[Gelöst] Pseudoscript für WLAN auf beide Netze aufteilen?
  • Ersteller Ersteller SF1975
S
SF1975
Guest
Ich wollte mal fragen, ob man dieses Script:
PHP:
 <?php
                |   SensorAndSwitch Automation Pro                                    |
                |   PseudoGeräte-Script                                               |
                |   -> WLAN                                                           |
                |      Fritz!Box WLAN                                                 |
        error_reporting(0);
        include "include/includefunctions.php";
        include "include/includefritzbox.php";
        include "include/includedateien.php";
        include "include/includeconf.php";
        include "include/includeconfig.php";
        include "include/includedefine.php";
        $fehler=true;
        if ($_GET["info"]=="status") {
            $Status = shell_exec("/usr/bin/ctlmgr_ctl r wlan settings/ap_enabled");
            if ($Status) {
                $fehler=false;
                echo "S#".trim($Status)."#";
            else {
                $fehler=true;
        if ($_GET["schalter"]=="1") {
            $Status = shell_exec("/usr/bin/ctlmgr_ctl w wlan settings/ap_enabled 1");
            if ($Status) {
                $fehler=false;
                echo "S#1#";
            else {
                $fehler=true;
        if ($_GET["schalter"]=="0") {
            $Status = shell_exec("/usr/bin/ctlmgr_ctl w wlan settings/ap_enabled 0");
            if ($Status) {
                $fehler=false;
                echo "S#0#";
            else {
                $fehler=true;
        if ($fehler) {
            $Login=$Conf["FB"]."/login_sid.lua";
            $user=$Conf["USER"];
            $password=$Conf["PASSWORD"];
            $url=FB."/query.lua?sid=".GetSessionID($Login,$user,$password)."&wlan=wlan:status/ap_enabled";
            $ch = curl_init();
            $timeout = 5;
            curl_setopt($ch, CURLOPT_URL, $url);
            curl_setopt($ch, CURLOPT_USERAGENT, "Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.0)");
            curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
            curl_setopt($ch, CURLOPT_SSL_VERIFYHOST,false);
            curl_setopt($ch, CURLOPT_SSL_VERIFYPEER,false);
            curl_setopt($ch, CURLOPT_MAXREDIRS, 10);
            curl_setopt($ch, CURLOPT_FOLLOWLOCATION, 1);
            curl_setopt($ch, CURLOPT_CONNECTTIMEOUT, $timeout);
            $Status = curl_exec($ch);
            curl_close($ch);
            if ($Status) {
                $x=explode('"',$Status);
                if ($x[3]=="0" or $x[3]=="1") {
                    $fehler=false;
                    echo 'P#WLAN-Statusanzeige: <img src="'.PIC.'mled'.$x[3].'.png">*HTML#';
                else {
                    $fehler=true;
                    echo "P##E##";
            else {
                $fehler=true;
                echo "P##E##";
        exit;
so aufteilen kann, dass es entweder das 2,4 oder das 5,0Ghz-Band anzeigt?
Abend
Bestimmt.
Hab nur leider keine 5Ghz fähige Box.
Schau mal in den Quelltext der betreffenden (AVM-Webinterface) Seite und poste mal die anonymisierten Daten ab...
fritz.box/wlan/radiochannel.lua
QUERIES = {
...die das WLAN betreffen.
Vielleicht kriegste das sogar selber hin, dann. ;)
Gerade mal geschaut. Es sind die Kanäle 13 und 136:
PHP:
QUERIES = {
  ["wlan:settings/ap_enabled"] = "1",
  ["wlan:settings/ap_enabled_scnd"] = "1",
Werde da heute mal mit spielen. Geil, es klappt:
pseudowlan-status-24.php
PHP:
 <?php
                |   -> WLAN                                                           |
                |      Fritz!Box WLAN         2,4Ghz                                  |
        error_reporting(0);
        $fehler=true;
            if ($Status) {
                $fehler=false;
            else {
                $fehler=true;
            if ($Status) {
                $fehler=false;
                echo "S#1#";
            else {
                $fehler=true;
            if ($Status) {
                $fehler=false;
                echo "S#0#";
            else {
                $fehler=true;
        if ($fehler) {
            $ch = curl_init();
            $timeout = 5;
            curl_close($ch);
            if ($Status) {
                    $fehler=false;
                    echo 'P#WLAN-Status 2,4Ghz: <img src="'.PIC.'mled'.$x[3].'.png">*HTML#';
                else {
                    $fehler=true;
                    echo "P##E##";
            else {
                $fehler=true;
                echo "P##E##";
        exit;
pseudowlan-status-50.php
PHP:
 <?php
                |   -> WLAN                                                           |
                |      Fritz!Box WLAN         5,0Ghz                                  |
        error_reporting(0);
        $fehler=true;
            $Status = shell_exec("/usr/bin/ctlmgr_ctl r wlan settings/ap_enabled_scnd");
            if ($Status) {
                $fehler=false;
            else {
                $fehler=true;
            $Status = shell_exec("/usr/bin/ctlmgr_ctl w wlan settings/ap_enabled_scnd 1");
            if ($Status) {
                $fehler=false;
                echo "S#1#";
            else {
                $fehler=true;
            $Status = shell_exec("/usr/bin/ctlmgr_ctl w wlan settings/ap_enabled_scnd 0");
            if ($Status) {
                $fehler=false;
                echo "S#0#";
            else {
                $fehler=true;
        if ($fehler) {
            $url=FB."/query.lua?sid=".GetSessionID($Login,$user,$password)."&wlan=wlan:status/ap_enabled_scnd";
            $ch = curl_init();
            $timeout = 5;
            curl_close($ch);
            if ($Status) {
                    $fehler=false;
                    echo 'P#WLAN-Status 5,0Ghz: <img src="'.PIC.'mled'.$x[3].'.png">*HTML#';
                else {
                    $fehler=true;
                    echo "P##E##";
            else {
                $fehler=true;
                echo "P##E##";
        exit;
pseudowds-status.php
PHP:
<?php
                |   -> WLAN                                                           |
                |      Fritz!Box WDS-Status                                           |
        error_reporting(0);
        $fehler=true;
            $Status = shell_exec("/usr/bin/ctlmgr_ctl r wlan settings/WDS_enabled");
            if ($Status) {
                $fehler=false;
            else {
                $fehler=true;
            $Status = shell_exec("/usr/bin/ctlmgr_ctl w wlan settings/WDS_enabled 1");
            if ($Status) {
                $fehler=false;
                echo "S#1#";
            else {
                $fehler=true;
            $Status = shell_exec("/usr/bin/ctlmgr_ctl w wlan settings/WDS_enabled 0");
            if ($Status) {
                $fehler=false;
                echo "S#0#";
            else {
                $fehler=true;
        if ($fehler) {
            $url=FB."/query.lua?sid=".GetSessionID($Login,$user,$password)."&wlan=wlan:status/WDS_enabled";
            $ch = curl_init();
            $timeout = 5;
            curl_close($ch);
            if ($Status) {
                    $fehler=false;
                    echo 'P#WLAN-WDS-Status: <img src="'.PIC.'mled'.$x[3].'.png">*HTML#';
                else {
                    $fehler=true;
                    echo "P##E##";
            else {
                $fehler=true;
                echo "P##E##";
        exit;
pseudomediaserver.php
PHP:
<?php
                |   -> WLAN                                                           |
                |      Fritz!Box Mediaserver-Status                                   |
        error_reporting(0);
        $fehler=true;
            $Status = shell_exec("/usr/bin/ctlmgr_ctl r mediasrv settings/enabled");
            if ($Status) {
                $fehler=false;
            else {
                $fehler=true;
            $Status = shell_exec("/usr/bin/ctlmgr_ctl w mediasrv settings/enabled 1");
            if ($Status) {
                $fehler=false;
                echo "S#1#";
            else {
                $fehler=true;
            $Status = shell_exec("/usr/bin/ctlmgr_ctl w mediasrv settings/enabled 0");
            if ($Status) {
                $fehler=false;
                echo "S#0#";
            else {
                $fehler=true;
        if ($fehler) {
            $url=FB."/query.lua?sid=".GetSessionID($Login,$user,$password)."&wlan=mediasrv:settings/enabled";
            $ch = curl_init();
            $timeout = 5;
            curl_close($ch);
            if ($Status) {
                    $fehler=false;
                    echo 'P#Mediaserver-Status: <img src="'.PIC.'mled'.$x[3].'.png">*HTML#';
                else {
                    $fehler=true;
                    echo "P##E##";
            else {
                $fehler=true;
                echo "P##E##";
        exit;
pseudoonlinspeicher.php
PHP:
 <?php
                |   -> WLAN                                                           |
                |      Fritz!Box Onlinespeicher-Status                                |
        error_reporting(0);
        $fehler=true;
            $Status = shell_exec("/usr/bin/ctlmgr_ctl r webdavclient status/connection_state");
            if ($Status) {
                $fehler=false;
            else {
                $fehler=true;
            $Status = shell_exec("/usr/bin/ctlmgr_ctl w webdavclient status/connection_state 1");
            if ($Status) {
                $fehler=false;
                echo "S#1#";
            else {
                $fehler=true;
            $Status = shell_exec("/usr/bin/ctlmgr_ctl w webdavclient status/connection_state 0");
            if ($Status) {
                $fehler=false;
                echo "S#0#";
            else {
                $fehler=true;
        if ($fehler) {
            $url=FB."/query.lua?sid=".GetSessionID($Login,$user,$password)."&wlan=webdavclient:status/connection_state";
            $ch = curl_init();
            $timeout = 5;
            curl_close($ch);
            if ($Status) {
                    $fehler=false;
                    echo 'P#Onlinespeicher-Status: <img src="'.PIC.'mled'.$x[3].'.png">*HTML#';
                else {
                    $fehler=true;
                    echo "P##E##";
            else {
                $fehler=true;
                echo "P##E##";
        exit;
Absolut geil, ich lerne immer mehr dazu :D. Thx für die Hilfe :dance:
Jetzt fehlt nur noch die Abfrage, ob bestimmte Rufnummern connected sind. Da komem ich aber noch nicht weiter. :-Ö
Moin
Genau das wollte ich erreichen.
Einmal verstanden und dann ist es plötzlich ganz leicht. ;)
PeterPawn hat ein Skript geschrieben, welches mit luavar arbeitet.
Das ist wesentlich schneller als ctlmgr_ctl.
Wenn ich es durchgecheckt und verstanden habe wirds in SaS auf der Fritz!Box eingesetzt.
Ich habe aber eine Weile gebaucht ;). Ist nicht so ganz easy, wenn man sich mit der Programmierung nicht auskennt. Bestimmt nicht alles ganz sauber, was Anmerkungen anbelangt, muss da noch mal nachbessern ;)
Moin
Das klingt interessant. Gerade die Fritzbox ist da etwas zäh bei vielen PseudoScript-Abarbeitungen. :)
Moin
luavar
Momentan gehen damit Abfragen, also Sensoren.
Immerhin wäre das schon eine Entlastung für die Fritz!Box.
Das Schalten (setzen von Variablen) selber geht noch nicht mit dem Skript.
Dieser Satz von PeterPawn klingt aber hoffnungsvoll:
:doktor:
PeterPawn schrieb:
Man kann über das Lua-Interface auch Variablen setzen ... das ist aber ein anderes Thema und dem widme ich mich später vielleicht einmal.
@SF1975,
hi SF1975 ich finde die Idee mit dem 2,4GHz und 5GHz W-Lan aufteilung gut. Muß ich noch irgenetwas beachten wenn ich diese Scripte einsetzen möchte und darf.
Möchte zumindest vorher mal fragen ob es dir recht ist denn schließlich hast du die Arbeit gehabt.
Gruß Benne007
Wenn ich die Scripte hier gepostet habe, kannst Du sie problemlos nutzen. Falls Du sas 4.x nutzt, musst Du sie ein wenig anpassen:
psgFBF-WLAN.php
<?php
        |   -> WLAN                                                           |
        |      Fritz!Box WLAN-Status                                          |
    include __DIR__."/../include/psg.php";
    $url=$Conf["FB"]."/query.lua?sid=".GetSessionID($Login,$user,$password)."&wlan=wlan:status/ap_enabled";
    $ch = curl_init();
    $timeout = 5;
    $Status1 = curl_exec($ch);
    curl_close($ch);
    $url=$Conf["FB"]."/query.lua?sid=".GetSessionID($Login,$user,$password)."&wlan=wlan:status/ap_enabled_scnd";
    $ch = curl_init();
    $timeout = 5;
    $Status2 = curl_exec($ch);
    curl_close($ch);
    $url=$Conf["FB"]."/query.lua?sid=".GetSessionID($Login,$user,$password)."&wlan=wlan:status/guest_ap_enabled";
    $ch = curl_init();
    $timeout = 5;
    $Status3 = curl_exec($ch);
    curl_close($ch);
    $t1="2";
    $t2="2";
    $t3="2";
    $x1=explode('"',$Status1);
    if ($x1[3]=="0" or $x1[3]=="1") {
        $t1=$x1[3];
    $x2=explode('"',$Status2);
    if ($x2[3]=="0" or $x2[3]=="1") {
        $t2=$x2[3];
    $x3=explode('"',$Status3);
    if ($x3[3]=="0" or $x3[3]=="1") {
        $t3=$x3[3];
    echo 'P#WLAN (2,4/5,0 Ghz & Gast): <img src="'.PIC.'mled'.$t1.'.png"> <img src="'.PIC.'mled'.$t2.'.png"> <img src="'.PIC.'mled'.$t3.'.png">*HTML#';
    exit;
@SF1975
Vielen Dank,
Habe die Scripte schon angepasst und läuft wunderbar.
Gruß Benne007
JSt Aero
