mein Problem ist, dass bei eingehenden ISDN-Verbindungen Asterisk mit "Segmentation Fault" aussteigt.
System: CentOS 4.5 mit Kernel 2.6.9-34.0.2.EL
lspci:
lsmod:
capiinfo:
asterisk:
Jemand ne Idee woran es liegen kann, die Karte lief noch bis vor kurzem ganz normal in einem Windows Server.
lspci:
00:09.0 Network controller: AVM Audiovisuelles MKTG & Computer System GmbH B1 ISDN
lsmod:
Module Size Used by
capi 18177 0
capifs 5961 2 capi
b1pci 10445 0
b1dma 16737 1 b1pci
b1 21965 2 b1pci,b1dma
kernelcapi 44769 4 capi,b1pci,b1dma,b1
capiinfo:
Number of Controllers : 1
Controller 1:
Manufacturer: AVM GmbH
CAPI Version: 2.0
Manufacturer Version: 3.11-03 (49.19)
Serial Number: 0402356
BChannels: 2
Global Options: 0x00000039
internal controller supported
DTMF supported
Supplementary Services supported
channel allocation supported (leased lines)
B1 protocols support: 0x4000001f
64 kbit/s with HDLC framing
64 kbit/s bit-transparent operation
V.110 asynconous operation with start/stop byte framing
V.110 synconous operation with HDLC framing
T.30 modem for fax group 3
B2 protocols support: 0x00000b1b
ISO 7776 (X.75 SLP)
Transparent
LAPD with Q.921 for D channel X.25 (SAPI 16)
T.30 for fax group 3
ISO 7776 (X.75 SLP) with V.42bis compression
V.120 asyncronous mode
V.120 bit-transparent mode
B3 protocols support: 0x8000003f
Transparent
T.90NL, T.70NL, T.90
ISO 8208 (X.25 DTE-DTE)
X.25 DCE
T.30 for fax group 3 with extensions
0100
0200
39000000
1f000040
1b0b0000
3f000080
00000000 00000000 00000000 00000000 00000000 00000000
01000001 00010000 00000000 00000000 00000000
Supplementary services support: 0x000003ff
Hold / Retrieve
Terminal Portability
ECT
3PTY
Call Forwarding
Call Deflection
MCID
CCBS
asterisk:
*CLI> capi debug
CAPI Debugging Enabled
CONNECT_IND ID=001 #0x0023 LEN=0046
Controller/PLCI/NCCI = 0x101
CIPValue = 0x10
CalledPartyNumber = <c1>151XX
CallingPartyNumber = <21 81>5111XXXXX
CalledPartySubaddress = default
CallingPartySubaddress = default
BC = <80 90 a3>
LLC = default
HLC = <91 81>
AdditionalInfo = default
-- CONNECT_IND (PLCI=0x101,DID=151XX,CID=5111XXXXX,CIP=0x10,CONTROLLER=0x1)
> ISDN1: msn='*' DNID='151XX' MSN
== ISDN1: Incoming call '05111XXXXX' -> '151XX'
INFO_IND ID=001 #0x0024 LEN=0021
InfoNumber = 0x70
InfoElement = <c1>151XX
INFO_RESP ID=001 #0x0024 LEN=0012
-- ISDN1: info element CALLED PARTY NUMBER
> ISDN1: INFO_IND DID digits not used in this state.
INFO_IND ID=001 #0x0025 LEN=0016
InfoNumber = 0x18
InfoElement = <89>
INFO_RESP ID=001 #0x0025 LEN=0012
-- ISDN1: info element CHANNEL IDENTIFICATION 89
INFO_IND ID=001 #0x0026 LEN=0016
InfoNumber = 0xa1
InfoElement = <a1>
INFO_RESP ID=001 #0x0026 LEN=0012
-- ISDN1: info element Sending Complete
CONNECT_RESP ID=001 #0x0026 LEN=0032
Reject = 0x1
BProtocol
B1protocol = 0x0
B2protocol = 0x0
B3protocol = 0x0
B1configuration = default
B2configuration = default
B3configuration = default
ConnectedNumber = default
ConnectedSubaddress = default
LLC = default
AdditionalInfo
BChannelinformation = default
Keypadfacility = default
Useruserdata = default
Facilitydataarray = default
DISCONNECT_IND ID=001 #0x0027 LEN=0014
Reason = 0x0
DISCONNECT_RESP ID=001 #0x0027 LEN=0012
-- ISDN1: DISCONNECT_IND on incoming without pbx, doing hangup.
Segmentation fault
[root@asterisk1 ~]#
