samba password
johnbock
2 Mrz 2008
I can't log onto my samba share when passwords are activated in the avm front-end. It works as soon as it's deactivated.
I attempted to changed the password on the command line, but that didn't work either.
Here's my configuration
 # cat /mod/etc/smb.conf
### global
[global]
netbios name = delaware
workgroup = XXXX
server string = %h (Samba %v)
syslog = 0
encrypt passwords = true
passdb backend = smbpasswd
obey pam restrictions = yes
socket options = TCP_NODELAY
unix charset = ISO-8859-1
preferred master = no
os level = 50
security = SHARE
guest account = ftpuser
interfaces = 10.0.1.101/255.255.255.0
bind interfaces only = yes
### expert
### default
[uStor02]
 path = /var/media/ftp/uStor02
 user = ftpuser
 read only = no
 guest ok = yes
 write cache size = 65536
### shares
### fin
BTW: I can't get any kind logging to work...
This setting causes samba not to use a username and password when it authenticates a smb connection setup. Authentication is based solely on a password per share and smb clients only setup a connection by providing a password.
you can change this with an entry in the samba expert settings in the Freetz-Webinterface:
this overrides the setting and you can logon with username and password
@johnbock: Are you trying to log on to your share from Windows or from Linux? For me, everything works fine from Windows, but form Linux I get:
christof@scooter:~$ smbclient -L  //fritz
Password:
Domain=[WARLICH] OS=[Unix] Server=[Samba 3.0.24]
        Sharename       Type      Comment
        daten           Disk      Zentralarchiv
        fritzbox        Disk      Fritzbox
        IPC$            IPC       IPC Service (fritz (Samba 3.0.24))
        Server               Comment
        FRITZBOX             fritz (Samba 3.0.24)
        SAM                  Samba 3.0.28a
        Workgroup            Master
        WARLICH              FRITZBOX
christof@scooter:~$ smbclient  //fritz/daten
Password:
Server not using user level security and no password supplied.
Server requested LANMAN password (share-level security) but 'client use lanman auth' is disabled
tree connect failed: SUCCESS - 0
christof@scooter:~$
You may refer to http://www.ip-phone-forum.de/showthread.php?t=168481 to see what I've tried to get closer to the issue.
@all: Could anyone having a Linux box post the output of the two commands:
smbclient -L //yourserver # do not type a password when you are prompted
smbclient //yourserver/yourshare # type your ftpuser password when you are prompted
Thanks for any help,
Christof
