- Mitglied seit
- 4 Apr 2006
- Beiträge
- 172
- Punkte für Reaktionen
- 0
- Punkte
- 0
folgende Fehlermeldung:
Eigentlich müsste der ruf doch an die Mailbox gehen, da
Die capi.conf sieht so aus
Ist der Aufbau der extensions.conf mit chan_capi-cm anders als bei der Nutzung von Bristuff mit HFC Karten? Kann ich mir ja eigentlich nicht vorstellen.
*CLI> == ISDN1: Incoming call '15' -> ''
== ISDN1: CAPI Hangingup
[globals]
[incoming]
exten => 480,1,VoiceMail(u415)
exten => 480,2,Hangup()
; CAPI config
; general section
[general]
nationalprefix=0
internationalprefix=00
rxgain=0.8
txgain=0.8
language=de ;set default language
;ulaw=yes ;set this, if you live in u-law world instead of a-law
; interface sections ...
[ISDN1] ;this example interface gets name 'ISDN1' and may be any
;name not starting with 'g' or 'contr'.
;ntmode=yes ;if isdn card operates in nt mode, set this to yes
isdnmode=DID ;'MSN' (point-to-multipoint) or 'DID' (direct inward dial)
;when using NT-mode, 'DID' should be set in any case
incomingmsn=* ;allow incoming calls to this list of MSNs/DIDs, * = any
;defaultcid=123 ;set a default caller id to that interface for dial-out,
;this caller id will be used when dial option 'd' is set.
;controller=0 ;ISDN4BSD default
;controller=7 ;ISDN4BSD USB default
controller=1 ;capi controller number to use
group=1 ;dialout group
;prefix=0 ;set a prefix to calling number on incoming calls
softdtmf=on ;enable/disable software dtmf detection, recommended for AVM cards
relaxdtmf=on ;in addition to softdtmf, you can use relaxed dtmf detection
accountcode= ;Asterisk accountcode to use in CDRs
context=incoming ;context for incoming calls
;holdtype=hold ;when Asterisk puts the call on hold, ISDN HOLD will be used. If
;set to 'local' (default value), no hold is done and Asterisk may
;play MOH.
;immediate=yes ;DID: immediate start of pbx with extension 's' if no digits were
; received on incoming call (no destination number yet)
;MSN: start pbx on CONNECT_IND and don't wait for SETUP/SENDING-COMPLETE.
; info like REDIRECTINGNUMBER may be lost, but this is necessary for
; drivers/pbx/telco which does not send SETUP or SENDING-COMPLETE.
;echosquelch=1 ;_VERY_PRIMITIVE_ echo suppression
;echocancel=yes ;EICON DIVA SERVER (CAPI) echo cancelation
;(possible values: 'no', 'yes', 'force', 'g164', 'g165')
echocancelold=yes;use facility selector 6 instead of correct 8 (necessary for older eicon drivers)
;echotail=64 ;echo cancel tail setting
;bridge=yes ;native bridging (CAPI line interconnect) if available
;callgroup=1 ;Asterisk call group
;language=de ;set language for this device (overwrites default language)
devices=2 ;number of concurrent calls on this controller
;(2 makes sense for single BRI, 30 for PRI)
