Eigenes 'tar' zum Image packen. AVM nutzt alten busybox...
Step 1, untar original image
Use nice tool ./tools/dumpsquashfs to unpack box image
Step 3 split kernel from hidden squashfs
The size of <../1.fritz.box_sl_wlan.09.03.87.image/var/tmp/kernel.image> is 674824
Squashfs signature found at 572416
kernel.raw created
kernelsquashfs.raw created
Step 4 unpack hidden squashfs
Step 5 Modification
Step 6 Modification
Achtung: Dein Boxtyp ist auf Fritz_Box_SL_WLAN gesetzt !
Bitte bei Bedarf in ./fritzbox_mod.6 anpassen !
can't find file to patch at input line 3
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|--- etc/init.d/rc.voip 2005-02-08 17:40:14.000000000 +0100
|+++ etc/init.d/rc.voip 2005-03-05 21:50:25.830034032 +0100
File to patch:
Skip this patch? [y] y
Skipping patch.
1 out of 1 hunk ignored
patche vpn in firmware
patche bftpd in firmware
patche dropbear in firmware
patche web interface push
patching file usr/www/all/html/de/menus/menu2_system.html
Hunk #1 succeeded at 14 (offset -1 lines).
patche web interface wds
patching file usr/www/all/html/de/menus/menu2_wlan.html
Hunk #1 succeeded at 36 with fuzz 1 (offset -1 lines).
entferne hilfedateien
entferne einrichtungsassistent
rm: Entfernen von „usr/www/all/html/assistent.html“ nicht möglich: Datei oder Verzeichnis nicht gefunden
patche erweitertes wget in firmware
patching file etc/init.d/rc.conf
Hunk #1 succeeded at 84 (offset -156 lines).
patching file etc/init.d/rc.S
Hunk #1 succeeded at 8 with fuzz 1.
Hunk #2 succeeded at 69 with fuzz 2.
Hunk #3 succeeded at 142 with fuzz 2.
Hunk #4 succeeded at 194 with fuzz 2 (offset -49 lines).
sed: kann usr/www/all/html/de/fon/* nicht lesen: Datei oder Verzeichnis nicht gefunden
set FIRMWARE_SUBVERSION=m4.28
Step 7 Modification
Image 7.neu_sl_87_m4.28.image/var/tmp/filesystem.image has size 2793472, limit is 3145728 ,building checksum.
File doesn't contain the checksum, adding
Calculated checksum is 8EC1664
Added successfully
Image 7.neu_sl_87_m4.28.image/var/tmp/kernel.image has size 506880, limit is 720896 ,building checksum.
Calculated checksum is 10642E92
Added successfully
Achtung: Dieses File lässt sich nicht auf eine Fritz_Box_FON laden !
Achtung: Dieses File lässt sich nicht auf eine Fritz_Box_WLAN laden !
Achtung: Dieses File lässt sich nicht auf eine Fritz_Box_FON_ATA laden !
Achtung: Dieses File lässt sich nicht auf eine Fritz_Box_5050 laden !
Achtung: Dieses File lässt sich nicht auf eine Fritz_Box_7050 laden !
patching file var/install
Create /home/lol/m4.28/neu_sl_87_m4.28.image
