Probleme mit Tor
xsapling
30 Jan 2005
wenn ich tor starte, dann er halte ich folgende Fehlermeldung und der Start mißlingt dann:
Nov  3 17:19:24 fritz daemon.warn Tor[5199]: You are running Tor as root. You don't need to, and you probably shouldn't.
Nov  3 17:19:29 fritz daemon.notice Tor[5199]: No current certificate known for authority moria1; launching request.
Nov  3 17:19:29 fritz daemon.notice Tor[5199]: No current certificate known for authority tor26; launching request.
Nov  3 17:19:29 fritz daemon.notice Tor[5199]: No current certificate known for authority dizum; launching request.
Nov  3 17:19:29 fritz daemon.notice Tor[5199]: No current certificate known for authority ides; launching request.
Nov  3 17:19:29 fritz daemon.notice Tor[5199]: No current certificate known for authority gabelmoo; launching request.
Nov  3 17:19:29 fritz daemon.notice Tor[5199]: No current certificate known for authority dannenberg; launching request.
Nov  3 17:19:29 fritz daemon.notice Tor[5199]: I learned some more directory information, but not enough to build a circuit: We have no network-status consensus.
Fehlen hier noch evtl. Portfreigaben oder dergleichen?
passiert mir auch, eine Lösung?
Im trunk sollte tor nicht als root:root ausgeführt werden. Läuft er tatsächlich als root?
MfG Oliver
nein, es ist jetzt nicht als root, hier ist mein log:
Dec  8 11:27:26 fritz authpriv.notice dropbear[445]: pubkey auth succeeded for 'root' with key md5 xxxxxxx from 192.168.178.5:51547
Dec  8 11:28:23 fritz daemon.notice Tor[530]: No current certificate known for authority moria1; launching request.
Dec  8 11:28:23 fritz daemon.notice Tor[530]: No current certificate known for authority tor26; launching request.
Dec  8 11:28:23 fritz daemon.notice Tor[530]: No current certificate known for authority dizum; launching request.
Dec  8 11:28:23 fritz daemon.notice Tor[530]: No current certificate known for authority ides; launching request.
Dec  8 11:28:23 fritz daemon.notice Tor[530]: No current certificate known for authority gabelmoo; launching request.
Dec  8 11:28:23 fritz daemon.notice Tor[530]: No current certificate known for authority dannenberg; launching request.
Dec  8 11:28:23 fritz daemon.notice Tor[530]: No current certificate known for authority urras; launching request.
Dec  8 11:28:23 fritz daemon.notice Tor[530]: Bootstrapped 5%: Connecting to directory server.
Dec  8 11:28:23 fritz daemon.notice Tor[530]: I learned some more directory information, but not enough to build a circuit: We have no network-status consensus.
Dec  8 11:28:23 fritz daemon.notice Tor[530]: Bootstrapped 10%: Finishing handshake with directory server.
Dec  8 11:28:25 fritz daemon.warn Tor[530]: TLS error: unexpected close while renegotiating
Dec  8 11:28:25 fritz daemon.notice Tor[530]: No current certificate known for authority moria1; launching request.
Dec  8 11:28:25 fritz daemon.notice Tor[530]: No current certificate known for authority tor26; launching request.
Dec  8 11:28:25 fritz daemon.notice Tor[530]: No current certificate known for authority dizum; launching request.
Dec  8 11:28:25 fritz daemon.notice Tor[530]: No current certificate known for authority ides; launching request.
Dec  8 11:28:25 fritz daemon.notice Tor[530]: No current certificate known for authority gabelmoo; launching request.
Dec  8 11:28:25 fritz daemon.notice Tor[530]: No current certificate known for authority dannenberg; launching request.
Dec  8 11:28:25 fritz daemon.notice Tor[530]: No current certificate known for authority urras; launching request.
Dec  8 11:28:26 fritz daemon.warn Tor[530]: TLS error: unexpected close while renegotiating
Dec  8 11:28:28 fritz daemon.warn Tor[530]: TLS error: unexpected close while renegotiating
Dec  8 11:28:42 fritz daemon.notice Tor[530]: Catching signal TERM, exiting cleanly.
die Benutzung von Tor muss ich bestimmte Ports zu öffnen?
Kommt drauf an, wie du den konfigurierst. Ein tor client kann auch tor relay für andere sein, dann musst Du die entsprechenden Ports öffnen (80,443,8080,...), wenn Du nur Client spielst, dann ist das, glaube ich, nicht unbedingt nötig. Lies dir mal die Beschreibung durch.
Tor nicht mehr im Freetz-UI aufgeführt
Ich habe gerade von Revision 4000 auf den neuesten Stand (4015) aktualisiert. Tor kann ich jetzt ohne Fehler über die Shell starten, allerdings fehlen die Tor-Einträge im Freetz-UI (Dienste, Einstellungen und Pakete).
Einzige zusätzliche Änderung von mir ausser dem svn update war das Abschalten des Freetz-Version-Strings.
Tritt das Problem nur bei mir auf?
Matthias
atrora
