Reboot again after factory reset
Fritsy
3 Nov 2008
I am using a Freetz generated image for my FritzBox 7170.
This image contains a modified setfactorydefaults script so each time i reset to factory default it uses my own settings, not the blank AVM settings.
This is working perfect except sometimes after a factory reset the remote management port (443) is closed.
When i just reboot the FritzBox or do a power cycle the problem is fixed and remote management is working again.
So to be sure i want the FritzBox 7170 to do reboot after it has returned from a factory reset.
Is this possible?
Can i edit some bootscript that will check if a factory reset has been done in the last 2 minutes and then do another reboot?
nikitarajusa
