Recover FritzBox 7050
driesve
26 Jun 2009
Hello,
First my excuses for writing in English, because I can't speak and understand the German language. My English isn't very good, but I'll try.
I bought a German FritzBox FON WLAN 7050 on Ebay, but i'm not going to use it as a modem, so Annex B isn't a problem.
But http://fritz.box is complete writen in the German language. So I tried changing it to English.
I followed many manuals on this forum, but nothing works and now, I don't get an ipaddress from my Fritzbox en sometimes I've a reboot loop.
So I want to go back to the German language, the firmware what was installed when I bought it.
Telnet doesn't work anymore, so I had to use ftp.
I gave my LAN adapter a fixed ipadress (192.168.178.10) and the gateway interface 192.168.178.1.
But it does not work. (see screenshot)
Can somebody help me?
Thanks in advance!
Hi driesve
First of all: Welcome to the Forum!
You are on the right way!
And it seems you are familiar with ftp/adam2. That's fine!
"WinError -4" usually occurs in case of a conflict between the installed Firmware with kernel 2.4 (in your case 14.04.15) and the used recovery file with kernel 2.6 (in your case 14.04.31?).
Solution: Use german recovery file 14.04.15 AnnexB.
Recommendation: Install the english FW 14.04.26 AnnexB. It has kernel 2.4, too.
You must only change the parameter "firmware_version" to the value "avme" and afterwards you can run english recovery file 14.04.26.
The ftp command is "quote SETENV firmware_version avme"
(if you have an older version of ftp it is "quote SETENV firmware_version,avme")
Good luck!
Thanks for your answer.
I used 14.04.15, but I had changed the Firmware_Info parameter, 14.04.15 wasn't the original value.
But the original firmware, when I bought my Fritzbox, was *.04.31. So I have changed Firmware_Info to 14.04.31 and tried the recovery file 14.04.31 and it works.
Now I can visit http://fritz.box, my FritzBox is repaired, but still in the German Language.
What have I to do, to change the language to English. Annex A of Annex B doesn't matter because I use a modem in bridge-mode and I'll have VDSL2.
I've installed 14.04.31 (see screenshot)
What have I to do, to change the language to English. I've installed 14.04.31
Changing from FW 14.04.31 (kernel 2.6) to FW 14.04.26 english (kernel 2.4) it's a little awful, because you have to manually change the bootloader at flash partition mtd2.
I don't recommend you to try that, because it is not so easy and a little dangerous: If you delete mtd2, you will kill your FB7050.
Further more, FW 14.04.31 (german) is a little more powerful than FW 14.04.26 (english).
You should learn the meaning of the german comments, most of them are self explaining.
There is a newer (german) version FW 14.04.33; you may update it to via GUI menu.
Thanks for your reply.
My Fritzbox is now working well, so I'm going to use the German-interface/firmware.
I'll use my fritzbox for routering and VOIP. I don't need support for Annex A because I'll use another modem in bridge mode.
Thanks for helping me with repairing my fritzbox.
Now I will try to learn the German language.
7050 Annex-B to Annex-A
el_valiente hi !
FRITZ!Box Fon WLAN 7050, Firmware-Version 14.04.31 Annex-B Deutsch
Recovery English Annex A .....
ftp adam2 login okey ....
quote SETENV annex A
quote SETENV HWRevision 77
quote SETENV ProductID Fritz_Box_7050_AnnexA
quote SETENV firmware_info 14.04.26
bye
Searching FRITZ!Box Fon WLAN 7050 (Annex A) at: 192.168.178.3
One system found! - Detecting the current version.
Version successfully detected!
Hardware: FRITZ!Box Fon WLAN 7050 (Annex A)
Bootstrap: 1203
Firmware: 14.04.26
Flash area (mtd1)
Deleting flash area (mtd1)
Restoring flash area (mtd1)
Checking flash area (mtd1)
Could not check the partition mtd1! WinError -4
Help Me Please ! :(
What about reading and followig the advices you allready got? It is not polite to hijack other threads and crosspost all over the forum :(
Once again:
You can not recover a box wth fw 04.31 with a recover of version 04.26.
So please follow the advices you got in the thread you opened for your problem:
Recover your box with the geman recove 04.31.
Then you may install a firmware prepared with the annex A modem-code.
Feel free to ask, but do not repeat the same question all over.
Tell what you allready did following the advices and what your specific problems are.
Jörg
fusionK
