[Problem] snom 710 hinter W921V nur ankommend möglich
fwmorpheus
24 Mai 2014
ich habe folgendes Problem:
Mein snom 710 registriert sich ordnungsgemäß beim SIP-Server der Telekom, allerdings bekomme ich beim Versuch, ausgehende Gespräche zu führen folgenden Protokolleintrag:
Sent to udp:217.0.16.106:5060 at 27/5/2014 16:33:28:644 (1493 bytes):
INVITE sip:[email protected];user=phone SIP/2.0
Via: SIP/2.0/UDP 79.XXX.XXX.XXX:5068;branch=z9hG4bK-42gfn0xp4cm5;rport
From: "0634496XXXXX" <sip:[email protected]>;tag=98p2kflpm7
To: <sip:[email protected];user=phone>
Call-ID: 5384a23873c9-ih4zx6wfp36b
CSeq: 2 INVITE
Max-Forwards: 70
Contact: <sip:[email protected]:5068;line=8osqevzi>;reg-id=1
X-Serialnumber: 000413766509
P-Key-Flags: resolution="31x13", keys="4"
User-Agent: snom710/8.7.3.25.5
Accept: application/sdp
Allow: INVITE, ACK, CANCEL, BYE, REFER, OPTIONS, NOTIFY, SUBSCRIBE, PRACK, MESSAGE, INFO, UPDATE
Allow-Events: talk, hold, refer, call-info
Supported: timer, 100rel, replaces, from-change
Session-Expires: 3600;refresher=uas
Min-SE: 90
Authorization: Digest username="[email protected]",realm="tel.t-online.de",nonce="78210b0578210b052ba5a93d3a42aefb91ca7e0bc88fdd4bed674cbef0929a34",uri="sip:[email protected];user=phone",response="20964ba24045c789cc24e3ff67217125",algorithm=MD5
Content-Type: application/sdp
Content-Length: 405
v=0
o=root 830309102 830309102 IN IP4 79.216.192.251
s=call
c=IN IP4 79.XXX.XXX.XXX
t=0 0
m=audio 30536 RTP/AVP 9 0 8 3 99 108 18 101
a=rtpmap:9 G722/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:3 GSM/8000
a=rtpmap:99 G726-32/8000
a=rtpmap:108 AAL2-G726-32/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=ptime:20
a=sendrecv
Received from udp:217.0.16.106:5060 at 27/5/2014 16:33:28:698 (294 bytes):
SIP/2.0 100 Rufaufbau
Via: SIP/2.0/UDP 79.XXX.XXX.XXX:5068;rport=5070;branch=z9hG4bK-42gfn0xp4cm5
From: 0634496XXXXX <sip:[email protected]>;tag=98p2kflpm7
CSeq: 2 INVITE
Content-Length: 0
Received from udp:217.0.16.106:5060 at 27/5/2014 16:33:28:737 (368 bytes):
SIP/2.0 403 Zugriff nicht erlaubt (45)
To: <sip:[email protected];user=phone>;tag=bf4a567b
Contact: <sip:[email protected]:5060>
CSeq: 2 INVITE
Content-Length: 0
Sent to udp:217.0.16.106:5060 at 27/5/2014 16:33:28:741 (425 bytes):
ACK sip:[email protected];user=phone SIP/2.0
CSeq: 2 ACK
Max-Forwards: 70
Content-Length: 0
Inzwischen bin ich überfragt, wo ich weiter ansetzen muss, um herauszubekommen, welche Infos dem Telekom-Server fehlen.
Gruß,
Phil
Versuche es mal mit SIP-Port 5060 statt 5068 im snom Phone.
SIP-Port 5060 ist eingestellt, ändert aber nichts.
Dann nimm mal SIP-Port 5068. An den wird nämlich die SIP Response gesandt.
Die SIP-Response kommt immer auf dem gleichen Port an, wie eingestellt. Egal welchen Port ich einstelle, es führt immer zum gleichen Ergebnis.
Ich vermute, dem Telekom-Server passt etwas ganz anderes an der Anfrage nicht. Da aber die Leistungsbeschreibung nicht offen vorliegt, fällt es mir schwer, mich reinzudenken.
Received from udp:217.0.16.106:[B][COLOR="#FF0000"]5060[/COLOR][/B] at 27/5/2014 16:33:28:698 (294 bytes):
Via: SIP/2.0/UDP 79.XXX.XXX.XXX:[B][COLOR="#FF0000"]5068[/COLOR][/B];rport=5070;branch=z9hG4bK-42gfn0xp4cm5
Das musst du mir erklären. :confused:
Es gibt da wohl den kleinen oder feinen Unterschied zwischen Client- und Server-Ports
Der erstere ist der Server-Port und der zweite ist der Client-Port. Warum steht der Client-Port auf 5068?
Weil der Speedport alles von 5060-5065 für sich beansprucht. Da führt auch kein Weg dran vorbei, außer wegwerfen.
brokoli1
