Hallo zusammen
ich versuche mit einem s2m Anschluss raus zu telefonieren. Doch leider kommt im Logbuch von Asterisk folgendes:
Ich hab noch einmal das Debugging hoch geschraubt:
Kann mir einer sagen, was die Gegenstelle von mir will?
Cause: Unknown (82), class = Invalid message (5)
-- Executing GotoIf("SIP/74486-081c5c30", "1?trunk-local|05430080|1:2") in new stack
-- Goto (trunk-local,05430080,1)
-- Executing Answer("SIP/74486-081c5c30", "") in new stack
-- Executing Wait("SIP/74486-081c5c30", "1") in new stack
-- Executing Set("SIP/74486-081c5c30", "CALLERID(num)=123") in new stack
-- Executing Dial("SIP/74486-081c5c30", "Zap/g1/24184848") in new stack
-- Called g1/24184848
-- Channel 0/1, span 9 got hangup, cause 18
May 10 00:41:38 WARNING[6248]: app_dial.c:733 wait_for_answer: Unable to forward voice
-- Hungup 'Zap/25-1'
== Everyone is busy/congested at this time (1:0/0/1)
-- Executing Goto("SIP/74486-081c5c30", "s-CHANUNAVAIL|1") in new stack
-- Goto (trunk-local,s-CHANUNAVAIL,1)
-- Executing Goto("SIP/74486-081c5c30", "s-NOANSWER|1") in new stack
-- Goto (trunk-local,s-NOANSWER,1)
-- Executing Busy("SIP/74486-081c5c30", "") in new stack
9 -- Making new call for cr 132
-- Requested transfer capability: 0x00 - SPEECH
9 > Protocol Discriminator: Q.931 (8) len=34
9 > Call Ref: len= 1 (reference 4/0x4) (Originator)
9 > Message type: SETUP (5)
9 > [04 03 80 90 a3]
9 > Bearer Capability (len= 5) [ Ext: 1 Q.931 Std: 0 Info transfer capability: Speech (0)
9 > Ext: 1 Trans mode/rate: 64kbps, circuit-mode (16)
9 > Ext: 1 User information layer 1: A-Law (35)
9 > [18 01 89]
9 > Channel ID (len= 3) [ Ext: 1 IntID: Implicit, Other Spare: 0, Exclusive Dchan: 0
9 > ChanSel: B1 channel
9 ]
9 > [1e 02 80 83]
9 > Progress Indicator (len= 4) [ Ext: 1 Coding: CCITT (ITU) standard (0) 0: 0 Location: User (0)
9 > Ext: 1 Progress Description: Calling equipment is non-ISDN. (3) ]
9 > [6c 05 21 81 31 32 33]
9 > Calling Number (len= 7) [ Ext: 0 TON: National Number (2) NPI: ISDN/Telephony Numbering Plan (E.164/E.163) (1)
9 > Presentation: Presentation permitted, user number passed network screening (1) '123' ]
9 > [70 09 a1 32 34 31 38 34 38 34 38]
9 > Called Number (len=11) [ Ext: 1 TON: National Number (2) NPI: ISDN/Telephony Numbering Plan (E.164/E.163) (1) '24184848' ]
9 < Protocol Discriminator: Q.931 (8) len=9
9 < Call Ref: len= 2 (reference 4/0x4) (Terminator)
9 < Message type: RELEASE COMPLETE (90)
9 < [08 02 82 d2]
9 < Cause (len= 4) [ Ext: 1 Coding: CCITT (ITU) standard (0) 0: 0 Location: Public network serving the local user (2)
9 < Ext: 1 Cause: Unknown (82), class = Invalid message (5) ]
9 -- Making new call for cr 32772
9 -- Processing IE 8 (cs0, Cause)
9 NEW_HANGUP DEBUG: Calling q931_hangup, ourstate Null, peerstate Null
9 NEW_HANGUP DEBUG: Destroying the call, ourstate Null, peerstate Null
-- Saved useragent "snom320/6.5.8" for peer 7226
-- Saved useragent "snom300/6.5.8" for peer 7244
9 No response to SETUP message
9 NEW_HANGUP DEBUG: Calling q931_hangup, ourstate Call Initiated, peerstate Overlap sending
9 > Protocol Discriminator: Q.931 (8) len=8
9 > Message type: DISCONNECT (69)
9 > [08 02 81 92]
9 > Cause (len= 4) [ Ext: 1 Coding: CCITT (ITU) standard (0) 0: 0 Location: Private network serving the local user (1)
9 > Ext: 1 Cause: No user responding (18), class = Normal Event (1) ]
9 NEW_HANGUP DEBUG: Calling q931_hangup, ourstate Disconnect Request, peerstate Disconnect Indication
9 < Message type: RELEASE (77)
9 < [08 02 82 d1]
9 < Ext: 1 Cause: Invalid call reference value (81), class = Invalid message (5) ]
9 > Call Ref: len= 1 (reference 132/0x84) (Terminator)
9 > Message type: RELEASE COMPLETE (90)
9 > [08 02 80 d1]
9 > Cause (len= 4) [ Ext: 1 Coding: CCITT (ITU) standard (0) 0: 0 Location: User (0)
9 > Ext: 1 Cause: Invalid call reference value (81), class = Invalid message (5) ]
== Spawn extension (trunk-local, s-NOANSWER, 1) exited non-zero on 'SIP/74486-081c5c30'
-- Saved useragent "snom300/6.5.8" for peer 7221
-- Saved useragent "snom300/6.5.8" for peer 7224
9 < [08 02 82 d1]
9 > [08 02 80 d1]
-- Saved useragent "snom360/6.5.8" for peer 7228
9 Timed out looking for release
9 > Message type: RELEASE (77)
9 > [08 02 81 90]
9 > Ext: 1 Cause: Normal Clearing (16), class = Normal Event (1) ]
9 < [08 02 82 d1]
9 Timed out looking for release complete
9 > [08 02 81 90]
9 < [08 02 82 d1]
