Probleme mit debug.cfg
reimundko
1 Jul 2006
Habe folgenden Fehler.
In Ihrer FRITZ!Box wurden vom Hersteller nicht unterstützte Änderungen durchgeführt.
Weitere Informationen.
Habe nun eine debug.cfg hier gefunden.
/usr/sbin/telnetd -l /sbin/ar7login
cd /var/tmp/
wget http://eportal.ep.funpic.de/foncalls.js
mount -o bind /var/tmp/foncalls.js /usr/www/html/html/de/fon/foncalls.js
# enable international settings
sed "s/LKZ 0/LKZ 1/g" /usr/www/all/html/de/fon/sip1.js > /var/tmp/sip1.js
chmod 444 /var/tmp/sip1.js
mount -o bind /var/tmp/sip1.js /usr/www/all/html/de/fon/sip1.js
# enable ENUM
sed "s/avme/avm/g" /usr/www/all/html/de/fon/sipoptionen.html > /var/tmp/sipoptionen.html
sed "s/avme/avm/g" /usr/www/all/html/de/fon/sipoptionen.js > /var/tmp/sipoptionen.js
chmod 444 /var/tmp/sipoptionen.html
chmod 444 /var/tmp/sipoptionen.js
mount -o bind /var/tmp/sipoptionen.html /usr/www/all/html/de/fon/sipoptionen.html
mount -o bind /var/tmp/sipoptionen.js /usr/www/all/html/de/fon/sipoptionen.js
# set hostname to fritz.box
hostname fritz.box
major=`grep tffs /proc/devices`
tffs_major=${major%%tffs}
#write calllog
cat > /var/calllog << 'ENDCALLLOG'
#!/bin/sh
CALLER=${1}
LINE=${3}
if [ -z "${LINE}" ]
then
  LINE=${2}
fi
if [ "${LINE}" = "ISDN" ]
then
  LINE=${2}
fi
if [ -z "${LINE}" ]
then
  LINE=${1}
  CALLER=""
fi
sh /var/tmp/parse_telefon.sh "${LINE}" "${CALLER}" &
ENDCALLLOG
# save /var/calllog
mknod /var/flash/calllog c $tffs_major $((0x77))
cp /var/calllog /var/flash/calllog
#CONTACTS
#contact=:anonym;
#CONTACTSEND
#LINES
#line=:anonym;
#LINESEND
# write reverse lookup script to file
cat > /var/tmp/invers.sh << 'ENDINVERS'
#!/bin/sh
number=$1
wget -q -O /var/tmp/name "http://www.dasoertliche.de/DB4Web/es/oetb2suche/home.htm?kw_invers=${number}&main=Antwort&s=2" 2>/dev/null
while read reverse
do
  case ${reverse} in
    *Detailansicht*)
      name=${reverse#*\>\ }
      name=${name%%\<*}
      break
  esac
done < /var/tmp/name
rm /var/tmp/name
echo "${name}"
ENDINVERS
# make it executable
chmod +x /var/tmp/invers.sh
# write send script to file
cat > /var/tmp/callmessage.sh << 'ENDCALLMESSAGE'
#!/bin/sh
caller=${2}
called=${1}
# search name in contact list
name=`cat /var/flash/debug.cfg 2>/dev/null | fgrep "#contact=${caller}:" | sed "s/#contact=${caller}://"`
name=${name%%\;*}
# name not found?
if [ -z "${name}" ]
then
  # do reverse lookup for at www.dasoertliche.de
  name=`/var/tmp/invers.sh ${caller}`
  # found name?
  if [ -n "${name}" ]
  then
    # add found contact to debug.cfg
    cat /var/flash/debug.cfg | sed -e "s/^#CONTACTSEND$/#contact=${caller}:${name};
#CONTACTSEND/g" > /var/tmp/debug.cfg
  else
    # add anonymous for contact to debug.cfg
    cat /var/flash/debug.cfg | sed -e "s/^#CONTACTSEND$/#contact=${caller}:${caller};
  fi
  cat /var/tmp/debug.cfg > /var/flash/debug.cfg
  rm /var/tmp/debug.cfg
fi
# name not found?
if [ -z "${name}" ]
then
  name=${caller}
fi
httpname=`echo "${name}" | sed -e '{s/ /%20/g;s/Ä/Ae/g;s/Ö/Oe/g;s/Ü/Ue/g;s/ä/ae/g;s/ö/oe/g;s/ü/ue/g;s/ß/ss/g;s/&/%26/g;}'`
# search line in line list
theline=`cat /var/flash/debug.cfg 2>/dev/null | fgrep "#line=${called}:" | sed "s/#line=${called}://"`
theline=${theline%%\;*}
# line not found?
if [ -z "${theline}" ]
then
  theline=${called}
fi
httptheline=`echo "${theline}" | sed -e '{s/ /%20/g;s/Ä/Ae/g;s/Ö/Oe/g;s/Ü/Ue/g;s/ä/ae/g;s/ö/oe/g;s/ü/ue/g;s/ß/ss/g;s/&/%26/g;}'`
# Send information to all DHCP clients
while read x x IP x
do
  wget -O /dev/null "http://${IP}:23232/?caller=${caller}&called=${called}&name=${name}&line=${theline}" >/dev/null 2>&1 &
done < /var/flash/multid.leases
# send information to PCs
wget -O /dev/null "http://192.168.178.2:23232/?caller=${caller}&called=${called}&name=${name}&line=${theline}" >/dev/null 2>&1 &
# send information to DBoxes -> TV screen
wget -O /dev/null "http://192.168.178.4/control/message?popup=Eingehender%20Anruf%0AAnrufer%3A%20${httpname}%0ALeitung%3A%20${httptheline}" >/dev/null 2>&1 &
# send information to DBoxes -> LCD
wget -O /dev/null "http://192.168.178.4/control/lcd?lock=1&clear=1&xpos=5&ypos=20&size=18&font=2&text=${httpname}&update=1" >/dev/null 2>&1 &
sleep 1
wget -O /dev/null "http://192.168.178.4/control/lcd?lock=1&clear=0&xpos=5&ypos=42&size=18&font=2&text=an%20${httptheline}&update=1" >/dev/null 2>&1 &
sleep 10
wget -O /dev/null "http://192.168.178.4/control/lcd?lock=0" >/dev/null 2>&1 &
sleep 3
killall wget
ENDCALLMESSAGE
chmod +x /var/tmp/callmessage.sh
# write dummy WakeOnCall script
echo "#!/bin/sh" > /var/tmp/woc.sh
make it executable
chmod +x /var/tmp/woc.sh
# write parse_telefon script to file
cat > /var/tmp/parse_telefon.sh << 'ENDPARSETEL'
#!/bin/sh
trap "" SIGCHLD
prefix=02207
caller="$2"
called="$1"
# normalize caller
case ${caller} in
  0049*)
    caller=0${caller#*0049}
  49????????*)
    caller=0${caller#*49}
  [1-9]????????*)
    caller=0${caller}
  [1-9]*)
    caller=${prefix}${caller}
esac
# exec woc.sh
/var/tmp/woc.sh ${called} ${caller} &
# exec callmessage.sh
/var/tmp/callmessage.sh ${called} ${caller} &
ENDPARSETEL
chmod +x /var/tmp/parse_telefon.sh
export IFILE=/usr/www/all/html/de/home/home.js
export OFILE=/var/tmp/home.js
umount $IFILE                 # darf nur einmal mount sein
sed 's/var signed.......query.box.status.signed_firmware..../var signed = "1"/g'  $IFILE >$OFILE
mount -o bind $OFILE $IFILE
habe nun mittels tftp -g -l debug.cfg -r debug.cfg IP die debug.cfg ins /var/tmp kopiert.
dann per cp /var/tmp/debug.cf /var/flash kopiert und box resetet.
Leider immer noch die gleiche Fehlermeldung
Wo mache ich da einen Fehler?
REimund
Wo der Fehler ist kann ich dir nicht sagen, aber die letzten 4 Zeilen beseitigen die Meldung bei mir.
MfG Oliver
mit folgendem Code in der debug.cfg gehts bei mir:
sed 's/<? query.box:status.signed_firmware ?>/1/' /usr/www/all/html/de/home/home.js > /var/tmp/home.js
mount -o bind /var/tmp/home.js /usr/www/all/html/de/home/home.js
bei mir klappt es damit:
# # # # # # # # # SIGNED_FIRMWARE Warnhinweis wegen Manipulation entfernen
dst=/var/tmp/signed_firmware
src=/usr/www/all/html/de/home
mkdir -pm 777 $dst
for file in home.js konfig.js; do
if [ -f $src/$file ]; then
sed -e 's,.*var signed =.*,var signed = "1",' $src/$file > $dst/$file
mount -o bind $dst/$file $src/$file
fi
done
# # # # # # # # # ENDE Warnhinweise entfernen
...aber vielleicht hast du ja einfach keine Leer- oder Kommentarzeile am Ende deiner Debug.cfg. Das kann dann dazu führen, dass die letzte Befehlszeile nicht ausgeführt wird (ein EOF ist leider kein CR/LF).
Joe
Bei der aktuellen Firmware ist der Pfad geändert:
sed 's/<? query.box:status.signed_firmware ?>/1/' /usr/www/html/html/de/home/home.js > /var/tmp/home.js
mount -o bind /var/tmp/home.js /usr/www/html/html/de/home/home.js
Bei mir hat die Änderung nur einer Zeile genügt:
# # # # # # # # # Warnhinweis wegen Manipulation entfernen
[COLOR="Red"]src=/usr/www/html/html/de/home[/COLOR]
mkdir -pm 777 $dst
	fi
done
Joe
fusionK
