- Mitglied seit
- 23 Aug 2005
- Beiträge
- 17
- Punkte für Reaktionen
- 0
- Punkte
- 0
ich hab eben die aktuelle SVN-Version von Freetz (Rev. 3656) installiert. Dazu habe ich SANE und das pixma-backend installiert (bei make menuconfig).
An meiner FritzBox 3130 hängt ein Canon Pixma MX310, der ab SANE 1.0.20 bzw. pixma 0.15 unterstützt wird.
Nun passiert aber das auf der FritzBox:
An Port 6566 lauscht auch kein Prozess für den Fernzugriff.
Weiß jemand, was da falsch läuft? Muss ich noch etwas machen?
/var/mod/root # sane-find-scanner
# sane-find-scanner will now attempt to detect your scanner. If the
# result is different from what you expected, first make sure your
# scanner is powered up and properly connected to your computer.
# No SCSI scanners found. If you expected something different, make sure that
# you have loaded a kernel SCSI driver for your SCSI adapter.
# Also you need support for SCSI Generic (sg) in your operating system.
# If using Linux, try "modprobe sg".
found USB scanner (vendor=0x04a9 [Canon], product=0x1728 [MX310 series]) at libusb:001:002
# Your USB scanner was (probably) detected. It may or may not be supported by
# SANE. Try scanimage -L and read the backend's manpage.
# Not checking for parallel port scanners.
# Most Scanners connected to the parallel port or other proprietary ports
# can't be detected by this program.
/var/mod/root # scanimage -L
No scanners were identified. If you were expecting something different,
check that the scanner is plugged in, turned on and detected by the
sane-find-scanner tool (if appropriate). Please read the documentation
which came with this software (README, FAQ, manpages).
