Realtime Problem
ammar
13 Jun 2006
Alles neu installiert, Realtime Tabellen (bzw zumindest die "sip" Tabelle) werden aber nicht ausgelesen.
# service asterisk start
Connected to Asterisk 1.6.2.19 currently running on asterisk16 (pid = 2401)
Verbosity is at least 3
asterisk16*CLI> sip show peers
Name/username              Host            Dyn Nat ACL Port     Status     Realtime
0 sip peers [Monitored: 0 online, 0 offline Unmonitored: 0 online, 0 offline]
asterisk16*CLI> realtime mysql status
general connected to asterisk@localhost, port 3306 with username astrealtime for 7 minutes.
asterisk16*CLI> realtime mysql cache
             general sip
             general voicemail_users
             general queue_members
Ich sehe keine Fehlermeldungen in Logs
/var/log/asterisk/messages
[Jul  6 16:42:14] NOTICE[2401] cdr.c: CDR simple logging enabled.
[Jul  6 16:42:14] NOTICE[2401] loader.c: 175 modules will be loaded.
[Jul  6 16:42:14] NOTICE[2401] res_smdi.c: No SMDI interfaces are available to listen on, not starting SMDI listener.
[Jul  6 16:42:14] NOTICE[2401] config.c: Registered Config Engine mysql
[Jul  6 16:42:14] NOTICE[2401] pbx_ael.c: Starting AEL load process.
[Jul  6 16:42:14] NOTICE[2401] pbx_ael.c: AEL load process: parsed config file name '/etc/asterisk/extensions.ael'.
[Jul  6 16:42:14] NOTICE[2401] pbx_ael.c: AEL load process: checked config file name '/etc/asterisk/extensions.ael'.
[Jul  6 16:42:14] NOTICE[2401] pbx_ael.c: AEL load process: compiled config file name '/etc/asterisk/extensions.ael'.
[Jul  6 16:42:14] NOTICE[2401] pbx_ael.c: AEL load process: merged config file name '/etc/asterisk/extensions.ael'.
[Jul  6 16:42:14] NOTICE[2401] pbx_ael.c: AEL load process: verified config file name '/etc/asterisk/extensions.ael'.
[Jul  6 16:42:14] NOTICE[2401] chan_skinny.c: Configuring skinny from skinny.conf
[Jul  6 16:42:14] WARNING[2401] chan_dahdi.c: Ignoring any changes to 'userbase' (on reload) at line 23.
[Jul  6 16:42:14] WARNING[2401] chan_dahdi.c: Ignoring any changes to 'vmsecret' (on reload) at line 31.
[Jul  6 16:42:14] WARNING[2401] chan_dahdi.c: Ignoring any changes to 'hassip' (on reload) at line 35.
[Jul  6 16:42:14] WARNING[2401] chan_dahdi.c: Ignoring any changes to 'hasiax' (on reload) at line 39.
[Jul  6 16:42:14] WARNING[2401] chan_dahdi.c: Ignoring any changes to 'hasmanager' (on reload) at line 47.
[Jul  6 16:42:14] WARNING[2401] utils.c: trying to reset empty pool
/var/log/mysql/mysql.log
110706 16:42:14      16 Connect     astrealtime@localhost on asterisk
                     16 Query       SET NAMES latin1
                     16 Query       DESC sip
                     16 Init DB     asterisk
                     16 Query       DESC voicemail_users
                     17 Connect     astrealtime@localhost on asterisk
                     17 Query       SET NAMES ''
                     17 Query       DESC cdr
                     16 Init DB     asterisk
                     16 Query       DESC queue_members
res_mysql.conf
[general]
dbhost = localhost
dbname = asterisk
dbuser = astrealtime
dbpass = ...
dbport = 3306
dbsock = /var/lib/mysql/mysql.sock
dbcharset = latin1
requirements=warn ; or createclose or createchar
extconfig.conf
sippeers => mysql,general,sip
sipusers => mysql,general,sip
mysql> desc sip;
| Field            | Type                         | Null | Key | Default  | Extra          |
| id               | int(11)                      | NO   | PRI | NULL     | auto_increment |
| name             | varchar(80)                  | NO   | UNI |          |                |
| host             | varchar(31)                  | NO   |     | dynamic  |                |
| nat              | varchar(5)                   | NO   |     | no       |                |
| type             | enum('user','peer','friend') | NO   |     | friend   |                |
| accountcode      | varchar(20)                  | YES  |     | NULL     |                |
| amaflags         | varchar(13)                  | YES  |     | NULL     |                |
| call-limit       | smallint(5) unsigned         | YES  |     | NULL     |                |
| callgroup        | varchar(10)                  | YES  |     | NULL     |                |
| callerid         | varchar(80)                  | YES  |     | NULL     |                |
| cancallforward   | char(3)                      | YES  |     | yes      |                |
| canreinvite      | char(3)                      | YES  |     | no       |                |
| context          | varchar(80)                  | YES  |     | interno  |                |
| defaultip        | varchar(15)                  | YES  |     | NULL     |                |
| dtmfmode         | varchar(7)                   | YES  |     | NULL     |                |
| fromuser         | varchar(80)                  | YES  |     | NULL     |                |
| fromdomain       | varchar(80)                  | YES  |     | NULL     |                |
| insecure         | varchar(4)                   | YES  |     | NULL     |                |
| language         | char(2)                      | YES  |     | NULL     |                |
| mailbox          | varchar(50)                  | YES  |     | NULL     |                |
| md5secret        | varchar(80)                  | YES  |     | NULL     |                |
| deny             | varchar(95)                  | YES  |     | NULL     |                |
| permit           | varchar(95)                  | YES  |     | NULL     |                |
| mask             | varchar(95)                  | YES  |     | NULL     |                |
| musiconhold      | varchar(100)                 | YES  |     | NULL     |                |
| pickupgroup      | varchar(10)                  | YES  |     | NULL     |                |
| qualify          | char(3)                      | YES  |     | yes      |                |
| regexten         | varchar(80)                  | YES  |     | NULL     |                |
| restrictcid      | char(3)                      | YES  |     | NULL     |                |
| rtptimeout       | char(3)                      | YES  |     | NULL     |                |
| rtpholdtimeout   | char(3)                      | YES  |     | NULL     |                |
| secret           | varchar(80)                  | YES  |     | asterisk |                |
| setvar           | varchar(100)                 | YES  |     | NULL     |                |
| disallow         | varchar(100)                 | YES  |     | all      |                |
| allow            | varchar(100)                 | YES  |     | alaw     |                |
| fullcontact      | varchar(80)                  | NO   |     |          |                |
| ipaddr           | varchar(15)                  | NO   |     |          |                |
| port             | smallint(5) unsigned         | NO   |     | 0        |                |
| regserver        | varchar(100)                 | YES  |     | NULL     |                |
| regseconds       | int(11)                      | NO   |     | 0        |                |
| lastms           | int(11)                      | NO   |     | 0        |                |
| username         | varchar(80)                  | NO   |     |          |                |
| defaultuser      | varchar(80)                  | NO   |     |          |                |
| subscribecontext | varchar(80)                  | YES  |     | NULL     |                |
| useragent        | varchar(20)                  | YES  |     | NULL     |                |
45 rows in set (0.01 sec)
Tabelle "sip" hat einige Einträge drinnen.
Habe mit rtcachefriends=yes und no ausprobiert, keine Auswirkung.
Hat wer eine Ahnung was ich da nicht richtig mache?
lG,
Ammar
figo12
