I hope someone can have a look at my issues when I try to use Aiccu and Radvd.
I'm running 74.04.90 with Freetz-1.2_rc1 on my 7270v3.
(wget http://freetz.org/downloads/freetz-1.2_rc1.tar.bz2)
During configuring of make I selected also IPv6 and packages:
aiccu, Dnsmasq, Dropbear, radvd, tcdpdump, Inadyn-mt, ndas
Currently I see 3 IPv6 related issues.
-The -6 option is not accepted with ping (e.g. ping -6 <IPv6 name | IPv6 address>) Solved by suggestion of Whoopie
-Aiccu is trying to start before NTP sync the router at router reboot. Solved by configuring a wait time (Maximal time waiting for time-synchronisation (seconds)). But I'm a bit surprised that the default settings don't behave to work in most situations.
- Radvd is complaining about 'sendmsg: Invalid argument' and fails to start.
Seen a number of times that the whole router rebooted when adapting radvd.
-when applying the initial configuration of radvd,
-when restarting radvd.
-when changing configuration of radvd.
Info after configuring aiccu and radvd via the web interface:
>>>> I'm missing a /64 route 2001:x.y::/64 pointing to lan.
>>>> Is this an function that is part of the radvd script that fails?
logread:
Jan 1 01:01:35 fritz local7.err syslog: Couldn't resolve host tic.sixxs.net, service 3874
Jan 1 01:01:35 fritz local7.err syslog: Couldn't connect to the TIC server tic.sixxs.net
Jan 1 01:01:35 fritz local7.err syslog: Couldn't retrieve first tunnel for the above reason, aborting
Jan 1 01:01:35 fritz user.notice FREETZMOD: Starting aiccu ... failed.
after restart of aiccu after a NTP sync:
Feb 4 12:44:14 fritz local7.info syslog: Succesfully retrieved tunnel information for Txxxxx
Feb 4 12:44:14 fritz local7.info syslog: AICCU running as PID 2822
Feb 4 12:44:14 fritz local7.info syslog: [AYIYA-start] : Anything in Anything (draft-02)
Feb 4 12:44:14 fritz local7.info syslog: [AYIYA-tun->tundev] : (Socket to TUN) started
Jan 1 01:01:35 fritz daemon.info radvd[2118]: version 1.7 started
Jan 1 01:01:36 fritz daemon.warn radvd[2119]: sendmsg: Invalid argument
Jan 1 01:01:36 fritz user.notice FREETZMOD: Starting radvd ... done.
>> I don't see this 'Invalid argument' when I start radvd manunally (see below). Is a script causing this?
# ping -6 2001:a:b:c::1 soved by suggestion of Whoopie
ping: invalid option -- 6
BusyBox v1.18.5 (2012-02-03 21:31:22 CET) multi-call binary.
Usage: ping [OPTIONS] HOST
Send ICMP ECHO_REQUEST packets to network hosts
Options:
-4,-6 Force IP or IPv6 name resolution
-c CNT Send only CNT pings
-s SIZE Send SIZE data bytes in packets (default:56)
-I IFACE/IP Use interface or IP address as source
-W SEC Seconds to wait for the first response (default:10)
(after all -c CNT packets are sent)
-w SEC Seconds until ping exits (default:infinite)
(can exit earlier with -c CNT)
-q Quiet, only displays output at start
and when finished
# ping 2001:a:b:c::1
ping: bad address '2001:a:b:c::1'
# cat /proc/sys/net/ipv6/conf/all/forwarding
If I start radvd manually it is ok, and I can get advertising and routing working:
Rebooted the router and via telnet performed the following steps:
# radvd -v
# cat /var/run/radvd.pid
# kill -9 <pid>
# rm /var/run/radvd.pid
# radvd -C /mod/etc/radvd.conf -d 2& <<< so config generated by web interface is ok.
Now radvd is working. It is advertising IPv6 addresses and a default IPv6 route.
# ip -f inet6 route add 2001:x:y::/64 dev lan
Now routing is also working. And I can ping an global IPv6 route or its DNS name from a connected (Win7) system.
IPv6 routing table of the 7270v3:
# ip -f inet6 route
2001:a:b:c::/64 dev sixxs metric 256 expires 42946491sec
2001:x:y::/64 dev lan metric 1024 expires 42949538sec
fe80::/64 dev lan metric 256 expires 42946258sec
fe80::/64 dev sixxs metric 256 expires 42946491sec
ff00::/8 dev lan metric 256 expires 42946258sec
default via 2001:a:b:c::1 dev sixxs metric 1024 expires 42946492sec
# ip -f inet6 route
2001:a:b:c::/64 dev sixxs metric 256 expires 42909512sec
fe80::/64 dev sixxs metric 256 expires 42909512sec
fe80::/64 dev lan metric 256 expires 42909513sec
ff00::/8 dev sixxs metric 256 expires 42909512sec
ff00::/8 dev lan metric 256 expires 42909513sec
default via 2001:a:b:c::1 dev sixxs metric 1024 expires 42909512sec
# ip -f inet6 addr
2: lo: <LOOPBACK,UP,LOWER_UP> mtu 16436
inet6 ::1/128 scope host
valid_lft forever preferred_lft forever
6: lan: <BROADCAST,MULTICAST,UP,LOWER_UP200> mtu 1500
inet6 2001:x:y::1/128 scope global <<<<< shouldn't this be a /64 address?
inet6 fe80::224:feff:fefa:a344/64 scope link
38: sixxs: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1280 qlen 500
inet6 2001:a:b:c::2/64 scope global
inet6 fe80::410:b:c:2/64 scope link
logread:
Options:
and when finished
# radvd -v
# kill -9 <pid>
# ip -f inet6 route
