Samba startet nicht
basti1985
13 Mrz 2009
samba startet nicht
sh /etc/init.d/rc.samba start
Starting samba...Looking for user 'ftpuser' ... found
sh: yes: unknown operand
done.
ps | grep smbd
 1593 root      1160 S    grep smbd
sh -x /etc/init.d/rc.samba
+ export PATH=/sbin:/bin:/usr/sbin:/usr/bin:/mod/sbin:/mod/bin:/mod/usr/sbin:/mod/usr/bin
+ export LD_LIBRARY_PATH=/mod/lib:/mod/usr/lib
+ BDIR=/sbin
+ DAEMON=samba
+ SMBD=smbd
+ NMBD=nmbd
+ MODPATH=/mod/etc
+ CONF=/mod/etc/smb.conf
+ . /etc/init.d/modlibrc
+ [ -n samba ]
+ [ ! -r /mod/etc/conf/samba.cfg ]
+ . /mod/etc/conf/samba.cfg
+ export SAMBA_ENABLED=yes
+ export SAMBA_INTERFACES=192.168.178.1/255.255.255.0
+ export SAMBA_MASTER=yes
+ export SAMBA_NETBIOS_NAME=FRITZ.BOX
+ export SAMBA_OS_LEVEL=100
+ export SAMBA_SERVER_STRING=%h (Samba %v)
+ export SAMBA_WORKGROUP=Arbeitsgruppe
+ [ -d /tmp/flash/samba ]
+ modreg cgi samba Samba
+ deffile=/mod/etc/default.samba/shares.def
+ [ -r /tmp/flash/samba/shares.def ]
+ modreg file shares Samba: Freigaben 1 /mod/etc/default.samba/shares.def
+ deffile=/mod/etc/default.samba/sharesx.def
+ [ -r /tmp/flash/samba/sharesx.def ]
+ modreg file sharesx Samba: Erweitert 1 /mod/etc/default.samba/sharesx.def
+ [ yes != yes ]
+ start
+ echo -n Starting samba...
Starting samba...+ config
+ mkdir -p /var/locks
+ mkdir -p /var/samba/lib
+ mkdir -p /var/samba/private
+ modlib_adduser ftpuser -G users -D -S -h /var/media/ftp -g ftp user
+ local user=ftpuser
+ shift
+ echo -n Looking for user 'ftpuser' ...
Looking for user 'ftpuser' ... + grep -q ^ftpuser: /etc/passwd
+ echo found
found
+ return 0
+ /mod/etc/default.samba/samba_conf
+ [ -r /var/tmp/smbpasswd.cleartext ]
+ pidof smbd
+ smbd -D -s /mod/etc/smb.conf
+ exitvals=0
+ NST=1
+ [ 0 -ge 1 ]
+ exitvaln=0
+ [ -x /sbin/nmbd -a 1 -eq 1 ]
+ nmbd -D -s /mod/etc/smb.conf
+ exitvaln=0
+ [ 0 -eq 0 -a 0 -eq 0 ]
+ echo done.
done.
+ exit 0
Freetz 1.0.3
FB: 7170
Ich hab die datei entsprechend deinem post angepasst.
nun erhalte ich folgende Ausgabe
done.
 /etc/init.d/rc.samba status
stopped
Hast du die Samba IP im Webinterface angepasst? Existiert das freigegebene Verzeichnis?
MfG Oliver
Vergleiche mal die Samba-Einstellungen aus diesem Bild
mit den Einstellungen deiner Fritzbox.
Den gleichen Fehler hatte ich gestern auch.
Das Bild der Fritzbox kann bei Dir etwas anders aussehen da meine 7170 als WDS-Repeater arbeitet.
danke an alle .. der samba tanzt :dance:
jedoch will die Benutzer-/Gruppenverwaltung noch nicht so recht aber das ist ja ein anderes Thema
nee wohl eher von der Gruppenverwaltung ...
useradd -G smbshare foobar
smbashare -> Gruppe
foobar -> User
OK, soweit bin ich noch nicht. Bei mir hängt es noch bei der ersten FTP-User-Geschichte. Der Rest kommt wenn ich dieses Problem gelöst habe.
[OT] Speichert deine FritzBox denn die FTP-User ? Nach einem Reload der Box sind bei mir die Default-User wieder aktiv.[/OT]
sunburstc
