S-Bus Extension mit SN4552 - aber wie?
mnagele
8 Nov 2006
Hallo:)
ich habe folgendes problem, ich möchte mit 2 SN4552 eine ISDN leitung übers lokale intranet "verlängern" (also eine S-Bus extension)
mein problem aber ist folgendes:
ich habe am BRI0/1 (wo das ISDN - telefon angesteckt ist) keine spannung. Also kein Telefonat möglich.
hier habe ich die aktuelle konfiguration der main station:
# SN4552/2BIS/EUI                                                #
# R3.20 2006-11-17 SIP                                           #
# 1970-01-01T00:15:18                                            #
# Generated configuration file                                   #
cli version 3.20
webserver port 80 language en
snmp community public ro
system hostname Main
system
  ic voice 0
profile service-policy PROF_QOS_OUT
  rate-limit 99 header-length 18 voice-margin 0
  source traffic-class local-voice
    priority
profile service-policy PROF_QOS_IN
  rate-limit 99 header-length 18 voice-margin 33
    priority
profile ppp default
profile tone-set default
profile voip default
  codec 1 g729 rx-length 20 tx-length 20
  codec 2 g711alaw64k rx-length 20 tx-length 20
  codec 3 g711ulaw64k rx-length 20 tx-length 20
  dejitter-max-delay 100
profile pstn default
profile sip default
profile aaa default
  method 1 local
  method 2 none
context ip router
  interface IF_IP_WAN
    ipaddress 10.124.50.216 255.255.255.0
    use profile service-policy PROF_QOS_IN in
    use profile service-policy PROF_QOS_OUT out
  interface IF_IP_LAN
    ipaddress 192.168.1.1 255.255.255.0
context ip router
  route 0.0.0.0 0.0.0.0 10.124.50.65 0
  route 192.168.1.1 255.255.255.0 10.124.50.217 0
context cs switch
  interface isdn IF_S0_00
    route call dest-interface IF_H323_BRANCH
context cs switch
  no shutdown
port ethernet 0 0
  encapsulation ip
  bind interface IF_IP_WAN router
  no shutdown
port ethernet 0 1
  encapsulation ip
  bind interface IF_IP_LAN router
  no shutdown
port bri 0 0
  clock auto
  encapsulation q921
  q921
    protocol pp
    uni-side auto
    encapsulation q931
    q931
      protocol dss1
      uni-side user
      encapsulation cc-isdn
      bind interface IF_S0_00 switch
port bri 0 0
  no shutdown
port bri 0 1
  clock auto
  encapsulation q921
  q921
    protocol pmp
    uni-side auto
    encapsulation q931
    q931
      protocol dss1
      uni-side net
port bri 0 1
  shutdown
und hier die aktuelle konfiguration der branch station:
# SN4552/2BIS/EUI                                                #
# 1970-01-01T00:17:53                                            #
cli version 3.20
system hostname Branch
system
  ic voice 0
    priority
    priority
profile ppp default
profile sip default
profile aaa default
  method 1 local
  method 2 none
context ip router
  interface IF_IP_WAN
    ipaddress 10.124.50.217 255.255.255.0
  interface IF_IP_LAN
context ip router
context cs switch
  interface isdn IF_S0_01
    route call dest-interface IF_H323_MAIN
context cs switch
  no shutdown
port ethernet 0 0
  encapsulation ip
  no shutdown
port ethernet 0 1
  encapsulation ip
  no shutdown
port bri 0 0
  clock auto
  encapsulation q921
  q921
    protocol pp
    uni-side auto
    encapsulation q931
    q931
      protocol dss1
      uni-side user
      bind interface IF_S0_01 switch
port bri 0 0
  no shutdown
port bri 0 1
  clock auto
  encapsulation q921
  q921
    protocol pmp
    uni-side auto
    encapsulation q931
    q931
      protocol dss1
      uni-side net
port bri 0 1
  shutdown
habe ich vielleicht einen fehler in der konfiguration? kann mir jemand weiterhelfen?
lg matthias.
Ich weiß nicht ganz genau, hat dieses Modell Endgeräte-Speisung?
Funktioniert das:
port bri 0 1
power-feed
mfg Guard-X
Nein, nur 4634 und 4638 bzw die modularen Geräte mit den entsprechenden Optionen.
Da hilft nur ein alter ntba am Port 0/0. Programmiert werden muß dazu nichts.
@Mnagele, Deine Konfig wird eh nicht funktionieren. Du hast die SIP-FW in deiner SN, ist das so gewollt? Dein Beispiel deutet auf H.323 hin. Weiterhin hast du kein einziges VoIP-Interface, bzw Gateway.
Hallo!
erstmal danke für die antworten! ich hab mir ein "power feed accessory" besorgen können, damit konnte ich fürs erste mein "stromproblem" lösen :)
Ich habe diese config von der mitgelieferten cd runter. ich möchte einfach nur eine isdn leitung übers intranet verlängern. irgendwie komm ich aber auf keinen grünen zweig.
gruss Matthias.
holh-66
