11-30 13:51:42.167 00000400 Error: Adding re_filter job 's|<a.*onmousedown[/&:?=_]="this\.href='http://staffpicks\.outbrain\.com/network/redir?"][target="_blank".*>.*</a>||g + \.ob_source' to filter easylistgermany+easylist failed: Error code 111. For details, check the pcre documentation.
2016-11-30 13:51:42.180 00000400 Error: Adding re_filter job 's|<a.*onmousedown[/&:?=_]="this\.href='https://paid\.outbrain\.com/network/redir?"][target="_blank".*>.*</a>||g' to filter easylistgermany+easylist failed: Error code 106. For details, check the pcre documentation.
2016-11-30 13:51:42.192 00000400 Error: Adding re_filter job 's|<a.*onmousedown[/&:?=_]="this\.href='https://paid\.outbrain\.com/network/redir?"][target="_blank".*>.*</a>||g + \.ob_source' to filter easylistgermany+easylist failed: Error code 106. For details, check the pcre documentation.
2016-11-30 13:51:42.228 00000400 Error: Adding re_filter job 'aside[id[/&:?=_]="div-gpt-ad"]' to filter easylistgermany+easylist failed: (pcrs:) Syntax error while parsing command
2016-11-30 13:52:04.116 00000400 Info: Loading actions file: /mod/etc/privoxy/match-all.action
2016-11-30 13:52:04.145 00000400 Info: Loading actions file: /mod/etc/privoxy/default.action
2016-11-30 13:52:04.329 00000400 Info: Loading actions file: /var/media/ftp/uStor01/privoxy/user.action
2016-11-30 13:52:09.864 00000400 Info: Listening on port 8118 on IP address 0.0.0.0
- - - Aktualisiert - - -
Ein kleiner Hinweis am Rande, mir ist egal welche Software eingesetzt wird.
Ob Privoxy oder Squid, ob iptables oder avm-firewall.
Mir geht es wirklich nur darum einen Filter zu haben, der die Werbung universell entfernt.
Ich hatte zwar auch an eine Cache-Funktion gedacht, aber ich vermute mal, dass die FritzBox für einen vernünftigen CacheProxy zu wenig RAM hat.
Du bist auch ganz sicher, dass die Module ipt_REDIRECT, nf_conntrack_ipv4 und nf_nat korrekt gebaut und geladen wurden ?
Was liefert ein
lsmod
bzw.
iptables -nvL
nach geladenen Regeln ?
Hi JohnDoe42,
danke für deine Antwort.
Um Fehler durch "trial and error" auszuschließen habe ich alles komplett frisch gestartet,
d.h. freetz-devel gelöscht und neu heruntergeladen, fritzbox frisch recovered.
Die Firmware habe ich mit folgenden Modulen neu gebaut:
Packages -> Packages -> Privoxy (inkl. zLib)/Dropbear
Packages -> Unstable -> Iptables kernel modules -> Select  kernel modules (IPv4) ->  nf_conntrack/nf_conntrack_ipv4/iptable_filter/iptable_nat
Packages -> Unstable -> Iptables kernel modules -> x_tables (both IPv4 and IPv6) -> xt_tcpudp
Ergebnis:
modprobe ip_tables -> OK
modprobe iptable_filter -> OK
modprobe x_tables -> OK
modprobe xt_tcpudp -> OK
modprobe ipt_REDIRECT -> modprobe: module ipt_REDIRECT not found in modules.dep
modprobe ip_nat -> modprobe: module ip_nat not found in modules.dep
modprobe iptable_nat -> modprobe: module iptable_nat not found in modules.depmodprobe nf_conntrack_ipv4 -> modprobe: module nf_conntrack_ipv4 not found in modules.dep
lsmod:
Module                  Size  Used by    Tainted: P
xt_tcpudp               1776  0
iptable_filter           768  0
ip_tables              10032  1 iptable_filter
x_tables               10192  2 xt_tcpudp,ip_tables
userman_mod            47680  4
wlan_scan_ap            6912  1
wlan_acl                2624  1
wlan_wep                3840  0
wlan_tkip               8784  2
wlan_ccmp               5488  0
sch_sfq                 4688  4
wlan_xauth               432  0
sch_llq                 7216  1
sch_tbf                 3616  1
ath_pci               131536  0
ath_spectral           83856  1 ath_pci
ath_rate_atheros       56624  1 ath_pci
wlan                  175744  9 wlan_scan_ap,wlan_acl,wlan_wep,wlan_tkip,wlan_ccmp,wlan_xauth,ath_pci,ath_rate_atheros
ath_dfs                33248  3 wlan_scan_ap,ath_pci,wlan
ath_hal               276432  6 ath_pci,ath_spectral,ath_rate_atheros,wlan,ath_dfs
avm_ath_extensions     29616  6 wlan_scan_ap,ath_pci,ath_rate_atheros,wlan,ath_dfs,ath_hal
kdsldmod             1065712  9 userman_mod
dsl_ur8               155776  0
ramzswap               15632  1
lzo_decompress          1856  1 ramzswap
lzo_compress            1696  1 ramzswap
dect_io                10224  0
avm_dect              216640  1 dect_io
capi_codec            349008  0
isdn_fbox_fon5        729936  5
pcmlink               276432  4 avm_dect,capi_codec,isdn_fbox_fon5
loop                   11552  2
jffs2                  94128  1
Piglet_noemif          41808  0
rtc_avm                 3536  1 pcmlink
rtc_core               11312  1 rtc_avm
led_modul_Fritz_Box_7270plus    66528  4
Ich habe diesmal gleich dropbear mit installiert, um mich nicht auf die "Rudi-Shell" verlassen zu müssen (da ich vermute, dass mir die Rudi-Shell nicht immer das modprobe-Ergebnis korrekt angezeigt hat).
Wie können die fehlenden Module aktiviert werden?
Meinst du "nf_nat" oder "ip_nat"?
Zunächst mal hat mein Vorschreiber, trotz knappem Stil, nach meiner Erfahrung nicht ganz unrecht: Die CPU der 7270 kommt speziell bei der Verwendung von Privoxy doch arg ins Schwitzen, was sich dann ca. alle zwei bis drei Tage in Reboots äußert. Ich habe das sehr oft nachgestellt, indem ich den Privoxy auf einer 7270 einfach mal abgestellt habe, Ergebnis: Keine Reboots mehr.
Wenn Du also unbedingt einen Privoxy oder eine Proxy-Kaskade (auf der 7270) in einem kleineren LAN betreiben möchtest, der von einigen Clients genutzt wird, solltest Du evtl. doch über einen Raspi nachdenken. Der Raspi3 läuft mit 1GB RAM hier sehr flüssig, auch mit Squid->Privoxy->Tor.
Nun zum Thema:
Offensichtlich sind die nötigen Module (nf_nat, ipt_REDIRECT, nf_conntrack und/oder nf_conntrack_ipv4) nicht gebaut (und können deshalb auch nicht geladen/benutzt werden).
Seit der FW-Version 06 geht aufgrund des Packet Accelerators das connection tracking mit iptables nicht mehr komplikationslos.
Du kannst, auf total eigene Gefahr und ohne jegliche Gewähr, versuchen, die iptables-configs wie hier zu lesen anzupassen. Desweiteren musst Du die Kernel-config anpassen, idealerweise so, daß Du die fehlenden Module auch als Module (also von Hand per modprobe ladbar,<M>) baust, damit im Zweifel die Box nicht total zerflasht ist.
Wichtigste Regel vor Beginn: Entsprechendes Recover herunterladen und Fritzbox- und Freetz-Sicherungen anlegen!!!!
Viel Erfolg.
dann vielen Dank an alle. :)
Wenn der Proxy für die 7270 zuviel Last bedeutet und die aktuelle Firmware aller FritzBoxen mit den iptables Probleme haben, dann ist mir das zu unsicher/instabil.
Es muss schon wirklich stabil und reibungslos laufen.
Ich denke über RasPi als Filter nach, die Idee finde ich gut.
Gibt es eine fertige Distri wo Webfilter und Cache-Proxy zusammen dabei sind (Pi-Hole scheint ja nur zu filtern)?
Etwas ähnliches habe ich bei IPfire gefunden:
Dagegen spricht allerdings:
  • läuft als eigener Router
    • ich möchte es gern hinter der FritzBox betreiben und trotzdem das WLAN der FritzBox nutzen
    • zum konfigurieren von manuellen Routen, fühle ich mich noch zu unsicher, da ich zum Beispiel nicht aus Versehen eine Sicherheitslücke durch falsche Konfiguration schaffen möchte
  • läuft nicht auf dem aktuellen Pi
Den Ansatz vom Pi-Hole, das Ganze per DNS-Umleitung zu erledigen fand ich da schon richtig gut.
Wenn sich dann noch ein transparenter Proxy mit dazu gesellt wäre das schon nahezu perfekt. ;)
Gibt es eine gute Anleitung zum setzen von Routen/Regeln unter Linux?
Würde mich gern in das Thema einarbeiten.
Wenn Du einen transparenten (also für einen Client im LAN unsichtbaren) Proxy möchtest, durch den der gesamte I-Net-Verkehr läuft, brauchst Du die REDIRECT-Regel auf dem sog. Border-Device, also i.A. dem Gerät, daß den I-Net-Zugang herstellt. Das dürfte in Deinem Fall die FritzBox sein. Dass dies mit der aktuellen 06er-FW schwierig ist, hatte ich oben beschrieben.
Du hast nun die Wahl zwischen einem anderen Router, dessen FW Du dahingehend beeinflussen kannst, dass er eine iptables/netfilter-REDIRECT-Regel akzeptiert, oder eben einem auf den jeweiligen Clients eingetragenen Proxy, der diesen dann natürlich bekannt ist. Wenn Du die Gefahr eines evtl. "Wiederaustragens" des Proxys siehst, müßtest Du Dich mal mit den Benutzerrechten Deines Betriebssystems vertraut machen, ggfs. kann man dass einschränken oder einen WPAD-Mechanismus versuchen.
Wie ich bereits oben schrieb, läuft ein Raspi3 mit einer Kaskade Squid->Privoxy->Tor sehr ordentlich mit einstelligen gleichzeitigen Clientanfragen.
Oder natürlich der Königsweg, nach dem hier einige lechzen: Du fragst bei AVM nach einer Kernel-Config, mit der man die aktuelle 72.06.06 erzeugen kann.
Aber das ist ein anderes Thema.
ich habe mir aus den ganzen Antworten und Gedanken einen Lösungsweg für mich entwickeln können.
@JohnDoe42: Ich möchte unbedingt einen transparenten Proxy einsetzen, damit auch Handys und andere mobilen Geräte gefiltert werden und somit etwas Traffic gespart wird.
Die 7270 hat wieder Stock-Firmware und arbeitet im Client-Modus als Switch mit AccessPoint (dafür sollte die Leistung noch ausreichen ;)).
Als Router kommt ein alter PC,Notebook oder Netbook zum Einsatz, vielleicht später etwas kleineres wie PC Engines APU1/2 oder Banana Pi BPI-R1/2.
Bei der Wahl für die passende Destribution scheiden sich die Geister zwischen pfSense und IPFire.
IPFire ist kompatibler was zum Beispiel die USB-Netzwerkkarten, den Energiesparmodus und das booten vom USB-Stick angeht, außerdem ist der Update Accelerator des Cache-Proxys eine feine Sache für Leute die keinen Update-Server wie Microsoft WSUS oder ähnliches nutzen wollen.
pfSense lässt sich professioneller konfigurieren, der pfBlockerNG lässt sich wesentlich einfacher pflegen als SquidGuard und blockt dadurch mehr.
Vielen Dank an alle für die guten Ratschläge.
holh-66
