Problem mit Asterisk-Start und app_txfax.so
fbraun
2 Feb 2006
Edit betateilchen: Abgetrennt von hier
xhallo,
bei mir kommt der selbe fehler.
wenn ich asterisk -vcg ausführe erscheint folgendes:
 asterisk:/var/run # asterisk -vcg
Asterisk 1.2.4, Copyright (C) 1999 - 2006 Digium, Inc. and others.
Created by Mark Spencer <[email protected]>
Asterisk comes with ABSOLUTELY NO WARRANTY; type 'show warranty' for details.
This is free software, with components licensed under the GNU General Public
License version 2 and other licenses; you are welcome to redistribute it under
certain conditions. Type 'show license' for details.
Asterisk Event Logger Started /var/log/asterisk/event_log
Asterisk Dynamic Loader loading preload modules:
Mar 31 10:24:00 NOTICE[28815]: cdr.c:1188 do_reload: CDR simple logging enabled.
Asterisk PBX Core Initializing
Registering builtin applications:
 [AbsoluteTimeout]
 [Answer]
 [BackGround]
 [Busy]
 [Congestion]
 [DigitTimeout]
 [Goto]
 [GotoIf]
 [GotoIfTime]
 [ExecIfTime]
 [Hangup]
 [NoOp]
 [Progress]
 [ResetCDR]
 [ResponseTimeout]
 [Ringing]
 [SayNumber]
 [SayDigits]
 [SayAlpha]
 [SayPhonetic]
 [SetAccount]
 [SetAMAFlags]
 [SetGlobalVar]
 [SetLanguage]
 [Set]
 [SetVar]
 [ImportVar]
 [Wait]
 [WaitExten]
Asterisk Dynamic Loader Starting:
 [res_musiconhold.so] => (Music On Hold Resource)
Mar 31 10:24:00 WARNING[28815]: res_musiconhold.c:833 moh_register: Unable to open pseudo channel for timing...  Sound may be choppy.
 [res_indications.so] => (Indications Configuration)
 [res_features.so] => (Call Features Resource)
 [res_agi.so] => (Asterisk Gateway Interface (AGI))
 [res_crypto.so] => (Cryptographic Digital Signatures)
 [res_adsi.so] => (ADSI Resource)
 [res_monitor.so] => (Call Monitoring Resource)
 [pbx_dundi.so] => (Distributed Universal Number Discovery (DUNDi))
 [pbx_functions.so] => (Builtin dialplan functions)
 [pbx_ael.so] => (Asterisk Extension Language Compiler)
Warning, flexible rate not heavily tested!
 [pbx_spool.so] => (Outgoing Spool Support)
 [pbx_loopback.so] => (Loopback Switch)
 [pbx_config.so] => (Text Extension Configuration)
 [pbx_realtime.so] => (Realtime Switch)
 [chan_mgcp.so] => (Media Gateway Control Protocol (MGCP))
 [chan_zap.so] => (Zapata Telephony w/PRI)
 [chan_local.so] => (Local Proxy Channel)
 [chan_iax2.so] => (Inter Asterisk eXchange (Ver 2))
Mar 31 10:24:00 WARNING[28815]: chan_iax2.c:9553 load_module: Unable to open IAX ti
 [chan_agent.so] => (Agent Proxy Channel)
 [chan_phone.so] => (Linux Telephony API Support)
 [chan_skinny.so] => (Skinny Client Control Protocol (Skinny))
 [chan_features.so] => (Feature Proxy Channel)
 [chan_oss.so] => (OSS Console Channel Driver)
 [chan_sip.so] => (Session Initiation Protocol (SIP))
 [app_sms.so] => (SMS/PSTN handler)
 [cdr_custom.so] => (Customizable Comma Separated Values CDR Backend)
 [app_hasnewvoicemail.so] => (Indicator for whether a voice mailbox has messages in
 [format_wav_gsm.so] => (Microsoft WAV format (Proprietary GSM))
 [app_url.so] => (Send URL Applications)
 [app_test.so] => (Interface Test Application)
 [app_eval.so] => (Reevaluates strings)
 [app_chanspy.so] => (Listen to the audio of an active channel
 [app_sendtext.so] => (Send Text Applications)
 [app_exec.so] => (Executes applications)
 [app_txtcidname.so] => (TXTCIDName)
 [cdr_manager.so] => (Asterisk Call Manager CDR Backend)
 [app_txfax.so]Mar 31 10:24:01 WARNING[28815]: loader.c:325 __load_resource: /usr/l
_str
Mar 31 10:24:01 WARNING[28815]: loader.c:554 load_modules: Loading module app_txfax
Ouch ... error while writing audio data: : Broken pipe
Es scheint ein Problem mit res_musiconhold.so, chan_iax2.so und cdr_manager.so zu geben. Doch wie behebe ich diese Problem? Krieg den asterisk so nicht mehr zum starten.
Vielen Dank im Voraus für jeden Tip!
Nein, du hast ein ganz anderes Problem :!:
_str
Dein Fehler liegt nicht in den von Dir vermuteten 3 Applikationen, sondern in der app_txfax.so - denn beim Laden dieser Applikation passiert der Abbruch des Asterisk-Starts. Leider kenne ich die Applikation nicht, um Dir da weiterhelfen zu können - aber Du weißt nun zumindest, wo Du den Fehler suchen mußt :wink:
Wie bekomme ich es hin, dass diese Applikation einfach nicht geladen wird?
in der /etc/asterisk/modules.conf einen entsprechenden Eintrag machen.
noload => app_txfax.so
Vielen Dank, hat geholfen. Werde das dann noch näher klären, warum das Modul Probleme macht....
Reischitz
