Probleme beime erstellen von samba
Notausstieg
6 Sep 2008
ich habe beim erstellen von sambe im trunk das folgende problem.
freetz@freetz:~/freetz-trunk$ make
for target in headers all; do \
        cmd() { PATH="/home/freetz/freetz-trunk/toolchain/target/bin:/home/freetz/freetz-trunk/toolchain/kernel/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games" LD_RUN_PATH="/usr/lib/freetz" make -j1  "$@"  || { printf "\n\\033[33m%s\\033[m\n" "ERROR: Build failed.";  exit 1; } };       if [ -e source/.echo_item_start -a ! -e source/.echo_item_build ]; then echo -n "building... "; touch source/.echo_item_build; fi; cmd -C source/target-mipsel_uClibc-0.9.29/samba-3.0.37/source \
                RANLIB="/home/freetz/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-ranlib" \
                CODEPAGEDIR="/mod/usr/share/samba" \
                $target; \
        done
make[1]: Betrete Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_uClibc-0.9.29/samba-3.0.37/source'
make delheaders; \
        make smbd/build_options.c; \
        make include/proto.h; \
        make include/build_env.h; \
        make nsswitch/winbindd_proto.h; \
        make web/swat_proto.h; \
        make client/client_proto.h; \
        make utils/ntlm_auth_proto.h; \
        make utils/net_proto.h; \
        make utils/passwd_proto.h;
make[2]: Betrete Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_uClibc-0.9.29/samba-3.0.37/source'
Removing prototype headers
make[2]: Verlasse Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_uClibc-0.9.29/samba-3.0.37/source'
Generating smbd/build_options.c
Building include/proto.h
creating /home/freetz/freetz-trunk/source/target-mipsel_uClibc-0.9.29/samba-3.0.37/source/include/proto.h
Building include/build_env.h
creating /home/freetz/freetz-trunk/source/target-mipsel_uClibc-0.9.29/samba-3.0.37/source/nsswitch/winbindd_proto.h
creating /home/freetz/freetz-trunk/source/target-mipsel_uClibc-0.9.29/samba-3.0.37/source/web/swat_proto.h
creating /home/freetz/freetz-trunk/source/target-mipsel_uClibc-0.9.29/samba-3.0.37/source/client/client_proto.h
creating /home/freetz/freetz-trunk/source/target-mipsel_uClibc-0.9.29/samba-3.0.37/source/utils/ntlm_auth_proto.h
creating /home/freetz/freetz-trunk/source/target-mipsel_uClibc-0.9.29/samba-3.0.37/source/utils/net_proto.h
creating /home/freetz/freetz-trunk/source/target-mipsel_uClibc-0.9.29/samba-3.0.37/source/utils/passwd_proto.h
make[1]: Verlasse Verzeichnis '/home/freetz/freetz-trunk/source/target-mipsel_uClibc-0.9.29/samba-3.0.37/source'
Using FLAGS      =  -Os -pipe -march=4kc -Wa,--trap -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -D_SAMBA_BUILD_=3 -DAVM_NO_PRINTING -DAVM_SMALLER  -I/home/freetz/freetz-trunk/source/target-mipsel_uClibc-0.9.29/samba-3.0.37/source/iniparser/src -Iinclude -I./include  -I. -I. -I./lib/replace -I./lib/talloc -I./tdb/include -I./libaddns -I./librpc -DHAVE_CONFIG_H
      PICFLAG    = -fPIC
      LIBS       = -lcrypt -lresolv -ldl
      LDFLAGS    =
      DYNEXP     = -Wl,--export-dynamic
      LDSHFLAGS  = -shared -Wl,-Bsymbolic
      SHLIBEXT   = so
      SONAMEFLAG = -Wl,-soname=
Compiling smbd/build_options.c
Building bin/libsmbd.a
mipsel-linux-ar: bin/libsmbd.a: No such file or directory
make[1]: *** [bin/libsmbd.a] Fehler 1
make: *** [source/target-mipsel_uClibc-0.9.29/samba-3.0.37/source/bin/smbpasswd] Fehler 1
ein make samba-dirclean und make samba-precompiled brachte nix (revision 5573)
Danke für eure Hilfe
Notausstieg
ok ich habs. man muss den Ordner bin erstellen, da dieser in dem Samba-Paket nicht enthalten ist. einfach ein mkdir auf "source/target-mipsel_uClibc-0.9.XX/samba-3.0.37/bin
Notausstieg
Hm, komisch. Ist das vielleicht von der tar version abhängig, ob der Ordner erstellt wird oder nicht?
MfG Oliver
Währe durchaus möglich. Werd ich morgen mal prüfen, da ich heut unterwegs bin. Entpackt habe ich mit aktuellstem Tar in Ubuntu 10.4 LTS minimal.
Notausstieg
Ah, ich glaub ich habs...
MfG Oliver
jo funktioniert. Diesmal macht er auch ganz artig von allein ein "mkdir bin"
Compiling registry/reg_util.c
Compiling registry/reg_dynamic.c
Compiling registry/reg_perfcount.c
Compiling lib/popt_common.c
mkdir bin
Compiling smbd/server.c
Linking bin/smbd
Compiling nmbd/asyncdns.c
Compiling nmbd/nmbd.c
Compiling nmbd/nmbd_become_dmb.c
Vielen Dank.
stego88
